--- ray/src/gen/xform.c 1999/06/04 16:22:06 2.20 +++ ray/src/gen/xform.c 2011/02/19 05:06:24 2.43 @@ -1,9 +1,6 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: xform.c,v 2.43 2011/02/19 05:06:24 greg Exp $"; #endif - /* * xform.c - program to transform object files. * Transformations must preserve aspect ratio. @@ -12,14 +9,14 @@ static char SCCSid[] = "$SunId$ LBL"; * 11/6/86 Finally added error checking! */ -#include "standard.h" - -#include "paths.h" - #include +#include "platform.h" +#include "paths.h" +#include "rtprocess.h" /* win_popen() */ +#include "rtio.h" +#include "rtmath.h" #include "object.h" - #include "otypes.h" int xac; /* global xform argument count */ @@ -29,39 +26,45 @@ int xfa; /* start of xf arguments */ XF tot; /* total transformation */ int reverse; /* boolean true if scene mirrored */ -int invert = 0; /* boolean true to invert surfaces */ +int invert; /* boolean true to invert surfaces */ -int expand = 1; /* boolean true to expand commands */ +int expand; /* boolean true to expand commands */ -char *newmod = NULL; /* new modifier for surfaces */ +char *newmod; /* new modifier for surfaces */ -char *idprefix = NULL; /* prefix for object identifiers */ +char *idprefix; /* prefix for object identifiers */ -#define ALIAS NUMOTYPE /* put alias at end of array */ +FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */ -#define NUMTYPES (NUMOTYPE+1) /* total number of object types */ - -FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */ - short tinvers[NUMOTYPE]; /* inverse types for surfaces */ int nrept = 1; /* number of array repetitions */ int stdinused = 0; /* stdin has been used by -f option? */ -extern char *malloc(), *fgets(), *fgetword(); - -char mainfn[MAXPATH]; /* main file name */ +char mainfn[PATH_MAX]; /* main file name */ FILE *mainfp = NULL; /* main file pointer */ #define progname (xav[0]) +static int doargf(int ac, char **av, int fi); +static int doarray(int ac, char **av, int ai); +static void xform(char *name, FILE *fin); +static void xfcomm(char *fname, FILE *fin); +static void xfobject(char *fname, FILE *fin); +static int addxform(FILE *fin); +static int alias(FILE *fin); +void initotypes(void); /* XXX conflict with otypes.h */ +static void openmain(char *iname); -main(argc, argv) /* get transform options and transform file */ -int argc; -char *argv[]; + +int +main( /* get transform options and transform file */ + int argc, + char *argv[] +) { - char *fname; + int mal_prefix = 0; int a; /* check for argument list file */ for (a = 1; a < argc; a++) @@ -72,20 +75,40 @@ char *argv[]; if (!strcmp(argv[a], "-a")) return(doarray(argc, argv, a)); - initotypes(); + initotypes(); /* initialize */ + invert = 0; + expand = 1; + newmod = NULL; + idprefix = NULL; for (a = 1; a < argc; a++) { if (argv[a][0] == '-') switch (argv[a][1]) { case 'm': - if (argv[a][2] || a+1 >= argc) + if (argv[a][2] | (a+1 >= argc)) break; - newmod = argv[++a]; + a++; + if (newmod == NULL) + newmod = argv[a]; continue; case 'n': - if (argv[a][2] || a+1 >= argc) + if (argv[a][2] | (a+1 >= argc)) break; - idprefix = argv[++a]; + a++; + if (idprefix == NULL) + idprefix = argv[a]; + else { + register char *newp; + newp = (char *)malloc(strlen(idprefix)+ + strlen(argv[a])+2); + if (newp == NULL) + exit(2); + sprintf(newp, "%s.%s", + idprefix, argv[a]); + if (mal_prefix++) + free((void *)idprefix); + idprefix = newp; + } continue; case 'c': if (argv[a][2]) @@ -100,7 +123,7 @@ char *argv[]; case 'I': if (argv[a][2]) break; - invert = 1; + invert = !invert; continue; } break; @@ -111,7 +134,7 @@ char *argv[]; a += xf(&tot, argc-a, argv+a); - if (reverse = tot.sca < 0.0) + if ( (reverse = tot.sca < 0.0) ) tot.sca = -tot.sca; if (invert) reverse = !reverse; @@ -143,17 +166,23 @@ char *argv[]; xform(mainfn, mainfp); } + if (mal_prefix) + free((void *)idprefix); return(0); } -doargf(ac, av, fi) /* take argument list from file */ -char **av; -int ac, fi; +int +doargf( /* take argument list from file */ + int ac, + char **av, + int fi +) { + int inquote; char *newav[256], **avp; - char argbuf[1024]; - char newid[128]; + char argbuf[2048]; + char *newid, newidbuf[128]; char *oldid; register char *cp; FILE *argfp; @@ -165,7 +194,8 @@ int ac, fi; } if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') { if (stdinused++) { - fprintf(stderr, "%s: cannot use stdin more than once\n", + fprintf(stderr, + "%s: cannot use stdin more than once\n", av[0]); exit(1); } @@ -173,13 +203,14 @@ int ac, fi; n = 100; /* we just don't know! */ } else { if ((argfp = fopen(av[fi+1], "r")) == NULL) { - fprintf(stderr, "%s: cannot open argument file \"%s\"\n", + fprintf(stderr, + "%s: cannot open argument file \"%s\"\n", av[0], av[fi+1]); exit(1); } n = 0; /* count number of lines in file */ - while (fgets(argbuf,sizeof(argbuf),argfp) != NULL) - n += argbuf[0] != '\n' & argbuf[0] != '#'; + while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) + n += argbuf[0] && argbuf[0] != '#'; if (!n) { fprintf(stderr, "%s: empty argument file \"%s\"\n", av[0], av[fi+1]); @@ -189,8 +220,8 @@ int ac, fi; rewind(argfp); } err = 0; k = 0; /* read each arg list and call main */ - while (fgets(argbuf,sizeof(argbuf),argfp) != NULL) { - if (argbuf[0] == '\n' | argbuf[0] == '#') + while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) { + if (!argbuf[0] || argbuf[0] == '#') continue; avp = newav+2; avp[0] = av[0]; @@ -200,22 +231,43 @@ int ac, fi; cp = argbuf; /* parse new words */ if (*cp == '!') cp++; if (!strncmp(cp, "xform ", 6)) cp += 6; + inquote = 0; for ( ; ; ) { + skipspaces: while (isspace(*cp)) /* nullify spaces */ *cp++ = '\0'; + if ((*cp == '"') | (*cp == '\'')) + inquote = *cp++; if (!*cp) /* all done? */ break; + if (cp[0] == '\\' && cp[1]) + if (*++cp == '\n') + goto skipspaces; avp[newac++] = cp; /* add argument to list */ - while (*++cp && !isspace(*cp)) - ; + if (inquote) { + while (*++cp) + if (*cp == inquote) { + *cp++ = '\0'; + break; + } + } else { + while (*++cp && !isspace(*cp)) + ; + } } for (i = fi+2; i < ac; i++) avp[newac++] = av[i]; avp[newac] = NULL; + newid = newidbuf; oldid = NULL; for (i = 2; i < newac; i++) if (!strcmp(avp[i-1], "-n")) { oldid = avp[i]; + if (strlen(oldid)+32 > sizeof(newidbuf)) { + newid = (char *)malloc(strlen(oldid)+32); + if (newid == NULL) + exit(2); + } avp[i] = newid; break; } @@ -231,6 +283,8 @@ int ac, fi; else sprintf(newid, "%s.%d", oldid, k); err |= main(newac, avp); + if (newid != newidbuf) + free((void *)newid); k++; } fclose(argfp); @@ -238,9 +292,12 @@ int ac, fi; } -doarray(ac, av, ai) /* make array */ -char **av; -int ac, ai; +int +doarray( /* make array */ + int ac, + char **av, + int ai +) { char *newav[256], **avp; char newid[128], repts[32]; @@ -283,9 +340,11 @@ int ac, ai; } -xform(name, fin) /* transform stream by tot.xfm */ -char *name; -register FILE *fin; +void +xform( /* transform stream by tot.xfm */ + char *name, + register FILE *fin +) { int nobjs = 0; register int c; @@ -316,14 +375,14 @@ register FILE *fin; } -xfcomm(fname, fin) /* transform a command */ -char *fname; -FILE *fin; +void +xfcomm( /* transform a command */ + char *fname, + FILE *fin +) { - extern FILE *popen(); - extern char *fgetline(); FILE *pin; - char buf[512]; + char buf[2048]; int i; fgetline(buf, sizeof(buf), fin); @@ -338,20 +397,22 @@ FILE *fin; } else { printf("\n%s", buf); if (xac > 1) { - printf(" | %s", xav[0]); + printf(" | %s -e", xav[0]); /* expand next time */ for (i = 1; i < xac; i++) - printf(" %s", xav[i]); + if (i >= xfa || strcmp(xav[i], "-c")) + printf(" %s", xav[i]); } putchar('\n'); } } -xfobject(fname, fin) /* transform an object */ -char *fname; -FILE *fin; +void +xfobject( /* transform an object */ + char *fname, + FILE *fin +) { - extern char *strcpy(); char typ[16], nam[MAXSTR]; int fn; /* modifier and type */ @@ -363,17 +424,24 @@ FILE *fin; progname, fname, typ); exit(1); } - if (ismodifier(fn)) - printf("\n%s %s ", nam, typ); - else - printf("\n%s %s ", newmod != NULL ? newmod : nam, - invert ? ofun[tinvers[fn]].funame : typ); + putchar('\n'); + if (ismodifier(fn)) { + fputword(nam, stdout); + printf(" %s ", typ); + } else { + fputword(newmod != NULL ? newmod : nam, stdout); + printf(" %s ", invert ? ofun[tinvers[fn]].funame : typ); + } /* object name */ fgetword(nam, sizeof(nam), fin); if (idprefix == NULL || ismodifier(fn)) - printf("%s\n", nam); - else - printf("%s.%s\n", idprefix, nam); + fputword(nam, stdout); + else { + char nnam[MAXSTR]; + sprintf(nnam, "%s.%s", idprefix, nam); + fputword(nnam, stdout); + } + putchar('\n'); /* transform arguments */ if ((*ofun[fn].funp)(fin) < 0) { fprintf(stderr, "%s: (%s): bad %s \"%s\"\n", @@ -383,8 +451,10 @@ FILE *fin; } -o_default(fin) /* pass on arguments unchanged */ -FILE *fin; +int +o_default( /* pass on arguments unchanged */ + FILE *fin +) { register int i; FUNARGS fa; @@ -393,8 +463,10 @@ FILE *fin; return(-1); /* string arguments */ printf("%d", fa.nsargs); - for (i = 0; i < fa.nsargs; i++) - printf(" %s", fa.sarg[i]); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } printf("\n"); #ifdef IARGS /* integer arguments */ @@ -415,8 +487,10 @@ FILE *fin; } -addxform(fin) /* add xf arguments to strings */ -FILE *fin; +int +addxform( /* add xf arguments to strings */ + FILE *fin +) { register int i; int resetarr = 0; @@ -428,8 +502,10 @@ FILE *fin; if (xac > xfa && strcmp(xav[xfa], "-i")) resetarr = 2; printf("%d", fa.nsargs + resetarr + xac-xfa); - for (i = 0; i < fa.nsargs; i++) - printf(" %s", fa.sarg[i]); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } if (resetarr) printf(" -i 1"); for (i = xfa; i < xac; i++) /* add xf arguments */ @@ -455,22 +531,10 @@ FILE *fin; int -otype(ofname) /* get object function number from its name */ -register char *ofname; +alias( /* transfer alias */ + FILE *fin +) { - register int i; - - for (i = 0; i < NUMTYPES; i++) - if (!strcmp(ofun[i].funame, ofname)) - return(i); - - return(-1); /* not found */ -} - - -alias(fin) /* transfer alias */ -FILE *fin; -{ char aliasnm[MAXSTR]; if (fgetword(aliasnm, MAXSTR, fin) == NULL) @@ -480,8 +544,10 @@ FILE *fin; } -m_glow(fin) /* transform arguments for proximity light */ -FILE *fin; +int +m_glow( /* transform arguments for proximity light */ + FILE *fin +) { FUNARGS fa; @@ -498,8 +564,10 @@ FILE *fin; } -m_spot(fin) /* transform arguments for spotlight */ -FILE *fin; +int +m_spot( /* transform arguments for spotlight */ + FILE *fin +) { FVECT v; FUNARGS fa; @@ -518,8 +586,10 @@ FILE *fin; } -m_mist(fin) /* transform arguments for mist */ -FILE *fin; +int +m_mist( /* transform arguments for mist */ + FILE *fin +) { FUNARGS fa; int i; @@ -560,8 +630,10 @@ FILE *fin; } -m_dielectric(fin) /* transform arguments for dielectric */ -FILE *fin; +int +m_dielectric( /* transform arguments for dielectric */ + FILE *fin +) { FUNARGS fa; @@ -580,8 +652,10 @@ FILE *fin; } -m_interface(fin) /* transform arguments for interface */ -FILE *fin; +int +m_interface( /* transform arguments for interface */ + FILE *fin +) { FUNARGS fa; @@ -605,8 +679,10 @@ FILE *fin; } -text(fin) /* transform text arguments */ -FILE *fin; +int +text( /* transform text arguments */ + FILE *fin +) { int i; FVECT v; @@ -618,8 +694,10 @@ FILE *fin; return(-1); /* string arguments */ printf("%d", fa.nsargs); - for (i = 0; i < fa.nsargs; i++) - printf(" %s", fa.sarg[i]); + for (i = 0; i < fa.nsargs; i++) { + fputc(' ', stdout); + fputword(fa.sarg[i], stdout); + } printf("\n0\n%d\n", fa.nfargs); /* anchor point */ multp3(v, fa.farg, tot.xfm); @@ -642,8 +720,10 @@ FILE *fin; } -o_source(fin) /* transform source arguments */ -FILE *fin; +int +o_source( /* transform source arguments */ + FILE *fin +) { FVECT dv; FUNARGS fa; @@ -663,8 +743,10 @@ FILE *fin; } -o_sphere(fin) /* transform sphere arguments */ -FILE *fin; +int +o_sphere( /* transform sphere arguments */ + FILE *fin +) { FVECT cent; double rad; @@ -687,8 +769,10 @@ FILE *fin; } -o_face(fin) /* transform face arguments */ -FILE *fin; +int +o_face( /* transform face arguments */ + FILE *fin +) { FVECT p; register int i; @@ -713,8 +797,10 @@ FILE *fin; } -o_cone(fin) /* transform cone and cup arguments */ -FILE *fin; +int +o_cone( /* transform cone and cup arguments */ + FILE *fin +) { FVECT p0, p1; double r0, r1; @@ -740,8 +826,10 @@ FILE *fin; } -o_cylinder(fin) /* transform cylinder and tube arguments */ -FILE *fin; +int +o_cylinder( /* transform cylinder and tube arguments */ + FILE *fin +) { FVECT p0, p1; double rad; @@ -765,8 +853,10 @@ FILE *fin; } -o_ring(fin) /* transform ring arguments */ -FILE *fin; +int +o_ring( /* transform ring arguments */ + FILE *fin +) { FVECT p0, pd; double r0, r1; @@ -796,17 +886,15 @@ FILE *fin; } -initotypes() /* initialize ofun[] array */ +void +initotypes(void) /* initialize ofun[] array */ { register int i; if (ofun[OBJ_SOURCE].funp == o_source) return; /* done already */ - /* alias is additional */ - ofun[ALIAS].funame = ALIASID; - ofun[ALIAS].flags = 0; /* functions get new transform */ - for (i = 0; i < NUMTYPES; i++) + for (i = 0; i < NUMOTYPE; i++) if (hasfunc(i)) ofun[i].funp = addxform; /* special cases */ @@ -819,16 +907,18 @@ initotypes() /* initialize ofun[] array */ ofun[OBJ_CYLINDER].funp = ofun[OBJ_TUBE].funp = o_cylinder; ofun[OBJ_RING].funp = o_ring; - ofun[OBJ_INSTANCE].funp = addxform; + ofun[OBJ_INSTANCE].funp = + ofun[OBJ_MESH].funp = addxform; ofun[MAT_GLOW].funp = m_glow; ofun[MAT_SPOT].funp = m_spot; ofun[MAT_DIELECTRIC].funp = m_dielectric; ofun[MAT_INTERFACE].funp = m_interface; ofun[MAT_MIST].funp = m_mist; + ofun[MAT_BSDF].funp = addxform; ofun[PAT_CTEXT].funp = ofun[PAT_BTEXT].funp = ofun[MIX_TEXT].funp = text; - ofun[ALIAS].funp = alias; + ofun[MOD_ALIAS].funp = alias; /* surface inverses */ tinvers[OBJ_FACE] = OBJ_FACE; tinvers[OBJ_SOURCE] = OBJ_SOURCE; @@ -844,8 +934,10 @@ initotypes() /* initialize ofun[] array */ #ifdef OLDXFORM -openmain(fname) -char *fname; +void +openmain( + char *fname +) { if (fname == NULL) { strcpy(mainfn, "standard input"); @@ -867,17 +959,17 @@ char *fname; strcpy(mainfn, fname); } #else -openmain(fname) /* open fname for input, changing to its directory */ -char *fname; +void +openmain( /* open input, changing directory for file */ + char *iname +) { - extern FILE *tmpfile(); - extern char *getlibpath(), *getpath(); - static char origdir[MAXPATH]; - static char curfn[MAXPATH]; + static char origdir[PATH_MAX]; + static char curfn[PATH_MAX]; static int diffdir; register char *fpath; - if (fname == NULL) { /* standard input */ + if (iname == NULL) { /* standard input */ if (mainfp == NULL) { register int c; strcpy(mainfn, "standard input"); @@ -894,28 +986,28 @@ char *fname; } while ((c = getc(stdin)) != EOF) putc(c, mainfp); - fclose(stdin); } rewind(mainfp); /* rewind copy */ return; } if (mainfp == NULL) { /* first call, initialize */ - getwd(origdir); - } else if (!strcmp(fname, curfn)) { /* just need to rewind? */ + getcwd(origdir, sizeof(origdir)); + } else if (!strcmp(iname, curfn)) { /* just need to rewind? */ rewind(mainfp); return; } else { /* else close old stream */ fclose(mainfp); - if (diffdir) { + mainfp = NULL; + if (diffdir) { /* return to our directory */ chdir(origdir); diffdir = 0; } } - strcpy(curfn, fname); /* remember file name */ - /* get full path */ - if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) { + strcpy(curfn, iname); /* remember input name */ + /* get full path for file */ + if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) { fprintf(stderr, "%s: cannot find file \"%s\"\n", - progname, fname); + progname, iname); exit(1); } if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */ @@ -943,11 +1035,11 @@ char *fname; diffdir++; } /* get final path component */ - for (fpath = fname+strlen(fname); - fpath > fname && !ISDIRSEP(fpath[-1]); fpath--) + for (fpath = iname+strlen(iname); + fpath > iname && !ISDIRSEP(fpath[-1]); fpath--) ; } - /* open the file */ + /* finally, open the file */ if ((mainfp = fopen(fpath, "r")) == NULL) { fprintf(stderr, "%s: cannot open file \"%s\"\n", progname, mainfn);
