--- ray/src/hd/holo.c 1997/10/31 10:23:29 3.1 +++ ray/src/hd/holo.c 1997/11/06 16:37:45 3.3 @@ -16,7 +16,10 @@ float hd_depthmap[DCINF-DCLIN]; static double logstep; +static int wg0[6] = {1,1,2,2,0,0}; +static int wg1[6] = {2,2,0,0,1,1}; + hdcompgrid(hp) /* compute derived grid vector and index */ register HOLO *hp; { @@ -59,10 +62,8 @@ register HOLO *hp; for (i = 1; i < 6; i++) { hp->wi[i] = 0; for (j = i; j < 6; j++) - hp->wi[i] += hp->grid[((j>>1)+1)%3] * - hp->grid[((j>>1)+2)%3]; - hp->wi[i] *= hp->grid[(((i-1)>>1)+1)%3] * - hp->grid[(((i-1)>>1)+2)%3]; + hp->wi[i] += hp->grid[wg0[j]] * hp->grid[wg1[j]]; + hp->wi[i] *= hp->grid[wg0[i-1]] * hp->grid[wg1[i-1]]; hp->wi[i] += hp->wi[i-1]; } } @@ -103,13 +104,13 @@ HDGRID *hproto; hdbcoord(gc, hp, i) /* compute beam coordinates from index */ -BCOORD gc; /* returned */ +GCOORD gc[2]; /* returned */ register HOLO *hp; register int i; { register int j, n; int n2, reverse; - BCOORD g2; + GCOORD g2[2]; /* check range */ if (i < 1 | i > nbeams(hp)) return(0); @@ -120,23 +121,23 @@ register int i; break; i -= hp->wi[gc[0].w=j]; /* find w1 */ - n2 = hp->grid[((j>>1)+1)%3] * hp->grid[((j>>1)+2)%3]; + n2 = hp->grid[wg0[j]] * hp->grid[wg1[j]]; while (++j < 5) { - n = n2 * hp->grid[((j>>1)+1)%3] * hp->grid[((j>>1)+2)%3]; + n = n2 * hp->grid[wg0[j]] * hp->grid[wg1[j]]; if (n > i) break; i -= n; } gc[1].w = j; /* find position on w0 */ - n2 = hp->grid[((j>>1)+1)%3] * hp->grid[((j>>1)+2)%3]; + n2 = hp->grid[wg0[j]] * hp->grid[wg1[j]]; n = i / n2; - gc[0].i[1] = n / hp->grid[((gc[0].w>>1)+1)%3]; - gc[0].i[0] = n - gc[0].i[1]*hp->grid[((gc[0].w>>1)+1)%3]; + gc[0].i[1] = n / hp->grid[wg0[gc[0].w]]; + gc[0].i[0] = n - gc[0].i[1]*hp->grid[wg0[gc[0].w]]; i -= n*n2; /* find position on w1 */ - gc[1].i[1] = i / hp->grid[((gc[1].w>>1)+1)%3]; - gc[1].i[0] = i - gc[1].i[1]*hp->grid[((gc[1].w>>1)+1)%3]; + gc[1].i[1] = i / hp->grid[wg0[gc[1].w]]; + gc[1].i[0] = i - gc[1].i[1]*hp->grid[wg0[gc[1].w]]; if (reverse) { copystruct(g2, gc+1); copystruct(gc+1, gc); @@ -149,9 +150,9 @@ register int i; int hdbindex(hp, gc) /* compute index from beam coordinates */ register HOLO *hp; -register BCOORD gc; +register GCOORD gc[2]; { - BCOORD g2; + GCOORD g2[2]; int reverse; register int i, j; /* check ordering and limits */ @@ -165,13 +166,12 @@ register BCOORD gc; return(0); i = 0; /* compute index */ for (j = gc[0].w+1; j < gc[1].w; j++) - i += hp->grid[((j>>1)+1)%3] * hp->grid[((j>>1)+2)%3]; - i *= hp->grid[((gc[0].w>>1)+1)%3] * hp->grid[((gc[0].w>>1)+2)%3]; + i += hp->grid[wg0[j]] * hp->grid[wg1[j]]; + i *= hp->grid[wg0[gc[0].w]] * hp->grid[wg1[gc[0].w]]; i += hp->wi[gc[0].w]; - i += (hp->grid[((gc[0].w>>1)+1)%3]*gc[0].i[1] + gc[0].i[0]) * - hp->grid[((gc[1].w>>1)+1)%3] * - hp->grid[((gc[1].w>>1)+2)%3] ; - i += hp->grid[((gc[1].w>>1)+1)%3]*gc[1].i[1] + gc[1].i[0]; + i += (hp->grid[wg0[gc[0].w]]*gc[0].i[1] + gc[0].i[0]) * + hp->grid[wg0[gc[1].w]] * hp->grid[wg1[gc[1].w]] ; + i += hp->grid[wg0[gc[1].w]]*gc[1].i[1] + gc[1].i[0]; if (reverse) i += hp->wi[5] - 1; return(i); @@ -179,33 +179,20 @@ register BCOORD gc; hdlseg(lseg, hp, i) /* compute line segment for beam */ -int lseg[2][3]; +register int lseg[2][3]; register HOLO *hp; int i; { - BCOORD gc; + GCOORD gc[2]; register int k; - if (!hdbcoord(gc, hp, i)) + if (!hdbcoord(gc, hp, i)) /* compute grid coordinates */ return(0); - for (k = 0; k < 2; k++) /* compute line segment */ - switch (gc[k].w>>1) { - case 0: - lseg[k][0] = (gc[k].w & 1) * (hp->grid[0]-1); - lseg[k][1] = gc[k].i[0]; - lseg[k][2] = gc[k].i[1]; - break; - case 1: - lseg[k][0] = gc[k].i[1]; - lseg[k][1] = (gc[k].w & 1) * (hp->grid[1]-1); - lseg[k][2] = gc[k].i[0]; - break; - case 2: - lseg[k][0] = gc[k].i[0]; - lseg[k][1] = gc[k].i[1]; - lseg[k][2] = (gc[k].w & 1) * (hp->grid[2]-1); - break; - } + for (k = 0; k < 2; k++) { /* compute end points */ + lseg[k][gc[k].w>>1] = gc[k].w&1 ? hp->grid[gc[k].w>>1]-1 : 0 ; + lseg[k][wg0[gc[k].w]] = gc[k].i[0]; + lseg[k][wg1[gc[k].w]] = gc[k].i[1]; + } return(1); } @@ -233,7 +220,7 @@ double hdray(ro, rd, hp, gc, r) /* compute ray within a beam */ FVECT ro, rd; /* returned */ register HOLO *hp; -register BCOORD gc; +register GCOORD gc[2]; BYTE r[2][2]; { FVECT p[2]; @@ -248,12 +235,12 @@ BYTE r[2][2]; p[i][0] += *v++; p[i][1] += *v++; p[i][2] += *v; } d = ( gc[i].i[0] + (1./256.)*(r[i][0]+.5) ) / - hp->grid[((gc[i].w>>1)+1)%3]; - v = hp->xv[((gc[i].w>>1)+1)%3]; + hp->grid[wg0[gc[i].w]]; + v = hp->xv[wg0[gc[i].w]]; p[i][0] += d * *v++; p[i][1] += d * *v++; p[i][2] += d * *v; d = (gc[i].i[1] + (1./256.)*(r[i][1]+.5)) / - hp->grid[((gc[i].w>>1)+2)%3]; - v = hp->xv[((gc[i].w>>1)+2)%3]; + hp->grid[wg1[gc[i].w]]; + v = hp->xv[wg1[gc[i].w]]; p[i][0] += d * *v++; p[i][1] += d * *v++; p[i][2] += d * *v; } VCOPY(ro, p[0]); /* assign ray origin and direction */ @@ -266,7 +253,7 @@ BYTE r[2][2]; double hdinter(gc, r, hp, ro, rd) /* compute ray intersection with section */ -register BCOORD gc; /* returned */ +register GCOORD gc[2]; /* returned */ BYTE r[2][2]; /* returned */ register HOLO *hp; FVECT ro, rd; /* rd should be normalized */ @@ -323,12 +310,12 @@ FVECT ro, rd; /* rd should be normalized */ } v = hp->gv[gc[i].w>>1][0]; d = DOT(vt, v); - if (d < 0. || (gc[i].i[0] = d) >= hp->grid[((gc[i].w>>1)+1)%3]) + if (d < 0. || (gc[i].i[0] = d) >= hp->grid[wg0[gc[i].w]]) return(FHUGE); /* outside wall */ r[i][0] = 256. * (d - gc[i].i[0]); v = hp->gv[gc[i].w>>1][1]; d = DOT(vt, v); - if (d < 0. || (gc[i].i[1] = d) >= hp->grid[((gc[i].w>>1)+2)%3]) + if (d < 0. || (gc[i].i[1] = d) >= hp->grid[wg1[gc[i].w]]) return(FHUGE); /* outside wall */ r[i][1] = 256. * (d - gc[i].i[1]); }
