--- ray/src/hd/SConscript 2016/03/10 01:49:56 1.9 +++ ray/src/hd/SConscript 2018/01/08 13:38:37 1.13 @@ -1,3 +1,5 @@ +from __future__ import division, print_function, unicode_literals + import os Import('env') @@ -18,22 +20,16 @@ clumpbeams = env.Object(source='clumpbeams.c') # standard targets PROGS = ( ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''') - + [env.version, holofile, holo, viewbeams], - ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtmem','rterror'],0), + + [env.version, holofile, holo, viewbeams], ['rtrad'],0), ('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams], - ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror'],1), -('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], - ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror'],1), -('rhinfo', Split('rhinfo.c') + [holofile, holo], - ['rtio','rtproc', 'rtmath','rterror'],1), -('rhoptimize', Split('rhoptimize.c') + [clumpbeams, holofile, holo], - ['rtio','rtproc', 'rtmath','rterror'],1), -('genrhgrid', Split('genrhgrid.c') + [holofile, holo], - ['rtio','rtmath','rtproc','rterror'],1), + ['rtrad'],1), +('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], ['rtrad'],1), +('rhinfo', Split('rhinfo.c') + [holofile, holo], ['rtrad'],1), +('rhoptimize', Split('rhoptimize.c') + [clumpbeams,holofile,holo], ['rtrad'],1), +('genrhgrid', Split('genrhgrid.c') + [holofile, holo], ['rtrad'],1), ) if 1: for p in PROGS: - print(p[0]) if not p[3] and os.name == 'nt': continue prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2] + mlib) @@ -53,11 +49,11 @@ if env.has_key('X11INCLUDE'): devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev') idevdir = os.path.join(xenv['RAD_BINDIR'],'dev') ocppflags = xenv.get('CPPFLAGS', []) + addobj = xenv.get('ADDOBJNOTIFY') # XXX the .hdi extension will cause problems on Windows xenv['PROGSUFFIX'] = '.hdi' - dlibs = ['rtpic','rtmath','rtcont','rtmem','rtargs','rtio','rterror','rtdummy'] def make_hdi(p): # build them obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5]) prog = xenv.Program(target=radbin(p[0]), @@ -71,14 +67,14 @@ if env.has_key('X11INCLUDE'): # (name, sources, libs, obj, objsrc, objflags) XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree], - dlibs + ['X11'] + mlib, + ['rtrad', 'X11'] + mlib, 'rhd_x11', 'rhd_x11.c', []), ) for p in XHDI: make_hdi(p) if env.has_key('OGL'): - rgllibs = ['rgl','rtscene','rtpath'] + rgllibs = ['rgl','rtrad'] ogl_common_s = Split('rhd_odraw.c rhd_geom.c') ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s) rhdobj = xenv.Object(source='rhdobj.c') @@ -86,17 +82,17 @@ if env.has_key('X11INCLUDE'): GLHDI = ( # glx1h ('glx1', ['rhd_qtree2c.c', rhd_qtree], - dlibs + ['GLU','GL','X11'] + mlib, + ['rtrad', 'GLU','GL','X11'] + mlib, 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']), # oglh - ('ogl', ogl_common, - rgllibs+dlibs+['GLU','GL','X11'] + mlib, + ('ogl', ogl_common + [addobj], + rgllibs+['rtrad', 'GLU','GL','X11'] + mlib, 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']), # ogloh - ('oglo', [rhdobj] + ogl_common, - rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib, + ('oglo', [rhdobj] + ogl_common + [addobj], + rgllibs+['rtrad']+['rtrad', 'GLU','GL','X11'] + mlib, 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']), ) for p in GLHDI: @@ -106,13 +102,13 @@ if env.has_key('X11INCLUDE'): GLSHDI = ( # oglsh ('ogls', ogl_common, - rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, - 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']), + rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib, + 'rhd_ogls', 'rhd_ogl.c', ['-DSTEREO']), # oglsoh ('oglso', [rhdobj] + ogl_common, - rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, - 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']), + rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib, + 'rhd_oglso', 'rhd_ogl.c', ['-DDOBJ', '-DSTEREO']), ) for p in GLHDI: make_hdi(p) @@ -120,3 +116,4 @@ if env.has_key('X11INCLUDE'): # vim: set syntax=python: +# vi: set ts=4 sw=4 :
