root/Development/ray/src/hd/holofile.c
Revision 3.57 - (view) (download) (annotate) - [select for diffs]
Thu Sep 9 01:41:21 2004 UTC (21 years, 4 months ago) by greg
Changes since 3.56: +7 -6 lines
Diff to previous 3.56
Reduced frequency of fragmentation checks and improved logic
Revision 3.56 - (view) (download) (annotate) - [select for diffs]
Thu Sep 9 01:06:19 2004 UTC (21 years, 4 months ago) by greg
Changes since 3.55: +7 -10 lines
Diff to previous 3.55
Revision 3.55 - (view) (download) (annotate) - [select for diffs]
Thu Jan 1 11:21:55 2004 UTC (22 years ago) by schorsch
Changes since 3.54: +132 -87 lines
Diff to previous 3.54
Ansification and prototypes.
Revision 3.54 - (view) (download) (annotate) - [select for diffs]
Wed Oct 22 02:06:34 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.53: +3 -3 lines
Diff to previous 3.53
Revision 3.53 - (view) (download) (annotate) - [select for diffs]
Mon Oct 20 16:01:55 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.52: +17 -13 lines
Diff to previous 3.52
Revision 3.52 - (view) (download) (annotate) - [select for diffs]
Sun Jul 27 22:12:02 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.51: +9 -8 lines
Diff to previous 3.51
Revision 3.51 - (view) (download) (annotate) - [select for diffs]
Mon Jul 21 22:30:18 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.50: +7 -7 lines
Diff to previous 3.50
Revision 3.50 - (view) (download) (annotate) - [select for diffs]
Mon Jul 7 17:21:50 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.49: +2 -2 lines
Diff to previous 3.49
Revision 3.49 - (view) (download) (annotate) - [select for diffs]
Mon Jun 30 14:59:11 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.48: +11 -7 lines
Diff to previous 3.48
Revision 3.48 - (view) (download) (annotate) - [select for diffs]
Fri Jun 20 00:25:49 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.47: +4 -4 lines
Diff to previous 3.47
Revision 3.47 - (view) (download) (annotate) - [select for diffs]
Fri Jun 13 15:27:04 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.46: +11 -11 lines
Diff to previous 3.46
Type fixing to lseek() call
Revision 3.46 - (view) (download) (annotate) - [select for diffs]
Thu May 29 16:26:21 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.45: +18 -18 lines
Diff to previous 3.45
Revision 3.45 - (view) (download) (annotate) - [select for diffs]
Thu May 15 05:13:35 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.44: +3 -3 lines
Diff to previous 3.44
Revision 3.44 - (view) (download) (annotate) - [select for diffs]
Tue May 13 17:58:33 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.43: +6 -6 lines
Diff to previous 3.43
Revision 3.43 - (view) (download) (annotate) - [select for diffs]
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.42: +2 -2 lines
Diff to previous 3.42
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Sat Feb 22 02:07:24 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.41: +20 -23 lines
Diff to previous 3.41
Thu Aug 5 15:53:09 1999 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.40: +26 -11 lines
Diff to previous 3.40
added -r option for read-only holodecks
Revision 3.40 - (view) (download) (annotate) - [select for diffs]
Fri Mar 12 09:37:48 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.39: +34 -0 lines
Diff to previous 3.39
moved hdalloc() from holo.c to holofile.c
Tue Mar 9 08:40:11 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.38: +12 -10 lines
Diff to previous 3.38
changed default fragment handling flags
fixed problem with inconsistent directory updating
Thu Feb 25 13:25:38 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.37: +2 -2 lines
Diff to previous 3.37
reduced default cache size
Wed Feb 10 17:09:20 1999 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.36: +4 -5 lines
Diff to previous 3.36
changed markdirty() to hdmarkdirty() to avoid naming conflicts
Mon Feb 1 09:56:18 1999 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.35: +7 -0 lines
Diff to previous 3.35
made caching code slightly more efficient
Mon Jan 25 09:58:41 1999 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.34: +5 -1 lines
Diff to previous 3.34
changed default CACHESIZE based on BIGMEM macro
Tue Jan 19 10:08:34 1999 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.33: +4 -2 lines
Diff to previous 3.33
fixed occupied disk sample accounting in biglob(hp)->nrd
Sat Jan 9 09:16:14 1999 UTC (27 years ago) by gwlarson
Changes since 3.32: +13 -14 lines
Diff to previous 3.32
changed to first-fit algorithm in hdallocfrag()
Thu Jan 7 22:04:49 1999 UTC (27 years ago) by gwlarson
Changes since 3.31: +72 -48 lines
Diff to previous 3.31
Wed Dec 30 11:30:04 1998 UTC (27 years ago) by gwlarson
Changes since 3.30: +9 -6 lines
Diff to previous 3.30
made it so we don't toss off large fragment for smaller one
fixed accumulation of empty fragments when maximum list size reached
Thu Dec 10 10:45:02 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.29: +1 -1 lines
Diff to previous 3.29
reduced size of fragment list to speed hdflush() calls
Wed Nov 11 10:56:07 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.28: +20 -13 lines
Diff to previous 3.28
modified markdirty() to ensure that no gap is smaller than BUFSIZ*4
Mon Nov 9 17:10:53 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.27: +65 -25 lines
Diff to previous 3.27
changed section directory code to write in segments
Wed Nov 4 16:44:16 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.26: +3 -2 lines
Diff to previous 3.26
bug fixes in hdinit() and hddone()
Fri Sep 18 16:47:27 1998 UTC (27 years, 3 months ago) by gwlarson
Changes since 3.25: +40 -24 lines
Diff to previous 3.25
added recovery from memory allocation errors
Fri Sep 18 13:51:01 1998 UTC (27 years, 3 months ago) by gwlarson
Changes since 3.24: +15 -5 lines
Diff to previous 3.24
added debugging statement to track hdfreecache() performance
Tue Sep 15 14:26:23 1998 UTC (27 years, 3 months ago) by gwlarson
Changes since 3.23: +2 -0 lines
Diff to previous 3.23
free fragment list in hddone(NULL) call
Wed Aug 12 17:53:59 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.22: +4 -4 lines
Diff to previous 3.22
changed parameters to function passed to hdloadbeams()
Thu Feb 12 16:30:04 1998 UTC (27 years, 11 months ago) by gwlarson
Changes since 3.21: +11 -4 lines
Diff to previous 3.21
added warning for truncated sections
Wed Jan 7 17:31:00 1998 UTC (28 years ago) by gregl
Diff to previous 3.20
parameter tuning -- doubled FREEBEAMS
Mon Jan 5 16:45:24 1998 UTC (28 years ago) by gregl
Diff to previous 3.19
changed dirty holodeck to just a warning
Sun Jan 4 12:32:53 1998 UTC (28 years ago) by gregl
Changes since 3.18: +109 -80 lines
Diff to previous 3.18
took fragment resource management out of hdsyncbeam()
Thu Jan 1 16:40:38 1998 UTC (28 years ago) by gregl
Changes since 3.17: +2 -5 lines
Diff to previous 3.17
changed hdsync() call before error() in hdsyncbeam()
Thu Jan 1 13:00:14 1998 UTC (28 years ago) by gregl
Changes since 3.16: +23 -14 lines
Diff to previous 3.16
Wed Dec 31 11:35:39 1997 UTC (28 years ago) by gregl
Changes since 3.15: +41 -38 lines
Diff to previous 3.15
more minor improvements to hdsyncbeam()
Mon Dec 29 15:17:45 1997 UTC (28 years ago) by gregl
Changes since 3.14: +44 -42 lines
Diff to previous 3.14
slight efficiency improvement in fragment code of hdsyncbeam()
Thu Dec 18 15:12:23 1997 UTC (28 years ago) by gregl
Changes since 3.13: +90 -34 lines
Diff to previous 3.13
Fri Dec 12 21:29:34 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.12: +22 -12 lines
Diff to previous 3.12
made recovery from file write errors more robust
Fri Dec 12 19:52:31 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.11: +25 -12 lines
Diff to previous 3.11
modified hdsync() to optionally sync all unflushed beams
Thu Dec 11 19:57:58 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.10: +30 -25 lines
Diff to previous 3.10
made beam writing safer in the event of signals
Thu Dec 11 11:29:35 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.9: +45 -3 lines
Diff to previous 3.9
added function to delete beams and clobber holodecks
Thu Dec 11 09:35:58 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.8: +5 -1 lines
Diff to previous 3.8
added preventative measure following write error in hdfreebeam()
Tue Nov 11 11:31:54 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.7: +20 -1 lines
Diff to previous 3.7
made file length testing more efficient
Thu Nov 6 09:50:12 1997 UTC (28 years, 2 months ago) by gregl
Diff to previous 3.6
undefined MAXFRAG
Thu Nov 6 09:37:04 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.5: +24 -1 lines
added marking and detection of inconsistent holodeck files
Wed Nov 5 17:28:49 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.4: +9 -10 lines
changed some constants related to paging
Tue Nov 4 10:42:03 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.3: +53 -30 lines
dynamically allocate fragment lists
Mon Nov 3 13:40:22 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.2: +11 -7 lines
bug fixes in hdgetbi()
Fri Oct 31 15:48:32 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.1: +20 -17 lines
initial bug fixes (hdgetbi)
Fri Oct 31 10:23:29 1997 UTC (28 years, 2 months ago) by gregl
