root/radiance/ray/src/hd/holo.c
Revision: 3.22
Committed: Fri May 20 02:06:39 2011 UTC (12 years ago) by greg
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1
Changes since 3.21: +3 -3 lines
2 static const char RCSid[] = "$Id: holo.c,v 3.21 2004/01/01 11:21:55 schorsch Exp $";
5 * Routines for converting holodeck coordinates, etc.
6 *
7 * 10/22/97 GWLarson
8 */
9
10 #include "holo.h"
11
12 float hd_depthmap[DCINF-DCLIN];
13
14 int hdwg0[6] = {1,1,2,2,0,0};
15 int hdwg1[6] = {2,2,0,0,1,1};
16
17 static double logstep;
18
19
20 extern void
21 hdcompgrid( /* compute derived grid vector and index */
22 register HOLO *hp
23 )
24 {
25 double d;
26 register int i, j;
27 /* initialize depth map */
28 if (hd_depthmap[0] < 1.) {
29 d = 1. + .5/DCLIN;
30 for (i = 0; i < DCINF-DCLIN; i++) {
31 hd_depthmap[i] = d;
32 d *= 1. + 1./DCLIN;
33 }
34 logstep = log(1. + 1./DCLIN);
35 }
36 /* compute grid coordinate vectors */
37 for (i = 0; i < 3; i++) {
38 fcross(hp->wg[i], hp->xv[(i+1)%3], hp->xv[(i+2)%3]);
39 d = DOT(hp->wg[i],hp->xv[i]);
40 if ((d <= FTINY) & (d >= -FTINY))
41 error(USER, "degenerate holodeck section");
42 d = hp->grid[i] / d;
43 hp->wg[i][0] *= d; hp->wg[i][1] *= d; hp->wg[i][2] *= d;
44 }
45 /* compute linear depth range */
46 hp->tlin = VLEN(hp->xv[0]) + VLEN(hp->xv[1]) + VLEN(hp->xv[2]);
47 /* compute wall super-indices from grid */
48 hp->wi[0] = 1; /**** index values begin at 1 ****/
49 for (i = 1; i < 6; i++) {
50 hp->wi[i] = 0;
51 for (j = i; j < 6; j++)
52 hp->wi[i] += hp->grid[hdwg0[j]] * hp->grid[hdwg1[j]];
53 hp->wi[i] *= hp->grid[hdwg0[i-1]] * hp->grid[hdwg1[i-1]];
54 hp->wi[i] += hp->wi[i-1];
55 }
56 }
57
58
59 extern int
60 hdbcoord( /* compute beam coordinates from index */
61 GCOORD gc[2], /* returned */
62 register HOLO *hp,
63 register int i
64 )
65 {
66 register int j, n;
67 int n2, reverse;
68 GCOORD g2[2];
69 /* check range */
70 if ((i < 1) | (i > nbeams(hp)))
71 return(0);
72 if ( (reverse = i >= hp->wi[5]) )
73 i -= hp->wi[5] - 1;
74 for (j = 0; j < 5; j++) /* find w0 */
75 if (hp->wi[j+1] > i)
76 break;
77 i -= hp->wi[gc[0].w=j];
78 /* find w1 */
79 n2 = hp->grid[hdwg0[j]] * hp->grid[hdwg1[j]];
80 while (++j < 5) {
81 n = n2 * hp->grid[hdwg0[j]] * hp->grid[hdwg1[j]];
82 if (n > i)
83 break;
84 i -= n;
85 }
86 gc[1].w = j;
87 /* find position on w0 */
88 n2 = hp->grid[hdwg0[j]] * hp->grid[hdwg1[j]];
89 n = i / n2;
90 gc[0].i[1] = n / hp->grid[hdwg0[gc[0].w]];
91 gc[0].i[0] = n - gc[0].i[1]*hp->grid[hdwg0[gc[0].w]];
92 i -= n*n2;
93 /* find position on w1 */
94 gc[1].i[1] = i / hp->grid[hdwg0[gc[1].w]];
95 gc[1].i[0] = i - gc[1].i[1]*hp->grid[hdwg0[gc[1].w]];
96 if (reverse) {
97 *g2 = *(gc+1);
98 *(gc+1) = *gc;
99 *gc = *g2;
100 }
101 return(1); /* we're done */
102 }
103
104
105 extern int
106 hdbindex( /* compute index from beam coordinates */
107 register HOLO *hp,
108 register GCOORD gc[2]
109 )
110 {
111 GCOORD g2[2];
112 int reverse;
113 register int i, j;
114 /* check ordering and limits */
115 if ( (reverse = gc[0].w > gc[1].w) ) {
116 *g2 = *(gc+1);
117 *(g2+1) = *gc;
118 gc = g2;
119 } else if (gc[0].w == gc[1].w)
120 return(0);
121 if ((gc[0].w < 0) | (gc[1].w > 5))
122 return(0);
123 i = 0; /* compute index */
124 for (j = gc[0].w+1; j < gc[1].w; j++)
125 i += hp->grid[hdwg0[j]] * hp->grid[hdwg1[j]];
126 i *= hp->grid[hdwg0[gc[0].w]] * hp->grid[hdwg1[gc[0].w]];
127 i += hp->wi[gc[0].w];
128 i += (hp->grid[hdwg0[gc[0].w]]*gc[0].i[1] + gc[0].i[0]) *
129 hp->grid[hdwg0[gc[1].w]] * hp->grid[hdwg1[gc[1].w]] ;
130 i += hp->grid[hdwg0[gc[1].w]]*gc[1].i[1] + gc[1].i[0];
131 if (reverse)
132 i += hp->wi[5] - 1;
133 return(i);
134 }
135
136
137 extern void
138 hdcell( /* compute cell coordinates */
139 register FVECT cp[4], /* returned (may be passed as FVECT cp[2][2]) */
140 register HOLO *hp,
141 register GCOORD *gc
142 )
143 {
144 register RREAL *v;
145 double d;
146 /* compute common component */
147 VCOPY(cp[0], hp->orig);
148 if (gc->w & 1) {
149 v = hp->xv[gc->w>>1];
150 cp[0][0] += v[0]; cp[0][1] += v[1]; cp[0][2] += v[2];
151 }
152 v = hp->xv[hdwg0[gc->w]];
153 d = (double)gc->i[0] / hp->grid[hdwg0[gc->w]];
154 VSUM(cp[0], cp[0], v, d);
155 v = hp->xv[hdwg1[gc->w]];
156 d = (double)gc->i[1] / hp->grid[hdwg1[gc->w]];
157 VSUM(cp[0], cp[0], v, d);
158 /* compute x1 sums */
159 v = hp->xv[hdwg0[gc->w]];
160 d = 1.0 / hp->grid[hdwg0[gc->w]];
161 VSUM(cp[1], cp[0], v, d);
162 VSUM(cp[3], cp[0], v, d);
163 /* compute y1 sums */
164 v = hp->xv[hdwg1[gc->w]];
165 d = 1.0 / hp->grid[hdwg1[gc->w]];
166 VSUM(cp[2], cp[0], v, d);
167 VSUM(cp[3], cp[3], v, d);
168 }
169
170
171 extern int
172 hdlseg( /* compute line segment for beam */
173 register int lseg[2][3],
174 register HOLO *hp,
175 GCOORD gc[2]
176 )
177 {
178 register int k;
179
180 for (k = 0; k < 2; k++) { /* compute end points */
181 lseg[k][gc[k].w>>1] = gc[k].w&1 ? hp->grid[gc[k].w>>1]-1 : 0 ;
182 lseg[k][hdwg0[gc[k].w]] = gc[k].i[0];
183 lseg[k][hdwg1[gc[k].w]] = gc[k].i[1];
184 }
185 return(1);
186 }
187
188
189 extern unsigned int
190 hdcode( /* compute depth code for d */
191 HOLO *hp,
192 double d
193 )
194 {
195 double tl = hp->tlin;
196 register long c;
197
198 if (d <= 0.)
199 return(0);
200 if (d >= .99*FHUGE)
201 return(DCINF);
202 if (d < tl)
203 return((unsigned)(d*DCLIN/tl));
204 c = (long)(log(d/tl)/logstep) + DCLIN;
205 return(c > DCINF ? (unsigned)DCINF : (unsigned)c);
206 }
207
208
209 extern void
210 hdgrid( /* compute grid coordinates */
211 FVECT gp, /* returned */
212 register HOLO *hp,
213 FVECT wp
214 )
215 {
216 FVECT vt;
217
218 VSUB(vt, wp, hp->orig);
219 gp[0] = DOT(vt, hp->wg[0]);
220 gp[1] = DOT(vt, hp->wg[1]);
221 gp[2] = DOT(vt, hp->wg[2]);
222 }
223
224
225 extern void
226 hdworld( /* compute world coordinates */
227 register FVECT wp,
228 register HOLO *hp,
229 FVECT gp
230 )
231 {
232 register double d;
233
234 d = gp[0]/hp->grid[0];
235 VSUM(wp, hp->orig, hp->xv[0], d);
236
237 d = gp[1]/hp->grid[1];
238 VSUM(wp, wp, hp->xv[1], d);
239
240 d = gp[2]/hp->grid[2];
241 VSUM(wp, wp, hp->xv[2], d);
242 }
243
244
245 extern double
246 hdray( /* compute ray within a beam */
247 FVECT ro,
248 FVECT rd, /* returned */
249 HOLO *hp,
250 GCOORD gc[2],
251 uby8 r[2][2]
252 )
253 {
254 FVECT cp[4], p[2];
255 register int i, j;
256 double d0, d1;
257 /* compute entry and exit points */
258 for (i = 0; i < 2; i++) {
259 hdcell(cp, hp, gc+i);
260 d0 = (1./256.)*(r[i][0]+.5);
261 d1 = (1./256.)*(r[i][1]+.5);
262 for (j = 0; j < 3; j++)
263 p[i][j] = (1.-d0-d1)*cp[0][j] +
264 d0*cp[1][j] + d1*cp[2][j];
265 }
266 VCOPY(ro, p[0]); /* assign ray origin and direction */
267 VSUB(rd, p[1], p[0]);
268 return(normalize(rd)); /* return maximum inside distance */
269 }
270
271
272 extern double
273 hdinter( /* compute ray intersection with section */
274 register GCOORD gc[2], /* returned */
275 uby8 r[2][2], /* returned (optional) */
276 double *ed, /* returned (optional) */
277 register HOLO *hp,
278 FVECT ro,
279 FVECT rd /* normalization of rd affects distances */
280 )
281 {
282 FVECT p[2], vt;
283 double d, t0, t1, d0, d1;
284 register RREAL *v;
285 register int i;
286 /* first, intersect walls */
287 gc[0].w = gc[1].w = -1;
288 t0 = -FHUGE; t1 = FHUGE;
289 VSUB(vt, ro, hp->orig);
290 for (i = 0; i < 3; i++) { /* for each wall pair */
291 d = -DOT(rd, hp->wg[i]); /* plane distance */
292 if (d <= FTINY && d >= -FTINY) /* check for parallel */
293 continue;
294 d1 = DOT(vt, hp->wg[i]); /* ray distances */
295 d0 = d1 / d;
296 d1 = (d1 - hp->grid[i]) / d;
297 if (d < 0) { /* check against best */
298 if (d0 > t0) {
299 t0 = d0;
300 gc[0].w = i<<1;
301 }
302 if (d1 < t1) {
303 t1 = d1;
304 gc[1].w = i<<1 | 1;
305 }
306 } else {
307 if (d1 > t0) {
308 t0 = d1;
309 gc[0].w = i<<1 | 1;
310 }
311 if (d0 < t1) {
312 t1 = d0;
313 gc[1].w = i<<1;
314 }
315 }
316 }
317 if ((gc[0].w < 0) | (gc[1].w < 0)) /* paranoid check */
318 return(FHUGE);
319 /* compute intersections */
320 VSUM(p[0], ro, rd, t0);
321 VSUM(p[1], ro, rd, t1);
322 /* now, compute grid coordinates */
323 for (i = 0; i < 2; i++) {
324 VSUB(vt, p[i], hp->orig);
325 v = hp->wg[hdwg0[gc[i].w]];
326 d = DOT(vt, v);
327 if (d < 0 || d >= hp->grid[hdwg0[gc[i].w]])
328 return(FHUGE); /* outside wall */
329 gc[i].i[0] = d;
330 if (r != NULL)
331 r[i][0] = 256. * (d - gc[i].i[0]);
332 v = hp->wg[hdwg1[gc[i].w]];
333 d = DOT(vt, v);
334 if (d < 0 || d >= hp->grid[hdwg1[gc[i].w]])
335 return(FHUGE); /* outside wall */
336 gc[i].i[1] = d;
337 if (r != NULL)
338 r[i][1] = 256. * (d - gc[i].i[1]);
339 }
340 if (ed != NULL) /* assign distance to exit point */
341 *ed = t1;
342 return(t0); /* return distance to entry point */
343 }
