root/radiance/ray/src/gen/xform.c
Revision: 2.22
Committed: Fri Jun 4 17:24:56 1999 UTC (25 years ago) by gwlarson
added -e option after appended xform command for -c option
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xform.c - program to transform object files.
9 * Transformations must preserve aspect ratio.
10 *
11 * 10/19/85
12 * 11/6/86 Finally added error checking!
13 */
14
15 #include "standard.h"
16
17 #include "paths.h"
18
19 #include <ctype.h>
20
21 #include "object.h"
22
23 #include "otypes.h"
24
25 int xac; /* global xform argument count */
26 char **xav; /* global xform argument pointer */
27 int xfa; /* start of xf arguments */
28
29 XF tot; /* total transformation */
30 int reverse; /* boolean true if scene mirrored */
31
32 int invert; /* boolean true to invert surfaces */
33
34 int expand; /* boolean true to expand commands */
35
36 char *newmod; /* new modifier for surfaces */
37
38 char *idprefix; /* prefix for object identifiers */
39
40 #define ALIAS NUMOTYPE /* put alias at end of array */
41
42 #define NUMTYPES (NUMOTYPE+1) /* total number of object types */
43
44 FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */
45
46 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
47
48 int nrept = 1; /* number of array repetitions */
49
50 int stdinused = 0; /* stdin has been used by -f option? */
51
52 extern char *malloc(), *fgets(), *fgetword();
53
54 char mainfn[MAXPATH]; /* main file name */
55 FILE *mainfp = NULL; /* main file pointer */
56
57 #define progname (xav[0])
58
59
60 main(argc, argv) /* get transform options and transform file */
61 int argc;
62 char *argv[];
63 {
64 int mal_prefix = 0;
65 char *fname;
66 int a;
67 /* check for argument list file */
68 for (a = 1; a < argc; a++)
69 if (!strcmp(argv[a], "-f"))
70 return(doargf(argc, argv, a));
71 /* check for regular array */
72 for (a = 1; a < argc; a++)
73 if (!strcmp(argv[a], "-a"))
74 return(doarray(argc, argv, a));
75
76 initotypes(); /* initialize */
77 invert = 0;
78 expand = 1;
79 newmod = NULL;
80 idprefix = NULL;
81
82 for (a = 1; a < argc; a++) {
83 if (argv[a][0] == '-')
84 switch (argv[a][1]) {
85 case 'm':
86 if (argv[a][2] | a+1 >= argc)
87 break;
88 a++;
89 if (newmod == NULL)
90 newmod = argv[a];
91 continue;
92 case 'n':
93 if (argv[a][2] | a+1 >= argc)
94 break;
95 a++;
96 if (idprefix == NULL)
97 idprefix = argv[a];
98 else {
99 register char *newp;
100 newp = (char *)malloc(strlen(idprefix)+
101 strlen(argv[a])+2);
102 if (newp == NULL)
103 exit(2);
104 sprintf(newp, "%s.%s",
105 idprefix, argv[a]);
106 if (mal_prefix++)
107 free((char *)idprefix);
108 idprefix = newp;
109 }
110 continue;
111 case 'c':
112 if (argv[a][2])
113 break;
114 expand = 0;
115 continue;
116 case 'e':
117 if (argv[a][2])
118 break;
119 expand = 1;
120 continue;
121 case 'I':
122 if (argv[a][2])
123 break;
124 invert = !invert;
125 continue;
126 }
127 break;
128 }
129
130 xav = argv;
131 xfa = a;
132
133 a += xf(&tot, argc-a, argv+a);
134
135 if (reverse = tot.sca < 0.0)
136 tot.sca = -tot.sca;
137 if (invert)
138 reverse = !reverse;
139
140 if (a < argc && argv[a][0] == '-') {
141 fprintf(stderr, "%s: command line error at '%s'\n",
142 argv[0], argv[a]);
143 exit(1);
144 }
145
146 xac = a;
147 /* simple header */
148 putchar('#');
149 for (a = 0; a < xac; a++)
150 printf(" %s", xav[a]);
151 putchar('\n');
152 /* transform input */
153 if (xac == argc) {
154 if (stdinused) {
155 fprintf(stderr, "%s: cannot use stdin more than once\n",
156 argv[0]);
157 exit(1);
158 }
159 openmain(NULL);
160 xform(mainfn, mainfp);
161 } else
162 for (a = xac; a < argc; a++) {
163 openmain(argv[a]);
164 xform(mainfn, mainfp);
165 }
166
167 if (mal_prefix)
168 free((char *)idprefix);
169 return(0);
170 }
171
172
173 doargf(ac, av, fi) /* take argument list from file */
174 char **av;
175 int ac, fi;
176 {
177 char *newav[256], **avp;
178 char argbuf[1024];
179 char newid[128];
180 char *oldid;
181 register char *cp;
182 FILE *argfp;
183 int n, i, k, newac, err;
184
185 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
186 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
187 exit(1);
188 }
189 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
190 if (stdinused++) {
191 fprintf(stderr, "%s: cannot use stdin more than once\n",
192 av[0]);
193 exit(1);
194 }
195 argfp = stdin;
196 n = 100; /* we just don't know! */
197 } else {
198 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
199 fprintf(stderr, "%s: cannot open argument file \"%s\"\n",
200 av[0], av[fi+1]);
201 exit(1);
202 }
203 n = 0; /* count number of lines in file */
204 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL)
205 n += argbuf[0] != '\n' & argbuf[0] != '#';
206 if (!n) {
207 fprintf(stderr, "%s: empty argument file \"%s\"\n",
208 av[0], av[fi+1]);
209 exit(1);
210 }
211 nrept *= n;
212 rewind(argfp);
213 }
214 err = 0; k = 0; /* read each arg list and call main */
215 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL) {
216 if (argbuf[0] == '\n' | argbuf[0] == '#')
217 continue;
218 avp = newav+2;
219 avp[0] = av[0];
220 for (i = 1; i < fi; i++)
221 avp[i] = av[i];
222 newac = i;
223 cp = argbuf; /* parse new words */
224 if (*cp == '!') cp++;
225 if (!strncmp(cp, "xform ", 6)) cp += 6;
226 for ( ; ; ) {
227 while (isspace(*cp)) /* nullify spaces */
228 *cp++ = '\0';
229 if (!*cp) /* all done? */
230 break;
231 avp[newac++] = cp; /* add argument to list */
232 while (*++cp && !isspace(*cp))
233 ;
234 }
235 for (i = fi+2; i < ac; i++)
236 avp[newac++] = av[i];
237 avp[newac] = NULL;
238 oldid = NULL;
239 for (i = 2; i < newac; i++)
240 if (!strcmp(avp[i-1], "-n")) {
241 oldid = avp[i];
242 avp[i] = newid;
243 break;
244 }
245 if (oldid == NULL) {
246 newav[0] = av[0];
247 newav[1] = "-n";
248 newav[2] = newid;
249 avp = newav;
250 newac += 2;
251 }
252 if (oldid == NULL)
253 sprintf(newid, "i%d", k);
254 else
255 sprintf(newid, "%s.%d", oldid, k);
256 err |= main(newac, avp);
257 k++;
258 }
259 fclose(argfp);
260 return(err);
261 }
262
263
264 doarray(ac, av, ai) /* make array */
265 char **av;
266 int ac, ai;
267 {
268 char *newav[256], **avp;
269 char newid[128], repts[32];
270 char *oldid = NULL;
271 int n, i, err;
272
273 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
274 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
275 exit(1);
276 }
277 nrept *= n;
278 avp = newav+2;
279 avp[0] = av[0];
280 for (i = 1; i < ac; i++)
281 if (!strcmp(av[i-1], "-n")) {
282 oldid = av[i];
283 avp[i] = newid;
284 } else
285 avp[i] = av[i];
286 avp[ai] = "-i";
287 avp[ai+1] = repts;
288 avp[i] = NULL;
289 if (oldid == NULL) {
290 newav[0] = av[0];
291 newav[1] = "-n";
292 newav[2] = newid;
293 avp = newav;
294 ac += 2;
295 }
296 err = 0;
297 for (i = 0; i < n; i++) {
298 if (oldid == NULL)
299 sprintf(newid, "a%d", i);
300 else
301 sprintf(newid, "%s.%d", oldid, i);
302 sprintf(repts, "%d", i);
303 err |= main(ac, avp);
304 }
305 return(err);
306 }
307
308
309 xform(name, fin) /* transform stream by tot.xfm */
310 char *name;
311 register FILE *fin;
312 {
313 int nobjs = 0;
314 register int c;
315
316 while ((c = getc(fin)) != EOF) {
317 if (isspace(c)) /* blank */
318 continue;
319 if (c == '#') { /* comment */
320 putchar(c);
321 do {
322 if ((c = getc(fin)) == EOF)
323 return;
324 putchar(c);
325 } while (c != '\n');
326 } else if (c == '!') { /* command */
327 ungetc(c, fin);
328 xfcomm(name, fin);
329 nobjs++;
330 } else { /* object */
331 ungetc(c, fin);
332 xfobject(name, fin);
333 nobjs++;
334 }
335 }
336 if (nobjs == 0)
337 fprintf(stderr, "%s: (%s): warning - empty file\n",
338 progname, name);
339 }
340
341
342 xfcomm(fname, fin) /* transform a command */
343 char *fname;
344 FILE *fin;
345 {
346 extern FILE *popen();
347 extern char *fgetline();
348 FILE *pin;
349 char buf[512];
350 int i;
351
352 fgetline(buf, sizeof(buf), fin);
353 if (expand) {
354 if ((pin = popen(buf+1, "r")) == NULL) {
355 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
356 progname, fname, buf);
357 exit(1);
358 }
359 xform(buf, pin);
360 pclose(pin);
361 } else {
362 printf("\n%s", buf);
363 if (xac > 1) {
364 printf(" | %s -e", xav[0]); /* expand next time */
365 for (i = 1; i < xac; i++)
366 if (i >= xfa || strcmp(xav[i], "-c"))
367 printf(" %s", xav[i]);
368 }
369 putchar('\n');
370 }
371 }
372
373
374 xfobject(fname, fin) /* transform an object */
375 char *fname;
376 FILE *fin;
377 {
378 extern char *strcpy();
379 char typ[16], nam[MAXSTR];
380 int fn;
381 /* modifier and type */
382 strcpy(typ, "EOF");
383 fgetword(nam, sizeof(nam), fin);
384 fgetword(typ, sizeof(typ), fin);
385 if ((fn = otype(typ)) < 0) {
386 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
387 progname, fname, typ);
388 exit(1);
389 }
390 if (ismodifier(fn))
391 printf("\n%s %s ", nam, typ);
392 else
393 printf("\n%s %s ", newmod != NULL ? newmod : nam,
394 invert ? ofun[tinvers[fn]].funame : typ);
395 /* object name */
396 fgetword(nam, sizeof(nam), fin);
397 if (idprefix == NULL || ismodifier(fn))
398 printf("%s\n", nam);
399 else
400 printf("%s.%s\n", idprefix, nam);
401 /* transform arguments */
402 if ((*ofun[fn].funp)(fin) < 0) {
403 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
404 progname, fname, ofun[fn].funame, nam);
405 exit(1);
406 }
407 }
408
409
410 o_default(fin) /* pass on arguments unchanged */
411 FILE *fin;
412 {
413 register int i;
414 FUNARGS fa;
415
416 if (readfargs(&fa, fin) != 1)
417 return(-1);
418 /* string arguments */
419 printf("%d", fa.nsargs);
420 for (i = 0; i < fa.nsargs; i++)
421 printf(" %s", fa.sarg[i]);
422 printf("\n");
423 #ifdef IARGS
424 /* integer arguments */
425 printf("%d", fa.niargs);
426 for (i = 0; i < fa.niargs; i++)
427 printf(" %d", fa.iarg[i]);
428 printf("\n");
429 #else
430 printf("0\n");
431 #endif
432 /* float arguments */
433 printf("%d", fa.nfargs);
434 for (i = 0; i < fa.nfargs; i++)
435 printf(" %18.12g", fa.farg[i]);
436 printf("\n");
437 freefargs(&fa);
438 return(0);
439 }
440
441
442 addxform(fin) /* add xf arguments to strings */
443 FILE *fin;
444 {
445 register int i;
446 int resetarr = 0;
447 FUNARGS fa;
448
449 if (readfargs(&fa, fin) != 1)
450 return(-1);
451 /* string arguments */
452 if (xac > xfa && strcmp(xav[xfa], "-i"))
453 resetarr = 2;
454 printf("%d", fa.nsargs + resetarr + xac-xfa);
455 for (i = 0; i < fa.nsargs; i++)
456 printf(" %s", fa.sarg[i]);
457 if (resetarr)
458 printf(" -i 1");
459 for (i = xfa; i < xac; i++) /* add xf arguments */
460 printf(" %s", xav[i]);
461 printf("\n");
462 #ifdef IARGS
463 /* integer arguments */
464 printf("%d", fa.niargs);
465 for (i = 0; i < fa.niargs; i++)
466 printf(" %d", fa.iarg[i]);
467 printf("\n");
468 #else
469 printf("0\n");
470 #endif
471 /* float arguments */
472 printf("%d", fa.nfargs);
473 for (i = 0; i < fa.nfargs; i++)
474 printf(" %18.12g", fa.farg[i]);
475 printf("\n");
476 freefargs(&fa);
477 return(0);
478 }
479
480
481 int
482 otype(ofname) /* get object function number from its name */
483 register char *ofname;
484 {
485 register int i;
486
487 for (i = 0; i < NUMTYPES; i++)
488 if (!strcmp(ofun[i].funame, ofname))
489 return(i);
490
491 return(-1); /* not found */
492 }
493
494
495 alias(fin) /* transfer alias */
496 FILE *fin;
497 {
498 char aliasnm[MAXSTR];
499
500 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
501 return(-1);
502 printf("\t%s\n", aliasnm);
503 return(0);
504 }
505
506
507 m_glow(fin) /* transform arguments for proximity light */
508 FILE *fin;
509 {
510 FUNARGS fa;
511
512 if (readfargs(&fa, fin) != 1)
513 return(-1);
514 if (fa.nsargs != 0 || fa.nfargs != 4)
515 return(-1);
516 printf("0\n0\n4");
517 printf(" %18.12g %18.12g %18.12g",
518 fa.farg[0], fa.farg[1], fa.farg[2]);
519 printf(" %18.12g\n", fa.farg[3] * tot.sca);
520 freefargs(&fa);
521 return(0);
522 }
523
524
525 m_spot(fin) /* transform arguments for spotlight */
526 FILE *fin;
527 {
528 FVECT v;
529 FUNARGS fa;
530
531 if (readfargs(&fa, fin) != 1)
532 return(-1);
533 if (fa.nsargs != 0 || fa.nfargs != 7)
534 return(-1);
535 printf("0\n0\n7");
536 printf(" %18.12g %18.12g %18.12g %18.12g\n",
537 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
538 multv3(v, fa.farg+4, tot.xfm);
539 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
540 freefargs(&fa);
541 return(0);
542 }
543
544
545 m_mist(fin) /* transform arguments for mist */
546 FILE *fin;
547 {
548 FUNARGS fa;
549 int i;
550
551 if (readfargs(&fa, fin) != 1)
552 return(-1);
553 if (fa.nfargs > 7)
554 return(-1);
555 printf("%d", fa.nsargs);
556 if (idprefix == NULL)
557 for (i = 0; i < fa.nsargs; i++)
558 printf(" %s", fa.sarg[i]);
559 else
560 for (i = 0; i < fa.nsargs; i++) {
561 char sname[256], *sp;
562 register char *cp1, *cp2 = sname;
563 /* add idprefix */
564 for (sp = fa.sarg[i]; *sp; sp = cp1) {
565 for (cp1 = idprefix; *cp1; )
566 *cp2++ = *cp1++;
567 *cp2++ = '.';
568 for (cp1 = sp; *cp1 &&
569 (*cp2++ = *cp1++) != '>'; )
570 ;
571 }
572 *cp2 = '\0';
573 printf(" %s", sname);
574 }
575 printf("\n0\n%d", fa.nfargs);
576 if (fa.nfargs > 2)
577 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
578 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
579 for (i = 3; i < fa.nfargs; i++)
580 printf(" %12.6g", fa.farg[i]);
581 printf("\n");
582 freefargs(&fa);
583 return(0);
584 }
585
586
587 m_dielectric(fin) /* transform arguments for dielectric */
588 FILE *fin;
589 {
590 FUNARGS fa;
591
592 if (readfargs(&fa, fin) != 1)
593 return(-1);
594 if (fa.nsargs != 0 || fa.nfargs != 5)
595 return(-1);
596 printf("0\n0\n5");
597 printf(" %12.6g %12.6g %12.6g",
598 pow(fa.farg[0], 1.0/tot.sca),
599 pow(fa.farg[1], 1.0/tot.sca),
600 pow(fa.farg[2], 1.0/tot.sca));
601 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
602 freefargs(&fa);
603 return(0);
604 }
605
606
607 m_interface(fin) /* transform arguments for interface */
608 FILE *fin;
609 {
610 FUNARGS fa;
611
612 if (readfargs(&fa, fin) != 1)
613 return(-1);
614 if (fa.nsargs != 0 || fa.nfargs != 8)
615 return(-1);
616 printf("0\n0\n8\n");
617 printf("%12.6g %12.6g %12.6g",
618 pow(fa.farg[0], 1.0/tot.sca),
619 pow(fa.farg[1], 1.0/tot.sca),
620 pow(fa.farg[2], 1.0/tot.sca));
621 printf(" %12.6g\n", fa.farg[3]);
622 printf("%12.6g %12.6g %12.6g",
623 pow(fa.farg[4], 1.0/tot.sca),
624 pow(fa.farg[5], 1.0/tot.sca),
625 pow(fa.farg[6], 1.0/tot.sca));
626 printf(" %12.6g\n", fa.farg[7]);
627 freefargs(&fa);
628 return(0);
629 }
630
631
632 text(fin) /* transform text arguments */
633 FILE *fin;
634 {
635 int i;
636 FVECT v;
637 FUNARGS fa;
638
639 if (readfargs(&fa, fin) != 1)
640 return(-1);
641 if (fa.nfargs < 9)
642 return(-1);
643 /* string arguments */
644 printf("%d", fa.nsargs);
645 for (i = 0; i < fa.nsargs; i++)
646 printf(" %s", fa.sarg[i]);
647 printf("\n0\n%d\n", fa.nfargs);
648 /* anchor point */
649 multp3(v, fa.farg, tot.xfm);
650 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
651 /* right vector */
652 multv3(v, fa.farg+3, tot.xfm);
653 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
654 /* down vector */
655 multv3(v, fa.farg+6, tot.xfm);
656 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
657 /* remaining arguments */
658 for (i = 9; i < fa.nfargs; i++) {
659 if (i%3 == 0)
660 putchar('\n');
661 printf(" %18.12g", fa.farg[i]);
662 }
663 putchar('\n');
664 freefargs(&fa);
665 return(0);
666 }
667
668
669 o_source(fin) /* transform source arguments */
670 FILE *fin;
671 {
672 FVECT dv;
673 FUNARGS fa;
674
675 if (readfargs(&fa, fin) != 1)
676 return(-1);
677 if (fa.nsargs != 0 || fa.nfargs != 4)
678 return(-1);
679 /* transform direction vector */
680 multv3(dv, fa.farg, tot.xfm);
681 /* output */
682 printf("0\n0\n4");
683 printf(" %18.12g %18.12g %18.12g %18.12g\n",
684 dv[0], dv[1], dv[2], fa.farg[3]);
685 freefargs(&fa);
686 return(0);
687 }
688
689
690 o_sphere(fin) /* transform sphere arguments */
691 FILE *fin;
692 {
693 FVECT cent;
694 double rad;
695 FUNARGS fa;
696
697 if (readfargs(&fa, fin) != 1)
698 return(-1);
699 if (fa.nsargs != 0 || fa.nfargs != 4)
700 return(-1);
701
702 multp3(cent, fa.farg, tot.xfm); /* transform center */
703
704 rad = fa.farg[3] * tot.sca; /* scale radius */
705
706 printf("0\n0\n4");
707 printf(" %18.12g %18.12g %18.12g %18.12g\n",
708 cent[0], cent[1], cent[2], rad);
709 freefargs(&fa);
710 return(0);
711 }
712
713
714 o_face(fin) /* transform face arguments */
715 FILE *fin;
716 {
717 FVECT p;
718 register int i;
719 FUNARGS fa;
720
721 if (readfargs(&fa, fin) != 1)
722 return(-1);
723 if (fa.nsargs != 0 || fa.nfargs % 3)
724 return(-1);
725
726 printf("0\n0\n%d\n", fa.nfargs);
727
728 for (i = 0; i < fa.nfargs; i += 3) {
729 if (reverse)
730 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
731 else
732 multp3(p, fa.farg+i, tot.xfm);
733 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
734 }
735 freefargs(&fa);
736 return(0);
737 }
738
739
740 o_cone(fin) /* transform cone and cup arguments */
741 FILE *fin;
742 {
743 FVECT p0, p1;
744 double r0, r1;
745 FUNARGS fa;
746
747 if (readfargs(&fa, fin) != 1)
748 return(-1);
749 if (fa.nsargs != 0 || fa.nfargs != 8)
750 return(-1);
751
752 printf("0\n0\n8\n");
753
754 multp3(p0, fa.farg, tot.xfm);
755 multp3(p1, fa.farg+3, tot.xfm);
756 r0 = fa.farg[6] * tot.sca;
757 r1 = fa.farg[7] * tot.sca;
758 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
759 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
760 printf(" %18.12g %18.12g\n", r0, r1);
761
762 freefargs(&fa);
763 return(0);
764 }
765
766
767 o_cylinder(fin) /* transform cylinder and tube arguments */
768 FILE *fin;
769 {
770 FVECT p0, p1;
771 double rad;
772 FUNARGS fa;
773
774 if (readfargs(&fa, fin) != 1)
775 return(-1);
776 if (fa.nsargs != 0 || fa.nfargs != 7)
777 return(-1);
778
779 printf("0\n0\n7\n");
780
781 multp3(p0, fa.farg, tot.xfm);
782 multp3(p1, fa.farg+3, tot.xfm);
783 rad = fa.farg[6] * tot.sca;
784 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
785 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
786 printf(" %18.12g\n", rad);
787 freefargs(&fa);
788 return(0);
789 }
790
791
792 o_ring(fin) /* transform ring arguments */
793 FILE *fin;
794 {
795 FVECT p0, pd;
796 double r0, r1;
797 FUNARGS fa;
798
799 if (readfargs(&fa, fin) != 1)
800 return(-1);
801 if (fa.nsargs != 0 || fa.nfargs != 8)
802 return(-1);
803
804 printf("0\n0\n8\n");
805
806 multp3(p0, fa.farg, tot.xfm);
807 multv3(pd, fa.farg+3, tot.xfm);
808 if (invert) {
809 pd[0] = -pd[0];
810 pd[1] = -pd[1];
811 pd[2] = -pd[2];
812 }
813 r0 = fa.farg[6] * tot.sca;
814 r1 = fa.farg[7] * tot.sca;
815 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
816 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
817 printf(" %18.12g %18.12g\n", r0, r1);
818 freefargs(&fa);
819 return(0);
820 }
821
822
823 initotypes() /* initialize ofun[] array */
824 {
825 register int i;
826
827 if (ofun[OBJ_SOURCE].funp == o_source)
828 return; /* done already */
829 /* alias is additional */
830 ofun[ALIAS].funame = ALIASID;
831 ofun[ALIAS].flags = 0;
832 /* functions get new transform */
833 for (i = 0; i < NUMTYPES; i++)
834 if (hasfunc(i))
835 ofun[i].funp = addxform;
836 /* special cases */
837 ofun[OBJ_SOURCE].funp = o_source;
838 ofun[OBJ_SPHERE].funp =
839 ofun[OBJ_BUBBLE].funp = o_sphere;
840 ofun[OBJ_FACE].funp = o_face;
841 ofun[OBJ_CONE].funp =
842 ofun[OBJ_CUP].funp = o_cone;
843 ofun[OBJ_CYLINDER].funp =
844 ofun[OBJ_TUBE].funp = o_cylinder;
845 ofun[OBJ_RING].funp = o_ring;
846 ofun[OBJ_INSTANCE].funp = addxform;
847 ofun[MAT_GLOW].funp = m_glow;
848 ofun[MAT_SPOT].funp = m_spot;
849 ofun[MAT_DIELECTRIC].funp = m_dielectric;
850 ofun[MAT_INTERFACE].funp = m_interface;
851 ofun[MAT_MIST].funp = m_mist;
852 ofun[PAT_CTEXT].funp =
853 ofun[PAT_BTEXT].funp =
854 ofun[MIX_TEXT].funp = text;
855 ofun[ALIAS].funp = alias;
856 /* surface inverses */
857 tinvers[OBJ_FACE] = OBJ_FACE;
858 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
859 tinvers[OBJ_CONE] = OBJ_CUP;
860 tinvers[OBJ_CUP] = OBJ_CONE;
861 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
862 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
863 tinvers[OBJ_RING] = OBJ_RING;
864 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
865 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
866 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
867 }
868
869
870 #ifdef OLDXFORM
871 openmain(fname)
872 char *fname;
873 {
874 if (fname == NULL) {
875 strcpy(mainfn, "standard input");
876 mainfp = stdin;
877 return;
878 }
879 if (mainfp != NULL) {
880 if (!strcmp(fname, mainfn)) {
881 rewind(mainfp);
882 return;
883 }
884 fclose(mainfp);
885 }
886 if ((mainfp = fopen(fname, "r")) == NULL) {
887 fprintf(stderr, "%s: cannot open file \"%s\"\n",
888 progname, fname);
889 exit(1);
890 }
891 strcpy(mainfn, fname);
892 }
893 #else
894 openmain(fname) /* open fname for input, changing to its directory */
895 char *fname;
896 {
897 extern FILE *tmpfile();
898 extern char *getlibpath(), *getpath();
899 static char origdir[MAXPATH];
900 static char curfn[MAXPATH];
901 static int diffdir;
902 register char *fpath;
903
904 if (fname == NULL) { /* standard input */
905 if (mainfp == NULL) {
906 register int c;
907 strcpy(mainfn, "standard input");
908 if (nrept <= 1) {
909 mainfp = stdin;
910 return; /* just read once */
911 }
912 /* else copy */
913 if ((mainfp = tmpfile()) == NULL) {
914 fprintf(stderr,
915 "%s: cannot create temporary file\n",
916 progname);
917 exit(1);
918 }
919 while ((c = getc(stdin)) != EOF)
920 putc(c, mainfp);
921 fclose(stdin);
922 }
923 rewind(mainfp); /* rewind copy */
924 return;
925 }
926 if (mainfp == NULL) { /* first call, initialize */
927 getwd(origdir);
928 } else if (!strcmp(fname, curfn)) { /* just need to rewind? */
929 rewind(mainfp);
930 return;
931 } else { /* else close old stream */
932 fclose(mainfp);
933 if (diffdir) {
934 chdir(origdir);
935 diffdir = 0;
936 }
937 }
938 strcpy(curfn, fname); /* remember file name */
939 /* get full path */
940 if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) {
941 fprintf(stderr, "%s: cannot find file \"%s\"\n",
942 progname, fname);
943 exit(1);
944 }
945 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
946 fpath += 2;
947 /* record path name */
948 strcpy(mainfn, fpath);
949 if (expand) { /* change to local directory */
950 register char *cp = fpath + strlen(fpath); /* get dir. */
951 while (cp > fpath) {
952 cp--;
953 if (ISDIRSEP(*cp)) {
954 if (cp == fpath)
955 cp++; /* root special case */
956 break;
957 }
958 }
959 *cp = '\0';
960 if (fpath[0]) { /* change to new directory? */
961 if (chdir(fpath) < 0) {
962 fprintf(stderr,
963 "%s: cannot change directory to \"%s\"\n",
964 progname, fpath);
965 exit(1);
966 }
967 diffdir++;
968 }
969 /* get final path component */
970 for (fpath = fname+strlen(fname);
971 fpath > fname && !ISDIRSEP(fpath[-1]); fpath--)
972 ;
973 }
974 /* open the file */
975 if ((mainfp = fopen(fpath, "r")) == NULL) {
976 fprintf(stderr, "%s: cannot open file \"%s\"\n",
977 progname, mainfn);
978 exit(1);
979 }
980 }
981 #endif
