--- ray/src/gen/xform.c 1989/10/05 09:49:04 1.8 +++ ray/src/gen/xform.c 2003/05/13 17:58:32 2.25 @@ -1,9 +1,6 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: xform.c,v 2.25 2003/05/13 17:58:32 greg Exp $"; #endif - /* * xform.c - program to transform object files. * Transformations must preserve aspect ratio. @@ -12,121 +9,111 @@ static char SCCSid[] = "$SunId$ LBL"; * 11/6/86 Finally added error checking! */ -#include +#include "standard.h" +#include "paths.h" + #include +#include "object.h" -typedef struct { - char *funame; /* function name */ - int (*funp)(); /* pointer to function */ -} FUN; +#include "otypes.h" int xac; /* global xform argument count */ char **xav; /* global xform argument pointer */ int xfa; /* start of xf arguments */ -double totxform[4][4]; /* total transformation matrix */ -double totscale; /* total scale factor */ -int reverse; /* boolean true if scene inverted */ +XF tot; /* total transformation */ +int reverse; /* boolean true if scene mirrored */ -int expand = 0; /* boolean true to expand commands */ +int invert; /* boolean true to invert surfaces */ -char *idprefix = NULL; /* prefix for object identifiers */ +int expand; /* boolean true to expand commands */ -extern int o_source(); -extern int o_sphere(); -extern int o_face(); -extern int o_cone(); -extern int o_cylinder(); -extern int o_ring(); -extern int m_glow(); -extern int m_spot(); -extern int m_dielectric(); -extern int m_interface(); -extern int text(); -extern int alias(); -extern int passargs(); -extern int addxform(); +char *newmod; /* new modifier for surfaces */ -FUN ofun[] = { - { "source", o_source }, - { "sphere", o_sphere }, - { "bubble", o_sphere }, - { "polygon", o_face }, - { "cone", o_cone }, - { "cup", o_cone }, - { "cylinder", o_cylinder }, - { "tube", o_cylinder }, - { "ring", o_ring }, - { "instance", addxform }, - { "alias", alias }, - { "antimatter", passargs }, - { "glow", m_glow }, - { "spotlight", m_spot }, - { "dielectric", m_dielectric }, - { "interface", m_interface }, - { "colortext", text }, - { "brighttext", text }, - { "texfunc", addxform }, - { "texdata", addxform }, - { "colorfunc", addxform }, - { "brightfunc", addxform }, - { "colorpict", addxform }, - { "colordata", addxform }, - { "brightdata", addxform }, - { "mixfunc", addxform }, - { "mixdata", addxform }, - { "mixtext", text }, - { "light", passargs }, - { "illum", passargs }, - { "plastic", passargs }, - { "metal", passargs }, - { "trans", passargs }, - { "glass", passargs }, - { 0 } /* terminator */ -}; +char *idprefix; /* prefix for object identifiers */ -#define issurface(t) ((t)<=9) +FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */ -typedef struct { - short nsargs; /* # of string arguments */ - char **sarg; /* string arguments */ - short niargs; /* # of integer arguments */ - int *iarg; /* integer arguments */ - short nfargs; /* # of float arguments */ - double *farg; /* float arguments */ -} FUNARGS; +short tinvers[NUMOTYPE]; /* inverse types for surfaces */ -#define MAXSTR 512 /* maximum string length */ +int nrept = 1; /* number of array repetitions */ -FUNARGS *getfargs(); -char *malloc(); +int stdinused = 0; /* stdin has been used by -f option? */ -#define progname (xav[0]) +char mainfn[MAXPATH]; /* main file name */ +FILE *mainfp = NULL; /* main file pointer */ +#define progname (xav[0]) + main(argc, argv) /* get transform options and transform file */ int argc; char *argv[]; { - FILE *fopen(); - FILE *fp; + int mal_prefix = 0; + char *fname; int a; - /* check for array */ + /* check for argument list file */ for (a = 1; a < argc; a++) + if (!strcmp(argv[a], "-f")) + return(doargf(argc, argv, a)); + /* check for regular array */ + for (a = 1; a < argc; a++) if (!strcmp(argv[a], "-a")) return(doarray(argc, argv, a)); + initotypes(); /* initialize */ + invert = 0; + expand = 1; + newmod = NULL; + idprefix = NULL; + for (a = 1; a < argc; a++) { if (argv[a][0] == '-') switch (argv[a][1]) { + case 'm': + if (argv[a][2] | a+1 >= argc) + break; + a++; + if (newmod == NULL) + newmod = argv[a]; + continue; case 'n': - idprefix = argv[++a]; + if (argv[a][2] | a+1 >= argc) + break; + a++; + if (idprefix == NULL) + idprefix = argv[a]; + else { + register char *newp; + newp = (char *)malloc(strlen(idprefix)+ + strlen(argv[a])+2); + if (newp == NULL) + exit(2); + sprintf(newp, "%s.%s", + idprefix, argv[a]); + if (mal_prefix++) + free((void *)idprefix); + idprefix = newp; + } continue; + case 'c': + if (argv[a][2]) + break; + expand = 0; + continue; case 'e': + if (argv[a][2]) + break; expand = 1; continue; + case 'I': + if (argv[a][2]) + break; + invert = !invert; + continue; } break; } @@ -134,38 +121,155 @@ char *argv[]; xav = argv; xfa = a; - totscale = 1.0; - setident4(totxform); + a += xf(&tot, argc-a, argv+a); - a += xf(totxform, &totscale, argc-a, argv+a); + if (reverse = tot.sca < 0.0) + tot.sca = -tot.sca; + if (invert) + reverse = !reverse; - if (reverse = totscale < 0.0) - totscale = -totscale; + if (a < argc && argv[a][0] == '-') { + fprintf(stderr, "%s: command line error at '%s'\n", + argv[0], argv[a]); + exit(1); + } xac = a; - - putchar('#'); /* simple header */ + /* simple header */ + putchar('#'); for (a = 0; a < xac; a++) printf(" %s", xav[a]); putchar('\n'); - - if (a == argc) - xform("standard input", stdin); - else - for ( ; a < argc; a++) { - if ((fp = fopen(argv[a], "r")) == NULL) { - fprintf(stderr, "%s: cannot open \"%s\"\n", - progname, argv[a]); - exit(1); - } - xform(argv[a], fp); - fclose(fp); + /* transform input */ + if (xac == argc) { + if (stdinused) { + fprintf(stderr, "%s: cannot use stdin more than once\n", + argv[0]); + exit(1); } + openmain(NULL); + xform(mainfn, mainfp); + } else + for (a = xac; a < argc; a++) { + openmain(argv[a]); + xform(mainfn, mainfp); + } + if (mal_prefix) + free((void *)idprefix); return(0); } +doargf(ac, av, fi) /* take argument list from file */ +char **av; +int ac, fi; +{ + int inquote; + char *newav[256], **avp; + char argbuf[1024]; + char newid[128]; + char *oldid; + register char *cp; + FILE *argfp; + int n, i, k, newac, err; + + if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) { + fprintf(stderr, "%s: missing file for -f option\n", av[0]); + exit(1); + } + if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') { + if (stdinused++) { + fprintf(stderr, + "%s: cannot use stdin more than once\n", + av[0]); + exit(1); + } + argfp = stdin; + n = 100; /* we just don't know! */ + } else { + if ((argfp = fopen(av[fi+1], "r")) == NULL) { + fprintf(stderr, + "%s: cannot open argument file \"%s\"\n", + av[0], av[fi+1]); + exit(1); + } + n = 0; /* count number of lines in file */ + while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) + n += argbuf[0] && argbuf[0] != '#'; + if (!n) { + fprintf(stderr, "%s: empty argument file \"%s\"\n", + av[0], av[fi+1]); + exit(1); + } + nrept *= n; + rewind(argfp); + } + err = 0; k = 0; /* read each arg list and call main */ + while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) { + if (!argbuf[0] || argbuf[0] == '#') + continue; + avp = newav+2; + avp[0] = av[0]; + for (i = 1; i < fi; i++) + avp[i] = av[i]; + newac = i; + cp = argbuf; /* parse new words */ + if (*cp == '!') cp++; + if (!strncmp(cp, "xform ", 6)) cp += 6; + inquote = 0; + for ( ; ; ) { + skipspaces: + while (isspace(*cp)) /* nullify spaces */ + *cp++ = '\0'; + if ((*cp == '"' | *cp == '\'')) + inquote = *cp++; + if (!*cp) /* all done? */ + break; + if (cp[0] == '\\' && cp[1]) + if (*++cp == '\n') + goto skipspaces; + avp[newac++] = cp; /* add argument to list */ + if (inquote) { + while (*++cp) + if (*cp == inquote) { + *cp++ = '\0'; + break; + } + } else { + while (*++cp && !isspace(*cp)) + ; + } + } + for (i = fi+2; i < ac; i++) + avp[newac++] = av[i]; + avp[newac] = NULL; + oldid = NULL; + for (i = 2; i < newac; i++) + if (!strcmp(avp[i-1], "-n")) { + oldid = avp[i]; + avp[i] = newid; + break; + } + if (oldid == NULL) { + newav[0] = av[0]; + newav[1] = "-n"; + newav[2] = newid; + avp = newav; + newac += 2; + } + if (oldid == NULL) + sprintf(newid, "i%d", k); + else + sprintf(newid, "%s.%d", oldid, k); + err |= main(newac, avp); + k++; + } + fclose(argfp); + return(err); +} + + doarray(ac, av, ai) /* make array */ char **av; int ac, ai; @@ -173,8 +277,13 @@ int ac, ai; char *newav[256], **avp; char newid[128], repts[32]; char *oldid = NULL; - int i, err; + int n, i, err; + if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) { + fprintf(stderr, "%s: missing count for -a option\n", av[0]); + exit(1); + } + nrept *= n; avp = newav+2; avp[0] = av[0]; for (i = 1; i < ac; i++) @@ -194,7 +303,7 @@ int ac, ai; ac += 2; } err = 0; - for (i = 0; i < atoi(av[ai+1]); i++) { + for (i = 0; i < n; i++) { if (oldid == NULL) sprintf(newid, "a%d", i); else @@ -206,10 +315,11 @@ int ac, ai; } -xform(name, fin) /* transform stream by totxform */ +xform(name, fin) /* transform stream by tot.xfm */ char *name; register FILE *fin; { + int nobjs = 0; register int c; while ((c = getc(fin)) != EOF) { @@ -225,19 +335,23 @@ register FILE *fin; } else if (c == '!') { /* command */ ungetc(c, fin); xfcomm(name, fin); + nobjs++; } else { /* object */ ungetc(c, fin); xfobject(name, fin); + nobjs++; } } + if (nobjs == 0) + fprintf(stderr, "%s: (%s): warning - empty file\n", + progname, name); } xfcomm(fname, fin) /* transform a command */ +char *fname; FILE *fin; { - FILE *popen(); - char *fgetline(); FILE *pin; char buf[512]; int i; @@ -252,9 +366,13 @@ FILE *fin; xform(buf, pin); pclose(pin); } else { - printf("\n%s | %s -e", buf, xav[0]); - for (i = 1; i < xac; i++) - printf(" %s", xav[i]); + printf("\n%s", buf); + if (xac > 1) { + printf(" | %s -e", xav[0]); /* expand next time */ + for (i = 1; i < xac; i++) + if (i >= xfa || strcmp(xav[i], "-c")) + printf(" %s", xav[i]); + } putchar('\n'); } } @@ -264,56 +382,67 @@ xfobject(fname, fin) /* transform an object */ char *fname; FILE *fin; { - char stmp[MAXSTR]; + char typ[16], nam[MAXSTR]; int fn; - - fscanf(fin, "%s", stmp); /* modifier */ - printf("\n%s ", stmp); - fscanf(fin, "%s", stmp); /* object type */ - if ((fn = otype(stmp)) < 0) { + /* modifier and type */ + strcpy(typ, "EOF"); + fgetword(nam, sizeof(nam), fin); + fgetword(typ, sizeof(typ), fin); + if ((fn = otype(typ)) < 0) { fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n", - progname, fname, stmp); + progname, fname, typ); exit(1); } - printf("%s ", stmp); - fscanf(fin, "%s", stmp); /* object name */ - if (idprefix != NULL && issurface(fn)) - printf("%s.%s\n", idprefix, stmp); + if (ismodifier(fn)) + printf("\n%s %s ", nam, typ); else - printf("%s\n", stmp); - /* transform arguments */ + printf("\n%s %s ", newmod != NULL ? newmod : nam, + invert ? ofun[tinvers[fn]].funame : typ); + /* object name */ + fgetword(nam, sizeof(nam), fin); + if (idprefix == NULL || ismodifier(fn)) + printf("%s\n", nam); + else + printf("%s.%s\n", idprefix, nam); + /* transform arguments */ if ((*ofun[fn].funp)(fin) < 0) { fprintf(stderr, "%s: (%s): bad %s \"%s\"\n", - progname, fname, ofun[fn].funame, stmp); + progname, fname, ofun[fn].funame, nam); exit(1); } } -passargs(fin) /* pass on arguments unchanged */ +o_default(fin) /* pass on arguments unchanged */ FILE *fin; { register int i; - register FUNARGS *fa; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); /* string arguments */ - printf("%d", fa->nsargs); - for (i = 0; i < fa->nsargs; i++) - printf(" %s", fa->sarg[i]); + printf("%d", fa.nsargs); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } printf("\n"); +#ifdef IARGS /* integer arguments */ - printf("%d", fa->niargs); - for (i = 0; i < fa->niargs; i++) - printf(" %d", fa->iarg[i]); + printf("%d", fa.niargs); + for (i = 0; i < fa.niargs; i++) + printf(" %d", fa.iarg[i]); printf("\n"); +#else + printf("0\n"); +#endif /* float arguments */ - printf("%d", fa->nfargs); - for (i = 0; i < fa->nfargs; i++) - printf(" %18.12g", fa->farg[i]); + printf("%d", fa.nfargs); + for (i = 0; i < fa.nfargs; i++) + printf(" %18.12g", fa.farg[i]); printf("\n"); - freefargs(fa); + freefargs(&fa); return(0); } @@ -322,54 +451,51 @@ addxform(fin) /* add xf arguments to strings */ FILE *fin; { register int i; - register FUNARGS *fa; + int resetarr = 0; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); /* string arguments */ - printf("%d", fa->nsargs + xac-xfa); - for (i = 0; i < fa->nsargs; i++) - printf(" %s", fa->sarg[i]); + if (xac > xfa && strcmp(xav[xfa], "-i")) + resetarr = 2; + printf("%d", fa.nsargs + resetarr + xac-xfa); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } + if (resetarr) + printf(" -i 1"); for (i = xfa; i < xac; i++) /* add xf arguments */ printf(" %s", xav[i]); printf("\n"); +#ifdef IARGS /* integer arguments */ - printf("%d", fa->niargs); - for (i = 0; i < fa->niargs; i++) - printf(" %d", fa->iarg[i]); + printf("%d", fa.niargs); + for (i = 0; i < fa.niargs; i++) + printf(" %d", fa.iarg[i]); printf("\n"); +#else + printf("0\n"); +#endif /* float arguments */ - printf("%d", fa->nfargs); - for (i = 0; i < fa->nfargs; i++) - printf(" %18.12g", fa->farg[i]); + printf("%d", fa.nfargs); + for (i = 0; i < fa.nfargs; i++) + printf(" %18.12g", fa.farg[i]); printf("\n"); - freefargs(fa); + freefargs(&fa); return(0); } -int -otype(ofname) /* get object function number from its name */ -register char *ofname; -{ - register int i; - - for (i = 0; ofun[i].funame != NULL; i++) - if (!strcmp(ofun[i].funame, ofname)) - return(i); - - return(-1); /* not found */ -} - - alias(fin) /* transfer alias */ FILE *fin; { - char alias[MAXSTR]; + char aliasnm[MAXSTR]; - if (fscanf(fin, "%s", alias) != 1) + if (fgetword(aliasnm, MAXSTR, fin) == NULL) return(-1); - printf("\t%s\n", alias); + printf("\t%s\n", aliasnm); return(0); } @@ -377,17 +503,17 @@ FILE *fin; m_glow(fin) /* transform arguments for proximity light */ FILE *fin; { - register FUNARGS *fa; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 4) + if (fa.nsargs != 0 || fa.nfargs != 4) return(-1); printf("0\n0\n4"); printf(" %18.12g %18.12g %18.12g", - fa->farg[0], fa->farg[1], fa->farg[2]); - printf(" %18.12g\n", fa->farg[3] * totscale); - freefargs(fa); + fa.farg[0], fa.farg[1], fa.farg[2]); + printf(" %18.12g\n", fa.farg[3] * tot.sca); + freefargs(&fa); return(0); } @@ -395,40 +521,81 @@ FILE *fin; m_spot(fin) /* transform arguments for spotlight */ FILE *fin; { - double v[3]; - register FUNARGS *fa; + FVECT v; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 7) + if (fa.nsargs != 0 || fa.nfargs != 7) return(-1); printf("0\n0\n7"); printf(" %18.12g %18.12g %18.12g %18.12g\n", - fa->farg[0], fa->farg[1], fa->farg[2], fa->farg[3]); - multv3(v, fa->farg+4, totxform); + fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]); + multv3(v, fa.farg+4, tot.xfm); printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); - freefargs(fa); + freefargs(&fa); return(0); } +m_mist(fin) /* transform arguments for mist */ +FILE *fin; +{ + FUNARGS fa; + int i; + + if (readfargs(&fa, fin) != 1) + return(-1); + if (fa.nfargs > 7) + return(-1); + printf("%d", fa.nsargs); + if (idprefix == NULL) + for (i = 0; i < fa.nsargs; i++) + printf(" %s", fa.sarg[i]); + else + for (i = 0; i < fa.nsargs; i++) { + char sname[256], *sp; + register char *cp1, *cp2 = sname; + /* add idprefix */ + for (sp = fa.sarg[i]; *sp; sp = cp1) { + for (cp1 = idprefix; *cp1; ) + *cp2++ = *cp1++; + *cp2++ = '.'; + for (cp1 = sp; *cp1 && + (*cp2++ = *cp1++) != '>'; ) + ; + } + *cp2 = '\0'; + printf(" %s", sname); + } + printf("\n0\n%d", fa.nfargs); + if (fa.nfargs > 2) + printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca, + fa.farg[1]/tot.sca, fa.farg[2]/tot.sca); + for (i = 3; i < fa.nfargs; i++) + printf(" %12.6g", fa.farg[i]); + printf("\n"); + freefargs(&fa); + return(0); +} + + m_dielectric(fin) /* transform arguments for dielectric */ FILE *fin; { - double pow(); - register FUNARGS *fa; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 5) + if (fa.nsargs != 0 || fa.nfargs != 5) return(-1); printf("0\n0\n5"); - printf(" %18.12g %18.12g %18.12g", - pow(fa->farg[0], 1.0/totscale), - pow(fa->farg[1], 1.0/totscale), - pow(fa->farg[2], 1.0/totscale)); - printf(" %18.12g %18.12g\n", fa->farg[3], fa->farg[4]); - freefargs(fa); + printf(" %12.6g %12.6g %12.6g", + pow(fa.farg[0], 1.0/tot.sca), + pow(fa.farg[1], 1.0/tot.sca), + pow(fa.farg[2], 1.0/tot.sca)); + printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]); + freefargs(&fa); return(0); } @@ -436,25 +603,24 @@ FILE *fin; m_interface(fin) /* transform arguments for interface */ FILE *fin; { - double pow(); - register FUNARGS *fa; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 8) + if (fa.nsargs != 0 || fa.nfargs != 8) return(-1); printf("0\n0\n8\n"); - printf("%18.12g %18.12g %18.12g", - pow(fa->farg[0], 1.0/totscale), - pow(fa->farg[1], 1.0/totscale), - pow(fa->farg[2], 1.0/totscale)); - printf(" %18.12g\n", fa->farg[3]); - printf("%18.12g %18.12g %18.12g", - pow(fa->farg[4], 1.0/totscale), - pow(fa->farg[5], 1.0/totscale), - pow(fa->farg[6], 1.0/totscale)); - printf(" %18.12g\n", fa->farg[7]); - freefargs(fa); + printf("%12.6g %12.6g %12.6g", + pow(fa.farg[0], 1.0/tot.sca), + pow(fa.farg[1], 1.0/tot.sca), + pow(fa.farg[2], 1.0/tot.sca)); + printf(" %12.6g\n", fa.farg[3]); + printf("%12.6g %12.6g %12.6g", + pow(fa.farg[4], 1.0/tot.sca), + pow(fa.farg[5], 1.0/tot.sca), + pow(fa.farg[6], 1.0/tot.sca)); + printf(" %12.6g\n", fa.farg[7]); + freefargs(&fa); return(0); } @@ -463,38 +629,37 @@ text(fin) /* transform text arguments */ FILE *fin; { int i; - double v[3]; - register FUNARGS *fa; + FVECT v; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->niargs != 0 || (fa->nfargs != 9 && - fa->nfargs != 11 && fa->nfargs != 15)) + if (fa.nfargs < 9) return(-1); /* string arguments */ - printf("%d", fa->nsargs); - for (i = 0; i < fa->nsargs; i++) - printf(" %s", fa->sarg[i]); - printf("\n0\n%d\n", fa->nfargs); + printf("%d", fa.nsargs); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } + printf("\n0\n%d\n", fa.nfargs); /* anchor point */ - multp3(v, fa->farg, totxform); + multp3(v, fa.farg, tot.xfm); printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); /* right vector */ - multv3(v, fa->farg+3, totxform); + multv3(v, fa.farg+3, tot.xfm); printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); /* down vector */ - multv3(v, fa->farg+6, totxform); - printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); - /* forground and background */ - if (fa->nfargs == 11) - printf(" %18.12g %18.12g\n", fa->farg[9], fa->farg[10]); - else if (fa->nfargs == 15) { - printf(" %18.12g %18.12g %18.12g\n", - fa->farg[9], fa->farg[10], fa->farg[11]); - printf(" %18.12g %18.12g %18.12g\n", - fa->farg[12], fa->farg[13], fa->farg[14]); + multv3(v, fa.farg+6, tot.xfm); + printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]); + /* remaining arguments */ + for (i = 9; i < fa.nfargs; i++) { + if (i%3 == 0) + putchar('\n'); + printf(" %18.12g", fa.farg[i]); } - freefargs(fa); + putchar('\n'); + freefargs(&fa); return(0); } @@ -502,20 +667,20 @@ FILE *fin; o_source(fin) /* transform source arguments */ FILE *fin; { - double dv[3]; - register FUNARGS *fa; + FVECT dv; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 4) + if (fa.nsargs != 0 || fa.nfargs != 4) return(-1); /* transform direction vector */ - multv3(dv, fa->farg, totxform); + multv3(dv, fa.farg, tot.xfm); /* output */ printf("0\n0\n4"); printf(" %18.12g %18.12g %18.12g %18.12g\n", - dv[0], dv[1], dv[2], fa->farg[3]); - freefargs(fa); + dv[0], dv[1], dv[2], fa.farg[3]); + freefargs(&fa); return(0); } @@ -523,22 +688,23 @@ FILE *fin; o_sphere(fin) /* transform sphere arguments */ FILE *fin; { - double cent[3], rad; - register FUNARGS *fa; + FVECT cent; + double rad; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 4) + if (fa.nsargs != 0 || fa.nfargs != 4) return(-1); - multp3(cent, fa->farg, totxform); /* transform center */ + multp3(cent, fa.farg, tot.xfm); /* transform center */ - rad = fa->farg[3] * totscale; /* scale radius */ + rad = fa.farg[3] * tot.sca; /* scale radius */ printf("0\n0\n4"); printf(" %18.12g %18.12g %18.12g %18.12g\n", cent[0], cent[1], cent[2], rad); - freefargs(fa); + freefargs(&fa); return(0); } @@ -546,25 +712,25 @@ FILE *fin; o_face(fin) /* transform face arguments */ FILE *fin; { - double p[3]; + FVECT p; register int i; - register FUNARGS *fa; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs % 3) + if (fa.nsargs != 0 || fa.nfargs % 3) return(-1); - printf("0\n0\n%d\n", fa->nfargs); + printf("0\n0\n%d\n", fa.nfargs); - for (i = 0; i < fa->nfargs; i += 3) { + for (i = 0; i < fa.nfargs; i += 3) { if (reverse) - multp3(p, fa->farg+(fa->nfargs-i-3), totxform); + multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm); else - multp3(p, fa->farg+i, totxform); + multp3(p, fa.farg+i, tot.xfm); printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]); } - freefargs(fa); + freefargs(&fa); return(0); } @@ -572,25 +738,26 @@ FILE *fin; o_cone(fin) /* transform cone and cup arguments */ FILE *fin; { - double p0[3], p1[3], r0, r1; - register FUNARGS *fa; + FVECT p0, p1; + double r0, r1; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 8) + if (fa.nsargs != 0 || fa.nfargs != 8) return(-1); printf("0\n0\n8\n"); - multp3(p0, fa->farg, totxform); - multp3(p1, fa->farg+3, totxform); - r0 = fa->farg[6] * totscale; - r1 = fa->farg[7] * totscale; + multp3(p0, fa.farg, tot.xfm); + multp3(p1, fa.farg+3, tot.xfm); + r0 = fa.farg[6] * tot.sca; + r1 = fa.farg[7] * tot.sca; printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]); printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]); printf(" %18.12g %18.12g\n", r0, r1); - freefargs(fa); + freefargs(&fa); return(0); } @@ -598,23 +765,24 @@ FILE *fin; o_cylinder(fin) /* transform cylinder and tube arguments */ FILE *fin; { - double p0[3], p1[3], rad; - register FUNARGS *fa; + FVECT p0, p1; + double rad; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 7) + if (fa.nsargs != 0 || fa.nfargs != 7) return(-1); printf("0\n0\n7\n"); - multp3(p0, fa->farg, totxform); - multp3(p1, fa->farg+3, totxform); - rad = fa->farg[6] * totscale; + multp3(p0, fa.farg, tot.xfm); + multp3(p1, fa.farg+3, tot.xfm); + rad = fa.farg[6] * tot.sca; printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]); printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]); printf(" %18.12g\n", rad); - freefargs(fa); + freefargs(&fa); return(0); } @@ -622,96 +790,185 @@ FILE *fin; o_ring(fin) /* transform ring arguments */ FILE *fin; { - double p0[3], pd[3], r0, r1; - register FUNARGS *fa; + FVECT p0, pd; + double r0, r1; + FUNARGS fa; - if ((fa = getfargs(fin)) == NULL) + if (readfargs(&fa, fin) != 1) return(-1); - if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 8) + if (fa.nsargs != 0 || fa.nfargs != 8) return(-1); printf("0\n0\n8\n"); - multp3(p0, fa->farg, totxform); - multv3(pd, fa->farg+3, totxform); - r0 = fa->farg[6] * totscale; - r1 = fa->farg[7] * totscale; + multp3(p0, fa.farg, tot.xfm); + multv3(pd, fa.farg+3, tot.xfm); + if (invert) { + pd[0] = -pd[0]; + pd[1] = -pd[1]; + pd[2] = -pd[2]; + } + r0 = fa.farg[6] * tot.sca; + r1 = fa.farg[7] * tot.sca; printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]); printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]); printf(" %18.12g %18.12g\n", r0, r1); - freefargs(fa); + freefargs(&fa); return(0); } -FUNARGS * -getfargs(fp) /* get function arguments from stream */ -FILE *fp; +initotypes() /* initialize ofun[] array */ { - char *strcpy(); - char sbuf[MAXSTR]; - int n; - register FUNARGS *fa; register int i; - if ((fa = (FUNARGS *)malloc((unsigned)sizeof(FUNARGS))) == NULL) - goto memerr; - if (fscanf(fp, "%d", &n) != 1 || n < 0) - return(NULL); - if (fa->nsargs = n) { - fa->sarg = (char **)malloc((unsigned)fa->nsargs*sizeof(char *)); - if (fa->sarg == NULL) - goto memerr; - for (i = 0; i < fa->nsargs; i++) { - if (fscanf(fp, "%s", sbuf) != 1) - return(NULL); - if ((fa->sarg[i] = malloc((unsigned)strlen(sbuf)+1)) == NULL) - goto memerr; - strcpy(fa->sarg[i], sbuf); - } - } else - fa->sarg = NULL; - if (fscanf(fp, "%d", &n) != 1 || n < 0) - return(NULL); - if (fa->niargs = n) { - fa->iarg = (int *)malloc((unsigned)fa->niargs*sizeof(int)); - if (fa->iarg == NULL) - goto memerr; - for (i = 0; i < fa->niargs; i++) - if (fscanf(fp, "%d", &fa->iarg[i]) != 1) - return(NULL); - } else - fa->iarg = NULL; - if (fscanf(fp, "%d", &n) != 1 || n < 0) - return(NULL); - if (fa->nfargs = n) { - fa->farg = (double *)malloc((unsigned)fa->nfargs*sizeof(double)); - if (fa->farg == NULL) - goto memerr; - for (i = 0; i < fa->nfargs; i++) - if (fscanf(fp, "%lf", &fa->farg[i]) != 1) - return(NULL); - } else - fa->farg = NULL; - return(fa); -memerr: - fprintf(stderr, "%s: out of memory in getfargs\n", progname); - exit(1); + if (ofun[OBJ_SOURCE].funp == o_source) + return; /* done already */ + /* functions get new transform */ + for (i = 0; i < NUMOTYPE; i++) + if (hasfunc(i)) + ofun[i].funp = addxform; + /* special cases */ + ofun[OBJ_SOURCE].funp = o_source; + ofun[OBJ_SPHERE].funp = + ofun[OBJ_BUBBLE].funp = o_sphere; + ofun[OBJ_FACE].funp = o_face; + ofun[OBJ_CONE].funp = + ofun[OBJ_CUP].funp = o_cone; + ofun[OBJ_CYLINDER].funp = + ofun[OBJ_TUBE].funp = o_cylinder; + ofun[OBJ_RING].funp = o_ring; + ofun[OBJ_INSTANCE].funp = addxform; + ofun[MAT_GLOW].funp = m_glow; + ofun[MAT_SPOT].funp = m_spot; + ofun[MAT_DIELECTRIC].funp = m_dielectric; + ofun[MAT_INTERFACE].funp = m_interface; + ofun[MAT_MIST].funp = m_mist; + ofun[PAT_CTEXT].funp = + ofun[PAT_BTEXT].funp = + ofun[MIX_TEXT].funp = text; + ofun[MOD_ALIAS].funp = alias; + /* surface inverses */ + tinvers[OBJ_FACE] = OBJ_FACE; + tinvers[OBJ_SOURCE] = OBJ_SOURCE; + tinvers[OBJ_CONE] = OBJ_CUP; + tinvers[OBJ_CUP] = OBJ_CONE; + tinvers[OBJ_SPHERE] = OBJ_BUBBLE; + tinvers[OBJ_BUBBLE] = OBJ_SPHERE; + tinvers[OBJ_RING] = OBJ_RING; + tinvers[OBJ_CYLINDER] = OBJ_TUBE; + tinvers[OBJ_TUBE] = OBJ_CYLINDER; + tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */ } -freefargs(fa) /* free memory associated with fa */ -register FUNARGS *fa; +#ifdef OLDXFORM +openmain(fname) +char *fname; { - register int i; + if (fname == NULL) { + strcpy(mainfn, "standard input"); + mainfp = stdin; + return; + } + if (mainfp != NULL) { + if (!strcmp(fname, mainfn)) { + rewind(mainfp); + return; + } + fclose(mainfp); + } + if ((mainfp = fopen(fname, "r")) == NULL) { + fprintf(stderr, "%s: cannot open file \"%s\"\n", + progname, fname); + exit(1); + } + strcpy(mainfn, fname); +} +#else +openmain(iname) /* open input, changing directory for file */ +char *iname; +{ + static char origdir[MAXPATH]; + static char curfn[MAXPATH]; + static int diffdir; + register char *fpath; - for (i = 0; i < fa->nsargs; i++) - free(fa->sarg[i]); - if (fa->nsargs) - free(fa->sarg); - if (fa->niargs) - free(fa->iarg); - if (fa->nfargs) - free(fa->farg); - free(fa); + if (iname == NULL) { /* standard input */ + if (mainfp == NULL) { + register int c; + strcpy(mainfn, "standard input"); + if (nrept <= 1) { + mainfp = stdin; + return; /* just read once */ + } + /* else copy */ + if ((mainfp = tmpfile()) == NULL) { + fprintf(stderr, + "%s: cannot create temporary file\n", + progname); + exit(1); + } + while ((c = getc(stdin)) != EOF) + putc(c, mainfp); + } + rewind(mainfp); /* rewind copy */ + return; + } + if (mainfp == NULL) { /* first call, initialize */ + getwd(origdir); + } else if (!strcmp(iname, curfn)) { /* just need to rewind? */ + rewind(mainfp); + return; + } else { /* else close old stream */ + fclose(mainfp); + mainfp = NULL; + if (diffdir) { /* return to our directory */ + chdir(origdir); + diffdir = 0; + } + } + strcpy(curfn, iname); /* remember input name */ + /* get full path for file */ + if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) { + fprintf(stderr, "%s: cannot find file \"%s\"\n", + progname, iname); + exit(1); + } + if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */ + fpath += 2; + /* record path name */ + strcpy(mainfn, fpath); + if (expand) { /* change to local directory */ + register char *cp = fpath + strlen(fpath); /* get dir. */ + while (cp > fpath) { + cp--; + if (ISDIRSEP(*cp)) { + if (cp == fpath) + cp++; /* root special case */ + break; + } + } + *cp = '\0'; + if (fpath[0]) { /* change to new directory? */ + if (chdir(fpath) < 0) { + fprintf(stderr, + "%s: cannot change directory to \"%s\"\n", + progname, fpath); + exit(1); + } + diffdir++; + } + /* get final path component */ + for (fpath = iname+strlen(iname); + fpath > iname && !ISDIRSEP(fpath[-1]); fpath--) + ; + } + /* finally, open the file */ + if ((mainfp = fopen(fpath, "r")) == NULL) { + fprintf(stderr, "%s: cannot open file \"%s\"\n", + progname, mainfn); + exit(1); + } } +#endif
