root/radiance/ray/src/gen/xform.c
Revision: 2.29
Committed: Thu Jul 3 22:41:44 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.28: +4 -2 lines
2 static const char RCSid[] = "$Id: xform.c,v 2.28 2003/06/30 14:59:11 schorsch Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13 #ifndef _WIN32
14 #include <unistd.h>
15 #endif
16
17 #include "standard.h"
18 #include "platform.h"
19 #include "paths.h"
20 #include "object.h"
21 #include "otypes.h"
22
23 int xac; /* global xform argument count */
24 char **xav; /* global xform argument pointer */
25 int xfa; /* start of xf arguments */
26
27 XF tot; /* total transformation */
28 int reverse; /* boolean true if scene mirrored */
29
30 int invert; /* boolean true to invert surfaces */
31
32 int expand; /* boolean true to expand commands */
33
34 char *newmod; /* new modifier for surfaces */
35
36 char *idprefix; /* prefix for object identifiers */
37
38 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
39
40 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
41
42 int nrept = 1; /* number of array repetitions */
43
44 int stdinused = 0; /* stdin has been used by -f option? */
45
46 char mainfn[PATH_MAX]; /* main file name */
47 FILE *mainfp = NULL; /* main file pointer */
48
49 #define progname (xav[0])
50
51
52 main(argc, argv) /* get transform options and transform file */
53 int argc;
54 char *argv[];
55 {
56 int mal_prefix = 0;
57 char *fname;
58 int a;
59 /* check for argument list file */
60 for (a = 1; a < argc; a++)
61 if (!strcmp(argv[a], "-f"))
62 return(doargf(argc, argv, a));
63 /* check for regular array */
64 for (a = 1; a < argc; a++)
65 if (!strcmp(argv[a], "-a"))
66 return(doarray(argc, argv, a));
67
68 initotypes(); /* initialize */
69 invert = 0;
70 expand = 1;
71 newmod = NULL;
72 idprefix = NULL;
73
74 for (a = 1; a < argc; a++) {
75 if (argv[a][0] == '-')
76 switch (argv[a][1]) {
77 case 'm':
78 if (argv[a][2] | a+1 >= argc)
79 break;
80 a++;
81 if (newmod == NULL)
82 newmod = argv[a];
83 continue;
84 case 'n':
85 if (argv[a][2] | a+1 >= argc)
86 break;
87 a++;
88 if (idprefix == NULL)
89 idprefix = argv[a];
90 else {
91 register char *newp;
92 newp = (char *)malloc(strlen(idprefix)+
93 strlen(argv[a])+2);
94 if (newp == NULL)
95 exit(2);
96 sprintf(newp, "%s.%s",
97 idprefix, argv[a]);
98 if (mal_prefix++)
99 free((void *)idprefix);
100 idprefix = newp;
101 }
102 continue;
103 case 'c':
104 if (argv[a][2])
105 break;
106 expand = 0;
107 continue;
108 case 'e':
109 if (argv[a][2])
110 break;
111 expand = 1;
112 continue;
113 case 'I':
114 if (argv[a][2])
115 break;
116 invert = !invert;
117 continue;
118 }
119 break;
120 }
121
122 xav = argv;
123 xfa = a;
124
125 a += xf(&tot, argc-a, argv+a);
126
127 if (reverse = tot.sca < 0.0)
128 tot.sca = -tot.sca;
129 if (invert)
130 reverse = !reverse;
131
132 if (a < argc && argv[a][0] == '-') {
133 fprintf(stderr, "%s: command line error at '%s'\n",
134 argv[0], argv[a]);
135 exit(1);
136 }
137
138 xac = a;
139 /* simple header */
140 putchar('#');
141 for (a = 0; a < xac; a++)
142 printf(" %s", xav[a]);
143 putchar('\n');
144 /* transform input */
145 if (xac == argc) {
146 if (stdinused) {
147 fprintf(stderr, "%s: cannot use stdin more than once\n",
148 argv[0]);
149 exit(1);
150 }
151 openmain(NULL);
152 xform(mainfn, mainfp);
153 } else
154 for (a = xac; a < argc; a++) {
155 openmain(argv[a]);
156 xform(mainfn, mainfp);
157 }
158
159 if (mal_prefix)
160 free((void *)idprefix);
161 return(0);
162 }
163
164
165 doargf(ac, av, fi) /* take argument list from file */
166 char **av;
167 int ac, fi;
168 {
169 int inquote;
170 char *newav[256], **avp;
171 char argbuf[1024];
172 char newid[128];
173 char *oldid;
174 register char *cp;
175 FILE *argfp;
176 int n, i, k, newac, err;
177
178 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
179 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
180 exit(1);
181 }
182 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
183 if (stdinused++) {
184 fprintf(stderr,
185 "%s: cannot use stdin more than once\n",
186 av[0]);
187 exit(1);
188 }
189 argfp = stdin;
190 n = 100; /* we just don't know! */
191 } else {
192 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
193 fprintf(stderr,
194 "%s: cannot open argument file \"%s\"\n",
195 av[0], av[fi+1]);
196 exit(1);
197 }
198 n = 0; /* count number of lines in file */
199 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
200 n += argbuf[0] && argbuf[0] != '#';
201 if (!n) {
202 fprintf(stderr, "%s: empty argument file \"%s\"\n",
203 av[0], av[fi+1]);
204 exit(1);
205 }
206 nrept *= n;
207 rewind(argfp);
208 }
209 err = 0; k = 0; /* read each arg list and call main */
210 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
211 if (!argbuf[0] || argbuf[0] == '#')
212 continue;
213 avp = newav+2;
214 avp[0] = av[0];
215 for (i = 1; i < fi; i++)
216 avp[i] = av[i];
217 newac = i;
218 cp = argbuf; /* parse new words */
219 if (*cp == '!') cp++;
220 if (!strncmp(cp, "xform ", 6)) cp += 6;
221 inquote = 0;
222 for ( ; ; ) {
223 skipspaces:
224 while (isspace(*cp)) /* nullify spaces */
225 *cp++ = '\0';
226 if ((*cp == '"' | *cp == '\''))
227 inquote = *cp++;
228 if (!*cp) /* all done? */
229 break;
230 if (cp[0] == '\\' && cp[1])
231 if (*++cp == '\n')
232 goto skipspaces;
233 avp[newac++] = cp; /* add argument to list */
234 if (inquote) {
235 while (*++cp)
236 if (*cp == inquote) {
237 *cp++ = '\0';
238 break;
239 }
240 } else {
241 while (*++cp && !isspace(*cp))
242 ;
243 }
244 }
245 for (i = fi+2; i < ac; i++)
246 avp[newac++] = av[i];
247 avp[newac] = NULL;
248 oldid = NULL;
249 for (i = 2; i < newac; i++)
250 if (!strcmp(avp[i-1], "-n")) {
251 oldid = avp[i];
252 avp[i] = newid;
253 break;
254 }
255 if (oldid == NULL) {
256 newav[0] = av[0];
257 newav[1] = "-n";
258 newav[2] = newid;
259 avp = newav;
260 newac += 2;
261 }
262 if (oldid == NULL)
263 sprintf(newid, "i%d", k);
264 else
265 sprintf(newid, "%s.%d", oldid, k);
266 err |= main(newac, avp);
267 k++;
268 }
269 fclose(argfp);
270 return(err);
271 }
272
273
274 doarray(ac, av, ai) /* make array */
275 char **av;
276 int ac, ai;
277 {
278 char *newav[256], **avp;
279 char newid[128], repts[32];
280 char *oldid = NULL;
281 int n, i, err;
282
283 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
284 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
285 exit(1);
286 }
287 nrept *= n;
288 avp = newav+2;
289 avp[0] = av[0];
290 for (i = 1; i < ac; i++)
291 if (!strcmp(av[i-1], "-n")) {
292 oldid = av[i];
293 avp[i] = newid;
294 } else
295 avp[i] = av[i];
296 avp[ai] = "-i";
297 avp[ai+1] = repts;
298 avp[i] = NULL;
299 if (oldid == NULL) {
300 newav[0] = av[0];
301 newav[1] = "-n";
302 newav[2] = newid;
303 avp = newav;
304 ac += 2;
305 }
306 err = 0;
307 for (i = 0; i < n; i++) {
308 if (oldid == NULL)
309 sprintf(newid, "a%d", i);
310 else
311 sprintf(newid, "%s.%d", oldid, i);
312 sprintf(repts, "%d", i);
313 err |= main(ac, avp);
314 }
315 return(err);
316 }
317
318
319 xform(name, fin) /* transform stream by tot.xfm */
320 char *name;
321 register FILE *fin;
322 {
323 int nobjs = 0;
324 register int c;
325
326 while ((c = getc(fin)) != EOF) {
327 if (isspace(c)) /* blank */
328 continue;
329 if (c == '#') { /* comment */
330 putchar(c);
331 do {
332 if ((c = getc(fin)) == EOF)
333 return;
334 putchar(c);
335 } while (c != '\n');
336 } else if (c == '!') { /* command */
337 ungetc(c, fin);
338 xfcomm(name, fin);
339 nobjs++;
340 } else { /* object */
341 ungetc(c, fin);
342 xfobject(name, fin);
343 nobjs++;
344 }
345 }
346 if (nobjs == 0)
347 fprintf(stderr, "%s: (%s): warning - empty file\n",
348 progname, name);
349 }
350
351
352 xfcomm(fname, fin) /* transform a command */
353 char *fname;
354 FILE *fin;
355 {
356 FILE *pin;
357 char buf[512];
358 int i;
359
360 fgetline(buf, sizeof(buf), fin);
361 if (expand) {
362 if ((pin = popen(buf+1, "r")) == NULL) {
363 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
364 progname, fname, buf);
365 exit(1);
366 }
367 xform(buf, pin);
368 pclose(pin);
369 } else {
370 printf("\n%s", buf);
371 if (xac > 1) {
372 printf(" | %s -e", xav[0]); /* expand next time */
373 for (i = 1; i < xac; i++)
374 if (i >= xfa || strcmp(xav[i], "-c"))
375 printf(" %s", xav[i]);
376 }
377 putchar('\n');
378 }
379 }
380
381
382 xfobject(fname, fin) /* transform an object */
383 char *fname;
384 FILE *fin;
385 {
386 char typ[16], nam[MAXSTR];
387 int fn;
388 /* modifier and type */
389 strcpy(typ, "EOF");
390 fgetword(nam, sizeof(nam), fin);
391 fgetword(typ, sizeof(typ), fin);
392 if ((fn = otype(typ)) < 0) {
393 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
394 progname, fname, typ);
395 exit(1);
396 }
397 if (ismodifier(fn))
398 printf("\n%s %s ", nam, typ);
399 else
400 printf("\n%s %s ", newmod != NULL ? newmod : nam,
401 invert ? ofun[tinvers[fn]].funame : typ);
402 /* object name */
403 fgetword(nam, sizeof(nam), fin);
404 if (idprefix == NULL || ismodifier(fn))
405 printf("%s\n", nam);
406 else
407 printf("%s.%s\n", idprefix, nam);
408 /* transform arguments */
409 if ((*ofun[fn].funp)(fin) < 0) {
410 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
411 progname, fname, ofun[fn].funame, nam);
412 exit(1);
413 }
414 }
415
416
417 o_default(fin) /* pass on arguments unchanged */
418 FILE *fin;
419 {
420 register int i;
421 FUNARGS fa;
422
423 if (readfargs(&fa, fin) != 1)
424 return(-1);
425 /* string arguments */
426 printf("%d", fa.nsargs);
427 for (i = 0; i < fa.nsargs; i++) {
428 fputc(' ', stdout);
429 fputword(fa.sarg[i], stdout);
430 }
431 printf("\n");
432 #ifdef IARGS
433 /* integer arguments */
434 printf("%d", fa.niargs);
435 for (i = 0; i < fa.niargs; i++)
436 printf(" %d", fa.iarg[i]);
437 printf("\n");
438 #else
439 printf("0\n");
440 #endif
441 /* float arguments */
442 printf("%d", fa.nfargs);
443 for (i = 0; i < fa.nfargs; i++)
444 printf(" %18.12g", fa.farg[i]);
445 printf("\n");
446 freefargs(&fa);
447 return(0);
448 }
449
450
451 addxform(fin) /* add xf arguments to strings */
452 FILE *fin;
453 {
454 register int i;
455 int resetarr = 0;
456 FUNARGS fa;
457
458 if (readfargs(&fa, fin) != 1)
459 return(-1);
460 /* string arguments */
461 if (xac > xfa && strcmp(xav[xfa], "-i"))
462 resetarr = 2;
463 printf("%d", fa.nsargs + resetarr + xac-xfa);
464 for (i = 0; i < fa.nsargs; i++) {
465 fputc(' ', stdout);
466 fputword(fa.sarg[i], stdout);
467 }
468 if (resetarr)
469 printf(" -i 1");
470 for (i = xfa; i < xac; i++) /* add xf arguments */
471 printf(" %s", xav[i]);
472 printf("\n");
473 #ifdef IARGS
474 /* integer arguments */
475 printf("%d", fa.niargs);
476 for (i = 0; i < fa.niargs; i++)
477 printf(" %d", fa.iarg[i]);
478 printf("\n");
479 #else
480 printf("0\n");
481 #endif
482 /* float arguments */
483 printf("%d", fa.nfargs);
484 for (i = 0; i < fa.nfargs; i++)
485 printf(" %18.12g", fa.farg[i]);
486 printf("\n");
487 freefargs(&fa);
488 return(0);
489 }
490
491
492 alias(fin) /* transfer alias */
493 FILE *fin;
494 {
495 char aliasnm[MAXSTR];
496
497 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
498 return(-1);
499 printf("\t%s\n", aliasnm);
500 return(0);
501 }
502
503
504 m_glow(fin) /* transform arguments for proximity light */
505 FILE *fin;
506 {
507 FUNARGS fa;
508
509 if (readfargs(&fa, fin) != 1)
510 return(-1);
511 if (fa.nsargs != 0 || fa.nfargs != 4)
512 return(-1);
513 printf("0\n0\n4");
514 printf(" %18.12g %18.12g %18.12g",
515 fa.farg[0], fa.farg[1], fa.farg[2]);
516 printf(" %18.12g\n", fa.farg[3] * tot.sca);
517 freefargs(&fa);
518 return(0);
519 }
520
521
522 m_spot(fin) /* transform arguments for spotlight */
523 FILE *fin;
524 {
525 FVECT v;
526 FUNARGS fa;
527
528 if (readfargs(&fa, fin) != 1)
529 return(-1);
530 if (fa.nsargs != 0 || fa.nfargs != 7)
531 return(-1);
532 printf("0\n0\n7");
533 printf(" %18.12g %18.12g %18.12g %18.12g\n",
534 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
535 multv3(v, fa.farg+4, tot.xfm);
536 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
537 freefargs(&fa);
538 return(0);
539 }
540
541
542 m_mist(fin) /* transform arguments for mist */
543 FILE *fin;
544 {
545 FUNARGS fa;
546 int i;
547
548 if (readfargs(&fa, fin) != 1)
549 return(-1);
550 if (fa.nfargs > 7)
551 return(-1);
552 printf("%d", fa.nsargs);
553 if (idprefix == NULL)
554 for (i = 0; i < fa.nsargs; i++)
555 printf(" %s", fa.sarg[i]);
556 else
557 for (i = 0; i < fa.nsargs; i++) {
558 char sname[256], *sp;
559 register char *cp1, *cp2 = sname;
560 /* add idprefix */
561 for (sp = fa.sarg[i]; *sp; sp = cp1) {
562 for (cp1 = idprefix; *cp1; )
563 *cp2++ = *cp1++;
564 *cp2++ = '.';
565 for (cp1 = sp; *cp1 &&
566 (*cp2++ = *cp1++) != '>'; )
567 ;
568 }
569 *cp2 = '\0';
570 printf(" %s", sname);
571 }
572 printf("\n0\n%d", fa.nfargs);
573 if (fa.nfargs > 2)
574 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
575 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
576 for (i = 3; i < fa.nfargs; i++)
577 printf(" %12.6g", fa.farg[i]);
578 printf("\n");
579 freefargs(&fa);
580 return(0);
581 }
582
583
584 m_dielectric(fin) /* transform arguments for dielectric */
585 FILE *fin;
586 {
587 FUNARGS fa;
588
589 if (readfargs(&fa, fin) != 1)
590 return(-1);
591 if (fa.nsargs != 0 || fa.nfargs != 5)
592 return(-1);
593 printf("0\n0\n5");
594 printf(" %12.6g %12.6g %12.6g",
595 pow(fa.farg[0], 1.0/tot.sca),
596 pow(fa.farg[1], 1.0/tot.sca),
597 pow(fa.farg[2], 1.0/tot.sca));
598 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
599 freefargs(&fa);
600 return(0);
601 }
602
603
604 m_interface(fin) /* transform arguments for interface */
605 FILE *fin;
606 {
607 FUNARGS fa;
608
609 if (readfargs(&fa, fin) != 1)
610 return(-1);
611 if (fa.nsargs != 0 || fa.nfargs != 8)
612 return(-1);
613 printf("0\n0\n8\n");
614 printf("%12.6g %12.6g %12.6g",
615 pow(fa.farg[0], 1.0/tot.sca),
616 pow(fa.farg[1], 1.0/tot.sca),
617 pow(fa.farg[2], 1.0/tot.sca));
618 printf(" %12.6g\n", fa.farg[3]);
619 printf("%12.6g %12.6g %12.6g",
620 pow(fa.farg[4], 1.0/tot.sca),
621 pow(fa.farg[5], 1.0/tot.sca),
622 pow(fa.farg[6], 1.0/tot.sca));
623 printf(" %12.6g\n", fa.farg[7]);
624 freefargs(&fa);
625 return(0);
626 }
627
628
629 text(fin) /* transform text arguments */
630 FILE *fin;
631 {
632 int i;
633 FVECT v;
634 FUNARGS fa;
635
636 if (readfargs(&fa, fin) != 1)
637 return(-1);
638 if (fa.nfargs < 9)
639 return(-1);
640 /* string arguments */
641 printf("%d", fa.nsargs);
642 for (i = 0; i < fa.nsargs; i++) {
643 fputc(' ', stdout);
644 fputword(fa.sarg[i], stdout);
645 }
646 printf("\n0\n%d\n", fa.nfargs);
647 /* anchor point */
648 multp3(v, fa.farg, tot.xfm);
649 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
650 /* right vector */
651 multv3(v, fa.farg+3, tot.xfm);
652 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
653 /* down vector */
654 multv3(v, fa.farg+6, tot.xfm);
655 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
656 /* remaining arguments */
657 for (i = 9; i < fa.nfargs; i++) {
658 if (i%3 == 0)
659 putchar('\n');
660 printf(" %18.12g", fa.farg[i]);
661 }
662 putchar('\n');
663 freefargs(&fa);
664 return(0);
665 }
666
667
668 o_source(fin) /* transform source arguments */
669 FILE *fin;
670 {
671 FVECT dv;
672 FUNARGS fa;
673
674 if (readfargs(&fa, fin) != 1)
675 return(-1);
676 if (fa.nsargs != 0 || fa.nfargs != 4)
677 return(-1);
678 /* transform direction vector */
679 multv3(dv, fa.farg, tot.xfm);
680 /* output */
681 printf("0\n0\n4");
682 printf(" %18.12g %18.12g %18.12g %18.12g\n",
683 dv[0], dv[1], dv[2], fa.farg[3]);
684 freefargs(&fa);
685 return(0);
686 }
687
688
689 o_sphere(fin) /* transform sphere arguments */
690 FILE *fin;
691 {
692 FVECT cent;
693 double rad;
694 FUNARGS fa;
695
696 if (readfargs(&fa, fin) != 1)
697 return(-1);
698 if (fa.nsargs != 0 || fa.nfargs != 4)
699 return(-1);
700
701 multp3(cent, fa.farg, tot.xfm); /* transform center */
702
703 rad = fa.farg[3] * tot.sca; /* scale radius */
704
705 printf("0\n0\n4");
706 printf(" %18.12g %18.12g %18.12g %18.12g\n",
707 cent[0], cent[1], cent[2], rad);
708 freefargs(&fa);
709 return(0);
710 }
711
712
713 o_face(fin) /* transform face arguments */
714 FILE *fin;
715 {
716 FVECT p;
717 register int i;
718 FUNARGS fa;
719
720 if (readfargs(&fa, fin) != 1)
721 return(-1);
722 if (fa.nsargs != 0 || fa.nfargs % 3)
723 return(-1);
724
725 printf("0\n0\n%d\n", fa.nfargs);
726
727 for (i = 0; i < fa.nfargs; i += 3) {
728 if (reverse)
729 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
730 else
731 multp3(p, fa.farg+i, tot.xfm);
732 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
733 }
734 freefargs(&fa);
735 return(0);
736 }
737
738
739 o_cone(fin) /* transform cone and cup arguments */
740 FILE *fin;
741 {
742 FVECT p0, p1;
743 double r0, r1;
744 FUNARGS fa;
745
746 if (readfargs(&fa, fin) != 1)
747 return(-1);
748 if (fa.nsargs != 0 || fa.nfargs != 8)
749 return(-1);
750
751 printf("0\n0\n8\n");
752
753 multp3(p0, fa.farg, tot.xfm);
754 multp3(p1, fa.farg+3, tot.xfm);
755 r0 = fa.farg[6] * tot.sca;
756 r1 = fa.farg[7] * tot.sca;
757 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
758 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
759 printf(" %18.12g %18.12g\n", r0, r1);
760
761 freefargs(&fa);
762 return(0);
763 }
764
765
766 o_cylinder(fin) /* transform cylinder and tube arguments */
767 FILE *fin;
768 {
769 FVECT p0, p1;
770 double rad;
771 FUNARGS fa;
772
773 if (readfargs(&fa, fin) != 1)
774 return(-1);
775 if (fa.nsargs != 0 || fa.nfargs != 7)
776 return(-1);
777
778 printf("0\n0\n7\n");
779
780 multp3(p0, fa.farg, tot.xfm);
781 multp3(p1, fa.farg+3, tot.xfm);
782 rad = fa.farg[6] * tot.sca;
783 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
784 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
785 printf(" %18.12g\n", rad);
786 freefargs(&fa);
787 return(0);
788 }
789
790
791 o_ring(fin) /* transform ring arguments */
792 FILE *fin;
793 {
794 FVECT p0, pd;
795 double r0, r1;
796 FUNARGS fa;
797
798 if (readfargs(&fa, fin) != 1)
799 return(-1);
800 if (fa.nsargs != 0 || fa.nfargs != 8)
801 return(-1);
802
803 printf("0\n0\n8\n");
804
805 multp3(p0, fa.farg, tot.xfm);
806 multv3(pd, fa.farg+3, tot.xfm);
807 if (invert) {
808 pd[0] = -pd[0];
809 pd[1] = -pd[1];
810 pd[2] = -pd[2];
811 }
812 r0 = fa.farg[6] * tot.sca;
813 r1 = fa.farg[7] * tot.sca;
814 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
815 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
816 printf(" %18.12g %18.12g\n", r0, r1);
817 freefargs(&fa);
818 return(0);
819 }
820
821
822 initotypes() /* initialize ofun[] array */
823 {
824 register int i;
825
826 if (ofun[OBJ_SOURCE].funp == o_source)
827 return; /* done already */
828 /* functions get new transform */
829 for (i = 0; i < NUMOTYPE; i++)
830 if (hasfunc(i))
831 ofun[i].funp = addxform;
832 /* special cases */
833 ofun[OBJ_SOURCE].funp = o_source;
834 ofun[OBJ_SPHERE].funp =
835 ofun[OBJ_BUBBLE].funp = o_sphere;
836 ofun[OBJ_FACE].funp = o_face;
837 ofun[OBJ_CONE].funp =
838 ofun[OBJ_CUP].funp = o_cone;
839 ofun[OBJ_CYLINDER].funp =
840 ofun[OBJ_TUBE].funp = o_cylinder;
841 ofun[OBJ_RING].funp = o_ring;
842 ofun[OBJ_INSTANCE].funp = addxform;
843 ofun[MAT_GLOW].funp = m_glow;
844 ofun[MAT_SPOT].funp = m_spot;
845 ofun[MAT_DIELECTRIC].funp = m_dielectric;
846 ofun[MAT_INTERFACE].funp = m_interface;
847 ofun[MAT_MIST].funp = m_mist;
848 ofun[PAT_CTEXT].funp =
849 ofun[PAT_BTEXT].funp =
850 ofun[MIX_TEXT].funp = text;
851 ofun[MOD_ALIAS].funp = alias;
852 /* surface inverses */
853 tinvers[OBJ_FACE] = OBJ_FACE;
854 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
855 tinvers[OBJ_CONE] = OBJ_CUP;
856 tinvers[OBJ_CUP] = OBJ_CONE;
857 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
858 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
859 tinvers[OBJ_RING] = OBJ_RING;
860 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
861 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
862 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
863 }
864
865
866 #ifdef OLDXFORM
867 openmain(fname)
868 char *fname;
869 {
870 if (fname == NULL) {
871 strcpy(mainfn, "standard input");
872 mainfp = stdin;
873 return;
874 }
875 if (mainfp != NULL) {
876 if (!strcmp(fname, mainfn)) {
877 rewind(mainfp);
878 return;
879 }
880 fclose(mainfp);
881 }
882 if ((mainfp = fopen(fname, "r")) == NULL) {
883 fprintf(stderr, "%s: cannot open file \"%s\"\n",
884 progname, fname);
885 exit(1);
886 }
887 strcpy(mainfn, fname);
888 }
889 #else
890 openmain(iname) /* open input, changing directory for file */
891 char *iname;
892 {
893 static char origdir[PATH_MAX];
894 static char curfn[PATH_MAX];
895 static int diffdir;
896 register char *fpath;
897
898 if (iname == NULL) { /* standard input */
899 if (mainfp == NULL) {
900 register int c;
901 strcpy(mainfn, "standard input");
902 if (nrept <= 1) {
903 mainfp = stdin;
904 return; /* just read once */
905 }
906 /* else copy */
907 if ((mainfp = tmpfile()) == NULL) {
908 fprintf(stderr,
909 "%s: cannot create temporary file\n",
910 progname);
911 exit(1);
912 }
913 while ((c = getc(stdin)) != EOF)
914 putc(c, mainfp);
915 }
916 rewind(mainfp); /* rewind copy */
917 return;
918 }
919 if (mainfp == NULL) { /* first call, initialize */
920 getcwd(origdir, sizeof(origdir));
921 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
922 rewind(mainfp);
923 return;
924 } else { /* else close old stream */
925 fclose(mainfp);
926 mainfp = NULL;
927 if (diffdir) { /* return to our directory */
928 chdir(origdir);
929 diffdir = 0;
930 }
931 }
932 strcpy(curfn, iname); /* remember input name */
933 /* get full path for file */
934 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
935 fprintf(stderr, "%s: cannot find file \"%s\"\n",
936 progname, iname);
937 exit(1);
938 }
939 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
940 fpath += 2;
941 /* record path name */
942 strcpy(mainfn, fpath);
943 if (expand) { /* change to local directory */
944 register char *cp = fpath + strlen(fpath); /* get dir. */
945 while (cp > fpath) {
946 cp--;
947 if (ISDIRSEP(*cp)) {
948 if (cp == fpath)
949 cp++; /* root special case */
950 break;
951 }
952 }
953 *cp = '\0';
954 if (fpath[0]) { /* change to new directory? */
955 if (chdir(fpath) < 0) {
956 fprintf(stderr,
957 "%s: cannot change directory to \"%s\"\n",
958 progname, fpath);
959 exit(1);
960 }
961 diffdir++;
962 }
963 /* get final path component */
964 for (fpath = iname+strlen(iname);
965 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
966 ;
967 }
968 /* finally, open the file */
969 if ((mainfp = fopen(fpath, "r")) == NULL) {
970 fprintf(stderr, "%s: cannot open file \"%s\"\n",
971 progname, mainfn);
972 exit(1);
973 }
974 }
975 #endif
