root/radiance/ray/src/gen/xform.c
Revision: 2.51
Committed: Sun Dec 2 16:30:30 2018 UTC (6 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R3
Changes since 2.50: +8 -6 lines
Echo empty lines and comments in output when using -f option
2 static const char RCSid[] = "$Id: xform.c,v 2.50 2016/03/04 00:21:21 greg Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "rtmath.h"
18 #include "object.h"
19 #include "otypes.h"
20
21 int xac; /* global xform argument count */
22 char **xav; /* global xform argument pointer */
23 int xfa; /* start of xf arguments */
24
25 XF tot; /* total transformation */
26 int reverse; /* boolean true if scene mirrored */
27
28 int invert; /* boolean true to invert surfaces */
29
30 int expand; /* boolean true to expand commands */
31
32 char *newmod; /* new modifier for surfaces */
33
34 char *idprefix; /* prefix for object identifiers */
35
36 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
37
38 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
39
40 int nrept = 1; /* number of array repetitions */
41
42 int stdinused = 0; /* stdin has been used by -f option? */
43
44 char mainfn[PATH_MAX]; /* main file name */
45 FILE *mainfp = NULL; /* main file pointer */
46
47 #define progname (xav[0])
48
49 static int doargf(int ac, char **av, int fi);
50 static int doarray(int ac, char **av, int ai);
51 static void xform(char *name, FILE *fin);
52 static void xfcomm(char *fname, FILE *fin);
53 static void xfobject(char *fname, FILE *fin);
54 static int addxform(FILE *fin);
55 static int alias(FILE *fin);
56 void initotypes(void); /* XXX conflict with otypes.h */
57 static void openmain(char *iname);
58
59
60 int
61 main( /* get transform options and transform file */
62 int argc,
63 char *argv[]
64 )
65 {
66 int mal_prefix = 0;
67 int a;
68 /* check for argument list file */
69 for (a = 1; a < argc; a++)
70 if (!strcmp(argv[a], "-f"))
71 return(doargf(argc, argv, a));
72 /* check for regular array */
73 for (a = 1; a < argc; a++)
74 if (!strcmp(argv[a], "-a"))
75 return(doarray(argc, argv, a));
76
77 initotypes(); /* initialize */
78 invert = 0;
79 expand = 1;
80 newmod = NULL;
81 idprefix = NULL;
82
83 for (a = 1; a < argc; a++) {
84 if (argv[a][0] == '-')
85 switch (argv[a][1]) {
86 case 'm':
87 if (argv[a][2] | (a+1 >= argc))
88 break;
89 a++;
90 if (newmod == NULL)
91 newmod = argv[a];
92 continue;
93 case 'n':
94 if (argv[a][2] | (a+1 >= argc))
95 break;
96 a++;
97 if (idprefix == NULL)
98 idprefix = argv[a];
99 else {
100 char *newp;
101 newp = (char *)malloc(strlen(idprefix)+
102 strlen(argv[a])+2);
103 if (newp == NULL)
104 exit(2);
105 sprintf(newp, "%s.%s",
106 idprefix, argv[a]);
107 if (mal_prefix++)
108 free(idprefix);
109 idprefix = newp;
110 }
111 continue;
112 case 'c':
113 if (argv[a][2])
114 break;
115 expand = 0;
116 continue;
117 case 'e':
118 if (argv[a][2])
119 break;
120 expand = 1;
121 continue;
122 case 'I':
123 if (argv[a][2])
124 break;
125 invert = !invert;
126 continue;
127 }
128 break;
129 }
130
131 xav = argv;
132 xfa = a;
133
134 a += xf(&tot, argc-a, argv+a);
135
136 if ( (reverse = (tot.sca < 0.0)) )
137 tot.sca = -tot.sca;
138 if (invert)
139 reverse = !reverse;
140
141 if (a < argc && argv[a][0] == '-') {
142 fprintf(stderr, "%s: command line error at '%s'\n",
143 argv[0], argv[a]);
144 exit(1);
145 }
146
147 xac = a;
148 /* simple header */
149 putchar('#');
150 for (a = 0; a < xac; a++)
151 printf(" %s", xav[a]);
152 putchar('\n');
153 /* transform input */
154 if (xac == argc) {
155 if (stdinused) {
156 fprintf(stderr, "%s: cannot use stdin more than once\n",
157 argv[0]);
158 exit(1);
159 }
160 openmain(NULL);
161 xform(mainfn, mainfp);
162 } else
163 for (a = xac; a < argc; a++) {
164 openmain(argv[a]);
165 xform(mainfn, mainfp);
166 }
167
168 if (mal_prefix)
169 free(idprefix);
170 return(0);
171 }
172
173
174 int
175 doargf( /* take argument list from file */
176 int ac,
177 char **av,
178 int fi
179 )
180 {
181 int inquote;
182 char *newav[256], **avp;
183 char argbuf[2048];
184 char *newid, newidbuf[128];
185 char *oldid;
186 char *cp;
187 FILE *argfp;
188 int n, i, k, newac, err;
189
190 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
191 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
192 exit(1);
193 }
194 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
195 if (stdinused++) {
196 fprintf(stderr,
197 "%s: cannot use stdin more than once\n",
198 av[0]);
199 exit(1);
200 }
201 argfp = stdin;
202 n = 100; /* we just don't know! */
203 } else {
204 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
205 fprintf(stderr,
206 "%s: cannot open argument file \"%s\"\n",
207 av[0], av[fi+1]);
208 exit(1);
209 }
210 n = 0; /* count number of lines in file */
211 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
212 n += (argbuf[0] != '\0') & (argbuf[0] != '#');
213 if (!n) {
214 fprintf(stderr, "%s: empty argument file \"%s\"\n",
215 av[0], av[fi+1]);
216 exit(1);
217 }
218 rewind(argfp);
219 }
220 nrept *= n;
221 err = 0; k = 0; /* read each arg list and call main */
222 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
223 if (!argbuf[0] | (argbuf[0] == '#')) {
224 printf("%s\n", argbuf);
225 continue;
226 }
227 avp = newav+2;
228 avp[0] = av[0];
229 for (i = 1; i < fi; i++)
230 avp[i] = av[i];
231 newac = i;
232 cp = argbuf; /* parse new words */
233 if (*cp == '!') cp++;
234 if (!strncmp(cp, "xform ", 6)) cp += 6;
235 inquote = 0;
236 for ( ; ; ) {
237 skipspaces:
238 while (isspace(*cp)) /* nullify spaces */
239 *cp++ = '\0';
240 if ((*cp == '"') | (*cp == '\''))
241 inquote = *cp++;
242 if (!*cp) /* all done? */
243 break;
244 if (cp[0] == '\\' && cp[1])
245 if (*++cp == '\n')
246 goto skipspaces;
247 avp[newac++] = cp; /* add argument to list */
248 if (inquote) {
249 while (*++cp)
250 if (*cp == inquote) {
251 *cp++ = '\0';
252 break;
253 }
254 } else {
255 while (*++cp && !isspace(*cp))
256 ;
257 }
258 }
259 for (i = fi+2; i < ac; i++)
260 avp[newac++] = av[i];
261 avp[newac] = NULL;
262 newid = newidbuf;
263 oldid = NULL;
264 for (i = 2; i < newac; i++)
265 if (!strcmp(avp[i-1], "-n")) {
266 oldid = avp[i];
267 if (strlen(oldid)+32 > sizeof(newidbuf)) {
268 newid = (char *)malloc(strlen(oldid)+32);
269 if (newid == NULL)
270 exit(2);
271 }
272 avp[i] = newid;
273 break;
274 }
275 if (oldid == NULL) {
276 newav[0] = av[0];
277 newav[1] = "-n";
278 newav[2] = newid;
279 avp = newav;
280 newac += 2;
281 }
282 if (oldid == NULL)
283 sprintf(newid, "i%d", k);
284 else
285 sprintf(newid, "%s.%d", oldid, k);
286 err |= main(newac, avp);
287 if (newid != newidbuf)
288 free(newid);
289 k++;
290 }
291 fclose(argfp);
292 return(err);
293 }
294
295
296 int
297 doarray( /* make array */
298 int ac,
299 char **av,
300 int ai
301 )
302 {
303 char *newav[256], **avp;
304 char newid[128], repts[32];
305 char *oldid = NULL;
306 int n, i, err;
307
308 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
309 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
310 exit(1);
311 }
312 nrept *= n;
313 avp = newav+2;
314 avp[0] = av[0];
315 for (i = 1; i < ac; i++)
316 if (!strcmp(av[i-1], "-n")) {
317 oldid = av[i];
318 avp[i] = newid;
319 } else
320 avp[i] = av[i];
321 avp[ai] = "-i";
322 avp[ai+1] = repts;
323 avp[i] = NULL;
324 if (oldid == NULL) {
325 newav[0] = av[0];
326 newav[1] = "-n";
327 newav[2] = newid;
328 avp = newav;
329 ac += 2;
330 }
331 err = 0;
332 for (i = 0; i < n; i++) {
333 if (oldid == NULL)
334 sprintf(newid, "a%d", i);
335 else
336 sprintf(newid, "%s.%d", oldid, i);
337 sprintf(repts, "%d", i);
338 err |= main(ac, avp);
339 }
340 return(err);
341 }
342
343
344 void
345 xform( /* transform stream by tot.xfm */
346 char *name,
347 FILE *fin
348 )
349 {
350 int nobjs = 0;
351 int c;
352
353 while ((c = getc(fin)) != EOF) {
354 if (isspace(c)) /* blank */
355 continue;
356 if (c == '#') { /* comment */
357 putchar(c);
358 do {
359 if ((c = getc(fin)) == EOF)
360 return;
361 putchar(c);
362 } while (c != '\n');
363 } else if (c == '!') { /* command */
364 ungetc(c, fin);
365 xfcomm(name, fin);
366 nobjs++;
367 } else { /* object */
368 ungetc(c, fin);
369 xfobject(name, fin);
370 nobjs++;
371 }
372 }
373 if (nobjs == 0)
374 fprintf(stderr, "%s: (%s): warning - empty file\n",
375 progname, name);
376 }
377
378
379 void
380 xfcomm( /* transform a command */
381 char *fname,
382 FILE *fin
383 )
384 {
385 FILE *pin;
386 char buf[2048];
387 int i;
388
389 fgetline(buf, sizeof(buf), fin);
390 if (expand) {
391 if ((pin = popen(buf+1, "r")) == NULL) {
392 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
393 progname, fname, buf);
394 exit(1);
395 }
396 xform(buf, pin);
397 pclose(pin);
398 } else {
399 printf("\n%s", buf);
400 if (xac > 1) {
401 printf(" | %s -e", xav[0]); /* expand next time */
402 for (i = 1; i < xac; i++)
403 if (i >= xfa || strcmp(xav[i], "-c"))
404 printf(" %s", xav[i]);
405 }
406 putchar('\n');
407 }
408 }
409
410
411 void
412 xfobject( /* transform an object */
413 char *fname,
414 FILE *fin
415 )
416 {
417 char typ[16], nam[MAXSTR];
418 int fn;
419 /* modifier and type */
420 strcpy(typ, "EOF");
421 fgetword(nam, sizeof(nam), fin);
422 fgetword(typ, sizeof(typ), fin);
423 if ((fn = otype(typ)) < 0) {
424 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
425 progname, fname, typ);
426 exit(1);
427 }
428 putchar('\n');
429 if (ismodifier(fn)) {
430 fputword(nam, stdout);
431 printf(" %s ", typ);
432 } else {
433 fputword(newmod != NULL ? newmod : nam, stdout);
434 printf(" %s ", invert ? ofun[tinvers[fn]].funame : typ);
435 }
436 /* object name */
437 fgetword(nam, sizeof(nam), fin);
438 if (idprefix == NULL || ismodifier(fn))
439 fputword(nam, stdout);
440 else {
441 char nnam[MAXSTR];
442 sprintf(nnam, "%s.%s", idprefix, nam);
443 fputword(nnam, stdout);
444 }
445 putchar('\n');
446 /* transform arguments */
447 if ((*ofun[fn].funp)(fin) < 0) {
448 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
449 progname, fname, ofun[fn].funame, nam);
450 exit(1);
451 }
452 }
453
454
455 int
456 o_default( /* pass on arguments unchanged */
457 FILE *fin
458 )
459 {
460 int i;
461 FUNARGS fa;
462
463 if (readfargs(&fa, fin) != 1)
464 return(-1);
465 /* string arguments */
466 printf("%d", fa.nsargs);
467 for (i = 0; i < fa.nsargs; i++) {
468 fputc(' ', stdout);
469 fputword(fa.sarg[i], stdout);
470 }
471 printf("\n");
472 #ifdef IARGS
473 /* integer arguments */
474 printf("%d", fa.niargs);
475 for (i = 0; i < fa.niargs; i++)
476 printf(" %d", fa.iarg[i]);
477 printf("\n");
478 #else
479 printf("0\n");
480 #endif
481 /* float arguments */
482 printf("%d", fa.nfargs);
483 for (i = 0; i < fa.nfargs; i++)
484 printf(" %18.12g", fa.farg[i]);
485 printf("\n");
486 freefargs(&fa);
487 return(0);
488 }
489
490
491 int
492 addxform( /* add xf arguments to strings */
493 FILE *fin
494 )
495 {
496 int i;
497 int resetarr = 0;
498 FUNARGS fa;
499
500 if (readfargs(&fa, fin) != 1)
501 return(-1);
502 /* string arguments */
503 if (xac > xfa && strcmp(xav[xfa], "-i"))
504 resetarr = 2;
505 printf("%d", fa.nsargs + resetarr + xac-xfa);
506 for (i = 0; i < fa.nsargs; i++) {
507 fputc(' ', stdout);
508 fputword(fa.sarg[i], stdout);
509 }
510 if (resetarr)
511 printf(" -i 1");
512 for (i = xfa; i < xac; i++) /* add xf arguments */
513 printf(" %s", xav[i]);
514 printf("\n");
515 #ifdef IARGS
516 /* integer arguments */
517 printf("%d", fa.niargs);
518 for (i = 0; i < fa.niargs; i++)
519 printf(" %d", fa.iarg[i]);
520 printf("\n");
521 #else
522 printf("0\n");
523 #endif
524 /* float arguments */
525 printf("%d", fa.nfargs);
526 for (i = 0; i < fa.nfargs; i++)
527 printf(" %18.12g", fa.farg[i]);
528 printf("\n");
529 freefargs(&fa);
530 return(0);
531 }
532
533
534 int
535 alias( /* transfer alias */
536 FILE *fin
537 )
538 {
539 char aliasnm[MAXSTR];
540
541 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
542 return(-1);
543 printf("\t%s\n", aliasnm);
544 return(0);
545 }
546
547
548 int
549 m_glow( /* transform arguments for proximity light */
550 FILE *fin
551 )
552 {
553 FUNARGS fa;
554
555 if (readfargs(&fa, fin) != 1)
556 return(-1);
557 if ((fa.nsargs != 0) | (fa.nfargs != 4))
558 return(-1);
559 printf("0\n0\n4");
560 printf(" %18.12g %18.12g %18.12g",
561 fa.farg[0], fa.farg[1], fa.farg[2]);
562 printf(" %18.12g\n", fa.farg[3] * tot.sca);
563 freefargs(&fa);
564 return(0);
565 }
566
567
568 int
569 m_spot( /* transform arguments for spotlight */
570 FILE *fin
571 )
572 {
573 FVECT v;
574 FUNARGS fa;
575
576 if (readfargs(&fa, fin) != 1)
577 return(-1);
578 if ((fa.nsargs != 0) | ( fa.nfargs != 7))
579 return(-1);
580 printf("0\n0\n7");
581 printf(" %18.12g %18.12g %18.12g %18.12g\n",
582 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
583 multv3(v, fa.farg+4, tot.xfm);
584 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
585 freefargs(&fa);
586 return(0);
587 }
588
589
590 int
591 m_mist( /* transform arguments for mist */
592 FILE *fin
593 )
594 {
595 FUNARGS fa;
596 int i;
597
598 if (readfargs(&fa, fin) != 1)
599 return(-1);
600 if (fa.nfargs > 7)
601 return(-1);
602 printf("%d", fa.nsargs);
603 if (idprefix == NULL)
604 for (i = 0; i < fa.nsargs; i++)
605 printf(" %s", fa.sarg[i]);
606 else
607 for (i = 0; i < fa.nsargs; i++) {
608 char sname[256], *sp;
609 char *cp1, *cp2 = sname;
610 /* add idprefix */
611 for (sp = fa.sarg[i]; *sp; sp = cp1) {
612 for (cp1 = idprefix; *cp1; )
613 *cp2++ = *cp1++;
614 *cp2++ = '.';
615 for (cp1 = sp; *cp1 &&
616 (*cp2++ = *cp1++) != '>'; )
617 ;
618 }
619 *cp2 = '\0';
620 printf(" %s", sname);
621 }
622 printf("\n0\n%d", fa.nfargs);
623 if (fa.nfargs > 2)
624 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
625 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
626 for (i = 3; i < fa.nfargs; i++)
627 printf(" %12.6g", fa.farg[i]);
628 printf("\n");
629 freefargs(&fa);
630 return(0);
631 }
632
633
634 int
635 m_dielectric( /* transform arguments for dielectric */
636 FILE *fin
637 )
638 {
639 FUNARGS fa;
640
641 if (readfargs(&fa, fin) != 1)
642 return(-1);
643 if (fa.nsargs != 0 || fa.nfargs != 5)
644 return(-1);
645 printf("0\n0\n5");
646 printf(" %12.6g %12.6g %12.6g",
647 pow(fa.farg[0], 1.0/tot.sca),
648 pow(fa.farg[1], 1.0/tot.sca),
649 pow(fa.farg[2], 1.0/tot.sca));
650 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
651 freefargs(&fa);
652 return(0);
653 }
654
655
656 int
657 m_interface( /* transform arguments for interface */
658 FILE *fin
659 )
660 {
661 FUNARGS fa;
662
663 if (readfargs(&fa, fin) != 1)
664 return(-1);
665 if (fa.nsargs != 0 || fa.nfargs != 8)
666 return(-1);
667 printf("0\n0\n8\n");
668 printf("%12.6g %12.6g %12.6g",
669 pow(fa.farg[0], 1.0/tot.sca),
670 pow(fa.farg[1], 1.0/tot.sca),
671 pow(fa.farg[2], 1.0/tot.sca));
672 printf(" %12.6g\n", fa.farg[3]);
673 printf("%12.6g %12.6g %12.6g",
674 pow(fa.farg[4], 1.0/tot.sca),
675 pow(fa.farg[5], 1.0/tot.sca),
676 pow(fa.farg[6], 1.0/tot.sca));
677 printf(" %12.6g\n", fa.farg[7]);
678 freefargs(&fa);
679 return(0);
680 }
681
682
683 int
684 text( /* transform text arguments */
685 FILE *fin
686 )
687 {
688 int i;
689 FVECT v;
690 FUNARGS fa;
691
692 if (readfargs(&fa, fin) != 1)
693 return(-1);
694 if (fa.nfargs < 9)
695 return(-1);
696 /* string arguments */
697 printf("%d", fa.nsargs);
698 for (i = 0; i < fa.nsargs; i++) {
699 fputc(' ', stdout);
700 fputword(fa.sarg[i], stdout);
701 }
702 printf("\n0\n%d\n", fa.nfargs);
703 /* anchor point */
704 multp3(v, fa.farg, tot.xfm);
705 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
706 /* right vector */
707 multv3(v, fa.farg+3, tot.xfm);
708 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
709 /* down vector */
710 multv3(v, fa.farg+6, tot.xfm);
711 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
712 /* remaining arguments */
713 for (i = 9; i < fa.nfargs; i++) {
714 if (i%3 == 0)
715 putchar('\n');
716 printf(" %18.12g", fa.farg[i]);
717 }
718 putchar('\n');
719 freefargs(&fa);
720 return(0);
721 }
722
723
724 int
725 o_source( /* transform source arguments */
726 FILE *fin
727 )
728 {
729 FVECT dv;
730 FUNARGS fa;
731
732 if (readfargs(&fa, fin) != 1)
733 return(-1);
734 if (fa.nsargs != 0 || fa.nfargs != 4)
735 return(-1);
736 /* transform direction vector */
737 multv3(dv, fa.farg, tot.xfm);
738 /* output */
739 printf("0\n0\n4");
740 printf(" %18.12g %18.12g %18.12g %18.12g\n",
741 dv[0], dv[1], dv[2], fa.farg[3]);
742 freefargs(&fa);
743 return(0);
744 }
745
746
747 int
748 o_sphere( /* transform sphere arguments */
749 FILE *fin
750 )
751 {
752 FVECT cent;
753 double rad;
754 FUNARGS fa;
755
756 if (readfargs(&fa, fin) != 1)
757 return(-1);
758 if (fa.nsargs != 0 || fa.nfargs != 4)
759 return(-1);
760
761 multp3(cent, fa.farg, tot.xfm); /* transform center */
762
763 rad = fa.farg[3] * tot.sca; /* scale radius */
764
765 printf("0\n0\n4");
766 printf(" %18.12g %18.12g %18.12g %18.12g\n",
767 cent[0], cent[1], cent[2], rad);
768 freefargs(&fa);
769 return(0);
770 }
771
772
773 int
774 o_face( /* transform face arguments */
775 FILE *fin
776 )
777 {
778 FVECT p;
779 int i;
780 FUNARGS fa;
781
782 if (readfargs(&fa, fin) != 1)
783 return(-1);
784 if (fa.nsargs != 0 || fa.nfargs % 3)
785 return(-1);
786
787 printf("0\n0\n%d\n", fa.nfargs);
788
789 for (i = 0; i < fa.nfargs; i += 3) {
790 if (reverse)
791 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
792 else
793 multp3(p, fa.farg+i, tot.xfm);
794 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
795 }
796 freefargs(&fa);
797 return(0);
798 }
799
800
801 int
802 o_cone( /* transform cone and cup arguments */
803 FILE *fin
804 )
805 {
806 FVECT p0, p1;
807 double r0, r1;
808 FUNARGS fa;
809
810 if (readfargs(&fa, fin) != 1)
811 return(-1);
812 if (fa.nsargs != 0 || fa.nfargs != 8)
813 return(-1);
814
815 printf("0\n0\n8\n");
816
817 multp3(p0, fa.farg, tot.xfm);
818 multp3(p1, fa.farg+3, tot.xfm);
819 r0 = fa.farg[6] * tot.sca;
820 r1 = fa.farg[7] * tot.sca;
821 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
822 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
823 printf(" %18.12g %18.12g\n", r0, r1);
824
825 freefargs(&fa);
826 return(0);
827 }
828
829
830 int
831 o_cylinder( /* transform cylinder and tube arguments */
832 FILE *fin
833 )
834 {
835 FVECT p0, p1;
836 double rad;
837 FUNARGS fa;
838
839 if (readfargs(&fa, fin) != 1)
840 return(-1);
841 if (fa.nsargs != 0 || fa.nfargs != 7)
842 return(-1);
843
844 printf("0\n0\n7\n");
845
846 multp3(p0, fa.farg, tot.xfm);
847 multp3(p1, fa.farg+3, tot.xfm);
848 rad = fa.farg[6] * tot.sca;
849 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
850 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
851 printf(" %18.12g\n", rad);
852 freefargs(&fa);
853 return(0);
854 }
855
856
857 int
858 o_ring( /* transform ring arguments */
859 FILE *fin
860 )
861 {
862 FVECT p0, pd;
863 double r0, r1;
864 FUNARGS fa;
865
866 if (readfargs(&fa, fin) != 1)
867 return(-1);
868 if (fa.nsargs != 0 || fa.nfargs != 8)
869 return(-1);
870
871 printf("0\n0\n8\n");
872
873 multp3(p0, fa.farg, tot.xfm);
874 multv3(pd, fa.farg+3, tot.xfm);
875 if (invert) {
876 pd[0] = -pd[0];
877 pd[1] = -pd[1];
878 pd[2] = -pd[2];
879 }
880 r0 = fa.farg[6] * tot.sca;
881 r1 = fa.farg[7] * tot.sca;
882 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
883 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
884 printf(" %18.12g %18.12g\n", r0, r1);
885 freefargs(&fa);
886 return(0);
887 }
888
889
890 void
891 initotypes(void) /* initialize ofun[] array */
892 {
893 int i;
894
895 if (ofun[OBJ_SOURCE].funp == o_source)
896 return; /* done already */
897 /* functions get new transform */
898 for (i = 0; i < NUMOTYPE; i++)
899 if (hasfunc(i))
900 ofun[i].funp = addxform;
901 /* special cases */
902 ofun[OBJ_SOURCE].funp = o_source;
903 ofun[OBJ_SPHERE].funp =
904 ofun[OBJ_BUBBLE].funp = o_sphere;
905 ofun[OBJ_FACE].funp = o_face;
906 ofun[OBJ_CONE].funp =
907 ofun[OBJ_CUP].funp = o_cone;
908 ofun[OBJ_CYLINDER].funp =
909 ofun[OBJ_TUBE].funp = o_cylinder;
910 ofun[OBJ_RING].funp = o_ring;
911 ofun[OBJ_INSTANCE].funp =
912 ofun[OBJ_MESH].funp = addxform;
913 ofun[MAT_GLOW].funp = m_glow;
914 ofun[MAT_SPOT].funp = m_spot;
915 ofun[MAT_DIELECTRIC].funp = m_dielectric;
916 ofun[MAT_INTERFACE].funp = m_interface;
917 ofun[MAT_MIST].funp = m_mist;
918 ofun[PAT_CTEXT].funp =
919 ofun[PAT_BTEXT].funp =
920 ofun[MIX_TEXT].funp = text;
921 ofun[MOD_ALIAS].funp = alias;
922 /* surface inverses */
923 tinvers[OBJ_FACE] = OBJ_FACE;
924 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
925 tinvers[OBJ_CONE] = OBJ_CUP;
926 tinvers[OBJ_CUP] = OBJ_CONE;
927 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
928 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
929 tinvers[OBJ_RING] = OBJ_RING;
930 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
931 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
932 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
933 tinvers[OBJ_MESH] = OBJ_MESH; /* ditto */
934 }
935
936
937 #ifdef OLDXFORM
938 void
939 openmain(
940 char *fname
941 )
942 {
943 if (fname == NULL) {
944 strcpy(mainfn, "standard input");
945 mainfp = stdin;
946 return;
947 }
948 if (mainfp != NULL) {
949 if (!strcmp(fname, mainfn)) {
950 rewind(mainfp);
951 return;
952 }
953 fclose(mainfp);
954 }
955 if ((mainfp = fopen(fname, "r")) == NULL) {
956 fprintf(stderr, "%s: cannot open file \"%s\"\n",
957 progname, fname);
958 exit(1);
959 }
960 strcpy(mainfn, fname);
961 }
962 #else
963 void
964 openmain( /* open input, changing directory for file */
965 char *iname
966 )
967 {
968 static char origdir[PATH_MAX];
969 static char curfn[PATH_MAX];
970 static int diffdir;
971 char *fpath;
972
973 if (iname == NULL) { /* standard input */
974 if (mainfp == NULL) {
975 int c;
976 strcpy(mainfn, "standard input");
977 if (nrept <= 1) {
978 mainfp = stdin;
979 return; /* just read once */
980 }
981 /* else copy */
982 if ((mainfp = tmpfile()) == NULL) {
983 fprintf(stderr,
984 "%s: cannot create temporary file\n",
985 progname);
986 exit(1);
987 }
988 while ((c = getc(stdin)) != EOF)
989 putc(c, mainfp);
990 }
991 rewind(mainfp); /* rewind copy */
992 return;
993 }
994 if (mainfp == NULL) { /* first call, initialize */
995 getcwd(origdir, sizeof(origdir));
996 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
997 rewind(mainfp);
998 return;
999 } else { /* else close old stream */
1000 fclose(mainfp);
1001 mainfp = NULL;
1002 if (diffdir) { /* return to our directory */
1003 chdir(origdir);
1004 diffdir = 0;
1005 }
1006 }
1007 strcpy(curfn, iname); /* remember input name */
1008 /* get full path for file */
1009 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
1010 fprintf(stderr, "%s: cannot find file \"%s\"\n",
1011 progname, iname);
1012 exit(1);
1013 }
1014 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
1015 fpath += 2;
1016 /* record path name */
1017 strcpy(mainfn, fpath);
1018 if (expand) { /* change to local directory */
1019 char *cp = fpath + strlen(fpath); /* get dir. */
1020 while (cp > fpath) {
1021 cp--;
1022 if (ISDIRSEP(*cp)) {
1023 if (cp == fpath)
1024 cp++; /* root special case */
1025 break;
1026 }
1027 }
1028 *cp = '\0';
1029 if (fpath[0]) { /* change to new directory? */
1030 if (chdir(fpath) < 0) {
1031 fprintf(stderr,
1032 "%s: cannot change directory to \"%s\"\n",
1033 progname, fpath);
1034 exit(1);
1035 }
1036 diffdir++;
1037 }
1038 /* get final path component */
1039 for (fpath = iname+strlen(iname);
1040 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
1041 ;
1042 }
1043 /* finally, open the file */
1044 if ((mainfp = fopen(fpath, "r")) == NULL) {
1045 fprintf(stderr, "%s: cannot open file \"%s\"\n",
1046 progname, mainfn);
1047 exit(1);
1048 }
1049 }
1050 #endif
