| 1 |
/* RCSid: $Id$ */
| 2 |
| 3 |
* Header file for holodeck programs
| 4 |
| 5 |
* 9/29/97 GWLarson
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include "color.h"
| 10 |
| 11 |
#ifndef HDMAX
| 12 |
#define HDMAX 128 /* maximum active holodeck sections */
| 13 |
#endif
| 14 |
| 15 |
#ifndef MAXDIRSE
| 16 |
#define MAXDIRSE 32 /* maximum seeks per directory write */
| 17 |
#endif
| 18 |
| 19 |
#define DCINF (unsigned)((1L<<16)-1) /* special value for infinity */
| 20 |
#define DCLIN (unsigned)(1L<<11) /* linear depth limit */
| 21 |
| 22 |
typedef struct {
| 23 |
BYTE r[2][2]; /* ray direction index */
| 24 |
COLR v; /* color value */
| 25 |
unsigned int2 d; /* depth code (from entry wall) */
| 26 |
} RAYVAL; /* ray value */
| 27 |
| 28 |
| 29 |
* Walls are ordered: X0 X1 X2 WN
| 30 |
* 0 ? ? 0
| 31 |
* 1 ? ? 1
| 32 |
* ? 0 ? 2
| 33 |
* ? 1 ? 3
| 34 |
* ? ? 0 4
| 35 |
* ? ? 1 5
| 36 |
| 37 |
* Grid on wall WN corresponds to X(WN/2+1)%3 and X(WN/2+2)%3, resp.
| 38 |
| 39 |
| 40 |
typedef struct {
| 41 |
short w; /* wall number */
| 42 |
short i[2]; /* index on wall grid */
| 43 |
} GCOORD; /* grid coordinates (two for beam) */
| 44 |
| 45 |
typedef struct {
| 46 |
unsigned int4 nrd; /* number of beam rays bundled on disk */
| 47 |
off_t fo; /* position in file */
| 48 |
} BEAMI; /* beam index */
| 49 |
| 50 |
typedef struct {
| 51 |
unsigned int4 nrm; /* number of beam rays bundled in memory */
| 52 |
unsigned long tick; /* clock tick for LRU replacement */
| 53 |
} BEAM; /* followed by nrm RAYVAL's */
| 54 |
| 55 |
#define hdbray(bp) ((RAYVAL *)((bp)+1))
| 56 |
#define hdbsiz(nr) (sizeof(BEAM)+(nr)*sizeof(RAYVAL))
| 57 |
| 58 |
typedef struct {
| 59 |
FVECT orig; /* prism origin (first) */
| 60 |
FVECT xv[3]; /* side vectors (second) */
| 61 |
int2 grid[3]; /* grid resolution (third) */
| 62 |
} HDGRID; /* holodeck section grid (must match HOLO struct) */
| 63 |
| 64 |
typedef struct holo {
| 65 |
| 66 |
| 67 |
| 68 |
int fd; /* file descriptor */
| 69 |
struct {
| 70 |
int s, n; /* dirty section start, length */
| 71 |
} dirseg[MAXDIRSE+1]; /* dirty beam index segments */
| 72 |
short dirty; /* number of dirty segments */
| 73 |
double tlin; /* linear range for depth encoding */
| 74 |
FVECT wg[3]; /* wall grid vectors (derived) */
| 75 |
int wi[6]; /* wall super-indices (derived) */
| 76 |
char *priv; /* pointer to private client data */
| 77 |
BEAM **bl; /* beam pointers (memory cache) */
| 78 |
BEAMI bi[1]; /* beam index (extends struct) */
| 79 |
} HOLO; /* holodeck section */
| 80 |
| 81 |
typedef struct {
| 82 |
HOLO *h; /* pointer to holodeck */
| 83 |
int b; /* beam index */
| 84 |
} HDBEAMI; /* holodeck beam index */
| 85 |
| 86 |
#define nbeams(hp) (((hp)->wi[5]-1)<<1)
| 87 |
#define biglob(hp) ((hp)->bi)
| 88 |
#define blglob(hp) (*(hp)->bl)
| 89 |
| 90 |
#define bnrays(hp,i) ((hp)->bl[i]!=NULL ? (hp)->bl[i]->nrm : (hp)->bi[i].nrd)
| 91 |
| 92 |
#define hdflush(hp) (hdfreebeam(hp,0), hdsync(hp,0))
| 93 |
#define hdclobber(hp) (hdkillbeam(hp,0), hdsync(hp,0))
| 94 |
| 95 |
extern HOLO *hdinit(), *hdalloc();
| 96 |
extern BEAM *hdgetbeam();
| 97 |
extern RAYVAL *hdnewrays();
| 98 |
extern unsigned hdmemuse();
| 99 |
extern off_t hdfiluse(), hdfilen(), hdallocfrag();
| 100 |
extern double hdray(), hdinter();
| 101 |
extern unsigned hdcode();
| 102 |
extern int hdfilord();
| 103 |
| 104 |
#define FF_NEVER 0 /* never free fragments */
| 105 |
#define FF_WRITE 01 /* free fragment on write */
| 106 |
#define FF_ALLOC 02 /* free fragment on ray alloc */
| 107 |
#define FF_READ 04 /* free fragment on read */
| 108 |
#define FF_KILL 010 /* free fragment on beam kill */
| 109 |
| 110 |
extern int hdfragflags; /* tells when to free fragments */
| 111 |
extern unsigned hdcachesize; /* target cache size (bytes) */
| 112 |
extern unsigned long hdclock; /* holodeck system clock */
| 113 |
extern HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */
| 114 |
| 115 |
extern float hd_depthmap[]; /* depth conversion map */
| 116 |
| 117 |
extern int hdwg0[6]; /* wall grid 0 index */
| 118 |
extern int hdwg1[6]; /* wall grid 1 index */
| 119 |
| 120 |
#define hddepth(hp,dc) ( (dc) >= DCINF ? FHUGE : \
| 121 |
(hp)->tlin * ( (dc) >= DCLIN ? \
| 122 |
hd_depthmap[(dc)-DCLIN] : \
| 123 |
((dc)+.5)/DCLIN ) )
| 124 |
| 125 |
#define HOLOFMT "Holodeck" /* file format identifier */
| 126 |
#define HOLOVERS 0 /* file format version number */
| 127 |
#define HOLOMAGIC (323+sizeof(off_t)+8*HOLOVERS) /* file magic number */
| 128 |
| 129 |
| 130 |
* A holodeck file consists of an information header terminated by a
| 131 |
* blank line, with "FORMAT=Holodeck" somewhere in it.
| 132 |
* The first integer after the information header is the
| 133 |
* above magic number, which includes the file format version number.
| 134 |
* The first longword after the magic number is a pointer to the pointer
| 135 |
* just before the SECOND holodeck section, or 0 if there is only one.
| 136 |
* This longword is immediately followed by the first holodeck
| 137 |
* section header and directory.
| 138 |
* Similarly, every holodeck section in the file is preceeded by
| 139 |
* a pointer to the following section, or 0 for the final section.
| 140 |
* Since holodeck files consist of directly written C data structures,
| 141 |
* they are not generally portable between different machine architectures.
| 142 |
* In particular, different floating point formats or bit/byte ordering
| 143 |
* will make the data unusable. This is unfortunate, and may be changed
| 144 |
* in future versions, but we thought this would be best for paging speed
| 145 |
* in our initial implementation.
| 146 |
