--- ray/src/hd/holofile.c 2004/09/09 01:41:21 3.57 +++ ray/src/hd/holofile.c 2023/12/19 20:22:36 3.62 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: holofile.c,v 3.57 2004/09/09 01:41:21 greg Exp $"; +static const char RCSid[] = "$Id: holofile.c,v 3.62 2023/12/19 20:22:36 greg Exp $"; #endif /* * Routines for managing holodeck files @@ -18,9 +18,9 @@ static const char RCSid[] = "$Id: holofile.c,v 3.57 20 #ifndef CACHESIZE #ifdef SMLMEM -#define CACHESIZE 5 +#define CACHESIZE 100 #else -#define CACHESIZE 17 /* default cache size (Mbytes, 0==inf) */ +#define CACHESIZE 1000 /* default cache size (Mbytes, 0==inf) */ #endif #endif #ifndef FREEBEAMS @@ -30,7 +30,7 @@ static const char RCSid[] = "$Id: holofile.c,v 3.57 20 #define PCTFREE 15 /* maximum fraction to free (%) */ #endif #ifndef MAXFRAGB -#define MAXFRAGB 16 /* fragment blocks/file to track (0==inf) */ +#define MAXFRAGB 64 /* fragment blocks/file to track (0==inf) */ #endif #ifndef FF_DEFAULT /* when to free a beam fragment */ @@ -42,7 +42,13 @@ static const char RCSid[] = "$Id: holofile.c,v 3.57 20 #endif #ifndef BSD +#ifdef write /* platform.h renames those for Windows */ +#undef write +#endif #define write writebuf /* safe i/o routines */ +#ifdef read +#undef read +#endif #define read readbuf #endif @@ -84,7 +90,7 @@ hdalloc( /* allocate and set holodeck section based o ) { HOLO hdhead; - register HOLO *hp; + HOLO *hp; int n; /* copy grid to temporary header */ memcpy((void *)&hdhead, (void *)hproto, sizeof(HDGRID)); @@ -120,7 +126,7 @@ hdrealloc( /* (re)allocate memory, retry then error */ char *rout ) { - register char *newp; + char *newp; /* call malloc/realloc */ if (ptr == NULL) newp = (char *)malloc(siz); else newp = (char *)realloc((void *)ptr, siz); @@ -140,7 +146,7 @@ hdrealloc( /* (re)allocate memory, retry then error */ void hdattach( /* start tracking file fragments for some section */ - register int fd, + int fd, int wr ) { @@ -163,7 +169,7 @@ hdattach( /* start tracking file fragments for some se void hdrelease( /* stop tracking file fragments for some section */ - register int fd + int fd ) { if ((fd < 0) | (fd >= nhdfragls) || !hdfragl[fd].nlinks) @@ -176,7 +182,7 @@ hdrelease( /* stop tracking file fragments for some s } -extern HOLO * +HOLO * hdinit( /* initialize a holodeck section in a file */ int fd, /* corresponding file descriptor */ HDGRID *hproto /* holodeck section grid */ @@ -185,8 +191,8 @@ hdinit( /* initialize a holodeck section in a file */ off_t rtrunc; off_t fpos; int writable; - register HOLO *hp; - register int n; + HOLO *hp; + int n; /* prepare for system errors */ errno = 0; if ((fpos = lseek(fd, (off_t)0, SEEK_CUR)) < 0) @@ -246,7 +252,8 @@ hdinit( /* initialize a holodeck section in a file */ } if (rtrunc) { sprintf(errmsg, "truncated section, %ld rays lost (%.1f%%)", - rtrunc, 100.*rtrunc/(rtrunc+biglob(hp)->nrd)); + (long)rtrunc, + 100.*rtrunc/(rtrunc+biglob(hp)->nrd)); error(WARNING, errmsg); } /* add to holodeck list */ @@ -265,13 +272,13 @@ memerr: void hdmarkdirty( /* mark holodeck directory position dirty */ - register HOLO *hp, + HOLO *hp, int i ) { static BEAMI smudge = {0, -1}; int mindist, minpos; - register int j; + int j; if (!hp->dirty++) { /* write smudge first time */ if (lseek(hp->fd, biglob(hp)->fo+(i-1)*sizeof(BEAMI), @@ -317,13 +324,13 @@ hdmarkdirty( /* mark holodeck directory position dirt } -extern int +int hdsync( /* update beams and directory on disk */ - register HOLO *hp, + HOLO *hp, int all ) { - register int j, n; + int j, n; if (hp == NULL) { /* do all holodecks */ n = 0; @@ -357,7 +364,7 @@ hdmemuse( /* return memory usage (in bytes) */ ) { long total = 0; - register int i, j; + int i, j; for (j = 0; hdlist[j] != NULL; j++) { total += blglob(hdlist[j])->nrm * sizeof(RAYVAL); @@ -381,7 +388,7 @@ hdmemuse( /* return memory usage (in bytes) */ } -extern off_t +off_t hdfilen( /* return file length for fd */ int fd ) @@ -401,13 +408,13 @@ hdfilen( /* return file length for fd */ } -extern off_t +off_t hdfiluse( /* compute file usage (in bytes) */ int fd /* open file descriptor to check */ ) { off_t total = 0; - register int j; + int j; for (j = 0; hdlist[j] != NULL; j++) { if (hdlist[j]->fd != fd) @@ -426,10 +433,10 @@ hdfiluse( /* compute file usage (in bytes) */ } -extern RAYVAL * +RAYVAL * hdnewrays( /* allocate space for add'l rays and return pointer */ - register HOLO *hp, - register int i, + HOLO *hp, + int i, int nr /* number of new rays desired */ ) { @@ -471,13 +478,13 @@ hdnewrays( /* allocate space for add'l rays and return } -extern BEAM * +BEAM * hdgetbeam( /* get beam (from file if necessary) */ - register HOLO *hp, - register int i + HOLO *hp, + int i ) { - register int n; + int n; CHECK((i < 1) | (i > nbeams(hp)), CONSISTENCY, "bad beam index given to hdgetbeam"); @@ -504,11 +511,11 @@ hdgetbeam( /* get beam (from file if necessary) */ int hdfilord( /* order beams for quick loading */ - register const void *hb1, - register const void *hb2 + const void *hb1, + const void *hb2 ) { - register off_t c; + off_t c; /* residents go first */ if (((HDBEAMI*)hb2)->h->bl[((HDBEAMI*)hb2)->b] != NULL) return(((HDBEAMI*)hb1)->h->bl[((HDBEAMI*)hb1)->b] == NULL); @@ -524,17 +531,17 @@ hdfilord( /* order beams for quick loading */ } -extern void +void hdloadbeams( /* load a list of beams in optimal order */ - register HDBEAMI *hb, /* list gets sorted by hdfilord() */ + HDBEAMI *hb, /* list gets sorted by hdfilord() */ int n, /* list length */ void (*bf)(BEAM *bp, HDBEAMI *hb) /* callback function (optional) */ ) { unsigned origcachesize, memuse; int bytesloaded, needbytes, bytes2free; - register BEAM *bp; - register int i; + BEAM *bp; + int i; /* precheck consistency */ if (n <= 0) return; for (i = n; i--; ) @@ -571,15 +578,15 @@ hdloadbeams( /* load a list of beams in optimal order } -extern int +int hdfreefrag( /* free a file fragment */ HOLO *hp, int i ) { - register BEAMI *bi = &hp->bi[i]; - register struct fraglist *f; - register int j, k; + BEAMI *bi = &hp->bi[i]; + struct fraglist *f; + int j, k; if (bi->nrd <= 0) return(0); @@ -608,7 +615,7 @@ hdfreefrag( /* free a file fragment */ } #endif if (j % FRAGBLK == 0) { /* more (or less) free list space */ - register BEAMI *newp; + BEAMI *newp; if (f->fi == NULL) newp = (BEAMI *)malloc((j+FRAGBLK)*sizeof(BEAMI)); else @@ -651,15 +658,15 @@ hdfreefrag( /* free a file fragment */ } -extern int +int hdfragOK( /* get fragment list status for file */ int fd, int *listlen, - register int32 *listsiz + int32 *listsiz ) { - register struct fraglist *f; - register int i; + struct fraglist *f; + int i; if ((fd < 0) | (fd >= nhdfragls) || !(f = &hdfragl[fd])->nlinks) return(0); /* listless */ @@ -682,8 +689,8 @@ hdallocfrag( /* allocate a file fragment */ uint32 nrays ) { - register struct fraglist *f; - register int j; + struct fraglist *f; + int j; off_t nfo; if (nrays == 0) @@ -708,8 +715,8 @@ hdallocfrag( /* allocate a file fragment */ int hdsyncbeam( /* sync beam in memory with beam on disk */ - register HOLO *hp, - register int i + HOLO *hp, + int i ) { int fragfreed; @@ -748,10 +755,10 @@ hdsyncbeam( /* sync beam in memory with beam on disk } -extern int +int hdfreebeam( /* free beam, writing if dirty */ - register HOLO *hp, - register int i + HOLO *hp, + int i ) { int nchanged; @@ -790,10 +797,10 @@ hdfreebeam( /* free beam, writing if dirty */ } -extern int +int hdkillbeam( /* delete beam from holodeck */ - register HOLO *hp, - register int i + HOLO *hp, + int i ) { int nchanged; @@ -838,13 +845,13 @@ hdkillbeam( /* delete beam from holodeck */ int hdlrulist( /* add beams from holodeck to LRU list */ - register HDBEAMI *hb, /* beam list */ + HDBEAMI *hb, /* beam list */ int nents, /* current list length */ int n, /* maximum list length */ - register HOLO *hp /* section we're adding from */ + HOLO *hp /* section we're adding from */ ) { - register int i, j; + int i, j; /* insert each beam from hp */ for (i = 1; i <= nbeams(hp); i++) { if (hp->bl[i] == NULL) /* check if loaded */ @@ -872,13 +879,13 @@ hdlrulist( /* add beams from holodeck to LRU list */ int hdfreecache( /* free up cache space, writing changes */ int pct, /* maximum percentage to free */ - register HOLO *honly /* NULL means check all */ + HOLO *honly /* NULL means check all */ ) { HDBEAMI hb[FREEBEAMS]; int freetarget; int n; - register int i; + int i; #ifdef DEBUG unsigned membefore; @@ -914,12 +921,12 @@ hdfreecache( /* free up cache space, writing changes } -extern void +void hddone( /* clean up holodeck section and free */ - register HOLO *hp /* NULL means clean up all */ + HOLO *hp /* NULL means clean up all */ ) { - register int i; + int i; if (hp == NULL) { /* NULL means clean up everything */ while (hdlist[0] != NULL)
