root/radiance/ray/src/gen/xform.c
Revision: 2.32
Committed: Fri Aug 29 21:44:17 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.31: +3 -2 lines
2 static const char RCSid[] = "$Id: xform.c,v 2.31 2003/07/27 22:12:02 schorsch Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13
14 #include "standard.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "object.h"
18 #include "otypes.h"
19
20 int xac; /* global xform argument count */
21 char **xav; /* global xform argument pointer */
22 int xfa; /* start of xf arguments */
23
24 XF tot; /* total transformation */
25 int reverse; /* boolean true if scene mirrored */
26
27 int invert; /* boolean true to invert surfaces */
28
29 int expand; /* boolean true to expand commands */
30
31 char *newmod; /* new modifier for surfaces */
32
33 char *idprefix; /* prefix for object identifiers */
34
35 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
36
37 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
38
39 int nrept = 1; /* number of array repetitions */
40
41 int stdinused = 0; /* stdin has been used by -f option? */
42
43 char mainfn[PATH_MAX]; /* main file name */
44 FILE *mainfp = NULL; /* main file pointer */
45
46 #define progname (xav[0])
47
48
49 main(argc, argv) /* get transform options and transform file */
50 int argc;
51 char *argv[];
52 {
53 int mal_prefix = 0;
54 char *fname;
55 int a;
56 /* check for argument list file */
57 for (a = 1; a < argc; a++)
58 if (!strcmp(argv[a], "-f"))
59 return(doargf(argc, argv, a));
60 /* check for regular array */
61 for (a = 1; a < argc; a++)
62 if (!strcmp(argv[a], "-a"))
63 return(doarray(argc, argv, a));
64
65 initotypes(); /* initialize */
66 invert = 0;
67 expand = 1;
68 newmod = NULL;
69 idprefix = NULL;
70
71 for (a = 1; a < argc; a++) {
72 if (argv[a][0] == '-')
73 switch (argv[a][1]) {
74 case 'm':
75 if (argv[a][2] | (a+1 >= argc))
76 break;
77 a++;
78 if (newmod == NULL)
79 newmod = argv[a];
80 continue;
81 case 'n':
82 if (argv[a][2] | (a+1 >= argc))
83 break;
84 a++;
85 if (idprefix == NULL)
86 idprefix = argv[a];
87 else {
88 register char *newp;
89 newp = (char *)malloc(strlen(idprefix)+
90 strlen(argv[a])+2);
91 if (newp == NULL)
92 exit(2);
93 sprintf(newp, "%s.%s",
94 idprefix, argv[a]);
95 if (mal_prefix++)
96 free((void *)idprefix);
97 idprefix = newp;
98 }
99 continue;
100 case 'c':
101 if (argv[a][2])
102 break;
103 expand = 0;
104 continue;
105 case 'e':
106 if (argv[a][2])
107 break;
108 expand = 1;
109 continue;
110 case 'I':
111 if (argv[a][2])
112 break;
113 invert = !invert;
114 continue;
115 }
116 break;
117 }
118
119 xav = argv;
120 xfa = a;
121
122 a += xf(&tot, argc-a, argv+a);
123
124 if ( (reverse = tot.sca < 0.0) )
125 tot.sca = -tot.sca;
126 if (invert)
127 reverse = !reverse;
128
129 if (a < argc && argv[a][0] == '-') {
130 fprintf(stderr, "%s: command line error at '%s'\n",
131 argv[0], argv[a]);
132 exit(1);
133 }
134
135 xac = a;
136 /* simple header */
137 putchar('#');
138 for (a = 0; a < xac; a++)
139 printf(" %s", xav[a]);
140 putchar('\n');
141 /* transform input */
142 if (xac == argc) {
143 if (stdinused) {
144 fprintf(stderr, "%s: cannot use stdin more than once\n",
145 argv[0]);
146 exit(1);
147 }
148 openmain(NULL);
149 xform(mainfn, mainfp);
150 } else
151 for (a = xac; a < argc; a++) {
152 openmain(argv[a]);
153 xform(mainfn, mainfp);
154 }
155
156 if (mal_prefix)
157 free((void *)idprefix);
158 return(0);
159 }
160
161
162 doargf(ac, av, fi) /* take argument list from file */
163 char **av;
164 int ac, fi;
165 {
166 int inquote;
167 char *newav[256], **avp;
168 char argbuf[1024];
169 char newid[128];
170 char *oldid;
171 register char *cp;
172 FILE *argfp;
173 int n, i, k, newac, err;
174
175 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
176 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
177 exit(1);
178 }
179 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
180 if (stdinused++) {
181 fprintf(stderr,
182 "%s: cannot use stdin more than once\n",
183 av[0]);
184 exit(1);
185 }
186 argfp = stdin;
187 n = 100; /* we just don't know! */
188 } else {
189 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
190 fprintf(stderr,
191 "%s: cannot open argument file \"%s\"\n",
192 av[0], av[fi+1]);
193 exit(1);
194 }
195 n = 0; /* count number of lines in file */
196 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
197 n += argbuf[0] && argbuf[0] != '#';
198 if (!n) {
199 fprintf(stderr, "%s: empty argument file \"%s\"\n",
200 av[0], av[fi+1]);
201 exit(1);
202 }
203 nrept *= n;
204 rewind(argfp);
205 }
206 err = 0; k = 0; /* read each arg list and call main */
207 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
208 if (!argbuf[0] || argbuf[0] == '#')
209 continue;
210 avp = newav+2;
211 avp[0] = av[0];
212 for (i = 1; i < fi; i++)
213 avp[i] = av[i];
214 newac = i;
215 cp = argbuf; /* parse new words */
216 if (*cp == '!') cp++;
217 if (!strncmp(cp, "xform ", 6)) cp += 6;
218 inquote = 0;
219 for ( ; ; ) {
220 skipspaces:
221 while (isspace(*cp)) /* nullify spaces */
222 *cp++ = '\0';
223 if ((*cp == '"') | (*cp == '\''))
224 inquote = *cp++;
225 if (!*cp) /* all done? */
226 break;
227 if (cp[0] == '\\' && cp[1])
228 if (*++cp == '\n')
229 goto skipspaces;
230 avp[newac++] = cp; /* add argument to list */
231 if (inquote) {
232 while (*++cp)
233 if (*cp == inquote) {
234 *cp++ = '\0';
235 break;
236 }
237 } else {
238 while (*++cp && !isspace(*cp))
239 ;
240 }
241 }
242 for (i = fi+2; i < ac; i++)
243 avp[newac++] = av[i];
244 avp[newac] = NULL;
245 oldid = NULL;
246 for (i = 2; i < newac; i++)
247 if (!strcmp(avp[i-1], "-n")) {
248 oldid = avp[i];
249 avp[i] = newid;
250 break;
251 }
252 if (oldid == NULL) {
253 newav[0] = av[0];
254 newav[1] = "-n";
255 newav[2] = newid;
256 avp = newav;
257 newac += 2;
258 }
259 if (oldid == NULL)
260 sprintf(newid, "i%d", k);
261 else
262 sprintf(newid, "%s.%d", oldid, k);
263 err |= main(newac, avp);
264 k++;
265 }
266 fclose(argfp);
267 return(err);
268 }
269
270
271 doarray(ac, av, ai) /* make array */
272 char **av;
273 int ac, ai;
274 {
275 char *newav[256], **avp;
276 char newid[128], repts[32];
277 char *oldid = NULL;
278 int n, i, err;
279
280 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
281 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
282 exit(1);
283 }
284 nrept *= n;
285 avp = newav+2;
286 avp[0] = av[0];
287 for (i = 1; i < ac; i++)
288 if (!strcmp(av[i-1], "-n")) {
289 oldid = av[i];
290 avp[i] = newid;
291 } else
292 avp[i] = av[i];
293 avp[ai] = "-i";
294 avp[ai+1] = repts;
295 avp[i] = NULL;
296 if (oldid == NULL) {
297 newav[0] = av[0];
298 newav[1] = "-n";
299 newav[2] = newid;
300 avp = newav;
301 ac += 2;
302 }
303 err = 0;
304 for (i = 0; i < n; i++) {
305 if (oldid == NULL)
306 sprintf(newid, "a%d", i);
307 else
308 sprintf(newid, "%s.%d", oldid, i);
309 sprintf(repts, "%d", i);
310 err |= main(ac, avp);
311 }
312 return(err);
313 }
314
315
316 xform(name, fin) /* transform stream by tot.xfm */
317 char *name;
318 register FILE *fin;
319 {
320 int nobjs = 0;
321 register int c;
322
323 while ((c = getc(fin)) != EOF) {
324 if (isspace(c)) /* blank */
325 continue;
326 if (c == '#') { /* comment */
327 putchar(c);
328 do {
329 if ((c = getc(fin)) == EOF)
330 return;
331 putchar(c);
332 } while (c != '\n');
333 } else if (c == '!') { /* command */
334 ungetc(c, fin);
335 xfcomm(name, fin);
336 nobjs++;
337 } else { /* object */
338 ungetc(c, fin);
339 xfobject(name, fin);
340 nobjs++;
341 }
342 }
343 if (nobjs == 0)
344 fprintf(stderr, "%s: (%s): warning - empty file\n",
345 progname, name);
346 }
347
348
349 xfcomm(fname, fin) /* transform a command */
350 char *fname;
351 FILE *fin;
352 {
353 FILE *pin;
354 char buf[512];
355 int i;
356
357 fgetline(buf, sizeof(buf), fin);
358 if (expand) {
359 if ((pin = popen(buf+1, "r")) == NULL) {
360 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
361 progname, fname, buf);
362 exit(1);
363 }
364 xform(buf, pin);
365 pclose(pin);
366 } else {
367 printf("\n%s", buf);
368 if (xac > 1) {
369 printf(" | %s -e", xav[0]); /* expand next time */
370 for (i = 1; i < xac; i++)
371 if (i >= xfa || strcmp(xav[i], "-c"))
372 printf(" %s", xav[i]);
373 }
374 putchar('\n');
375 }
376 }
377
378
379 xfobject(fname, fin) /* transform an object */
380 char *fname;
381 FILE *fin;
382 {
383 char typ[16], nam[MAXSTR];
384 int fn;
385 /* modifier and type */
386 strcpy(typ, "EOF");
387 fgetword(nam, sizeof(nam), fin);
388 fgetword(typ, sizeof(typ), fin);
389 if ((fn = otype(typ)) < 0) {
390 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
391 progname, fname, typ);
392 exit(1);
393 }
394 if (ismodifier(fn))
395 printf("\n%s %s ", nam, typ);
396 else
397 printf("\n%s %s ", newmod != NULL ? newmod : nam,
398 invert ? ofun[tinvers[fn]].funame : typ);
399 /* object name */
400 fgetword(nam, sizeof(nam), fin);
401 if (idprefix == NULL || ismodifier(fn))
402 printf("%s\n", nam);
403 else
404 printf("%s.%s\n", idprefix, nam);
405 /* transform arguments */
406 if ((*ofun[fn].funp)(fin) < 0) {
407 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
408 progname, fname, ofun[fn].funame, nam);
409 exit(1);
410 }
411 }
412
413
414 o_default(fin) /* pass on arguments unchanged */
415 FILE *fin;
416 {
417 register int i;
418 FUNARGS fa;
419
420 if (readfargs(&fa, fin) != 1)
421 return(-1);
422 /* string arguments */
423 printf("%d", fa.nsargs);
424 for (i = 0; i < fa.nsargs; i++) {
425 fputc(' ', stdout);
426 fputword(fa.sarg[i], stdout);
427 }
428 printf("\n");
429 #ifdef IARGS
430 /* integer arguments */
431 printf("%d", fa.niargs);
432 for (i = 0; i < fa.niargs; i++)
433 printf(" %d", fa.iarg[i]);
434 printf("\n");
435 #else
436 printf("0\n");
437 #endif
438 /* float arguments */
439 printf("%d", fa.nfargs);
440 for (i = 0; i < fa.nfargs; i++)
441 printf(" %18.12g", fa.farg[i]);
442 printf("\n");
443 freefargs(&fa);
444 return(0);
445 }
446
447
448 addxform(fin) /* add xf arguments to strings */
449 FILE *fin;
450 {
451 register int i;
452 int resetarr = 0;
453 FUNARGS fa;
454
455 if (readfargs(&fa, fin) != 1)
456 return(-1);
457 /* string arguments */
458 if (xac > xfa && strcmp(xav[xfa], "-i"))
459 resetarr = 2;
460 printf("%d", fa.nsargs + resetarr + xac-xfa);
461 for (i = 0; i < fa.nsargs; i++) {
462 fputc(' ', stdout);
463 fputword(fa.sarg[i], stdout);
464 }
465 if (resetarr)
466 printf(" -i 1");
467 for (i = xfa; i < xac; i++) /* add xf arguments */
468 printf(" %s", xav[i]);
469 printf("\n");
470 #ifdef IARGS
471 /* integer arguments */
472 printf("%d", fa.niargs);
473 for (i = 0; i < fa.niargs; i++)
474 printf(" %d", fa.iarg[i]);
475 printf("\n");
476 #else
477 printf("0\n");
478 #endif
479 /* float arguments */
480 printf("%d", fa.nfargs);
481 for (i = 0; i < fa.nfargs; i++)
482 printf(" %18.12g", fa.farg[i]);
483 printf("\n");
484 freefargs(&fa);
485 return(0);
486 }
487
488
489 alias(fin) /* transfer alias */
490 FILE *fin;
491 {
492 char aliasnm[MAXSTR];
493
494 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
495 return(-1);
496 printf("\t%s\n", aliasnm);
497 return(0);
498 }
499
500
501 m_glow(fin) /* transform arguments for proximity light */
502 FILE *fin;
503 {
504 FUNARGS fa;
505
506 if (readfargs(&fa, fin) != 1)
507 return(-1);
508 if (fa.nsargs != 0 || fa.nfargs != 4)
509 return(-1);
510 printf("0\n0\n4");
511 printf(" %18.12g %18.12g %18.12g",
512 fa.farg[0], fa.farg[1], fa.farg[2]);
513 printf(" %18.12g\n", fa.farg[3] * tot.sca);
514 freefargs(&fa);
515 return(0);
516 }
517
518
519 m_spot(fin) /* transform arguments for spotlight */
520 FILE *fin;
521 {
522 FVECT v;
523 FUNARGS fa;
524
525 if (readfargs(&fa, fin) != 1)
526 return(-1);
527 if (fa.nsargs != 0 || fa.nfargs != 7)
528 return(-1);
529 printf("0\n0\n7");
530 printf(" %18.12g %18.12g %18.12g %18.12g\n",
531 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
532 multv3(v, fa.farg+4, tot.xfm);
533 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
534 freefargs(&fa);
535 return(0);
536 }
537
538
539 m_mist(fin) /* transform arguments for mist */
540 FILE *fin;
541 {
542 FUNARGS fa;
543 int i;
544
545 if (readfargs(&fa, fin) != 1)
546 return(-1);
547 if (fa.nfargs > 7)
548 return(-1);
549 printf("%d", fa.nsargs);
550 if (idprefix == NULL)
551 for (i = 0; i < fa.nsargs; i++)
552 printf(" %s", fa.sarg[i]);
553 else
554 for (i = 0; i < fa.nsargs; i++) {
555 char sname[256], *sp;
556 register char *cp1, *cp2 = sname;
557 /* add idprefix */
558 for (sp = fa.sarg[i]; *sp; sp = cp1) {
559 for (cp1 = idprefix; *cp1; )
560 *cp2++ = *cp1++;
561 *cp2++ = '.';
562 for (cp1 = sp; *cp1 &&
563 (*cp2++ = *cp1++) != '>'; )
564 ;
565 }
566 *cp2 = '\0';
567 printf(" %s", sname);
568 }
569 printf("\n0\n%d", fa.nfargs);
570 if (fa.nfargs > 2)
571 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
572 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
573 for (i = 3; i < fa.nfargs; i++)
574 printf(" %12.6g", fa.farg[i]);
575 printf("\n");
576 freefargs(&fa);
577 return(0);
578 }
579
580
581 m_dielectric(fin) /* transform arguments for dielectric */
582 FILE *fin;
583 {
584 FUNARGS fa;
585
586 if (readfargs(&fa, fin) != 1)
587 return(-1);
588 if (fa.nsargs != 0 || fa.nfargs != 5)
589 return(-1);
590 printf("0\n0\n5");
591 printf(" %12.6g %12.6g %12.6g",
592 pow(fa.farg[0], 1.0/tot.sca),
593 pow(fa.farg[1], 1.0/tot.sca),
594 pow(fa.farg[2], 1.0/tot.sca));
595 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
596 freefargs(&fa);
597 return(0);
598 }
599
600
601 m_interface(fin) /* transform arguments for interface */
602 FILE *fin;
603 {
604 FUNARGS fa;
605
606 if (readfargs(&fa, fin) != 1)
607 return(-1);
608 if (fa.nsargs != 0 || fa.nfargs != 8)
609 return(-1);
610 printf("0\n0\n8\n");
611 printf("%12.6g %12.6g %12.6g",
612 pow(fa.farg[0], 1.0/tot.sca),
613 pow(fa.farg[1], 1.0/tot.sca),
614 pow(fa.farg[2], 1.0/tot.sca));
615 printf(" %12.6g\n", fa.farg[3]);
616 printf("%12.6g %12.6g %12.6g",
617 pow(fa.farg[4], 1.0/tot.sca),
618 pow(fa.farg[5], 1.0/tot.sca),
619 pow(fa.farg[6], 1.0/tot.sca));
620 printf(" %12.6g\n", fa.farg[7]);
621 freefargs(&fa);
622 return(0);
623 }
624
625
626 text(fin) /* transform text arguments */
627 FILE *fin;
628 {
629 int i;
630 FVECT v;
631 FUNARGS fa;
632
633 if (readfargs(&fa, fin) != 1)
634 return(-1);
635 if (fa.nfargs < 9)
636 return(-1);
637 /* string arguments */
638 printf("%d", fa.nsargs);
639 for (i = 0; i < fa.nsargs; i++) {
640 fputc(' ', stdout);
641 fputword(fa.sarg[i], stdout);
642 }
643 printf("\n0\n%d\n", fa.nfargs);
644 /* anchor point */
645 multp3(v, fa.farg, tot.xfm);
646 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
647 /* right vector */
648 multv3(v, fa.farg+3, tot.xfm);
649 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
650 /* down vector */
651 multv3(v, fa.farg+6, tot.xfm);
652 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
653 /* remaining arguments */
654 for (i = 9; i < fa.nfargs; i++) {
655 if (i%3 == 0)
656 putchar('\n');
657 printf(" %18.12g", fa.farg[i]);
658 }
659 putchar('\n');
660 freefargs(&fa);
661 return(0);
662 }
663
664
665 o_source(fin) /* transform source arguments */
666 FILE *fin;
667 {
668 FVECT dv;
669 FUNARGS fa;
670
671 if (readfargs(&fa, fin) != 1)
672 return(-1);
673 if (fa.nsargs != 0 || fa.nfargs != 4)
674 return(-1);
675 /* transform direction vector */
676 multv3(dv, fa.farg, tot.xfm);
677 /* output */
678 printf("0\n0\n4");
679 printf(" %18.12g %18.12g %18.12g %18.12g\n",
680 dv[0], dv[1], dv[2], fa.farg[3]);
681 freefargs(&fa);
682 return(0);
683 }
684
685
686 o_sphere(fin) /* transform sphere arguments */
687 FILE *fin;
688 {
689 FVECT cent;
690 double rad;
691 FUNARGS fa;
692
693 if (readfargs(&fa, fin) != 1)
694 return(-1);
695 if (fa.nsargs != 0 || fa.nfargs != 4)
696 return(-1);
697
698 multp3(cent, fa.farg, tot.xfm); /* transform center */
699
700 rad = fa.farg[3] * tot.sca; /* scale radius */
701
702 printf("0\n0\n4");
703 printf(" %18.12g %18.12g %18.12g %18.12g\n",
704 cent[0], cent[1], cent[2], rad);
705 freefargs(&fa);
706 return(0);
707 }
708
709
710 o_face(fin) /* transform face arguments */
711 FILE *fin;
712 {
713 FVECT p;
714 register int i;
715 FUNARGS fa;
716
717 if (readfargs(&fa, fin) != 1)
718 return(-1);
719 if (fa.nsargs != 0 || fa.nfargs % 3)
720 return(-1);
721
722 printf("0\n0\n%d\n", fa.nfargs);
723
724 for (i = 0; i < fa.nfargs; i += 3) {
725 if (reverse)
726 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
727 else
728 multp3(p, fa.farg+i, tot.xfm);
729 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
730 }
731 freefargs(&fa);
732 return(0);
733 }
734
735
736 o_cone(fin) /* transform cone and cup arguments */
737 FILE *fin;
738 {
739 FVECT p0, p1;
740 double r0, r1;
741 FUNARGS fa;
742
743 if (readfargs(&fa, fin) != 1)
744 return(-1);
745 if (fa.nsargs != 0 || fa.nfargs != 8)
746 return(-1);
747
748 printf("0\n0\n8\n");
749
750 multp3(p0, fa.farg, tot.xfm);
751 multp3(p1, fa.farg+3, tot.xfm);
752 r0 = fa.farg[6] * tot.sca;
753 r1 = fa.farg[7] * tot.sca;
754 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
755 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
756 printf(" %18.12g %18.12g\n", r0, r1);
757
758 freefargs(&fa);
759 return(0);
760 }
761
762
763 o_cylinder(fin) /* transform cylinder and tube arguments */
764 FILE *fin;
765 {
766 FVECT p0, p1;
767 double rad;
768 FUNARGS fa;
769
770 if (readfargs(&fa, fin) != 1)
771 return(-1);
772 if (fa.nsargs != 0 || fa.nfargs != 7)
773 return(-1);
774
775 printf("0\n0\n7\n");
776
777 multp3(p0, fa.farg, tot.xfm);
778 multp3(p1, fa.farg+3, tot.xfm);
779 rad = fa.farg[6] * tot.sca;
780 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
781 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
782 printf(" %18.12g\n", rad);
783 freefargs(&fa);
784 return(0);
785 }
786
787
788 o_ring(fin) /* transform ring arguments */
789 FILE *fin;
790 {
791 FVECT p0, pd;
792 double r0, r1;
793 FUNARGS fa;
794
795 if (readfargs(&fa, fin) != 1)
796 return(-1);
797 if (fa.nsargs != 0 || fa.nfargs != 8)
798 return(-1);
799
800 printf("0\n0\n8\n");
801
802 multp3(p0, fa.farg, tot.xfm);
803 multv3(pd, fa.farg+3, tot.xfm);
804 if (invert) {
805 pd[0] = -pd[0];
806 pd[1] = -pd[1];
807 pd[2] = -pd[2];
808 }
809 r0 = fa.farg[6] * tot.sca;
810 r1 = fa.farg[7] * tot.sca;
811 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
812 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
813 printf(" %18.12g %18.12g\n", r0, r1);
814 freefargs(&fa);
815 return(0);
816 }
817
818
819 initotypes() /* initialize ofun[] array */
820 {
821 register int i;
822
823 if (ofun[OBJ_SOURCE].funp == o_source)
824 return; /* done already */
825 /* functions get new transform */
826 for (i = 0; i < NUMOTYPE; i++)
827 if (hasfunc(i))
828 ofun[i].funp = addxform;
829 /* special cases */
830 ofun[OBJ_SOURCE].funp = o_source;
831 ofun[OBJ_SPHERE].funp =
832 ofun[OBJ_BUBBLE].funp = o_sphere;
833 ofun[OBJ_FACE].funp = o_face;
834 ofun[OBJ_CONE].funp =
835 ofun[OBJ_CUP].funp = o_cone;
836 ofun[OBJ_CYLINDER].funp =
837 ofun[OBJ_TUBE].funp = o_cylinder;
838 ofun[OBJ_RING].funp = o_ring;
839 ofun[OBJ_INSTANCE].funp =
840 ofun[OBJ_MESH].funp = addxform;
841 ofun[MAT_GLOW].funp = m_glow;
842 ofun[MAT_SPOT].funp = m_spot;
843 ofun[MAT_DIELECTRIC].funp = m_dielectric;
844 ofun[MAT_INTERFACE].funp = m_interface;
845 ofun[MAT_MIST].funp = m_mist;
846 ofun[PAT_CTEXT].funp =
847 ofun[PAT_BTEXT].funp =
848 ofun[MIX_TEXT].funp = text;
849 ofun[MOD_ALIAS].funp = alias;
850 /* surface inverses */
851 tinvers[OBJ_FACE] = OBJ_FACE;
852 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
853 tinvers[OBJ_CONE] = OBJ_CUP;
854 tinvers[OBJ_CUP] = OBJ_CONE;
855 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
856 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
857 tinvers[OBJ_RING] = OBJ_RING;
858 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
859 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
860 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
861 }
862
863
864 #ifdef OLDXFORM
865 openmain(fname)
866 char *fname;
867 {
868 if (fname == NULL) {
869 strcpy(mainfn, "standard input");
870 mainfp = stdin;
871 return;
872 }
873 if (mainfp != NULL) {
874 if (!strcmp(fname, mainfn)) {
875 rewind(mainfp);
876 return;
877 }
878 fclose(mainfp);
879 }
880 if ((mainfp = fopen(fname, "r")) == NULL) {
881 fprintf(stderr, "%s: cannot open file \"%s\"\n",
882 progname, fname);
883 exit(1);
884 }
885 strcpy(mainfn, fname);
886 }
887 #else
888 openmain(iname) /* open input, changing directory for file */
889 char *iname;
890 {
891 static char origdir[PATH_MAX];
892 static char curfn[PATH_MAX];
893 static int diffdir;
894 register char *fpath;
895
896 if (iname == NULL) { /* standard input */
897 if (mainfp == NULL) {
898 register int c;
899 strcpy(mainfn, "standard input");
900 if (nrept <= 1) {
901 mainfp = stdin;
902 return; /* just read once */
903 }
904 /* else copy */
905 if ((mainfp = tmpfile()) == NULL) {
906 fprintf(stderr,
907 "%s: cannot create temporary file\n",
908 progname);
909 exit(1);
910 }
911 while ((c = getc(stdin)) != EOF)
912 putc(c, mainfp);
913 }
914 rewind(mainfp); /* rewind copy */
915 return;
916 }
917 if (mainfp == NULL) { /* first call, initialize */
918 getcwd(origdir, sizeof(origdir));
919 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
920 rewind(mainfp);
921 return;
922 } else { /* else close old stream */
923 fclose(mainfp);
924 mainfp = NULL;
925 if (diffdir) { /* return to our directory */
926 chdir(origdir);
927 diffdir = 0;
928 }
929 }
930 strcpy(curfn, iname); /* remember input name */
931 /* get full path for file */
932 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
933 fprintf(stderr, "%s: cannot find file \"%s\"\n",
934 progname, iname);
935 exit(1);
936 }
937 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
938 fpath += 2;
939 /* record path name */
940 strcpy(mainfn, fpath);
941 if (expand) { /* change to local directory */
942 register char *cp = fpath + strlen(fpath); /* get dir. */
943 while (cp > fpath) {
944 cp--;
945 if (ISDIRSEP(*cp)) {
946 if (cp == fpath)
947 cp++; /* root special case */
948 break;
949 }
950 }
951 *cp = '\0';
952 if (fpath[0]) { /* change to new directory? */
953 if (chdir(fpath) < 0) {
954 fprintf(stderr,
955 "%s: cannot change directory to \"%s\"\n",
956 progname, fpath);
957 exit(1);
958 }
959 diffdir++;
960 }
961 /* get final path component */
962 for (fpath = iname+strlen(iname);
963 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
964 ;
965 }
966 /* finally, open the file */
967 if ((mainfp = fopen(fpath, "r")) == NULL) {
968 fprintf(stderr, "%s: cannot open file \"%s\"\n",
969 progname, mainfn);
970 exit(1);
971 }
972 }
973 #endif
