| 1 |
import os
| 2 |
| 3 |
Import('env')
| 4 |
| 5 |
# math libs
| 6 |
mlib = env['RAD_MLIB']
| 7 |
| 8 |
# common objects
| 9 |
viewbeams = env.Object(source='viewbeams.c')
| 10 |
holo = env.Object(source='holo.c')
| 11 |
holofile = env.Object(source='holofile.c')
| 12 |
Version = env.Object(source='Version.c')
| 13 |
| 14 |
| 15 |
# standard targets
| 16 |
PROGS = (
| 17 |
('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
| 18 |
+ [Version, holofile, holo, viewbeams],
| 19 |
['rtpic','rtio','rtproc','rtpath','rtargs','rtmath','rtmem','rterror']),
| 20 |
('rhpict', Split('rhpict.c rhpict2.c')+[Version, holofile, holo, viewbeams],
| 21 |
['rtpic','rtio','rtproc','rtargs','rtmath','rtmem','rterror']),
| 22 |
('rhcopy', Split('rhcopy.c clumpbeams.c') + [holofile, holo],
| 23 |
| 24 |
('rhinfo', Split('rhinfo.c') + [holofile, holo],
| 25 |
['rtio','rtproc', 'rtmath','rterror']),
| 26 |
#('genrhenv', Split('genrhenv.c') + [holofile, holo],
| 27 |
# []), # XXX broken
| 28 |
('genrhgrid', Split('genrhgrid.c') + [holofile, holo],
| 29 |
['rtio','rtmath','rtproc','rterror']),
| 30 |
| 31 |
if os.name != 'nt': # pending some major work...
| 32 |
for p in PROGS:
| 33 |
prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
| 34 |
source=p[1], LIBS=p[2] + mlib)
| 35 |
Default(prog)
| 36 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
| 37 |
| 38 |
# display drivers
| 39 |
if env.has_key('X11INCLUDE'):
| 40 |
xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
| 41 |
LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
| 42 |
# common objects
| 43 |
rhdisp = xenv.Object(source='rhdisp.c')
| 44 |
rhdisp2 = xenv.Object(source='rhdisp2.c')
| 45 |
rhd_qtree = env.Object(source='rhd_qtree.c')
| 46 |
xcommon = [rhdisp, rhdisp2, holo, viewbeams]
| 47 |
# other stuff
| 48 |
devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
| 49 |
idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
| 50 |
ocppflags = xenv.get('CPPFLAGS', [])
| 51 |
| 52 |
# XXX the .hdi extension will cause problems on Windows
| 53 |
xenv['PROGSUFFIX'] = '.hdi'
| 54 |
| 55 |
dlibs = ['rtpic','rtio','rtmath','rtcont','rtmem','rtargs','rterror']
| 56 |
def make_hdi(p): # build them
| 57 |
obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
| 58 |
prog = xenv.Program(target=os.path.join(devdir, p[0]),
| 59 |
source=[obj] + p[1] + xcommon, LIBS=p[2])
| 60 |
Default(prog)
| 61 |
inst = xenv.Install(idevdir, prog)
| 62 |
# XXX what are the alternative "<driver>h" names good for?
| 63 |
insth = xenv.InstallAs(target=os.path.join(idevdir,
| 64 |
p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
| 65 |
env.Append(RAD_BININSTALL=[inst, insth])
| 66 |
| 67 |
# (name, sources, libs, obj, objsrc, objflags)
| 68 |
XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
| 69 |
dlibs + ['X11'] + mlib,
| 70 |
'rhd_x11', 'rhd_x11.c', []),
| 71 |
| 72 |
for p in XHDI:
| 73 |
make_hdi(p)
| 74 |
| 75 |
if env.has_key('OGL'):
| 76 |
rgllibs = ['rgl','rtscene','rtpath']
| 77 |
# XXX There's a BITS(x) macro missing in sm_geom.h
| 78 |
#sm_common_s = Split('''sm_samp.c sm_qtree.c sm_stree.c sm_geom.c
| 79 |
# sm_list.c sm_del.c sm_ogl.c sm_usets.c sm.c''')
| 80 |
#sm_common = map(lambda s:xenv.Object(source=s), sm_common_s)
| 81 |
ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
| 82 |
ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
| 83 |
rhdobj = xenv.Object(source='rhdobj.c')
| 84 |
| 85 |
GLHDI = (
| 86 |
('glx1', ['rhd_qtree2c.c', rhd_qtree],
| 87 |
dlibs + ['GLU','GL','X11'] + mlib,
| 88 |
'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
| 89 |
| 90 |
#('glx', sm_common,
| 91 |
# dlibs + ['GLU','GL','X11'] + mlib,
| 92 |
# 'rhd_glx0', 'rhd_glx.c', ['-DNOSTEREO']),
| 93 |
| 94 |
#('glxo', [rhdobj] + sm_common,
| 95 |
# rgllibs+dlibs+['GLU','GL','X11'] + mlib,
| 96 |
# 'rhd_glxo', 'rhd_glx.c', ['-DDOBJ', '-DNOSTEREO']),
| 97 |
| 98 |
('ogl', ogl_common,
| 99 |
| 100 |
'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
| 101 |
| 102 |
('oglo', [rhdobj] + ogl_common,
| 103 |
rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib,
| 104 |
'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
| 105 |
| 106 |
for p in GLHDI:
| 107 |
make_hdi(p)
| 108 |
if xenv['RAD_STEREO'] == '-DSTEREO':
| 109 |
| 110 |
GLSHDI = (
| 111 |
#('glxs', sm_common,
| 112 |
# dlibs + ['GLU','GL','X11','Xext'] + mlib,
| 113 |
# 'rhd_glxs', 'rhd_glx.c' ['-DSTEREO']),
| 114 |
| 115 |
#('glxso', [rhdobj] + sm_common,
| 116 |
# rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
| 117 |
# 'rhd_glxo', 'rhd_glx.c' ['-DDOBJ', '-DSTEREO']),
| 118 |
| 119 |
('ogls', ogl_common,
| 120 |
| 121 |
'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
| 122 |
| 123 |
('oglso', [rhdobj] + ogl_common,
| 124 |
| 125 |
'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
| 126 |
| 127 |
for p in GLHDI:
| 128 |
make_hdi(p)
| 129 |
| 130 |
| 131 |
