root/Development/ray/src/hd/SConscript
Revision: 1.12
Committed: Mon Mar 28 17:35:13 2016 UTC (9 years, 9 months ago) by schorsch
syntax.
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 # common objects
13 viewbeams = env.Object(source='viewbeams.c')
14 holo = env.Object(source='holo.c')
15 holofile = env.Object(source='holofile.c')
16 clumpbeams = env.Object(source='clumpbeams.c')
17
18 # standard targets
19 PROGS = (
20 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
21 + [env.version, holofile, holo, viewbeams], ['rtrad'],0),
22 ('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams],
23 ['rtrad'],1),
24 ('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], ['rtrad'],1),
25 ('rhinfo', Split('rhinfo.c') + [holofile, holo], ['rtrad'],1),
26 ('rhoptimize', Split('rhoptimize.c') + [clumpbeams,holofile,holo], ['rtrad'],1),
27 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo], ['rtrad'],1),
28 )
29 if 1:
30 for p in PROGS:
31 if not p[3] and os.name == 'nt': continue
32 prog = env.Program(target=radbin(p[0]),
33 source=p[1], LIBS=p[2] + mlib)
34 Default(prog)
35 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
36
37 # display drivers
38 if env.has_key('X11INCLUDE'):
39 xenv = env.Clone(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
40 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
41 # common objects
42 rhdisp = xenv.Object(source='rhdisp.c')
43 rhdisp2 = xenv.Object(source='rhdisp2.c')
44 rhd_qtree = env.Object(source='rhd_qtree.c')
45 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
46 # other stuff
47 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
48 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
49 ocppflags = xenv.get('CPPFLAGS', [])
50 addobj = xenv.get('ADDOBJNOTIFY')
51
52 # XXX the .hdi extension will cause problems on Windows
53 xenv['PROGSUFFIX'] = '.hdi'
54
55 def make_hdi(p): # build them
56 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
57 prog = xenv.Program(target=radbin(p[0]),
58 source=[obj] + p[1] + xcommon, LIBS=p[2])
59 Default(prog)
60 inst = xenv.Install(idevdir, prog)
61 # XXX what are the alternative "<driver>h" names good for?
62 insth = xenv.InstallAs(target=radbin(
63 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
64 env.Append(RAD_BININSTALL=[inst, insth])
65
66 # (name, sources, libs, obj, objsrc, objflags)
67 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
68 ['rtrad', 'X11'] + mlib,
69 'rhd_x11', 'rhd_x11.c', []),
70 )
71 for p in XHDI:
72 make_hdi(p)
73
74 if env.has_key('OGL'):
75 rgllibs = ['rgl','rtrad']
76 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
77 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
78 rhdobj = xenv.Object(source='rhdobj.c')
79
80 GLHDI = (
81 # glx1h
82 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
83 ['rtrad', 'GLU','GL','X11'] + mlib,
84 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
85
86 # oglh
87 ('ogl', ogl_common + [addobj],
88 rgllibs+['rtrad', 'GLU','GL','X11'] + mlib,
89 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
90
91 # ogloh
92 ('oglo', [rhdobj] + ogl_common + [addobj],
93 rgllibs+['rtrad']+['rtrad', 'GLU','GL','X11'] + mlib,
94 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
95 )
96 for p in GLHDI:
97 make_hdi(p)
98 if xenv['RAD_STEREO'] == '-DSTEREO':
99
100 GLSHDI = (
101 # oglsh
102 ('ogls', ogl_common,
103 rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib,
104 'rhd_ogls', 'rhd_ogl.c', ['-DSTEREO']),
105
106 # oglsoh
107 ('oglso', [rhdobj] + ogl_common,
108 rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib,
109 'rhd_oglso', 'rhd_ogl.c', ['-DDOBJ', '-DSTEREO']),
110 )
111 for p in GLHDI:
112 make_hdi(p)
113
114
115
116 # vim: set syntax=python:
