root/Development/ray/src/hd/SConscript
Revision: 1.8
Committed: Sat Mar 5 13:24:58 2016 UTC (9 years, 6 months ago) by schorsch
Changes since 1.7: +10 -7 lines
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 # common objects
13 viewbeams = env.Object(source='viewbeams.c')
14 holo = env.Object(source='holo.c')
15 holofile = env.Object(source='holofile.c')
16 clumpbeams = env.Object(source='clumpbeams.c')
17
18 # standard targets
19 PROGS = (
20 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
21 + [env.version, holofile, holo, viewbeams],
22 ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtmem','rterror']),
23 ('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams],
24 ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']),
25 ('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo],
26 ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']),
27 ('rhinfo', Split('rhinfo.c') + [holofile, holo],
28 ['rtio','rtproc', 'rtmath','rterror']),
29 ('rhoptimize', Split('rhoptimize.c') + [clumpbeams, holofile, holo],
30 ['rtio','rtproc', 'rtmath','rterror']),
31 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo],
32 ['rtio','rtmath','rtproc','rterror']),
33 )
34 if os.name != 'nt': # pending some major work...
35 for p in PROGS:
36 prog = env.Program(target=radbin(p[0]),
37 source=p[1], LIBS=p[2] + mlib)
38 Default(prog)
39 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
40
41 # display drivers
42 if env.has_key('X11INCLUDE'):
43 xenv = env.Clone(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
44 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
45 # common objects
46 rhdisp = xenv.Object(source='rhdisp.c')
47 rhdisp2 = xenv.Object(source='rhdisp2.c')
48 rhd_qtree = env.Object(source='rhd_qtree.c')
49 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
50 # other stuff
51 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
52 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
53 ocppflags = xenv.get('CPPFLAGS', [])
54
55 # XXX the .hdi extension will cause problems on Windows
56 xenv['PROGSUFFIX'] = '.hdi'
57
58 dlibs = ['rtpic','rtmath','rtcont','rtmem','rtargs','rtio','rterror','rtdummy']
59 def make_hdi(p): # build them
60 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
61 prog = xenv.Program(target=radbin(p[0]),
62 source=[obj] + p[1] + xcommon, LIBS=p[2])
63 Default(prog)
64 inst = xenv.Install(idevdir, prog)
65 # XXX what are the alternative "<driver>h" names good for?
66 insth = xenv.InstallAs(target=radbin(
67 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
68 env.Append(RAD_BININSTALL=[inst, insth])
69
70 # (name, sources, libs, obj, objsrc, objflags)
71 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
72 dlibs + ['X11'] + mlib,
73 'rhd_x11', 'rhd_x11.c', []),
74 )
75 for p in XHDI:
76 make_hdi(p)
77
78 if env.has_key('OGL'):
79 rgllibs = ['rgl','rtscene','rtpath']
80 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
81 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
82 rhdobj = xenv.Object(source='rhdobj.c')
83
84 GLHDI = (
85 # glx1h
86 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
87 dlibs + ['GLU','GL','X11'] + mlib,
88 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
89
90 # oglh
91 ('ogl', ogl_common,
92 rgllibs+dlibs+['GLU','GL','X11'] + mlib,
93 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
94
95 # ogloh
96 ('oglo', [rhdobj] + ogl_common,
97 rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib,
98 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
99 )
100 for p in GLHDI:
101 make_hdi(p)
102 if xenv['RAD_STEREO'] == '-DSTEREO':
103
104 GLSHDI = (
105 # oglsh
106 ('ogls', ogl_common,
107 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
108 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
109
110 # oglsoh
111 ('oglso', [rhdobj] + ogl_common,
112 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
113 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
114 )
115 for p in GLHDI:
116 make_hdi(p)
117
118
119
120 # vim: set syntax=python:
