root/Development/ray/src/hd/SConscript
Revision: 1.5
Committed: Mon Sep 19 12:37:46 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 1.4: +4 -1 lines
Added rhoptimize to SCons build.
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # common objects
9 viewbeams = env.Object(source='viewbeams.c')
10 holo = env.Object(source='holo.c')
11 holofile = env.Object(source='holofile.c')
12 clumpbeams = env.Object(source='clumpbeams.c')
13 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
14
15
16 # standard targets
17 PROGS = (
18 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
19 + [Version, holofile, holo, viewbeams],
20 ['rtpic','rtio','rtproc','rtpath','rtargs','rtmath','rtmem','rterror']),
21 ('rhpict', Split('rhpict.c rhpict2.c')+[Version, holofile, holo, viewbeams],
22 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
23 ('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo],
24 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
25 ('rhinfo', Split('rhinfo.c') + [holofile, holo],
26 ['rtio','rtproc', 'rtmath','rterror']),
27 ('rhoptimize', Split('rhoptimize.c') + [clumpbeams, holofile, holo],
28 ['rtio','rtproc', 'rtmath','rterror']),
29 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo],
30 ['rtio','rtmath','rtproc','rterror']),
31 )
32 if os.name != 'nt': # pending some major work...
33 for p in PROGS:
34 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
35 source=p[1], LIBS=p[2] + mlib)
36 Default(prog)
37 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
38
39 # display drivers
40 if env.has_key('X11INCLUDE'):
41 xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
42 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
43 # common objects
44 rhdisp = xenv.Object(source='rhdisp.c')
45 rhdisp2 = xenv.Object(source='rhdisp2.c')
46 rhd_qtree = env.Object(source='rhd_qtree.c')
47 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
48 # other stuff
49 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
50 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
51 ocppflags = xenv.get('CPPFLAGS', [])
52
53 # XXX the .hdi extension will cause problems on Windows
54 xenv['PROGSUFFIX'] = '.hdi'
55
56 dlibs = ['rtpic','rtio','rtmath','rtcont','rtmem','rtargs','rterror']
57 def make_hdi(p): # build them
58 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
59 prog = xenv.Program(target=os.path.join(devdir, p[0]),
60 source=[obj] + p[1] + xcommon, LIBS=p[2])
61 Default(prog)
62 inst = xenv.Install(idevdir, prog)
63 # XXX what are the alternative "<driver>h" names good for?
64 insth = xenv.InstallAs(target=os.path.join(idevdir,
65 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
66 env.Append(RAD_BININSTALL=[inst, insth])
67
68 # (name, sources, libs, obj, objsrc, objflags)
69 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
70 dlibs + ['X11'] + mlib,
71 'rhd_x11', 'rhd_x11.c', []),
72 )
73 for p in XHDI:
74 make_hdi(p)
75
76 if env.has_key('OGL'):
77 rgllibs = ['rgl','rtscene','rtpath']
78 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
79 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
80 rhdobj = xenv.Object(source='rhdobj.c')
81
82 GLHDI = (
83 # glx1h
84 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
85 dlibs + ['GLU','GL','X11'] + mlib,
86 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
87
88 # oglh
89 ('ogl', ogl_common,
90 rgllibs+dlibs+['GLU','GL','X11'] + mlib,
91 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
92
93 # ogloh
94 ('oglo', [rhdobj] + ogl_common,
95 rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib,
96 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
97 )
98 for p in GLHDI:
99 make_hdi(p)
100 if xenv['RAD_STEREO'] == '-DSTEREO':
101
102 GLSHDI = (
103 # oglsh
104 ('ogls', ogl_common,
105 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
106 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
107
108 # oglsoh
109 ('oglso', [rhdobj] + ogl_common,
110 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
111 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
112 )
113 for p in GLHDI:
114 make_hdi(p)
115
116
117
