root/Development/ray/src/hd/SConscript
Revision: 1.3
Committed: Sun Jul 4 12:08:48 2004 UTC (21 years, 5 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # common objects
9 viewbeams = env.Object(source='viewbeams.c')
10 holo = env.Object(source='holo.c')
11 holofile = env.Object(source='holofile.c')
12 Version = env.Object(source='../rt/Version.c') # XXX ../rt/not_nice
13
14
15 # standard targets
16 PROGS = (
17 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
18 + [Version, holofile, holo, viewbeams],
19 ['rtpic','rtio','rtproc','rtpath','rtargs','rtmath','rtmem','rterror']),
20 ('rhpict', Split('rhpict.c rhpict2.c')+[Version, holofile, holo, viewbeams],
21 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
22 ('rhcopy', Split('rhcopy.c clumpbeams.c') + [holofile, holo],
23 ['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
24 ('rhinfo', Split('rhinfo.c') + [holofile, holo],
25 ['rtio','rtproc', 'rtmath','rterror']),
26 #('genrhenv', Split('genrhenv.c') + [holofile, holo],
27 # []), # XXX broken
28 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo],
29 ['rtio','rtmath','rtproc','rterror']),
30 )
31 if os.name != 'nt': # pending some major work...
32 for p in PROGS:
33 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
34 source=p[1], LIBS=p[2] + mlib)
35 Default(prog)
36 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
37
38 # display drivers
39 if env.has_key('X11INCLUDE'):
40 xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
41 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
42 # common objects
43 rhdisp = xenv.Object(source='rhdisp.c')
44 rhdisp2 = xenv.Object(source='rhdisp2.c')
45 rhd_qtree = env.Object(source='rhd_qtree.c')
46 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
47 # other stuff
48 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
49 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
50 ocppflags = xenv.get('CPPFLAGS', [])
51
52 # XXX the .hdi extension will cause problems on Windows
53 xenv['PROGSUFFIX'] = '.hdi'
54
55 dlibs = ['rtpic','rtio','rtmath','rtcont','rtmem','rtargs','rterror']
56 def make_hdi(p): # build them
57 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
58 prog = xenv.Program(target=os.path.join(devdir, p[0]),
59 source=[obj] + p[1] + xcommon, LIBS=p[2])
60 Default(prog)
61 inst = xenv.Install(idevdir, prog)
62 # XXX what are the alternative "<driver>h" names good for?
63 insth = xenv.InstallAs(target=os.path.join(idevdir,
64 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
65 env.Append(RAD_BININSTALL=[inst, insth])
66
67 # (name, sources, libs, obj, objsrc, objflags)
68 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
69 dlibs + ['X11'] + mlib,
70 'rhd_x11', 'rhd_x11.c', []),
71 )
72 for p in XHDI:
73 make_hdi(p)
74
75 if env.has_key('OGL'):
76 rgllibs = ['rgl','rtscene','rtpath']
77 # XXX There's a BITS(x) macro missing in sm_geom.h
78 #sm_common_s = Split('''sm_samp.c sm_qtree.c sm_stree.c sm_geom.c
79 # sm_list.c sm_del.c sm_ogl.c sm_usets.c sm.c''')
80 #sm_common = map(lambda s:xenv.Object(source=s), sm_common_s)
81 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
82 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
83 rhdobj = xenv.Object(source='rhdobj.c')
84
85 GLHDI = (
86 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
87 dlibs + ['GLU','GL','X11'] + mlib,
88 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
89
90 #('glx', sm_common,
91 # dlibs + ['GLU','GL','X11'] + mlib,
92 # 'rhd_glx0', 'rhd_glx.c', ['-DNOSTEREO']),
93
94 #('glxo', [rhdobj] + sm_common,
95 # rgllibs+dlibs+['GLU','GL','X11'] + mlib,
96 # 'rhd_glxo', 'rhd_glx.c', ['-DDOBJ', '-DNOSTEREO']),
97
98 ('ogl', ogl_common,
99 rgllibs+dlibs+['GLU','GL','X11'] + mlib,
100 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
101
102 ('oglo', [rhdobj] + ogl_common,
103 rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib,
104 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
105 )
106 for p in GLHDI:
107 make_hdi(p)
108 if xenv['RAD_STEREO'] == '-DSTEREO':
109
110 GLSHDI = (
111 #('glxs', sm_common,
112 # dlibs + ['GLU','GL','X11','Xext'] + mlib,
113 # 'rhd_glxs', 'rhd_glx.c' ['-DSTEREO']),
114
115 #('glxso', [rhdobj] + sm_common,
116 # rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
117 # 'rhd_glxo', 'rhd_glx.c' ['-DDOBJ', '-DSTEREO']),
118
119 ('ogls', ogl_common,
120 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
121 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
122
123 ('oglso', [rhdobj] + ogl_common,
124 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
125 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
126 )
127 for p in GLHDI:
128 make_hdi(p)
129
130
131
