root/radiance/ray/src/hd/clumpbeams.c
Changes since 3.7: +30 -16 lines
Diff to previous 3.7 , to selected 3.3
Ansification and prototypes.
Mon Nov 17 02:21:53 2003 UTC (20 years, 5 months ago) by greg
Diff to previous 3.6 , to selected 3.3
Unix compile fixes for previous change
Sun Jul 27 22:12:02 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.5: +3 -3 lines
Diff to previous 3.5 , to selected 3.3
Mon Jul 21 22:30:18 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.4: +5 -5 lines
Diff to previous 3.4 , to selected 3.3
Changes since 3.3: +5 -5 lines
Diff to previous 3.3
Revision 3.3 - (view) (download) (annotate) - [selected]
Changes since 3.2: +3 -6 lines
Diff to previous 3.2
Tue Nov 10 18:05:41 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.1: +4 -27 lines
Diff to previous 3.1 , to selected 3.3
change clumpbeams() callback function to take clump's queue
Mon Nov 9 17:11:04 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to selected 3.3
