root/radiance/ray/src/hd/clumpbeams.c
Fri Oct 5 19:19:16 2018 UTC (5 years, 8 months ago) by greg
Changes since 3.8: +7 -7 lines
Diff to previous 3.8 , to selected 3.5
Changes since 3.7: +30 -16 lines
Diff to previous 3.7 , to selected 3.5
Ansification and prototypes.
Mon Nov 17 02:21:53 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 3.6 , to selected 3.5
Unix compile fixes for previous change
Changes since 3.5: +3 -3 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Changes since 3.4: +5 -5 lines
Diff to previous 3.4
Changes since 3.3: +5 -5 lines
Diff to previous 3.3 , to selected 3.5
Changes since 3.2: +3 -6 lines
Diff to previous 3.2 , to selected 3.5
Tue Nov 10 18:05:41 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.1: +4 -27 lines
Diff to previous 3.1 , to selected 3.5
change clumpbeams() callback function to take clump's queue
Mon Nov 9 17:11:04 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to selected 3.5
