1 |
/* RCSid: $Id: holo.h,v 3.24 2004/01/01 11:21:55 schorsch Exp $ */ |
2 |
3 |
* Header file for holodeck programs |
4 |
5 |
* 9/29/97 GWLarson |
6 |
7 |
#ifndef _RAD_HOLO_H_ |
8 |
#define _RAD_HOLO_H_ |
9 |
10 |
#include "standard.h" |
11 |
#include "color.h" |
12 |
13 |
#ifdef __cplusplus |
14 |
extern "C" { |
15 |
#endif |
16 |
17 |
#ifndef HDMAX |
18 |
#define HDMAX 128 /* maximum active holodeck sections */ |
19 |
#endif |
20 |
21 |
#ifndef MAXDIRSE |
22 |
#define MAXDIRSE 32 /* maximum seeks per directory write */ |
23 |
#endif |
24 |
25 |
#define DCINF (unsigned)((1L<<16)-1) /* special value for infinity */ |
26 |
#define DCLIN (unsigned)(1L<<11) /* linear depth limit */ |
27 |
28 |
typedef struct { |
29 |
BYTE r[2][2]; /* ray direction index */ |
30 |
COLR v; /* color value */ |
31 |
uint16 d; /* depth code (from entry wall) */ |
32 |
} RAYVAL; /* ray value */ |
33 |
34 |
35 |
* Walls are ordered: X0 X1 X2 WN |
36 |
* 0 ? ? 0 |
37 |
* 1 ? ? 1 |
38 |
* ? 0 ? 2 |
39 |
* ? 1 ? 3 |
40 |
* ? ? 0 4 |
41 |
* ? ? 1 5 |
42 |
43 |
* Grid on wall WN corresponds to X(WN/2+1)%3 and X(WN/2+2)%3, resp. |
44 |
45 |
46 |
typedef struct { |
47 |
short w; /* wall number */ |
48 |
short i[2]; /* index on wall grid */ |
49 |
} GCOORD; /* grid coordinates (two for beam) */ |
50 |
51 |
typedef struct { |
52 |
uint32 nrd; /* number of beam rays bundled on disk */ |
53 |
off_t fo; /* position in file */ |
54 |
} BEAMI; /* beam index */ |
55 |
56 |
typedef struct { |
57 |
uint32 nrm; /* number of beam rays bundled in memory */ |
58 |
unsigned long tick; /* clock tick for LRU replacement */ |
59 |
} BEAM; /* followed by nrm RAYVAL's */ |
60 |
61 |
#define hdbray(bp) ((RAYVAL *)((bp)+1)) |
62 |
#define hdbsiz(nr) (sizeof(BEAM)+(nr)*sizeof(RAYVAL)) |
63 |
64 |
typedef struct { |
65 |
FVECT orig; /* prism origin (first) */ |
66 |
FVECT xv[3]; /* side vectors (second) */ |
67 |
int16 grid[3]; /* grid resolution (third) */ |
68 |
} HDGRID; /* holodeck section grid (must match HOLO struct) */ |
69 |
70 |
typedef struct holo { |
71 |
72 |
73 |
74 |
int fd; /* file descriptor */ |
75 |
struct { |
76 |
int s, n; /* dirty section start, length */ |
77 |
} dirseg[MAXDIRSE+1]; /* dirty beam index segments */ |
78 |
short dirty; /* number of dirty segments */ |
79 |
double tlin; /* linear range for depth encoding */ |
80 |
FVECT wg[3]; /* wall grid vectors (derived) */ |
81 |
int wi[6]; /* wall super-indices (derived) */ |
82 |
char *priv; /* pointer to private client data */ |
83 |
BEAM **bl; /* beam pointers (memory cache) */ |
84 |
BEAMI bi[1]; /* beam index (extends struct) */ |
85 |
} HOLO; /* holodeck section */ |
86 |
87 |
typedef struct { |
88 |
HOLO *h; /* pointer to holodeck */ |
89 |
int b; /* beam index */ |
90 |
} HDBEAMI; /* holodeck beam index */ |
91 |
92 |
#define nbeams(hp) (((hp)->wi[5]-1)<<1) |
93 |
#define biglob(hp) ((hp)->bi) |
94 |
#define blglob(hp) (*(hp)->bl) |
95 |
96 |
#define bnrays(hp,i) ((hp)->bl[i]!=NULL ? (hp)->bl[i]->nrm : (hp)->bi[i].nrd) |
97 |
98 |
#define hdflush(hp) (hdfreebeam(hp,0), hdsync(hp,0)) |
99 |
#define hdclobber(hp) (hdkillbeam(hp,0), hdsync(hp,0)) |
100 |
101 |
102 |
extern HOLO *hdinit(), *hdalloc(); |
103 |
extern BEAM *hdgetbeam(); |
104 |
extern RAYVAL *hdnewrays(); |
105 |
extern unsigned hdmemuse(); |
106 |
extern off_t hdfiluse(), hdfilen(), hdallocfrag(); |
107 |
extern double hdray(), hdinter(); |
108 |
extern unsigned hdcode(); |
109 |
extern int hdfilord(); |
110 |
111 |
112 |
#define FF_NEVER 0 /* never free fragments */ |
113 |
#define FF_WRITE 01 /* free fragment on write */ |
114 |
#define FF_ALLOC 02 /* free fragment on ray alloc */ |
115 |
#define FF_READ 04 /* free fragment on read */ |
116 |
#define FF_KILL 010 /* free fragment on beam kill */ |
117 |
118 |
extern int hdfragflags; /* tells when to free fragments */ |
119 |
extern unsigned hdcachesize; /* target cache size (bytes) */ |
120 |
extern unsigned long hdclock; /* holodeck system clock */ |
121 |
extern HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ |
122 |
123 |
extern float hd_depthmap[]; /* depth conversion map */ |
124 |
125 |
extern int hdwg0[6]; /* wall grid 0 index */ |
126 |
extern int hdwg1[6]; /* wall grid 1 index */ |
127 |
128 |
#define hddepth(hp,dc) ( (dc) >= DCINF ? FHUGE : \ |
129 |
(hp)->tlin * ( (dc) >= DCLIN ? \ |
130 |
hd_depthmap[(dc)-DCLIN] : \ |
131 |
((dc)+.5)/DCLIN ) ) |
132 |
133 |
#define HOLOFMT "Holodeck" /* file format identifier */ |
134 |
#define HOLOVERS 0 /* file format version number */ |
135 |
#define HOLOMAGIC (323+sizeof(off_t)+8*HOLOVERS) /* file magic number */ |
136 |
137 |
138 |
* A holodeck file consists of an information header terminated by a |
139 |
* blank line, with "FORMAT=Holodeck" somewhere in it. |
140 |
* The first integer after the information header is the |
141 |
* above magic number, which includes the file format version number. |
142 |
* The first longword after the magic number is a pointer to the pointer |
143 |
* just before the SECOND holodeck section, or 0 if there is only one. |
144 |
* This longword is immediately followed by the first holodeck |
145 |
* section header and directory. |
146 |
* Similarly, every holodeck section in the file is preceeded by |
147 |
* a pointer to the following section, or 0 for the final section. |
148 |
* Since holodeck files consist of directly written C data structures, |
149 |
* they are not generally portable between different machine architectures. |
150 |
* In particular, different floating point formats or bit/byte ordering |
151 |
* will make the data unusable. This is unfortunate, and may be changed |
152 |
* in future versions, but we thought this would be best for paging speed |
153 |
* in our initial implementation. |
154 |
155 |
156 |
/* clumpbeams.c */ |
157 |
extern void clumpbeams(HOLO *hp, int maxcnt, int maxsiz, |
158 |
int (*cf)(HOLO *hp, int *bqueue, int bqlen)); |
159 |
/* holo.c */ |
160 |
extern void hdcompgrid(HOLO *hp); |
161 |
extern int hdbcoord(GCOORD gc[2], HOLO *hp, int i); |
162 |
extern int hdbindex(HOLO *hp, GCOORD gc[2]); |
163 |
extern void hdcell(FVECT cp[4], HOLO *hp, GCOORD *gc); |
164 |
extern int hdlseg(int lseg[2][3], HOLO *hp, GCOORD gc[2]); |
165 |
extern unsigned int hdcode(HOLO *hp, double d); |
166 |
extern void hdgrid( FVECT gp, HOLO *hp, FVECT wp); |
167 |
extern void hdworld(FVECT wp, HOLO *hp, FVECT gp); |
168 |
extern double hdray(FVECT ro, FVECT rd, HOLO *hp, GCOORD gc[2], BYTE r[2][2]); |
169 |
extern double hdinter(GCOORD gc[2], BYTE r[2][2], double *ed, HOLO *hp, |
170 |
FVECT ro, FVECT rd); |
171 |
/* holofile.c */ |
172 |
extern HOLO * hdinit(int fd, HDGRID *hproto); |
173 |
extern void hddone(HOLO *hp); |
174 |
extern int hdsync(HOLO *hp, int all); |
175 |
extern off_t hdfilen(int fd); |
176 |
extern off_t hdfiluse(int fd); |
177 |
extern RAYVAL * hdnewrays(HOLO *hp, int i, int nr); |
178 |
extern BEAM * hdgetbeam(HOLO *hp, int i); |
179 |
extern void hdloadbeams(HDBEAMI *hb, int n, void (*bf)(BEAM *bp, HDBEAMI *hb)); |
180 |
extern int hdfreebeam(HOLO *hp, int i); |
181 |
extern int hdfreefrag(HOLO *hp, int i); |
182 |
extern int hdfragOK(int fd, int *listlen, int32 *listsiz); |
183 |
extern int hdkillbeam(HOLO *hp, int i); |
184 |
185 |
186 |
187 |
188 |
#endif |
189 |
#endif /* _RAD_HOLO_H_ */ |
190 |
