--- ray/src/hd/holo.h 1997/11/11 16:59:34 3.5 +++ ray/src/hd/holo.h 1998/01/01 10:12:24 3.11 @@ -18,7 +18,7 @@ #define int2 short #endif #ifndef int4 -#define int4 long +#define int4 int #endif #define DCINF (unsigned)((1L<<16)-1) /* special value for infinity */ @@ -82,22 +82,29 @@ typedef struct holo { BEAMI bi[1]; /* beam index (extends struct) */ } HOLO; /* holodeck section */ +typedef struct { + HOLO *h; /* pointer to holodeck */ + int b; /* beam index */ +} HDBEAMI; /* holodeck beam index */ + #define nbeams(hp) (2*((hp)->wi[5]-1)) #define biglob(hp) ((hp)->bi) #define blglob(hp) (*(hp)->bl) #define bnrays(hp,i) ((hp)->bl[i]!=NULL ? (hp)->bl[i]->nrm : (hp)->bi[i].nrd) -#define hdflush(hp) (hdfreebeam(hp,0) && hdsync(hp)) +#define hdflush(hp) (hdfreebeam(hp,0) && hdsync(hp,0)) +#define hdclobber(hp) (hdkillbeam(hp,0) && hdsync(hp,0)) extern HOLO *hdinit(), *hdalloc(); extern BEAM *hdgetbeam(); extern RAYVAL *hdnewrays(); -extern long hdmemuse(), hdfiluse(); +extern unsigned hdmemuse(); +extern long hdfiluse(), hdfilen(); extern double hdray(), hdinter(); extern unsigned hdcode(); -extern int hdcachesize; /* target cache size (bytes) */ +extern unsigned hdcachesize; /* target cache size (bytes) */ extern unsigned long hdclock; /* holodeck system clock */ extern HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ @@ -110,15 +117,15 @@ extern float hd_depthmap[]; /* depth conversion map * #define HOLOFMT "Holodeck" /* file format identifier */ #define HOLOVERS 0 /* file format version number */ -#define HOLOMAGIC (327+HOLOVERS) /* file magic number */ +#define HOLOMAGIC (323+sizeof(long)+8*HOLOVERS) /* file magic number */ /* * A holodeck file consists of an information header terminated by a * blank line, with "FORMAT=Holodeck" somewhere in it. * The first integer after the information header is the * above magic number, which includes the file format version number. - * The first longword after the magic number is the position - * of the SECOND holodeck section, or 0 if there is only one. + * The first longword after the magic number is a pointer to the pointer + * just before the SECOND holodeck section, or 0 if there is only one. * This longword is immediately followed by the first holodeck * section header and directory. * Similarly, every holodeck section in the file is preceeded by
