root/Development/ray/src/hd/SConscript
Revision: 1.4
Committed: Mon Nov 8 19:24:46 2004 UTC (21 years ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1
Changes since 1.3: +5 -22 lines
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # common objects
9 viewbeams = env.Object(source='viewbeams.c')
10 holo = env.Object(source='holo.c')
11 holofile = env.Object(source='holofile.c')
12 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
13
14
15 # standard targets
16 PROGS = (
17 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
18 + [Version, holofile, holo, viewbeams],
19 ['rtpic','rtio','rtproc','rtpath','rtargs','rtmath','rtmem','rterror']),
20 ('rhpict', Split('rhpict.c rhpict2.c')+[Version, holofile, holo, viewbeams],
21 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
22 ('rhcopy', Split('rhcopy.c clumpbeams.c') + [holofile, holo],
23 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
24 ('rhinfo', Split('rhinfo.c') + [holofile, holo],
25 ['rtio','rtproc', 'rtmath','rterror']),
26 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo],
27 ['rtio','rtmath','rtproc','rterror']),
28 )
29 if os.name != 'nt': # pending some major work...
30 for p in PROGS:
31 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
32 source=p[1], LIBS=p[2] + mlib)
33 Default(prog)
34 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
35
36 # display drivers
37 if env.has_key('X11INCLUDE'):
38 xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
39 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
40 # common objects
41 rhdisp = xenv.Object(source='rhdisp.c')
42 rhdisp2 = xenv.Object(source='rhdisp2.c')
43 rhd_qtree = env.Object(source='rhd_qtree.c')
44 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
45 # other stuff
46 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
47 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
48 ocppflags = xenv.get('CPPFLAGS', [])
49
50 # XXX the .hdi extension will cause problems on Windows
51 xenv['PROGSUFFIX'] = '.hdi'
52
53 dlibs = ['rtpic','rtio','rtmath','rtcont','rtmem','rtargs','rterror']
54 def make_hdi(p): # build them
55 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
56 prog = xenv.Program(target=os.path.join(devdir, p[0]),
57 source=[obj] + p[1] + xcommon, LIBS=p[2])
58 Default(prog)
59 inst = xenv.Install(idevdir, prog)
60 # XXX what are the alternative "<driver>h" names good for?
61 insth = xenv.InstallAs(target=os.path.join(idevdir,
62 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
63 env.Append(RAD_BININSTALL=[inst, insth])
64
65 # (name, sources, libs, obj, objsrc, objflags)
66 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
67 dlibs + ['X11'] + mlib,
68 'rhd_x11', 'rhd_x11.c', []),
69 )
70 for p in XHDI:
71 make_hdi(p)
72
73 if env.has_key('OGL'):
74 rgllibs = ['rgl','rtscene','rtpath']
75 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
76 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
77 rhdobj = xenv.Object(source='rhdobj.c')
78
79 GLHDI = (
80 # glx1h
81 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
82 dlibs + ['GLU','GL','X11'] + mlib,
83 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
84
85 # oglh
86 ('ogl', ogl_common,
87 rgllibs+dlibs+['GLU','GL','X11'] + mlib,
88 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
89
90 # ogloh
91 ('oglo', [rhdobj] + ogl_common,
92 rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib,
93 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
94 )
95 for p in GLHDI:
96 make_hdi(p)
97 if xenv['RAD_STEREO'] == '-DSTEREO':
98
99 GLSHDI = (
100 # oglsh
101 ('ogls', ogl_common,
102 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
103 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
104
105 # oglsoh
106 ('oglso', [rhdobj] + ogl_common,
107 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
108 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
109 )
110 for p in GLHDI:
111 make_hdi(p)
112
113
114
