root/radiance/ray/src/hd/holo.c
Fri May 20 02:06:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.21: +3 -3 lines
Diff to previous 3.21 , to selected 3.19
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.20: +62 -44 lines
Diff to previous 3.20 , to selected 3.19
Ansification and prototypes.
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.19: +7 -7 lines
Diff to previous 3.19
Revision 3.19 - (view) (download) (annotate) - [selected]
Mon Jul 21 22:30:18 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.18: +6 -6 lines
Diff to previous 3.18
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.17: +3 -3 lines
Diff to previous 3.17 , to selected 3.19
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.16: +1 -4 lines
Diff to previous 3.16 , to selected 3.19
Fri Mar 12 09:37:47 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.15: +0 -34 lines
Diff to previous 3.15 , to selected 3.19
moved hdalloc() from holo.c to holofile.c
Thu Dec 3 15:18:39 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.14: +11 -11 lines
Diff to previous 3.14 , to selected 3.19
got rid of unnecessary constants in HOLO struct
Mon Aug 31 15:40:13 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.13: +5 -13 lines
Diff to previous 3.13 , to selected 3.19
made use of new VSUB() macro
Tue Jan 6 15:08:50 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.12: +45 -43 lines
Diff to previous 3.12 , to selected 3.19
Sat Jan 3 15:55:55 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.11: +3 -3 lines
Diff to previous 3.11 , to selected 3.19
made hdcode() safe for 16-bit integers (why?)
Fri Dec 19 11:49:19 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.10: +6 -5 lines
Diff to previous 3.10 , to selected 3.19
made ray position argument to hdinter() optional
Thu Dec 18 09:33:12 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.9: +6 -6 lines
Diff to previous 3.9 , to selected 3.19
added far distance return value to hdinter()
Mon Dec 15 20:43:24 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.8: +2 -5 lines
Diff to previous 3.8 , to selected 3.19
changed hdlseg() arguments
Thu Nov 20 10:52:57 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.7: +11 -4 lines
Diff to previous 3.7 , to selected 3.19
fixed wrong calculation in hdworld()
Wed Nov 12 16:29:43 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.6: +11 -0 lines
Diff to previous 3.6 , to selected 3.19
added hdworld() routine
Tue Nov 11 17:03:28 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.5: +24 -23 lines
Diff to previous 3.5 , to selected 3.19
simplified intersection code
added hdgrid() routine to compute grid coordinates
Tue Nov 11 15:14:02 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.4: +33 -35 lines
Diff to previous 3.4 , to selected 3.19
consolidated code for hdcell() and hdray()
Tue Nov 11 14:40:59 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.3: +27 -1 lines
Diff to previous 3.3 , to selected 3.19
added hdcell() routine to compute cell corners
Thu Nov 6 16:37:45 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.2: +7 -7 lines
Diff to previous 3.2 , to selected 3.19
changed BCOORD to GCOORD[2]
Mon Nov 3 11:03:23 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.1: +30 -43 lines
Diff to previous 3.1 , to selected 3.19
changed to indexed array to avoid expensive modulo evaluations
Fri Oct 31 10:23:29 1997 UTC (27 years, 6 months ago) by gregl
Diff to selected 3.19
