Removed more unused files and compiles (genrhenv and glx driver)
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
created rhinfo program
changes to ogl driver
added missing dependencies for rhdobj.o
first attempt and Delaunay triangulation driver
created genrhgrid program
wrote genrhenv program to create holodeck environment maps
reverted to using quadtree for GLX driver
created GLX driver
change driver suffix
added rhcopy program
made persist file vary with process id so multiple rholo's don't interfere
removed device prefix
added Version.c
added compiles for x11 driver
