--- ray/src/hd/holo.h 1997/12/16 15:01:25 3.8 +++ ray/src/hd/holo.h 1998/01/04 12:32:52 3.12 @@ -18,7 +18,7 @@ #define int2 short #endif #ifndef int4 -#define int4 long +#define int4 int #endif #define DCINF (unsigned)((1L<<16)-1) /* special value for infinity */ @@ -82,6 +82,11 @@ typedef struct holo { BEAMI bi[1]; /* beam index (extends struct) */ } HOLO; /* holodeck section */ +typedef struct { + HOLO *h; /* pointer to holodeck */ + int b; /* beam index */ +} HDBEAMI; /* holodeck beam index */ + #define nbeams(hp) (2*((hp)->wi[5]-1)) #define biglob(hp) ((hp)->bi) #define blglob(hp) (*(hp)->bl) @@ -94,11 +99,12 @@ typedef struct holo { extern HOLO *hdinit(), *hdalloc(); extern BEAM *hdgetbeam(); extern RAYVAL *hdnewrays(); -extern long hdmemuse(), hdfiluse(), hdfilen(); +extern unsigned hdmemuse(); +extern long hdfiluse(), hdfilen(), hdallocfrag(); extern double hdray(), hdinter(); extern unsigned hdcode(); -extern int hdcachesize; /* target cache size (bytes) */ +extern unsigned hdcachesize; /* target cache size (bytes) */ extern unsigned long hdclock; /* holodeck system clock */ extern HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ @@ -111,7 +117,7 @@ extern float hd_depthmap[]; /* depth conversion map * #define HOLOFMT "Holodeck" /* file format identifier */ #define HOLOVERS 0 /* file format version number */ -#define HOLOMAGIC (327+HOLOVERS) /* file magic number */ +#define HOLOMAGIC (323+sizeof(long)+8*HOLOVERS) /* file magic number */ /* * A holodeck file consists of an information header terminated by a
