| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* xform.c - program to transform object files.
| 9 |
* Transformations must preserve aspect ratio.
| 10 |
| 11 |
* 10/19/85
| 12 |
* 11/6/86 Finally added error checking!
| 13 |
| 14 |
| 15 |
#include <stdio.h>
| 16 |
| 17 |
#include <ctype.h>
| 18 |
| 19 |
| 20 |
typedef struct {
| 21 |
char *funame; /* function name */
| 22 |
int (*funp)(); /* pointer to function */
| 23 |
} FUN;
| 24 |
| 25 |
int xac; /* global xform argument count */
| 26 |
char **xav; /* global xform argument pointer */
| 27 |
int xfa; /* start of xf arguments */
| 28 |
| 29 |
double totxform[4][4]; /* total transformation matrix */
| 30 |
double totscale; /* total scale factor */
| 31 |
int reverse; /* boolean true if scene inverted */
| 32 |
| 33 |
int expand = 0; /* boolean true to expand commands */
| 34 |
| 35 |
char *idprefix = NULL; /* prefix for object identifiers */
| 36 |
| 37 |
extern int o_source();
| 38 |
extern int o_sphere();
| 39 |
extern int o_face();
| 40 |
extern int o_cone();
| 41 |
extern int o_cylinder();
| 42 |
extern int o_ring();
| 43 |
extern int m_glow();
| 44 |
extern int m_spot();
| 45 |
extern int m_dielectric();
| 46 |
extern int m_interface();
| 47 |
extern int text();
| 48 |
extern int alias();
| 49 |
extern int passargs();
| 50 |
extern int addxform();
| 51 |
| 52 |
FUN ofun[] = {
| 53 |
{ "source", o_source },
| 54 |
{ "sphere", o_sphere },
| 55 |
{ "bubble", o_sphere },
| 56 |
{ "polygon", o_face },
| 57 |
{ "cone", o_cone },
| 58 |
{ "cup", o_cone },
| 59 |
{ "cylinder", o_cylinder },
| 60 |
{ "tube", o_cylinder },
| 61 |
{ "ring", o_ring },
| 62 |
{ "instance", addxform },
| 63 |
{ "alias", alias },
| 64 |
{ "antimatter", passargs },
| 65 |
{ "glow", m_glow },
| 66 |
{ "spotlight", m_spot },
| 67 |
{ "dielectric", m_dielectric },
| 68 |
{ "interface", m_interface },
| 69 |
{ "colortext", text },
| 70 |
{ "brighttext", text },
| 71 |
{ "texfunc", addxform },
| 72 |
{ "texdata", addxform },
| 73 |
{ "colorfunc", addxform },
| 74 |
{ "brightfunc", addxform },
| 75 |
{ "colorpict", addxform },
| 76 |
{ "colordata", addxform },
| 77 |
{ "brightdata", addxform },
| 78 |
{ "mixfunc", addxform },
| 79 |
{ "mixdata", addxform },
| 80 |
{ "mixtext", text },
| 81 |
{ "light", passargs },
| 82 |
{ "illum", passargs },
| 83 |
{ "plastic", passargs },
| 84 |
{ "metal", passargs },
| 85 |
{ "trans", passargs },
| 86 |
{ "glass", passargs },
| 87 |
{ 0 } /* terminator */
| 88 |
| 89 |
| 90 |
#define issurface(t) ((t)<=9)
| 91 |
| 92 |
typedef struct {
| 93 |
short nsargs; /* # of string arguments */
| 94 |
char **sarg; /* string arguments */
| 95 |
short niargs; /* # of integer arguments */
| 96 |
int *iarg; /* integer arguments */
| 97 |
short nfargs; /* # of float arguments */
| 98 |
double *farg; /* float arguments */
| 99 |
} FUNARGS;
| 100 |
| 101 |
#define MAXSTR 512 /* maximum string length */
| 102 |
| 103 |
FUNARGS *getfargs();
| 104 |
char *malloc();
| 105 |
| 106 |
#define progname (xav[0])
| 107 |
| 108 |
| 109 |
main(argc, argv) /* get transform options and transform file */
| 110 |
int argc;
| 111 |
char *argv[];
| 112 |
| 113 |
FILE *fopen();
| 114 |
FILE *fp;
| 115 |
int a;
| 116 |
| 117 |
xav = argv;
| 118 |
| 119 |
for (a = 1; a < argc; a++) {
| 120 |
if (argv[a][0] == '-')
| 121 |
switch (argv[a][1]) {
| 122 |
case 'n':
| 123 |
idprefix = argv[++a];
| 124 |
continue;
| 125 |
case 'e':
| 126 |
expand = 1;
| 127 |
continue;
| 128 |
| 129 |
break;
| 130 |
| 131 |
| 132 |
xfa = a;
| 133 |
| 134 |
totscale = 1.0;
| 135 |
setident4(totxform);
| 136 |
| 137 |
a += xf(totxform, &totscale, argc-a, argv+a);
| 138 |
| 139 |
if (reverse = totscale < 0.0)
| 140 |
totscale = -totscale;
| 141 |
| 142 |
xac = a;
| 143 |
| 144 |
putchar('#'); /* simple header */
| 145 |
for (a = 0; a < xac; a++)
| 146 |
printf(" %s", xav[a]);
| 147 |
putchar('\n');
| 148 |
| 149 |
if (a == argc)
| 150 |
xform("standard input", stdin);
| 151 |
else
| 152 |
for ( ; a < argc; a++) {
| 153 |
if ((fp = fopen(argv[a], "r")) == NULL) {
| 154 |
fprintf(stderr, "%s: cannot open \"%s\"\n",
| 155 |
progname, argv[a]);
| 156 |
exit(1);
| 157 |
| 158 |
xform(argv[a], fp);
| 159 |
fclose(fp);
| 160 |
| 161 |
| 162 |
exit(0);
| 163 |
| 164 |
| 165 |
| 166 |
xform(name, fin) /* transform stream by totxform */
| 167 |
char *name;
| 168 |
register FILE *fin;
| 169 |
| 170 |
register int c;
| 171 |
| 172 |
while ((c = getc(fin)) != EOF) {
| 173 |
if (isspace(c)) /* blank */
| 174 |
continue;
| 175 |
if (c == '#') { /* comment */
| 176 |
putchar(c);
| 177 |
do {
| 178 |
if ((c = getc(fin)) == EOF)
| 179 |
return;
| 180 |
putchar(c);
| 181 |
} while (c != '\n');
| 182 |
} else if (c == '!') { /* command */
| 183 |
ungetc(c, fin);
| 184 |
xfcomm(name, fin);
| 185 |
} else { /* object */
| 186 |
ungetc(c, fin);
| 187 |
xfobject(name, fin);
| 188 |
| 189 |
| 190 |
| 191 |
| 192 |
| 193 |
xfcomm(fname, fin) /* transform a command */
| 194 |
FILE *fin;
| 195 |
| 196 |
FILE *popen();
| 197 |
char *fgetline();
| 198 |
FILE *pin;
| 199 |
char buf[512];
| 200 |
int i;
| 201 |
| 202 |
fgetline(buf, sizeof(buf), fin);
| 203 |
if (expand) {
| 204 |
if ((pin = popen(buf+1, "r")) == NULL) {
| 205 |
fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
| 206 |
progname, fname, buf);
| 207 |
exit(1);
| 208 |
| 209 |
xform(buf, pin);
| 210 |
pclose(pin);
| 211 |
} else {
| 212 |
printf("\n%s | %s -e", buf, xav[0]);
| 213 |
for (i = 1; i < xac; i++)
| 214 |
printf(" %s", xav[i]);
| 215 |
putchar('\n');
| 216 |
| 217 |
| 218 |
| 219 |
| 220 |
xfobject(fname, fin) /* transform an object */
| 221 |
char *fname;
| 222 |
FILE *fin;
| 223 |
| 224 |
char stmp[MAXSTR];
| 225 |
int fn;
| 226 |
| 227 |
fscanf(fin, "%s", stmp); /* modifier */
| 228 |
printf("\n%s ", stmp);
| 229 |
fscanf(fin, "%s", stmp); /* object type */
| 230 |
if ((fn = otype(stmp)) < 0) {
| 231 |
fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
| 232 |
progname, fname, stmp);
| 233 |
exit(1);
| 234 |
| 235 |
printf("%s ", stmp);
| 236 |
fscanf(fin, "%s", stmp); /* object name */
| 237 |
if (idprefix != NULL && issurface(fn))
| 238 |
printf("%s.%s\n", idprefix, stmp);
| 239 |
else
| 240 |
printf("%s\n", stmp);
| 241 |
/* transform arguments */
| 242 |
if ((*ofun[fn].funp)(fin) < 0) {
| 243 |
fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
| 244 |
progname, fname, ofun[fn].funame, stmp);
| 245 |
exit(1);
| 246 |
| 247 |
| 248 |
| 249 |
| 250 |
passargs(fin) /* pass on arguments unchanged */
| 251 |
FILE *fin;
| 252 |
| 253 |
register int i;
| 254 |
register FUNARGS *fa;
| 255 |
| 256 |
if ((fa = getfargs(fin)) == NULL)
| 257 |
return(-1);
| 258 |
| 259 |
printf("%d", fa->nsargs);
| 260 |
for (i = 0; i < fa->nsargs; i++)
| 261 |
printf(" %s", fa->sarg[i]);
| 262 |
printf("\n");
| 263 |
| 264 |
printf("%d", fa->niargs);
| 265 |
for (i = 0; i < fa->niargs; i++)
| 266 |
printf(" %d", fa->iarg[i]);
| 267 |
printf("\n");
| 268 |
| 269 |
printf("%d", fa->nfargs);
| 270 |
for (i = 0; i < fa->nfargs; i++)
| 271 |
printf(" %18.12g", fa->farg[i]);
| 272 |
printf("\n");
| 273 |
freefargs(fa);
| 274 |
return(0);
| 275 |
| 276 |
| 277 |
| 278 |
addxform(fin) /* add xf arguments to strings */
| 279 |
FILE *fin;
| 280 |
| 281 |
register int i;
| 282 |
| 283 |
| 284 |
| 285 |
return(-1);
| 286 |
| 287 |
printf("%d", fa->nsargs + xac-xfa);
| 288 |
| 289 |
| 290 |
for (i = xfa; i < xac; i++) /* add xf arguments */
| 291 |
| 292 |
printf("\n");
| 293 |
| 294 |
| 295 |
| 296 |
| 297 |
printf("\n");
| 298 |
| 299 |
| 300 |
| 301 |
| 302 |
printf("\n");
| 303 |
freefargs(fa);
| 304 |
return(0);
| 305 |
| 306 |
| 307 |
| 308 |
int
| 309 |
otype(ofname) /* get object function number from its name */
| 310 |
register char *ofname;
| 311 |
| 312 |
register int i;
| 313 |
| 314 |
for (i = 0; ofun[i].funame != NULL; i++)
| 315 |
if (!strcmp(ofun[i].funame, ofname))
| 316 |
return(i);
| 317 |
| 318 |
return(-1); /* not found */
| 319 |
| 320 |
| 321 |
| 322 |
alias(fin) /* transfer alias */
| 323 |
FILE *fin;
| 324 |
| 325 |
char alias[MAXSTR];
| 326 |
| 327 |
if (fscanf(fin, "%s", alias) != 1)
| 328 |
return(-1);
| 329 |
printf("\t%s\n", alias);
| 330 |
return(0);
| 331 |
| 332 |
| 333 |
| 334 |
m_glow(fin) /* transform arguments for proximity light */
| 335 |
FILE *fin;
| 336 |
| 337 |
| 338 |
| 339 |
| 340 |
return(-1);
| 341 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 4)
| 342 |
return(-1);
| 343 |
printf("0\n0\n4");
| 344 |
printf(" %18.12g %18.12g %18.12g",
| 345 |
fa->farg[0], fa->farg[1], fa->farg[2]);
| 346 |
printf(" %18.12g\n", fa->farg[3] * totscale);
| 347 |
freefargs(fa);
| 348 |
return(0);
| 349 |
| 350 |
| 351 |
| 352 |
m_spot(fin) /* transform arguments for spotlight */
| 353 |
FILE *fin;
| 354 |
| 355 |
double v[3];
| 356 |
| 357 |
| 358 |
| 359 |
return(-1);
| 360 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 7)
| 361 |
return(-1);
| 362 |
printf("0\n0\n7");
| 363 |
printf(" %18.12g %18.12g %18.12g %18.12g\n",
| 364 |
fa->farg[0], fa->farg[1], fa->farg[2], fa->farg[3]);
| 365 |
multv3(v, fa->farg+4, totxform);
| 366 |
printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
| 367 |
freefargs(fa);
| 368 |
return(0);
| 369 |
| 370 |
| 371 |
| 372 |
m_dielectric(fin) /* transform arguments for dielectric */
| 373 |
FILE *fin;
| 374 |
| 375 |
double pow();
| 376 |
| 377 |
| 378 |
| 379 |
return(-1);
| 380 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 5)
| 381 |
return(-1);
| 382 |
printf("0\n0\n5");
| 383 |
| 384 |
pow(fa->farg[0], 1.0/totscale),
| 385 |
pow(fa->farg[1], 1.0/totscale),
| 386 |
pow(fa->farg[2], 1.0/totscale));
| 387 |
printf(" %18.12g %18.12g\n", fa->farg[3], fa->farg[4]);
| 388 |
freefargs(fa);
| 389 |
return(0);
| 390 |
| 391 |
| 392 |
| 393 |
m_interface(fin) /* transform arguments for interface */
| 394 |
FILE *fin;
| 395 |
| 396 |
double pow();
| 397 |
| 398 |
| 399 |
| 400 |
return(-1);
| 401 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 8)
| 402 |
return(-1);
| 403 |
printf("0\n0\n8\n");
| 404 |
printf("%18.12g %18.12g %18.12g",
| 405 |
| 406 |
| 407 |
| 408 |
printf(" %18.12g\n", fa->farg[3]);
| 409 |
| 410 |
pow(fa->farg[4], 1.0/totscale),
| 411 |
pow(fa->farg[5], 1.0/totscale),
| 412 |
pow(fa->farg[6], 1.0/totscale));
| 413 |
printf(" %18.12g\n", fa->farg[7]);
| 414 |
freefargs(fa);
| 415 |
return(0);
| 416 |
| 417 |
| 418 |
| 419 |
text(fin) /* transform text arguments */
| 420 |
FILE *fin;
| 421 |
| 422 |
int i;
| 423 |
double v[3];
| 424 |
| 425 |
| 426 |
| 427 |
return(-1);
| 428 |
if (fa->niargs != 0 || (fa->nfargs != 9 &&
| 429 |
fa->nfargs != 11 && fa->nfargs != 15))
| 430 |
return(-1);
| 431 |
| 432 |
| 433 |
| 434 |
| 435 |
printf("\n0\n%d\n", fa->nfargs);
| 436 |
/* anchor point */
| 437 |
multp3(v, fa->farg, totxform);
| 438 |
printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
| 439 |
/* right vector */
| 440 |
multv3(v, fa->farg+3, totxform);
| 441 |
| 442 |
/* down vector */
| 443 |
multv3(v, fa->farg+6, totxform);
| 444 |
| 445 |
/* forground and background */
| 446 |
if (fa->nfargs == 11)
| 447 |
printf(" %18.12g %18.12g\n", fa->farg[9], fa->farg[10]);
| 448 |
else if (fa->nfargs == 15) {
| 449 |
| 450 |
fa->farg[9], fa->farg[10], fa->farg[11]);
| 451 |
| 452 |
fa->farg[12], fa->farg[13], fa->farg[14]);
| 453 |
| 454 |
freefargs(fa);
| 455 |
return(0);
| 456 |
| 457 |
| 458 |
| 459 |
o_source(fin) /* transform source arguments */
| 460 |
FILE *fin;
| 461 |
| 462 |
double dv[3];
| 463 |
| 464 |
| 465 |
| 466 |
return(-1);
| 467 |
| 468 |
return(-1);
| 469 |
/* transform direction vector */
| 470 |
multv3(dv, fa->farg, totxform);
| 471 |
/* output */
| 472 |
printf("0\n0\n4");
| 473 |
| 474 |
dv[0], dv[1], dv[2], fa->farg[3]);
| 475 |
freefargs(fa);
| 476 |
return(0);
| 477 |
| 478 |
| 479 |
| 480 |
o_sphere(fin) /* transform sphere arguments */
| 481 |
FILE *fin;
| 482 |
| 483 |
double cent[3], rad;
| 484 |
| 485 |
| 486 |
| 487 |
return(-1);
| 488 |
| 489 |
return(-1);
| 490 |
| 491 |
multp3(cent, fa->farg, totxform); /* transform center */
| 492 |
| 493 |
rad = fa->farg[3] * totscale; /* scale radius */
| 494 |
| 495 |
printf("0\n0\n4");
| 496 |
| 497 |
cent[0], cent[1], cent[2], rad);
| 498 |
freefargs(fa);
| 499 |
return(0);
| 500 |
| 501 |
| 502 |
| 503 |
o_face(fin) /* transform face arguments */
| 504 |
FILE *fin;
| 505 |
| 506 |
double p[3];
| 507 |
register int i;
| 508 |
| 509 |
| 510 |
| 511 |
return(-1);
| 512 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs % 3)
| 513 |
return(-1);
| 514 |
| 515 |
printf("0\n0\n%d\n", fa->nfargs);
| 516 |
| 517 |
for (i = 0; i < fa->nfargs; i += 3) {
| 518 |
if (reverse)
| 519 |
multp3(p, fa->farg+(fa->nfargs-i-3), totxform);
| 520 |
else
| 521 |
multp3(p, fa->farg+i, totxform);
| 522 |
printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
| 523 |
| 524 |
freefargs(fa);
| 525 |
return(0);
| 526 |
| 527 |
| 528 |
| 529 |
o_cone(fin) /* transform cone and cup arguments */
| 530 |
FILE *fin;
| 531 |
| 532 |
double p0[3], p1[3], r0, r1;
| 533 |
| 534 |
| 535 |
| 536 |
return(-1);
| 537 |
| 538 |
return(-1);
| 539 |
| 540 |
| 541 |
| 542 |
multp3(p0, fa->farg, totxform);
| 543 |
multp3(p1, fa->farg+3, totxform);
| 544 |
r0 = fa->farg[6] * totscale;
| 545 |
r1 = fa->farg[7] * totscale;
| 546 |
printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
| 547 |
printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
| 548 |
printf(" %18.12g %18.12g\n", r0, r1);
| 549 |
| 550 |
freefargs(fa);
| 551 |
return(0);
| 552 |
| 553 |
| 554 |
| 555 |
o_cylinder(fin) /* transform cylinder and tube arguments */
| 556 |
FILE *fin;
| 557 |
| 558 |
double p0[3], p1[3], rad;
| 559 |
| 560 |
| 561 |
| 562 |
return(-1);
| 563 |
| 564 |
return(-1);
| 565 |
| 566 |
printf("0\n0\n7\n");
| 567 |
| 568 |
| 569 |
| 570 |
rad = fa->farg[6] * totscale;
| 571 |
| 572 |
| 573 |
printf(" %18.12g\n", rad);
| 574 |
freefargs(fa);
| 575 |
return(0);
| 576 |
| 577 |
| 578 |
| 579 |
o_ring(fin) /* transform ring arguments */
| 580 |
FILE *fin;
| 581 |
| 582 |
double p0[3], pd[3], r0, r1;
| 583 |
| 584 |
| 585 |
| 586 |
return(-1);
| 587 |
| 588 |
return(-1);
| 589 |
| 590 |
| 591 |
| 592 |
| 593 |
multv3(pd, fa->farg+3, totxform);
| 594 |
| 595 |
| 596 |
| 597 |
printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
| 598 |
| 599 |
freefargs(fa);
| 600 |
return(0);
| 601 |
| 602 |
| 603 |
| 604 |
FUNARGS *
| 605 |
getfargs(fp) /* get function arguments from stream */
| 606 |
FILE *fp;
| 607 |
| 608 |
char *strcpy();
| 609 |
char sbuf[MAXSTR];
| 610 |
int n;
| 611 |
| 612 |
register int i;
| 613 |
| 614 |
if ((fa = (FUNARGS *)malloc((unsigned)sizeof(FUNARGS))) == NULL)
| 615 |
goto memerr;
| 616 |
if (fscanf(fp, "%d", &n) != 1 || n < 0)
| 617 |
return(NULL);
| 618 |
if (fa->nsargs = n) {
| 619 |
fa->sarg = (char **)malloc((unsigned)fa->nsargs*sizeof(char *));
| 620 |
if (fa->sarg == NULL)
| 621 |
goto memerr;
| 622 |
for (i = 0; i < fa->nsargs; i++) {
| 623 |
if (fscanf(fp, "%s", sbuf) != 1)
| 624 |
return(NULL);
| 625 |
if ((fa->sarg[i] = malloc((unsigned)strlen(sbuf)+1)) == NULL)
| 626 |
goto memerr;
| 627 |
strcpy(fa->sarg[i], sbuf);
| 628 |
| 629 |
} else
| 630 |
fa->sarg = NULL;
| 631 |
| 632 |
return(NULL);
| 633 |
if (fa->niargs = n) {
| 634 |
fa->iarg = (int *)malloc((unsigned)fa->niargs*sizeof(int));
| 635 |
if (fa->iarg == NULL)
| 636 |
goto memerr;
| 637 |
| 638 |
if (fscanf(fp, "%d", &fa->iarg[i]) != 1)
| 639 |
return(NULL);
| 640 |
} else
| 641 |
fa->iarg = NULL;
| 642 |
| 643 |
return(NULL);
| 644 |
if (fa->nfargs = n) {
| 645 |
fa->farg = (double *)malloc((unsigned)fa->nfargs*sizeof(double));
| 646 |
if (fa->farg == NULL)
| 647 |
goto memerr;
| 648 |
| 649 |
if (fscanf(fp, "%lf", &fa->farg[i]) != 1)
| 650 |
return(NULL);
| 651 |
} else
| 652 |
fa->farg = NULL;
| 653 |
return(fa);
| 654 |
memerr:
| 655 |
fprintf(stderr, "%s: out of memory in getfargs\n", progname);
| 656 |
exit(1);
| 657 |
| 658 |
| 659 |
| 660 |
freefargs(fa) /* free memory associated with fa */
| 661 |
| 662 |
| 663 |
register int i;
| 664 |
| 665 |
| 666 |
free(fa->sarg[i]);
| 667 |
if (fa->nsargs)
| 668 |
free(fa->sarg);
| 669 |
if (fa->niargs)
| 670 |
free(fa->iarg);
| 671 |
if (fa->nfargs)
| 672 |
free(fa->farg);
| 673 |
free(fa);
| 674 |
