root/radiance/ray/src/hd/clumpbeams.c
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.7: +30 -16 lines
Diff to previous 3.7 , to selected 3.4
Ansification and prototypes.
Mon Nov 17 02:21:53 2003 UTC (21 years, 5 months ago) by greg
Diff to previous 3.6 , to selected 3.4
Unix compile fixes for previous change
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.5: +3 -3 lines
Diff to previous 3.5 , to selected 3.4
Mon Jul 21 22:30:18 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.4: +5 -5 lines
Diff to previous 3.4
Revision 3.4 - (view) (download) (annotate) - [selected]
Changes since 3.3: +5 -5 lines
Diff to previous 3.3
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.2: +3 -6 lines
Diff to previous 3.2 , to selected 3.4
Tue Nov 10 18:05:41 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.1: +4 -27 lines
Diff to previous 3.1 , to selected 3.4
change clumpbeams() callback function to take clump's queue
Mon Nov 9 17:11:04 1998 UTC (26 years, 6 months ago) by gwlarson
Diff to selected 3.4
