root/Development/ray/src/hd/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:29 2003 UTC (22 years ago) by schorsch
1 import os
2
3 Import('env')
4
5
6 # math libs
7 mlib = env['RAD_MLIB']
8
9 # common objects
10 viewbeams = env.Object(source='viewbeams.c')
11 holo = env.Object(source='holo.c')
12
13 # standard targets
14 PROGS = (
15 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c
16 holofile.c Version.c''') + [holo, viewbeams]),
17 ('rhpict', Split('rhpict.c rhpict2.c holofile.c Version.c')+[holo, viewbeams]),
18 ('rhcopy', Split('rhcopy.c clumpbeams.c holofile.c') + [holo]),
19 ('rhinfo', Split('rhinfo.c holofile.c') + [holo]),
20 #('genrhenv', Split('genrhenv.c holofile.c') + [holo]), # XXX broken
21 ('genrhgrid', Split('genrhgrid.c') + [holo]),
22 )
23 if os.name != 'nt': # pending some major work...
24 for p in PROGS:
25 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
26 source=p[1], LIBS=['rt'] + mlib)
27 Default(prog)
28 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
29
30 # display drivers
31 if env.has_key('X11INCLUDE'):
32 xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
33 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
34 # common objects
35 rhdisp = xenv.Object(source='rhdisp.c')
36 rhdisp2 = xenv.Object(source='rhdisp2.c')
37 rhd_qtree = env.Object(source='rhd_qtree.c')
38 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
39 # other stuff
40 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
41 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
42 ocppflags = xenv.get('CPPFLAGS', [])
43
44 # XXX the .hdi extension will cause problems on Windows
45 xenv['PROGSUFFIX'] = '.hdi'
46
47 def make_hdi(p): # build them
48 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
49 prog = xenv.Program(target=os.path.join(devdir, p[0]),
50 source=[obj] + p[1] + xcommon, LIBS=p[2])
51 Default(prog)
52 inst = xenv.Install(idevdir, prog)
53 # XXX what are the alternative "<driver>h" names good for?
54 insth = xenv.InstallAs(target=os.path.join(idevdir,
55 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
56 env.Append(RAD_BININSTALL=[inst, insth])
57
58 # (name, sources, libs, obj, objsrc, objflags)
59 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
60 ['rt','X11'] + mlib,
61 'rhd_x11', 'rhd_x11.c', []),
62 )
63 for p in XHDI:
64 make_hdi(p)
65
66 if env.has_key('OGL'):
67 # XXX There's a BITS(x) macro missing in sm_geom.h
68 #sm_common_s = Split('''sm_samp.c sm_qtree.c sm_stree.c sm_geom.c
69 # sm_list.c sm_del.c sm_ogl.c sm_usets.c sm.c''')
70 #sm_common = map(lambda s:xenv.Object(source=s), sm_common_s)
71 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
72 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
73 rhdobj = xenv.Object(source='rhdobj.c')
74
75 GLHDI = (
76 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
77 ['rt','GLU','GL','X11'] + mlib,
78 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
79
80 #('glx', sm_common,
81 # ['rt','GLU','GL','X11'] + mlib,
82 # 'rhd_glx0', 'rhd_glx.c', ['-DNOSTEREO']),
83
84 #('glxo', [rhdobj] + sm_common,
85 # ['rgl','rt','GLU','GL','X11'] + mlib,
86 # 'rhd_glxo', 'rhd_glx.c', ['-DDOBJ', '-DNOSTEREO']),
87
88 ('ogl', ogl_common,
89 ['rgl','rt','GLU','GL','X11'] + mlib,
90 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
91
92 ('oglo', [rhdobj] + ogl_common,
93 ['rgl','rt','GLU','GL','X11'] + mlib,
94 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
95 )
96 for p in GLHDI:
97 make_hdi(p)
98 if xenv['RAD_STEREO'] == '-DSTEREO':
99
100 GLSHDI = (
101 #('glxs', sm_common,
102 # ['rt','GLU','GL','X11','Xext'] + mlib,
103 # 'rhd_glxs', 'rhd_glx.c' ['-DSTEREO']),
104
105 #('glxso', [rhdobj] + sm_common,
106 # ['rgl','rt','GLU','GL','X11','Xext'] + mlib,
107 # 'rhd_glxo', 'rhd_glx.c' ['-DDOBJ', '-DSTEREO']),
108
109 ('ogls', ogl_common,
110 ['rgl','rt','GLU','GL','X11','Xext'] + mlib,
111 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
112
113 ('oglso', [rhdobj] + ogl_common,
114 ['rgl','rt','GLU','GL','X11','Xext'] + mlib,
115 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
116 )
117 for p in GLHDI:
118 make_hdi(p)
119
120
121
