root/radiance/ray/src/hd/CMakeLists.txt
Mon Jan 8 16:51:32 2018 UTC (7 years, 4 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Changes since 1.7: +43 -9 lines
Diff to previous 1.7
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Mar 20 22:49:21 2014 UTC (11 years, 1 month ago) by greg
Changes since 1.6: +7 -6 lines
Diff to previous 1.6
Changes to speed installation on cloud computing systems
Wed May 30 18:31:11 2012 UTC (12 years, 11 months ago) by greg
Changes since 1.5: +3 -0 lines
Diff to previous 1.5
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
Changes since 1.4: +8 -2 lines
Diff to previous 1.4
Mon Nov 7 18:46:03 2011 UTC (13 years, 6 months ago) by greg
Changes since 1.3: +0 -9 lines
Diff to previous 1.3
Removed redundant section
Fri Oct 28 20:46:47 2011 UTC (13 years, 6 months ago) by greg
Changes since 1.2: +3 -0 lines
Diff to previous 1.2
Fixes to Version.c update in cmake build system
Wed Oct 26 16:48:01 2011 UTC (13 years, 6 months ago) by greg
Diff to previous 1.1
Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
