root/radiance/ray/src/gen/xform.c
Revision: 2.13
Committed: Tue Jun 18 21:12:51 1996 UTC (29 years ago) by greg
Changes since 2.12: +44 -30 lines
bug fix in array option and made expansion the default
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xform.c - program to transform object files.
9 * Transformations must preserve aspect ratio.
10 *
11 * 10/19/85
12 * 11/6/86 Finally added error checking!
13 */
14
15 #include "standard.h"
16
17 #include "paths.h"
18
19 #include <ctype.h>
20
21 #include "object.h"
22
23 #include "otypes.h"
24
25 int xac; /* global xform argument count */
26 char **xav; /* global xform argument pointer */
27 int xfa; /* start of xf arguments */
28
29 XF tot; /* total transformation */
30 int reverse; /* boolean true if scene mirrored */
31
32 int invert = 0; /* boolean true to invert surfaces */
33
34 int expand = 1; /* boolean true to expand commands */
35
36 char *newmod = NULL; /* new modifier for surfaces */
37
38 char *idprefix = NULL; /* prefix for object identifiers */
39
40 #define ALIAS NUMOTYPE /* put alias at end of array */
41
42 #define NUMTYPES (NUMOTYPE+1) /* total number of object types */
43
44 FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */
45
46 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
47
48 int nrept = 1; /* number of array repetitions */
49
50 extern char *malloc(), *fgetword();
51
52 char *mainfn[MAXPATH]; /* main file name */
53 FILE *mainfp = NULL; /* main file pointer */
54
55 #define progname (xav[0])
56
57
58 main(argc, argv) /* get transform options and transform file */
59 int argc;
60 char *argv[];
61 {
62 char *fname;
63 int a;
64 /* check for array */
65 for (a = 1; a < argc; a++)
66 if (!strcmp(argv[a], "-a"))
67 return(doarray(argc, argv, a));
68
69 initotypes();
70
71 for (a = 1; a < argc; a++) {
72 if (argv[a][0] == '-')
73 switch (argv[a][1]) {
74 case 'm':
75 if (argv[a][2] || a+1 >= argc)
76 break;
77 newmod = argv[++a];
78 continue;
79 case 'n':
80 if (argv[a][2] || a+1 >= argc)
81 break;
82 idprefix = argv[++a];
83 continue;
84 case 'c':
85 if (argv[a][2])
86 break;
87 expand = 0;
88 continue;
89 case 'e':
90 if (argv[a][2])
91 break;
92 expand = 1;
93 continue;
94 case 'I':
95 if (argv[a][2])
96 break;
97 invert = 1;
98 continue;
99 }
100 break;
101 }
102
103 xav = argv;
104 xfa = a;
105
106 a += xf(&tot, argc-a, argv+a);
107
108 if (reverse = tot.sca < 0.0)
109 tot.sca = -tot.sca;
110 if (invert)
111 reverse = !reverse;
112
113 if (a < argc && argv[a][0] == '-') {
114 fprintf(stderr, "%s: command line error at '%s'\n",
115 argv[0], argv[a]);
116 exit(1);
117 }
118
119 xac = a;
120 /* simple header */
121 putchar('#');
122 for (a = 0; a < xac; a++)
123 printf(" %s", xav[a]);
124 putchar('\n');
125 /* transform input */
126 if (xac == argc) {
127 openmain(NULL);
128 xform(mainfn, mainfp);
129 } else
130 for (a = xac; a < argc; a++) {
131 openmain(argv[a]);
132 xform(mainfn, mainfp);
133 }
134
135 return(0);
136 }
137
138
139 doarray(ac, av, ai) /* make array */
140 char **av;
141 int ac, ai;
142 {
143 char *newav[256], **avp;
144 char newid[128], repts[32];
145 char *oldid = NULL;
146 int n, i, err;
147
148 avp = newav+2;
149 avp[0] = av[0];
150 for (i = 1; i < ac; i++)
151 if (!strcmp(av[i-1], "-n")) {
152 oldid = av[i];
153 avp[i] = newid;
154 } else
155 avp[i] = av[i];
156 avp[ai] = "-i";
157 avp[ai+1] = repts;
158 avp[i] = NULL;
159 if (oldid == NULL) {
160 newav[0] = av[0];
161 newav[1] = "-n";
162 newav[2] = newid;
163 avp = newav;
164 ac += 2;
165 }
166 nrept *= n = atoi(av[ai+1]);
167 err = 0;
168 for (i = 0; i < n; i++) {
169 if (oldid == NULL)
170 sprintf(newid, "a%d", i);
171 else
172 sprintf(newid, "%s.%d", oldid, i);
173 sprintf(repts, "%d", i);
174 err |= main(ac, avp);
175 }
176 return(err);
177 }
178
179
180 xform(name, fin) /* transform stream by tot.xfm */
181 char *name;
182 register FILE *fin;
183 {
184 int nobjs = 0;
185 register int c;
186
187 while ((c = getc(fin)) != EOF) {
188 if (isspace(c)) /* blank */
189 continue;
190 if (c == '#') { /* comment */
191 putchar(c);
192 do {
193 if ((c = getc(fin)) == EOF)
194 return;
195 putchar(c);
196 } while (c != '\n');
197 } else if (c == '!') { /* command */
198 ungetc(c, fin);
199 xfcomm(name, fin);
200 nobjs++;
201 } else { /* object */
202 ungetc(c, fin);
203 xfobject(name, fin);
204 nobjs++;
205 }
206 }
207 if (nobjs == 0)
208 fprintf(stderr, "%s: (%s): warning - empty file\n",
209 progname, name);
210 }
211
212
213 xfcomm(fname, fin) /* transform a command */
214 char *fname;
215 FILE *fin;
216 {
217 extern FILE *popen();
218 extern char *fgetline();
219 FILE *pin;
220 char buf[512];
221 int i;
222
223 fgetline(buf, sizeof(buf), fin);
224 if (expand) {
225 if ((pin = popen(buf+1, "r")) == NULL) {
226 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
227 progname, fname, buf);
228 exit(1);
229 }
230 xform(buf, pin);
231 pclose(pin);
232 } else {
233 printf("\n%s", buf);
234 if (xac > 1) {
235 printf(" | %s", xav[0]);
236 for (i = 1; i < xac; i++)
237 printf(" %s", xav[i]);
238 }
239 putchar('\n');
240 }
241 }
242
243
244 xfobject(fname, fin) /* transform an object */
245 char *fname;
246 FILE *fin;
247 {
248 extern char *strcpy();
249 char typ[16], nam[MAXSTR];
250 int fn;
251 /* modifier and type */
252 strcpy(typ, "EOF");
253 fgetword(nam, sizeof(nam), fin);
254 fgetword(typ, sizeof(typ), fin);
255 if ((fn = otype(typ)) < 0) {
256 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
257 progname, fname, typ);
258 exit(1);
259 }
260 if (ismodifier(fn))
261 printf("\n%s %s ", nam, typ);
262 else
263 printf("\n%s %s ", newmod != NULL ? newmod : nam,
264 invert ? ofun[tinvers[fn]].funame : typ);
265 /* object name */
266 fgetword(nam, sizeof(nam), fin);
267 if (idprefix == NULL || ismodifier(fn))
268 printf("%s\n", nam);
269 else
270 printf("%s.%s\n", idprefix, nam);
271 /* transform arguments */
272 if ((*ofun[fn].funp)(fin) < 0) {
273 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
274 progname, fname, ofun[fn].funame, nam);
275 exit(1);
276 }
277 }
278
279
280 o_default(fin) /* pass on arguments unchanged */
281 FILE *fin;
282 {
283 register int i;
284 FUNARGS fa;
285
286 if (readfargs(&fa, fin) != 1)
287 return(-1);
288 /* string arguments */
289 printf("%d", fa.nsargs);
290 for (i = 0; i < fa.nsargs; i++)
291 printf(" %s", fa.sarg[i]);
292 printf("\n");
293 #ifdef IARGS
294 /* integer arguments */
295 printf("%d", fa.niargs);
296 for (i = 0; i < fa.niargs; i++)
297 printf(" %d", fa.iarg[i]);
298 printf("\n");
299 #else
300 printf("0\n");
301 #endif
302 /* float arguments */
303 printf("%d", fa.nfargs);
304 for (i = 0; i < fa.nfargs; i++)
305 printf(" %18.12g", fa.farg[i]);
306 printf("\n");
307 freefargs(&fa);
308 return(0);
309 }
310
311
312 addxform(fin) /* add xf arguments to strings */
313 FILE *fin;
314 {
315 register int i;
316 int resetarr = 0;
317 FUNARGS fa;
318
319 if (readfargs(&fa, fin) != 1)
320 return(-1);
321 /* string arguments */
322 if (xac > xfa && strcmp(xav[xfa], "-i"))
323 resetarr = 2;
324 printf("%d", fa.nsargs + resetarr + xac-xfa);
325 for (i = 0; i < fa.nsargs; i++)
326 printf(" %s", fa.sarg[i]);
327 if (resetarr)
328 printf(" -i 1");
329 for (i = xfa; i < xac; i++) /* add xf arguments */
330 printf(" %s", xav[i]);
331 printf("\n");
332 #ifdef IARGS
333 /* integer arguments */
334 printf("%d", fa.niargs);
335 for (i = 0; i < fa.niargs; i++)
336 printf(" %d", fa.iarg[i]);
337 printf("\n");
338 #else
339 printf("0\n");
340 #endif
341 /* float arguments */
342 printf("%d", fa.nfargs);
343 for (i = 0; i < fa.nfargs; i++)
344 printf(" %18.12g", fa.farg[i]);
345 printf("\n");
346 freefargs(&fa);
347 return(0);
348 }
349
350
351 int
352 otype(ofname) /* get object function number from its name */
353 register char *ofname;
354 {
355 register int i;
356
357 for (i = 0; i < NUMTYPES; i++)
358 if (!strcmp(ofun[i].funame, ofname))
359 return(i);
360
361 return(-1); /* not found */
362 }
363
364
365 alias(fin) /* transfer alias */
366 FILE *fin;
367 {
368 char aliasnm[MAXSTR];
369
370 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
371 return(-1);
372 printf("\t%s\n", aliasnm);
373 return(0);
374 }
375
376
377 m_glow(fin) /* transform arguments for proximity light */
378 FILE *fin;
379 {
380 FUNARGS fa;
381
382 if (readfargs(&fa, fin) != 1)
383 return(-1);
384 if (fa.nsargs != 0 || fa.nfargs != 4)
385 return(-1);
386 printf("0\n0\n4");
387 printf(" %18.12g %18.12g %18.12g",
388 fa.farg[0], fa.farg[1], fa.farg[2]);
389 printf(" %18.12g\n", fa.farg[3] * tot.sca);
390 freefargs(&fa);
391 return(0);
392 }
393
394
395 m_spot(fin) /* transform arguments for spotlight */
396 FILE *fin;
397 {
398 FVECT v;
399 FUNARGS fa;
400
401 if (readfargs(&fa, fin) != 1)
402 return(-1);
403 if (fa.nsargs != 0 || fa.nfargs != 7)
404 return(-1);
405 printf("0\n0\n7");
406 printf(" %18.12g %18.12g %18.12g %18.12g\n",
407 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
408 multv3(v, fa.farg+4, tot.xfm);
409 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
410 freefargs(&fa);
411 return(0);
412 }
413
414
415 m_mist(fin) /* transform arguments for mist */
416 FILE *fin;
417 {
418 FUNARGS fa;
419 int i;
420
421 if (readfargs(&fa, fin) != 1)
422 return(-1);
423 if (fa.nfargs > 5)
424 return(-1);
425 printf("%d", fa.nsargs);
426 if (idprefix == NULL)
427 for (i = 0; i < fa.nsargs; i++)
428 printf(" %s", fa.sarg[i]);
429 else
430 for (i = 0; i < fa.nsargs; i++) {
431 char sname[256], *sp;
432 register char *cp1, *cp2 = sname;
433 /* add idprefix */
434 for (sp = fa.sarg[i]; *sp; sp = cp1) {
435 for (cp1 = idprefix; *cp1; )
436 *cp2++ = *cp1++;
437 *cp2++ = '.';
438 for (cp1 = sp; *cp1 &&
439 (*cp2++ = *cp1++) != '>'; )
440 ;
441 }
442 *cp2 = '\0';
443 printf(" %s", sname);
444 }
445 printf("\n0\n%d", fa.nfargs);
446 if (fa.nfargs > 2)
447 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
448 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
449 if (fa.nfargs > 3)
450 printf(" %12.6g", fa.farg[3]);
451 if (fa.nfargs > 4)
452 printf(" %12.6g", fa.farg[4]);
453 printf("\n");
454 freefargs(&fa);
455 return(0);
456 }
457
458
459 m_dielectric(fin) /* transform arguments for dielectric */
460 FILE *fin;
461 {
462 FUNARGS fa;
463
464 if (readfargs(&fa, fin) != 1)
465 return(-1);
466 if (fa.nsargs != 0 || fa.nfargs != 5)
467 return(-1);
468 printf("0\n0\n5");
469 printf(" %12.6g %12.6g %12.6g",
470 pow(fa.farg[0], 1.0/tot.sca),
471 pow(fa.farg[1], 1.0/tot.sca),
472 pow(fa.farg[2], 1.0/tot.sca));
473 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
474 freefargs(&fa);
475 return(0);
476 }
477
478
479 m_interface(fin) /* transform arguments for interface */
480 FILE *fin;
481 {
482 FUNARGS fa;
483
484 if (readfargs(&fa, fin) != 1)
485 return(-1);
486 if (fa.nsargs != 0 || fa.nfargs != 8)
487 return(-1);
488 printf("0\n0\n8\n");
489 printf("%12.6g %12.6g %12.6g",
490 pow(fa.farg[0], 1.0/tot.sca),
491 pow(fa.farg[1], 1.0/tot.sca),
492 pow(fa.farg[2], 1.0/tot.sca));
493 printf(" %12.6g\n", fa.farg[3]);
494 printf("%12.6g %12.6g %12.6g",
495 pow(fa.farg[4], 1.0/tot.sca),
496 pow(fa.farg[5], 1.0/tot.sca),
497 pow(fa.farg[6], 1.0/tot.sca));
498 printf(" %12.6g\n", fa.farg[7]);
499 freefargs(&fa);
500 return(0);
501 }
502
503
504 text(fin) /* transform text arguments */
505 FILE *fin;
506 {
507 int i;
508 FVECT v;
509 FUNARGS fa;
510
511 if (readfargs(&fa, fin) != 1)
512 return(-1);
513 if (fa.nfargs < 9)
514 return(-1);
515 /* string arguments */
516 printf("%d", fa.nsargs);
517 for (i = 0; i < fa.nsargs; i++)
518 printf(" %s", fa.sarg[i]);
519 printf("\n0\n%d\n", fa.nfargs);
520 /* anchor point */
521 multp3(v, fa.farg, tot.xfm);
522 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
523 /* right vector */
524 multv3(v, fa.farg+3, tot.xfm);
525 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
526 /* down vector */
527 multv3(v, fa.farg+6, tot.xfm);
528 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
529 /* remaining arguments */
530 for (i = 9; i < fa.nfargs; i++) {
531 if (i%3 == 0)
532 putchar('\n');
533 printf(" %18.12g", fa.farg[i]);
534 }
535 putchar('\n');
536 freefargs(&fa);
537 return(0);
538 }
539
540
541 o_source(fin) /* transform source arguments */
542 FILE *fin;
543 {
544 FVECT dv;
545 FUNARGS fa;
546
547 if (readfargs(&fa, fin) != 1)
548 return(-1);
549 if (fa.nsargs != 0 || fa.nfargs != 4)
550 return(-1);
551 /* transform direction vector */
552 multv3(dv, fa.farg, tot.xfm);
553 /* output */
554 printf("0\n0\n4");
555 printf(" %18.12g %18.12g %18.12g %18.12g\n",
556 dv[0], dv[1], dv[2], fa.farg[3]);
557 freefargs(&fa);
558 return(0);
559 }
560
561
562 o_sphere(fin) /* transform sphere arguments */
563 FILE *fin;
564 {
565 FVECT cent;
566 double rad;
567 FUNARGS fa;
568
569 if (readfargs(&fa, fin) != 1)
570 return(-1);
571 if (fa.nsargs != 0 || fa.nfargs != 4)
572 return(-1);
573
574 multp3(cent, fa.farg, tot.xfm); /* transform center */
575
576 rad = fa.farg[3] * tot.sca; /* scale radius */
577
578 printf("0\n0\n4");
579 printf(" %18.12g %18.12g %18.12g %18.12g\n",
580 cent[0], cent[1], cent[2], rad);
581 freefargs(&fa);
582 return(0);
583 }
584
585
586 o_face(fin) /* transform face arguments */
587 FILE *fin;
588 {
589 FVECT p;
590 register int i;
591 FUNARGS fa;
592
593 if (readfargs(&fa, fin) != 1)
594 return(-1);
595 if (fa.nsargs != 0 || fa.nfargs % 3)
596 return(-1);
597
598 printf("0\n0\n%d\n", fa.nfargs);
599
600 for (i = 0; i < fa.nfargs; i += 3) {
601 if (reverse)
602 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
603 else
604 multp3(p, fa.farg+i, tot.xfm);
605 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
606 }
607 freefargs(&fa);
608 return(0);
609 }
610
611
612 o_cone(fin) /* transform cone and cup arguments */
613 FILE *fin;
614 {
615 FVECT p0, p1;
616 double r0, r1;
617 FUNARGS fa;
618
619 if (readfargs(&fa, fin) != 1)
620 return(-1);
621 if (fa.nsargs != 0 || fa.nfargs != 8)
622 return(-1);
623
624 printf("0\n0\n8\n");
625
626 multp3(p0, fa.farg, tot.xfm);
627 multp3(p1, fa.farg+3, tot.xfm);
628 r0 = fa.farg[6] * tot.sca;
629 r1 = fa.farg[7] * tot.sca;
630 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
631 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
632 printf(" %18.12g %18.12g\n", r0, r1);
633
634 freefargs(&fa);
635 return(0);
636 }
637
638
639 o_cylinder(fin) /* transform cylinder and tube arguments */
640 FILE *fin;
641 {
642 FVECT p0, p1;
643 double rad;
644 FUNARGS fa;
645
646 if (readfargs(&fa, fin) != 1)
647 return(-1);
648 if (fa.nsargs != 0 || fa.nfargs != 7)
649 return(-1);
650
651 printf("0\n0\n7\n");
652
653 multp3(p0, fa.farg, tot.xfm);
654 multp3(p1, fa.farg+3, tot.xfm);
655 rad = fa.farg[6] * tot.sca;
656 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
657 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
658 printf(" %18.12g\n", rad);
659 freefargs(&fa);
660 return(0);
661 }
662
663
664 o_ring(fin) /* transform ring arguments */
665 FILE *fin;
666 {
667 FVECT p0, pd;
668 double r0, r1;
669 FUNARGS fa;
670
671 if (readfargs(&fa, fin) != 1)
672 return(-1);
673 if (fa.nsargs != 0 || fa.nfargs != 8)
674 return(-1);
675
676 printf("0\n0\n8\n");
677
678 multp3(p0, fa.farg, tot.xfm);
679 multv3(pd, fa.farg+3, tot.xfm);
680 if (invert) {
681 pd[0] = -pd[0];
682 pd[1] = -pd[1];
683 pd[2] = -pd[2];
684 }
685 r0 = fa.farg[6] * tot.sca;
686 r1 = fa.farg[7] * tot.sca;
687 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
688 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
689 printf(" %18.12g %18.12g\n", r0, r1);
690 freefargs(&fa);
691 return(0);
692 }
693
694
695 initotypes() /* initialize ofun[] array */
696 {
697 register int i;
698
699 if (ofun[OBJ_SOURCE].funp == o_source)
700 return; /* done already */
701 /* alias is additional */
702 ofun[ALIAS].funame = ALIASID;
703 ofun[ALIAS].flags = 0;
704 /* functions get new transform */
705 for (i = 0; i < NUMTYPES; i++)
706 if (hasfunc(i))
707 ofun[i].funp = addxform;
708 /* special cases */
709 ofun[OBJ_SOURCE].funp = o_source;
710 ofun[OBJ_SPHERE].funp =
711 ofun[OBJ_BUBBLE].funp = o_sphere;
712 ofun[OBJ_FACE].funp = o_face;
713 ofun[OBJ_CONE].funp =
714 ofun[OBJ_CUP].funp = o_cone;
715 ofun[OBJ_CYLINDER].funp =
716 ofun[OBJ_TUBE].funp = o_cylinder;
717 ofun[OBJ_RING].funp = o_ring;
718 ofun[OBJ_INSTANCE].funp = addxform;
719 ofun[MAT_GLOW].funp = m_glow;
720 ofun[MAT_SPOT].funp = m_spot;
721 ofun[MAT_DIELECTRIC].funp = m_dielectric;
722 ofun[MAT_INTERFACE].funp = m_interface;
723 ofun[MAT_MIST].funp = m_mist;
724 ofun[PAT_CTEXT].funp =
725 ofun[PAT_BTEXT].funp =
726 ofun[MIX_TEXT].funp = text;
727 ofun[ALIAS].funp = alias;
728 /* surface inverses */
729 tinvers[OBJ_FACE] = OBJ_FACE;
730 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
731 tinvers[OBJ_CONE] = OBJ_CUP;
732 tinvers[OBJ_CUP] = OBJ_CONE;
733 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
734 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
735 tinvers[OBJ_RING] = OBJ_RING;
736 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
737 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
738 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
739 }
740
741
742 #ifdef OLDXFORM
743 openmain(fname)
744 char *fname;
745 {
746 if (fname == NULL) {
747 strcpy(mainfn, "standard input");
748 mainfp = stdin;
749 return;
750 }
751 if (mainfp != NULL) {
752 if (!strcmp(fname, mainfn)) {
753 rewind(mainfp);
754 return;
755 }
756 fclose(mainfp);
757 }
758 if ((mainfp = fopen(fname, "r")) == NULL) {
759 fprintf(stderr, "%s: cannot open file \"%s\"\n",
760 progname, fname);
761 exit(1);
762 }
763 strcpy(mainfn, fname);
764 }
765 #else
766 openmain(fname) /* open fname for input, changing to its directory */
767 char *fname;
768 {
769 extern FILE *tmpfile();
770 extern char *getlibpath(), *getpath();
771 static char origdir[MAXPATH];
772 static char curfn[MAXPATH];
773 static int diffdir;
774 register char *fpath;
775
776 if (fname == NULL) { /* standard input */
777 if (mainfp == NULL) {
778 register int c;
779 strcpy(mainfn, "standard input");
780 if (nrept <= 1) {
781 mainfp = stdin;
782 return; /* just read once */
783 }
784 /* else copy */
785 if ((mainfp = tmpfile()) == NULL) {
786 fprintf(stderr,
787 "%s: cannot create temporary file\n",
788 progname);
789 exit(1);
790 }
791 while ((c = getc(stdin)) != EOF)
792 putc(c, mainfp);
793 fclose(stdin);
794 }
795 rewind(mainfp); /* rewind copy */
796 return;
797 }
798 if (mainfp == NULL) { /* first call, initialize */
799 getwd(origdir);
800 } else if (!strcmp(fname, curfn)) { /* just need to rewind? */
801 rewind(mainfp);
802 return;
803 } else { /* else close old stream */
804 fclose(mainfp);
805 if (diffdir) {
806 chdir(origdir);
807 diffdir = 0;
808 }
809 }
810 strcpy(curfn, fname); /* remember file name */
811 /* get full path */
812 if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) {
813 fprintf(stderr, "%s: cannot find file \"%s\"\n",
814 progname, fname);
815 exit(1);
816 }
817 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
818 fpath += 2;
819 /* record path name */
820 strcpy(mainfn, fpath);
821 if (expand) { /* change to local directory */
822 register char *cp = fpath + strlen(fpath); /* get dir. */
823 while (cp > fpath) {
824 cp--;
825 if (ISDIRSEP(*cp)) {
826 if (cp == fpath)
827 cp++; /* root special case */
828 break;
829 }
830 }
831 *cp = '\0';
832 if (fpath[0]) { /* change to new directory? */
833 if (chdir(fpath) < 0) {
834 fprintf(stderr,
835 "%s: cannot change directory to \"%s\"\n",
836 progname, fpath);
837 exit(1);
838 }
839 diffdir++;
840 }
841 /* get final path component */
842 for (fpath = fname+strlen(fname);
843 fpath > fname && !ISDIRSEP(fpath[-1]); fpath--)
844 ;
845 }
846 /* open the file */
847 if ((mainfp = fopen(fpath, "r")) == NULL) {
848 fprintf(stderr, "%s: cannot open file \"%s\"\n",
849 progname, mainfn);
850 exit(1);
851 }
852 }
853 #endif
