--- ray/src/gen/xform.c 2011/06/22 17:05:00 2.45 +++ ray/src/gen/xform.c 2014/07/09 23:14:58 2.48 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: xform.c,v 2.45 2011/06/22 17:05:00 greg Exp $"; +static const char RCSid[] = "$Id: xform.c,v 2.48 2014/07/09 23:14:58 greg Exp $"; #endif /* * xform.c - program to transform object files. @@ -19,6 +19,11 @@ static const char RCSid[] = "$Id: xform.c,v 2.45 2011/ #include "object.h" #include "otypes.h" +#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ +#undef getc +#define getc getc_unlocked +#endif + int xac; /* global xform argument count */ char **xav; /* global xform argument pointer */ int xfa; /* start of xf arguments */ @@ -98,7 +103,7 @@ main( /* get transform options and transform file */ if (idprefix == NULL) idprefix = argv[a]; else { - register char *newp; + char *newp; newp = (char *)malloc(strlen(idprefix)+ strlen(argv[a])+2); if (newp == NULL) @@ -106,7 +111,7 @@ main( /* get transform options and transform file */ sprintf(newp, "%s.%s", idprefix, argv[a]); if (mal_prefix++) - free((void *)idprefix); + free(idprefix); idprefix = newp; } continue; @@ -134,7 +139,7 @@ main( /* get transform options and transform file */ a += xf(&tot, argc-a, argv+a); - if ( (reverse = tot.sca < 0.0) ) + if ( (reverse = (tot.sca < 0.0)) ) tot.sca = -tot.sca; if (invert) reverse = !reverse; @@ -167,7 +172,7 @@ main( /* get transform options and transform file */ } if (mal_prefix) - free((void *)idprefix); + free(idprefix); return(0); } @@ -184,7 +189,7 @@ doargf( /* take argument list from file */ char argbuf[2048]; char *newid, newidbuf[128]; char *oldid; - register char *cp; + char *cp; FILE *argfp; int n, i, k, newac, err; @@ -284,7 +289,7 @@ doargf( /* take argument list from file */ sprintf(newid, "%s.%d", oldid, k); err |= main(newac, avp); if (newid != newidbuf) - free((void *)newid); + free(newid); k++; } fclose(argfp); @@ -343,11 +348,11 @@ doarray( /* make array */ void xform( /* transform stream by tot.xfm */ char *name, - register FILE *fin + FILE *fin ) { int nobjs = 0; - register int c; + int c; while ((c = getc(fin)) != EOF) { if (isspace(c)) /* blank */ @@ -456,7 +461,7 @@ o_default( /* pass on arguments unchanged */ FILE *fin ) { - register int i; + int i; FUNARGS fa; if (readfargs(&fa, fin) != 1) @@ -492,7 +497,7 @@ addxform( /* add xf arguments to strings */ FILE *fin ) { - register int i; + int i; int resetarr = 0; FUNARGS fa; @@ -605,7 +610,7 @@ m_mist( /* transform arguments for mist */ else for (i = 0; i < fa.nsargs; i++) { char sname[256], *sp; - register char *cp1, *cp2 = sname; + char *cp1, *cp2 = sname; /* add idprefix */ for (sp = fa.sarg[i]; *sp; sp = cp1) { for (cp1 = idprefix; *cp1; ) @@ -775,7 +780,7 @@ o_face( /* transform face arguments */ ) { FVECT p; - register int i; + int i; FUNARGS fa; if (readfargs(&fa, fin) != 1) @@ -889,7 +894,7 @@ o_ring( /* transform ring arguments */ void initotypes(void) /* initialize ofun[] array */ { - register int i; + int i; if (ofun[OBJ_SOURCE].funp == o_source) return; /* done already */ @@ -967,11 +972,11 @@ openmain( /* open input, changing directory for file static char origdir[PATH_MAX]; static char curfn[PATH_MAX]; static int diffdir; - register char *fpath; + char *fpath; if (iname == NULL) { /* standard input */ if (mainfp == NULL) { - register int c; + int c; strcpy(mainfn, "standard input"); if (nrept <= 1) { mainfp = stdin; @@ -1015,7 +1020,7 @@ openmain( /* open input, changing directory for file /* record path name */ strcpy(mainfn, fpath); if (expand) { /* change to local directory */ - register char *cp = fpath + strlen(fpath); /* get dir. */ + char *cp = fpath + strlen(fpath); /* get dir. */ while (cp > fpath) { cp--; if (ISDIRSEP(*cp)) {
