--- ray/src/hd/SConscript 2003/10/21 19:27:29 1.1 +++ ray/src/hd/SConscript 2016/03/05 13:24:58 1.8 @@ -2,34 +2,45 @@ import os Import('env') - # math libs mlib = env['RAD_MLIB'] +# compose paths +def radbin(name): return os.path.join('$RAD_BUILDBIN', name) +def radlib(name): return os.path.join('$RAD_BUILDLIB', name) + # common objects viewbeams = env.Object(source='viewbeams.c') holo = env.Object(source='holo.c') +holofile = env.Object(source='holofile.c') +clumpbeams = env.Object(source='clumpbeams.c') # standard targets PROGS = ( -('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c - holofile.c Version.c''') + [holo, viewbeams]), -('rhpict', Split('rhpict.c rhpict2.c holofile.c Version.c')+[holo, viewbeams]), -('rhcopy', Split('rhcopy.c clumpbeams.c holofile.c') + [holo]), -('rhinfo', Split('rhinfo.c holofile.c') + [holo]), -#('genrhenv', Split('genrhenv.c holofile.c') + [holo]), # XXX broken -('genrhgrid', Split('genrhgrid.c') + [holo]), +('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''') + + [env.version, holofile, holo, viewbeams], + ['rtpic','rtproc','rtpath','rtio','rtargs','rtmath','rtmem','rterror']), +('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams], + ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']), +('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], + ['rtpic','rtproc','rtargs','rtio','rtmath','rtmem','rterror']), +('rhinfo', Split('rhinfo.c') + [holofile, holo], + ['rtio','rtproc', 'rtmath','rterror']), +('rhoptimize', Split('rhoptimize.c') + [clumpbeams, holofile, holo], + ['rtio','rtproc', 'rtmath','rterror']), +('genrhgrid', Split('genrhgrid.c') + [holofile, holo], + ['rtio','rtmath','rtproc','rterror']), ) if os.name != 'nt': # pending some major work... for p in PROGS: - prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]), - source=p[1], LIBS=['rt'] + mlib) + prog = env.Program(target=radbin(p[0]), + source=p[1], LIBS=p[2] + mlib) Default(prog) env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) # display drivers if env.has_key('X11INCLUDE'): - xenv = env.Copy(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'], + xenv = env.Clone(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'], LIBPATH=[env['X11LIB']] + env['LIBPATH'],) # common objects rhdisp = xenv.Object(source='rhdisp.c') @@ -44,53 +55,46 @@ if env.has_key('X11INCLUDE'): # XXX the .hdi extension will cause problems on Windows xenv['PROGSUFFIX'] = '.hdi' + dlibs = ['rtpic','rtmath','rtcont','rtmem','rtargs','rtio','rterror','rtdummy'] def make_hdi(p): # build them obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5]) - prog = xenv.Program(target=os.path.join(devdir, p[0]), + prog = xenv.Program(target=radbin(p[0]), source=[obj] + p[1] + xcommon, LIBS=p[2]) Default(prog) inst = xenv.Install(idevdir, prog) # XXX what are the alternative "h" names good for? - insth = xenv.InstallAs(target=os.path.join(idevdir, + insth = xenv.InstallAs(target=radbin( p[0] + 'h' + xenv['PROGSUFFIX']), source=prog) env.Append(RAD_BININSTALL=[inst, insth]) # (name, sources, libs, obj, objsrc, objflags) XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree], - ['rt','X11'] + mlib, + dlibs + ['X11'] + mlib, 'rhd_x11', 'rhd_x11.c', []), ) for p in XHDI: make_hdi(p) if env.has_key('OGL'): - # XXX There's a BITS(x) macro missing in sm_geom.h - #sm_common_s = Split('''sm_samp.c sm_qtree.c sm_stree.c sm_geom.c - # sm_list.c sm_del.c sm_ogl.c sm_usets.c sm.c''') - #sm_common = map(lambda s:xenv.Object(source=s), sm_common_s) + rgllibs = ['rgl','rtscene','rtpath'] ogl_common_s = Split('rhd_odraw.c rhd_geom.c') ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s) rhdobj = xenv.Object(source='rhdobj.c') GLHDI = ( + # glx1h ('glx1', ['rhd_qtree2c.c', rhd_qtree], - ['rt','GLU','GL','X11'] + mlib, + dlibs + ['GLU','GL','X11'] + mlib, 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']), - #('glx', sm_common, - # ['rt','GLU','GL','X11'] + mlib, - # 'rhd_glx0', 'rhd_glx.c', ['-DNOSTEREO']), - - #('glxo', [rhdobj] + sm_common, - # ['rgl','rt','GLU','GL','X11'] + mlib, - # 'rhd_glxo', 'rhd_glx.c', ['-DDOBJ', '-DNOSTEREO']), - + # oglh ('ogl', ogl_common, - ['rgl','rt','GLU','GL','X11'] + mlib, + rgllibs+dlibs+['GLU','GL','X11'] + mlib, 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']), + # ogloh ('oglo', [rhdobj] + ogl_common, - ['rgl','rt','GLU','GL','X11'] + mlib, + rgllibs+['rtproc']+dlibs+['GLU','GL','X11'] + mlib, 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']), ) for p in GLHDI: @@ -98,20 +102,14 @@ if env.has_key('X11INCLUDE'): if xenv['RAD_STEREO'] == '-DSTEREO': GLSHDI = ( - #('glxs', sm_common, - # ['rt','GLU','GL','X11','Xext'] + mlib, - # 'rhd_glxs', 'rhd_glx.c' ['-DSTEREO']), - - #('glxso', [rhdobj] + sm_common, - # ['rgl','rt','GLU','GL','X11','Xext'] + mlib, - # 'rhd_glxo', 'rhd_glx.c' ['-DDOBJ', '-DSTEREO']), - + # oglsh ('ogls', ogl_common, - ['rgl','rt','GLU','GL','X11','Xext'] + mlib, + rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']), + # oglsoh ('oglso', [rhdobj] + ogl_common, - ['rgl','rt','GLU','GL','X11','Xext'] + mlib, + rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib, 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']), ) for p in GLHDI: @@ -119,3 +117,4 @@ if env.has_key('X11INCLUDE'): +# vim: set syntax=python:
