root/radiance/ray/src/hd/holofile.c
Revision: 3.13
Committed: Fri Dec 12 21:29:34 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.12: +22 -12 lines
made recovery from file write errors more robust
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for managing holodeck files
9 *
10 * 9/30/97 GWLarson
11 */
12
13 #include "holo.h"
14
15 #ifndef CACHESIZE
16 #define CACHESIZE 16 /* default cache size (Mbytes, 0==inf) */
17 #endif
18 #ifndef FREEBEAMS
19 #define FREEBEAMS 512 /* maximum beams to free at a time */
20 #endif
21 #ifndef PCTFREE
22 #define PCTFREE 20 /* maximum fraction to free (%) */
23 #endif
24
25 /* define MAXFRAG if you want to limit fragment tracking memory */
26
27 #ifndef BSD
28 #define write writebuf /* safe i/o routines */
29 #define read readbuf
30 #endif
31
32 #define FRAGBLK 64 /* number of fragments to allocate at a time */
33
34 int hdcachesize = CACHESIZE*1024*1024; /* target cache size (bytes) */
35 unsigned long hdclock; /* clock value */
36
37 HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
38
39 static struct fragment {
40 short nlinks; /* number of holodeck sections using us */
41 short writerr; /* write error encountered */
42 int nfrags; /* number of known fragments */
43 BEAMI *fi; /* fragments, descending file position */
44 long flen; /* last known file length */
45 } *hdfrag; /* fragment lists, indexed by file descriptor */
46
47 static int nhdfrags; /* size of hdfrag array */
48
49
50 hdattach(fd) /* start tracking file fragments for some section */
51 register int fd;
52 {
53 if (fd >= nhdfrags) {
54 if (nhdfrags)
55 hdfrag = (struct fragment *)realloc((char *)hdfrag,
56 (fd+1)*sizeof(struct fragment));
57 else
58 hdfrag = (struct fragment *)malloc(
59 (fd+1)*sizeof(struct fragment));
60 if (hdfrag == NULL)
61 error(SYSTEM, "out of memory in hdattach");
62 bzero((char *)(hdfrag+nhdfrags),
63 (fd+1-nhdfrags)*sizeof(struct fragment));
64 nhdfrags = fd+1;
65 }
66 hdfrag[fd].nlinks++;
67 hdfrag[fd].flen = lseek(fd, 0L, 2); /* get file length */
68 }
69
70
71 /* Do we need a routine to locate file fragments given known occupants? */
72
73
74 hdrelease(fd) /* stop tracking file fragments for some section */
75 register int fd;
76 {
77 if (fd < 0 | fd >= nhdfrags || !hdfrag[fd].nlinks)
78 return;
79 if (!--hdfrag[fd].nlinks && hdfrag[fd].nfrags) {
80 free((char *)hdfrag[fd].fi);
81 hdfrag[fd].fi = NULL;
82 hdfrag[fd].nfrags = 0;
83 }
84 }
85
86
87 markdirty(hp) /* mark holodeck section directory dirty */
88 register HOLO *hp;
89 {
90 static BEAMI smudge = {0, -1};
91
92 if (hp->dirty) /* already marked? */
93 return;
94 hp->dirty = 1;
95 if (lseek(hp->fd, biglob(hp)->fo+(nbeams(hp)-1)*sizeof(BEAMI), 0) < 0
96 || write(hp->fd, (char *)&smudge,
97 sizeof(BEAMI)) != sizeof(BEAMI))
98 error(SYSTEM, "seek/write error in markdirty");
99 }
100
101
102 HOLO *
103 hdinit(fd, hproto) /* initialize a holodeck section in a file */
104 int fd; /* corresponding file descriptor */
105 HDGRID *hproto; /* holodeck section grid */
106 {
107 long fpos;
108 register HOLO *hp;
109 register int n;
110 /* prepare for system errors */
111 errno = 0;
112 if ((fpos = lseek(fd, 0L, 1)) < 0)
113 error(SYSTEM, "cannot determine holodeck file position");
114 if (hproto == NULL) { /* assume we're loading it */
115 HDGRID hpr;
116 /* load header */
117 if (read(fd, (char *)&hpr, sizeof(HDGRID)) != sizeof(HDGRID))
118 error(SYSTEM, "cannot load holodeck header");
119 /* allocate grid */
120 if ((hp = hdalloc(&hpr)) == NULL)
121 goto memerr;
122 /* load beam directory */
123 n = nbeams(hp)*sizeof(BEAMI);
124 if (read(fd, (char *)(hp->bi+1), n) != n)
125 error(SYSTEM, "failure loading holodeck directory");
126 /* check that it's clean */
127 if (hp->bi[nbeams(hp)].fo < 0)
128 error(USER, "dirty holodeck section");
129 } else { /* assume we're creating it */
130 if ((hp = hdalloc(hproto)) == NULL)
131 goto memerr;
132 /* write header and skeleton */
133 n = nbeams(hp)*sizeof(BEAMI);
134 if (write(fd, (char *)hproto, sizeof(HDGRID)) !=
135 sizeof(HDGRID) ||
136 write(fd, (char *)(hp->bi+1), n) != n)
137 error(SYSTEM, "cannot write header to holodeck file");
138 }
139 hp->fd = fd;
140 hp->dirty = 0;
141 biglob(hp)->fo = fpos + sizeof(HDGRID);
142 /* start tracking fragments */
143 hdattach(fd);
144 /* check rays on disk */
145 fpos = hdfilen(fd);
146 biglob(hp)->nrd = 0;
147 for (n = hproto == NULL ? nbeams(hp) : 0; n > 0; n--)
148 if (hp->bi[n].nrd)
149 if (hp->bi[n].fo + hp->bi[n].nrd > fpos)
150 hp->bi[n].nrd = 0; /* off end */
151 else
152 biglob(hp)->nrd += hp->bi[n].nrd;
153 /* add to holodeck list */
154 for (n = 0; n < HDMAX; n++)
155 if (hdlist[n] == NULL) {
156 hdlist[n] = hp;
157 break;
158 }
159 /* all done */
160 return(hp);
161 memerr:
162 error(SYSTEM, "cannot allocate holodeck grid");
163 }
164
165
166 int
167 hdsync(hp, all) /* update beams and directory on disk */
168 register HOLO *hp;
169 int all;
170 {
171 register int j, n;
172
173 if (hp == NULL) { /* do all holodecks */
174 n = 0;
175 for (j = 0; hdlist[j] != NULL; j++)
176 n += hdsync(hdlist[j], all);
177 return(n);
178 }
179 /* sync the beams */
180 for (j = all ? nbeams(hp) : 0; j > 0; j--)
181 if (hp->bl[j] != NULL)
182 hdsyncbeam(hp, j);
183 if (!hp->dirty) /* directory clean? */
184 return(0);
185 errno = 0;
186 if (lseek(hp->fd, biglob(hp)->fo, 0) < 0)
187 error(SYSTEM, "cannot seek on holodeck file");
188 n = nbeams(hp)*sizeof(BEAMI);
189 if (write(hp->fd, (char *)(hp->bi+1), n) != n)
190 error(SYSTEM, "cannot update holodeck section directory");
191 hp->dirty = 0;
192 return(1);
193 }
194
195
196 long
197 hdmemuse(all) /* return memory usage (in bytes) */
198 int all; /* include overhead (painful) */
199 {
200 long total = 0;
201 register int i, j;
202
203 for (j = 0; hdlist[j] != NULL; j++) {
204 total += blglob(hdlist[j])->nrm * sizeof(RAYVAL);
205 if (all) {
206 total += sizeof(HOLO) + sizeof(BEAM *) +
207 nbeams(hdlist[j]) *
208 (sizeof(BEAM *)+sizeof(BEAMI));
209 for (i = nbeams(hdlist[j]); i > 0; i--)
210 if (hdlist[j]->bl[i] != NULL)
211 total += sizeof(BEAM);
212 }
213 }
214 if (all)
215 for (j = 0; j < nhdfrags; j++) {
216 total += sizeof(struct fragment);
217 if (hdfrag[j].nfrags)
218 total += FRAGBLK*sizeof(BEAMI) *
219 ((hdfrag[j].nfrags-1)/FRAGBLK + 1) ;
220 }
221 return(total);
222 }
223
224
225 long
226 hdfilen(fd) /* return file length for fd */
227 int fd;
228 {
229 long fpos, flen;
230
231 if (fd < 0)
232 return(-1);
233 if (fd >= nhdfrags || !hdfrag[fd].nlinks) {
234 if ((fpos = lseek(fd, 0L, 1)) < 0)
235 return(-1);
236 flen = lseek(fd, 0L, 2);
237 lseek(fd, fpos, 0);
238 return(flen);
239 }
240 return(hdfrag[fd].flen);
241 }
242
243
244 long
245 hdfiluse(fd, all) /* compute file usage (in bytes) */
246 int fd; /* open file descriptor to check */
247 int all; /* include overhead and unflushed data */
248 {
249 long total = 0;
250 register int i, j;
251
252 for (j = 0; hdlist[j] != NULL; j++) {
253 if (hdlist[j]->fd != fd)
254 continue;
255 total += biglob(hdlist[j])->nrd * sizeof(RAYVAL);
256 if (all) {
257 for (i = nbeams(hdlist[j]); i > 0; i--)
258 if (hdlist[j]->bl[i] != NULL)
259 total += sizeof(RAYVAL) *
260 (hdlist[j]->bl[i]->nrm -
261 hdlist[j]->bi[i].nrd);
262 total += sizeof(HDGRID) +
263 nbeams(hdlist[j])*sizeof(BEAMI);
264 }
265 }
266 return(total); /* does not include fragments */
267 }
268
269
270 RAYVAL *
271 hdnewrays(hp, i, nr) /* allocate space for add'l rays and return pointer */
272 register HOLO *hp;
273 register int i;
274 int nr; /* number of new rays desired */
275 {
276 RAYVAL *p;
277 int n;
278
279 if (nr <= 0)
280 return(NULL);
281 if (i < 1 | i > nbeams(hp))
282 error(CONSISTENCY, "bad beam index given to hdnewrays");
283 if (hp->bl[i] != NULL)
284 hp->bl[i]->tick = hdclock; /* preempt swap */
285 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
286 hdfreecache(PCTFREE, NULL); /* free some space */
287 errno = 0;
288 if (hp->bl[i] == NULL) { /* allocate (and load) */
289 n = hp->bi[i].nrd + nr;
290 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
291 goto memerr;
292 blglob(hp)->nrm += n;
293 if (n = hp->bl[i]->nrm = hp->bi[i].nrd) {
294 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
295 error(SYSTEM, "seek error on holodeck file");
296 n *= sizeof(RAYVAL);
297 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
298 error(SYSTEM,
299 "error reading beam from holodeck file");
300 }
301 } else { /* just grow in memory */
302 hp->bl[i] = (BEAM *)realloc( (char *)hp->bl[i],
303 hdbsiz(hp->bl[i]->nrm + nr) );
304 if (hp->bl[i] == NULL)
305 goto memerr;
306 blglob(hp)->nrm += nr;
307 }
308 p = hdbray(hp->bl[i]) + hp->bl[i]->nrm;
309 hp->bl[i]->nrm += nr; /* update in-core structure */
310 bzero((char *)p, nr*sizeof(RAYVAL));
311 hp->bl[i]->tick = ++hdclock; /* update LRU clock */
312 blglob(hp)->tick = hdclock;
313 return(p); /* point to new rays */
314 memerr:
315 error(SYSTEM, "out of memory in hdnewrays");
316 }
317
318
319 BEAM *
320 hdgetbeam(hp, i) /* get beam (from file if necessary) */
321 register HOLO *hp;
322 register int i;
323 {
324 register int n;
325
326 if (i < 1 | i > nbeams(hp))
327 error(CONSISTENCY, "bad beam index given to hdgetbeam");
328 if (hp->bl[i] == NULL) { /* load from disk */
329 if (!(n = hp->bi[i].nrd))
330 return(NULL);
331 if (hdcachesize > 0 && hdmemuse(0) >= hdcachesize)
332 hdfreecache(PCTFREE, NULL); /* get free space */
333 errno = 0;
334 if ((hp->bl[i] = (BEAM *)malloc(hdbsiz(n))) == NULL)
335 error(SYSTEM, "cannot allocate memory for beam");
336 blglob(hp)->nrm += hp->bl[i]->nrm = n;
337 if (lseek(hp->fd, hp->bi[i].fo, 0) < 0)
338 error(SYSTEM, "seek error on holodeck file");
339 n *= sizeof(RAYVAL);
340 if (read(hp->fd, (char *)hdbray(hp->bl[i]), n) != n)
341 error(SYSTEM, "error reading beam from holodeck file");
342 }
343 hp->bl[i]->tick = ++hdclock; /* update LRU clock */
344 blglob(hp)->tick = hdclock;
345 return(hp->bl[i]);
346 }
347
348
349 int
350 hdsyncbeam(hp, i) /* sync beam in memory with beam on disk */
351 register HOLO *hp;
352 register int i;
353 {
354 unsigned int nrays;
355 long nfo;
356 unsigned int n;
357 /* check file status */
358 if (hdfrag[hp->fd].writerr)
359 return(-1);
360 #ifdef DEBUG
361 if (i < 1 | i > nbeams(hp))
362 error(CONSISTENCY, "bad beam index in hdsyncbeam");
363 #endif
364 /* is current fragment OK? */
365 if (hp->bl[i] == NULL || (nrays = hp->bl[i]->nrm) == hp->bi[i].nrd)
366 return(0);
367 /* locate fragment */
368 if (hp->fd >= nhdfrags || !hdfrag[hp->fd].nlinks) /* untracked */
369 hp->bi[i].fo = lseek(hp->fd, 0L, 2);
370
371 else if (hp->bi[i].fo + hp->bi[i].nrd*sizeof(RAYVAL) ==
372 hdfrag[hp->fd].flen) /* EOF special case */
373 hdfrag[hp->fd].flen = (nfo=hp->bi[i].fo) + nrays*sizeof(RAYVAL);
374
375 else { /* general case */
376 register struct fragment *f = &hdfrag[hp->fd];
377 register int j, k;
378 /* relinquish old fragment */
379 if (hp->bi[i].nrd) {
380 j = f->nfrags++;
381 #ifdef MAXFRAG
382 if (j >= MAXFRAG-1)
383 f->nfrags--;
384 #endif
385 if (j % FRAGBLK == 0) { /* more frag. space */
386 if (f->fi == NULL)
387 f->fi = (BEAMI *)malloc(
388 FRAGBLK*sizeof(BEAMI));
389 else
390 f->fi = (BEAMI *)realloc((char *)f->fi,
391 (j+FRAGBLK)*sizeof(BEAMI));
392 if (f->fi == NULL)
393 error(SYSTEM,
394 "out of memory in hdsyncbeam");
395 }
396 for ( ; ; j--) { /* insert in descending list */
397 if (!j || hp->bi[i].fo < f->fi[j-1].fo) {
398 f->fi[j].fo = hp->bi[i].fo;
399 f->fi[j].nrd = hp->bi[i].nrd;
400 break;
401 }
402 copystruct(f->fi+j, f->fi+j-1);
403 }
404 /* coalesce adjacent fragments */
405 for (j = k = 0; k < f->nfrags; j++, k++) {
406 if (k > j)
407 copystruct(f->fi+j, f->fi+k);
408 while (k+1 < f->nfrags && f->fi[k+1].fo +
409 f->fi[k+1].nrd*sizeof(RAYVAL)
410 == f->fi[j].fo) {
411 f->fi[j].fo -=
412 f->fi[++k].nrd*sizeof(RAYVAL);
413 f->fi[j].nrd += f->fi[k].nrd;
414 }
415 }
416 f->nfrags = j;
417 }
418 k = -1; /* find closest-sized fragment */
419 for (j = nrays ? f->nfrags : 0; j-- > 0; )
420 if (f->fi[j].nrd >= nrays &&
421 (k < 0 || f->fi[j].nrd < f->fi[k].nrd))
422 if (f->fi[k=j].nrd == nrays)
423 break;
424 if (k < 0) { /* no fragment -- extend file */
425 nfo = f->flen;
426 f->flen += nrays*sizeof(RAYVAL);
427 } else { /* else use fragment */
428 nfo = f->fi[k].fo;
429 if (f->fi[k].nrd == nrays) { /* delete fragment */
430 f->nfrags--;
431 for (j = k; j < f->nfrags; j++)
432 copystruct(f->fi+j, f->fi+j+1);
433 } else { /* else shrink it */
434 f->fi[k].fo += nrays*sizeof(RAYVAL);
435 f->fi[k].nrd -= nrays;
436 }
437 }
438 }
439 if (nrays) { /* write the new fragment */
440 errno = 0;
441 if (lseek(hp->fd, nfo, 0) < 0)
442 error(SYSTEM, "cannot seek on holodeck file");
443 n = hp->bl[i]->nrm * sizeof(RAYVAL);
444 if (write(hp->fd, (char *)hdbray(hp->bl[i]), n) != n) {
445 hdfrag[hp->fd].writerr++;
446 hdsync(hp, 0); /* sync directory */
447 error(SYSTEM, "write error in hdsyncbeam");
448 }
449 }
450 biglob(hp)->nrd += nrays - hp->bi[i].nrd;
451 hp->bi[i].nrd = nrays;
452 hp->bi[i].fo = nfo;
453 markdirty(hp); /* section directory now out of date */
454 return(1);
455 }
456
457
458 int
459 hdfreebeam(hp, i) /* free beam, writing if dirty */
460 register HOLO *hp;
461 register int i;
462 {
463 int nchanged;
464
465 if (hp == NULL) { /* clear all holodecks */
466 nchanged = 0;
467 for (i = 0; hdlist[i] != NULL; i++)
468 nchanged += hdfreebeam(hdlist[i], 0);
469 return(nchanged);
470 }
471 if (hdfrag[hp->fd].writerr) /* check for file error */
472 return(0);
473 if (i == 0) { /* clear entire holodeck */
474 nchanged = 0;
475 for (i = nbeams(hp); i > 0; i--)
476 if (hp->bl[i] != NULL)
477 nchanged += hdfreebeam(hp, i);
478 return(nchanged);
479 }
480 #ifdef DEBUG
481 if (i < 1 | i > nbeams(hp))
482 error(CONSISTENCY, "bad beam index to hdfreebeam");
483 #endif
484 if (hp->bl[i] == NULL)
485 return(0);
486 /* check for additions */
487 nchanged = hp->bl[i]->nrm - hp->bi[i].nrd;
488 if (nchanged)
489 hdsyncbeam(hp, i); /* write new fragment */
490 blglob(hp)->nrm -= hp->bl[i]->nrm;
491 free((char *)hp->bl[i]); /* free memory */
492 hp->bl[i] = NULL;
493 return(nchanged);
494 }
495
496
497 int
498 hdkillbeam(hp, i) /* delete beam from holodeck */
499 register HOLO *hp;
500 register int i;
501 {
502 static BEAM emptybeam;
503 int nchanged;
504
505 if (hp == NULL) { /* clobber all holodecks */
506 nchanged = 0;
507 for (i = 0; hdlist[i] != NULL; i++)
508 nchanged += hdkillbeam(hdlist[i], 0);
509 return(nchanged);
510 }
511 if (i == 0) { /* clobber entire holodeck */
512 nchanged = 0;
513 for (i = nbeams(hp); i > 0; i--)
514 if (hp->bi[i].nrd > 0 || hp->bl[i] != NULL)
515 nchanged += hdkillbeam(hp, i);
516 #ifdef DEBUG
517 if (biglob(hp)->nrd != 0 | blglob(hp)->nrm != 0)
518 error(CONSISTENCY, "bad beam count in hdkillbeam");
519 #endif
520 return(nchanged);
521 }
522 #ifdef DEBUG
523 if (i < 1 | i > nbeams(hp))
524 error(CONSISTENCY, "bad beam index to hdkillbeam");
525 #endif
526 if (hp->bl[i] != NULL) { /* free memory */
527 blglob(hp)->nrm -= nchanged = hp->bl[i]->nrm;
528 free((char *)hp->bl[i]);
529 } else
530 nchanged = hp->bi[i].nrd;
531 if (hp->bi[i].nrd) { /* free file fragment */
532 hp->bl[i] = &emptybeam;
533 hdsyncbeam(hp, i);
534 }
535 hp->bl[i] = NULL;
536 return(nchanged);
537 }
538
539
540 hdlrulist(ha, ba, n, hp) /* add beams from holodeck to LRU list */
541 register HOLO *ha[]; /* section list (NULL terminated) */
542 register int ba[]; /* beam index to go with section */
543 int n; /* length of arrays minus 1 */
544 register HOLO *hp; /* section we're adding from */
545 {
546 register int i, j;
547 int nents;
548 /* find last entry in LRU list */
549 for (j = 0; ha[j] != NULL; j++)
550 ;
551 nents = j;
552 /* insert each beam from hp */
553 for (i = nbeams(hp); i > 0; i--) {
554 if (hp->bl[i] == NULL) /* check if loaded */
555 continue;
556 if ((j = ++nents) > n) /* grow list if we can */
557 nents--;
558 for ( ; ; ) { /* bubble into place */
559 if (!--j || hp->bl[i]->tick >=
560 ha[j-1]->bl[ba[j-1]]->tick) {
561 ha[j] = hp;
562 ba[j] = i;
563 break;
564 }
565 ha[j] = ha[j-1];
566 ba[j] = ba[j-1];
567 }
568 }
569 ha[nents] = NULL; /* all done */
570 ba[nents] = 0;
571 }
572
573
574 hdfreecache(pct, honly) /* free up cache space, writing changes */
575 int pct; /* maximum percentage to free */
576 register HOLO *honly; /* NULL means check all */
577 {
578 HOLO *hp[FREEBEAMS+1];
579 int bn[FREEBEAMS+1];
580 int freetarget;
581 register int i;
582 /* compute free target */
583 freetarget = (honly != NULL) ? blglob(honly)->nrm :
584 hdmemuse(0)/sizeof(RAYVAL) ;
585 freetarget = freetarget*pct/100;
586 /* find least recently used */
587 hp[0] = NULL;
588 bn[0] = 0;
589 if (honly != NULL)
590 hdlrulist(hp, bn, FREEBEAMS, honly);
591 else
592 for (i = 0; hdlist[i] != NULL; i++)
593 hdlrulist(hp, bn, FREEBEAMS, hdlist[i]);
594 /* free LRU beams */
595 for (i = 0; hp[i] != NULL; i++) {
596 hdfreebeam(hp[i], bn[i]);
597 if ((freetarget -= hp[i]->bi[bn[i]].nrd) <= 0)
598 break;
599 }
600 hdsync(honly, 0); /* synchronize directories as necessary */
601 }
602
603
604 hddone(hp) /* clean up holodeck section and free */
605 register HOLO *hp; /* NULL means clean up all */
606 {
607 register int i;
608
609 if (hp == NULL) { /* NULL means clean up everything */
610 while (hdlist[0] != NULL)
611 hddone(hdlist[0]);
612 return;
613 }
614 /* flush all data and free memory */
615 hdflush(hp);
616 /* release fragment resources */
617 hdrelease(hp->fd);
618 /* remove hp from active list */
619 for (i = 0; hdlist[i] != NULL; i++)
620 if (hdlist[i] == hp) {
621 while ((hdlist[i] = hdlist[i+1]) != NULL)
622 i++;
623 break;
624 }
625 free((char *)hp->bl); /* free beam list */
626 free((char *)hp); /* free holodeck struct */
627 }
