--- ray/src/hd/SConscript 2003/10/27 10:35:42 1.2 +++ ray/src/hd/SConscript 2008/04/21 07:31:29 1.6 @@ -9,22 +9,23 @@ mlib = env['RAD_MLIB'] viewbeams = env.Object(source='viewbeams.c') holo = env.Object(source='holo.c') holofile = env.Object(source='holofile.c') -Version = env.Object(source='Version.c') +clumpbeams = env.Object(source='clumpbeams.c') +Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice # standard targets PROGS = ( ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''') + [Version, holofile, holo, viewbeams], - ['rtpic','rtio','rtproc','rtpath','rtargs','rtmath','rtmem','rterror']), + ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtmem','rterror']), ('rhpict', Split('rhpict.c rhpict2.c')+[Version, holofile, holo, viewbeams], - ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']), -('rhcopy', Split('rhcopy.c clumpbeams.c') + [holofile, holo], - ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']), + ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']), +('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], + ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']), ('rhinfo', Split('rhinfo.c') + [holofile, holo], ['rtio','rtproc', 'rtmath','rterror']), -#('genrhenv', Split('genrhenv.c') + [holofile, holo], -# []), # XXX broken +('rhoptimize', Split('rhoptimize.c') + [clumpbeams, holofile, holo], + ['rtio','rtproc', 'rtmath','rterror']), ('genrhgrid', Split('genrhgrid.c') + [holofile, holo], ['rtio','rtmath','rtproc','rterror']), ) @@ -52,7 +53,7 @@ if env.has_key('X11INCLUDE'): # XXX the .hdi extension will cause problems on Windows xenv['PROGSUFFIX'] = '.hdi' - dlibs = ['rtpic','rtio','rtmath','rtcont','rtmem','rtargs','rterror'] + dlibs = ['rtpic','rtmath','rtcont','rtmem','rtargs','rtio','rterror'] def make_hdi(p): # build them obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5]) prog = xenv.Program(target=os.path.join(devdir, p[0]), @@ -74,31 +75,22 @@ if env.has_key('X11INCLUDE'): if env.has_key('OGL'): rgllibs = ['rgl','rtscene','rtpath'] - # XXX There's a BITS(x) macro missing in sm_geom.h - #sm_common_s = Split('''sm_samp.c sm_qtree.c sm_stree.c sm_geom.c - # sm_list.c sm_del.c sm_ogl.c sm_usets.c sm.c''') - #sm_common = map(lambda s:xenv.Object(source=s), sm_common_s) ogl_common_s = Split('rhd_odraw.c rhd_geom.c') ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s) rhdobj = xenv.Object(source='rhdobj.c') GLHDI = ( + # glx1h ('glx1', ['rhd_qtree2c.c', rhd_qtree], dlibs + ['GLU','GL','X11'] + mlib, 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']), - #('glx', sm_common, - # dlibs + ['GLU','GL','X11'] + mlib, - # 'rhd_glx0', 'rhd_glx.c', ['-DNOSTEREO']), - - #('glxo', [rhdobj] + sm_common, - # rgllibs+dlibs+['GLU','GL','X11'] + mlib, - # 'rhd_glxo', 'rhd_glx.c', ['-DDOBJ', '-DNOSTEREO']), - + # oglh ('ogl', ogl_common, rgllibs+dlibs+['GLU','GL','X11'] + mlib, 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']), + # ogloh ('oglo', [rhdobj] + ogl_common, rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib, 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']), @@ -108,18 +100,12 @@ if env.has_key('X11INCLUDE'): if xenv['RAD_STEREO'] == '-DSTEREO': GLSHDI = ( - #('glxs', sm_common, - # dlibs + ['GLU','GL','X11','Xext'] + mlib, - # 'rhd_glxs', 'rhd_glx.c' ['-DSTEREO']), - - #('glxso', [rhdobj] + sm_common, - # rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, - # 'rhd_glxo', 'rhd_glx.c' ['-DDOBJ', '-DSTEREO']), - + # oglsh ('ogls', ogl_common, rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']), + # oglsoh ('oglso', [rhdobj] + ogl_common, rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
