1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* xform.c - program to transform object files. |
9 |
* Transformations must preserve aspect ratio. |
10 |
11 |
* 10/19/85 |
12 |
* 11/6/86 Finally added error checking! |
13 |
14 |
15 |
#include <stdio.h> |
16 |
17 |
#include <ctype.h> |
18 |
19 |
20 |
typedef struct { |
21 |
char *funame; /* function name */ |
22 |
int (*funp)(); /* pointer to function */ |
23 |
} FUN; |
24 |
25 |
int xac; /* global xform argument count */ |
26 |
char **xav; /* global xform argument pointer */ |
27 |
int xfa; /* start of xf arguments */ |
28 |
29 |
double totxform[4][4]; /* total transformation matrix */ |
30 |
double totscale; /* total scale factor */ |
31 |
int reverse; /* boolean true if scene inverted */ |
32 |
33 |
int expand = 0; /* boolean true to expand commands */ |
34 |
35 |
char *idprefix = NULL; /* prefix for object identifiers */ |
36 |
37 |
extern int o_source(); |
38 |
extern int o_sphere(); |
39 |
extern int o_face(); |
40 |
extern int o_cone(); |
41 |
extern int o_cylinder(); |
42 |
extern int o_ring(); |
43 |
extern int m_glow(); |
44 |
extern int m_spot(); |
45 |
extern int m_dielectric(); |
46 |
extern int m_interface(); |
47 |
extern int text(); |
48 |
extern int alias(); |
49 |
extern int passargs(); |
50 |
extern int addxform(); |
51 |
52 |
FUN ofun[] = { |
53 |
{ "source", o_source }, |
54 |
{ "sphere", o_sphere }, |
55 |
{ "bubble", o_sphere }, |
56 |
{ "polygon", o_face }, |
57 |
{ "cone", o_cone }, |
58 |
{ "cup", o_cone }, |
59 |
{ "cylinder", o_cylinder }, |
60 |
{ "tube", o_cylinder }, |
61 |
{ "ring", o_ring }, |
62 |
{ "instance", addxform }, |
63 |
{ "alias", alias }, |
64 |
{ "antimatter", passargs }, |
65 |
{ "glow", m_glow }, |
66 |
{ "spotlight", m_spot }, |
67 |
{ "dielectric", m_dielectric }, |
68 |
{ "interface", m_interface }, |
69 |
{ "colortext", text }, |
70 |
{ "brighttext", text }, |
71 |
{ "texfunc", addxform }, |
72 |
{ "texdata", addxform }, |
73 |
{ "colorfunc", addxform }, |
74 |
{ "brightfunc", addxform }, |
75 |
{ "colorpict", addxform }, |
76 |
{ "colordata", addxform }, |
77 |
{ "brightdata", addxform }, |
78 |
{ "mixfunc", addxform }, |
79 |
{ "mixdata", addxform }, |
80 |
{ "mixtext", text }, |
81 |
{ "light", passargs }, |
82 |
{ "illum", passargs }, |
83 |
{ "plastic", passargs }, |
84 |
{ "metal", passargs }, |
85 |
{ "trans", passargs }, |
86 |
{ "glass", passargs }, |
87 |
{ 0 } /* terminator */ |
88 |
89 |
90 |
#define issurface(t) ((t)<=9) |
91 |
92 |
typedef struct { |
93 |
short nsargs; /* # of string arguments */ |
94 |
char **sarg; /* string arguments */ |
95 |
short niargs; /* # of integer arguments */ |
96 |
int *iarg; /* integer arguments */ |
97 |
short nfargs; /* # of float arguments */ |
98 |
double *farg; /* float arguments */ |
99 |
} FUNARGS; |
100 |
101 |
#define MAXSTR 512 /* maximum string length */ |
102 |
103 |
FUNARGS *getfargs(); |
104 |
char *malloc(); |
105 |
106 |
#define progname (xav[0]) |
107 |
108 |
109 |
main(argc, argv) /* get transform options and transform file */ |
110 |
int argc; |
111 |
char *argv[]; |
112 |
113 |
FILE *fopen(); |
114 |
FILE *fp; |
115 |
int a; |
116 |
117 |
xav = argv; |
118 |
119 |
for (a = 1; a < argc; a++) { |
120 |
if (argv[a][0] == '-') |
121 |
switch (argv[a][1]) { |
122 |
case 'n': |
123 |
idprefix = argv[++a]; |
124 |
continue; |
125 |
case 'e': |
126 |
expand = 1; |
127 |
continue; |
128 |
129 |
break; |
130 |
131 |
132 |
xfa = a; |
133 |
134 |
totscale = 1.0; |
135 |
setident4(totxform); |
136 |
137 |
a += xf(totxform, &totscale, argc-a, argv+a); |
138 |
139 |
if (reverse = totscale < 0.0) |
140 |
totscale = -totscale; |
141 |
142 |
xac = a; |
143 |
144 |
putchar('#'); /* simple header */ |
145 |
for (a = 0; a < xac; a++) |
146 |
printf(" %s", xav[a]); |
147 |
putchar('\n'); |
148 |
149 |
if (a == argc) |
150 |
xform("standard input", stdin); |
151 |
else |
152 |
for ( ; a < argc; a++) { |
153 |
if ((fp = fopen(argv[a], "r")) == NULL) { |
154 |
fprintf(stderr, "%s: cannot open \"%s\"\n", |
155 |
progname, argv[a]); |
156 |
exit(1); |
157 |
158 |
xform(argv[a], fp); |
159 |
fclose(fp); |
160 |
161 |
162 |
exit(0); |
163 |
164 |
165 |
166 |
xform(name, fin) /* transform stream by totxform */ |
167 |
char *name; |
168 |
register FILE *fin; |
169 |
170 |
register int c; |
171 |
172 |
while ((c = getc(fin)) != EOF) { |
173 |
if (isspace(c)) /* blank */ |
174 |
continue; |
175 |
if (c == '#') { /* comment */ |
176 |
putchar(c); |
177 |
do { |
178 |
if ((c = getc(fin)) == EOF) |
179 |
return; |
180 |
putchar(c); |
181 |
} while (c != '\n'); |
182 |
} else if (c == '!') { /* command */ |
183 |
ungetc(c, fin); |
184 |
if (expand) |
185 |
xfcomm(name, fin); |
186 |
else { |
187 |
putchar('\n'); |
188 |
while ((c = getc(fin)) != EOF && c != '\n') |
189 |
putchar(c); |
190 |
printf(" |"); |
191 |
for (c = 0; c < xac; c++) |
192 |
printf(" %s", xav[c]); |
193 |
putchar('\n'); |
194 |
195 |
} else { /* object */ |
196 |
ungetc(c, fin); |
197 |
xfobject(name, fin); |
198 |
199 |
200 |
201 |
202 |
203 |
xfcomm(fname, fin) /* expand a command */ |
204 |
FILE *fin; |
205 |
206 |
FILE *popen(); |
207 |
char *fgets(); |
208 |
FILE *pin; |
209 |
char buf[512]; |
210 |
211 |
fgets(buf, sizeof(buf), fin); |
212 |
if (buf[strlen(buf)-1] == '\n') |
213 |
buf[strlen(buf)-1] = '\0'; |
214 |
if ((pin = popen(buf+1, "r")) == NULL) { |
215 |
fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n", |
216 |
progname, fname, buf); |
217 |
exit(1); |
218 |
219 |
xform(buf, pin); |
220 |
pclose(pin); |
221 |
222 |
223 |
224 |
xfobject(fname, fin) /* transform an object */ |
225 |
char *fname; |
226 |
FILE *fin; |
227 |
228 |
char stmp[MAXSTR]; |
229 |
int fn; |
230 |
231 |
fscanf(fin, "%s", stmp); /* modifier */ |
232 |
printf("\n%s ", stmp); |
233 |
fscanf(fin, "%s", stmp); /* object type */ |
234 |
if ((fn = otype(stmp)) < 0) { |
235 |
fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n", |
236 |
progname, fname, stmp); |
237 |
exit(1); |
238 |
239 |
printf("%s ", stmp); |
240 |
fscanf(fin, "%s", stmp); /* object name */ |
241 |
if (idprefix != NULL && issurface(fn)) |
242 |
printf("%s.%s\n", idprefix, stmp); |
243 |
else |
244 |
printf("%s\n", stmp); |
245 |
/* transform arguments */ |
246 |
if ((*ofun[fn].funp)(fin) < 0) { |
247 |
fprintf(stderr, "%s: (%s): bad %s \"%s\"\n", |
248 |
progname, fname, ofun[fn].funame, stmp); |
249 |
exit(1); |
250 |
251 |
252 |
253 |
254 |
passargs(fin) /* pass on arguments unchanged */ |
255 |
FILE *fin; |
256 |
257 |
register int i; |
258 |
register FUNARGS *fa; |
259 |
260 |
if ((fa = getfargs(fin)) == NULL) |
261 |
return(-1); |
262 |
263 |
printf("%d", fa->nsargs); |
264 |
for (i = 0; i < fa->nsargs; i++) |
265 |
printf(" %s", fa->sarg[i]); |
266 |
printf("\n"); |
267 |
268 |
printf("%d", fa->niargs); |
269 |
for (i = 0; i < fa->niargs; i++) |
270 |
printf(" %d", fa->iarg[i]); |
271 |
printf("\n"); |
272 |
273 |
printf("%d", fa->nfargs); |
274 |
for (i = 0; i < fa->nfargs; i++) |
275 |
printf(" %18.12g", fa->farg[i]); |
276 |
printf("\n"); |
277 |
freefargs(fa); |
278 |
return(0); |
279 |
280 |
281 |
282 |
addxform(fin) /* add xf arguments to strings */ |
283 |
FILE *fin; |
284 |
285 |
register int i; |
286 |
287 |
288 |
289 |
return(-1); |
290 |
291 |
printf("%d", fa->nsargs + xac-xfa); |
292 |
293 |
294 |
for (i = xfa; i < xac; i++) /* add xf arguments */ |
295 |
printf(" %s", xav[i]); |
296 |
printf("\n"); |
297 |
298 |
299 |
300 |
301 |
printf("\n"); |
302 |
303 |
304 |
305 |
306 |
printf("\n"); |
307 |
freefargs(fa); |
308 |
return(0); |
309 |
310 |
311 |
312 |
int |
313 |
otype(ofname) /* get object function number from its name */ |
314 |
register char *ofname; |
315 |
316 |
register int i; |
317 |
318 |
for (i = 0; ofun[i].funame != NULL; i++) |
319 |
if (!strcmp(ofun[i].funame, ofname)) |
320 |
return(i); |
321 |
322 |
return(-1); /* not found */ |
323 |
324 |
325 |
326 |
alias(fin) /* transfer alias */ |
327 |
FILE *fin; |
328 |
329 |
char alias[MAXSTR]; |
330 |
331 |
if (fscanf(fin, "%s", alias) != 1) |
332 |
return(-1); |
333 |
printf("\t%s\n", alias); |
334 |
return(0); |
335 |
336 |
337 |
338 |
m_glow(fin) /* transform arguments for proximity light */ |
339 |
FILE *fin; |
340 |
341 |
342 |
343 |
344 |
return(-1); |
345 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 4) |
346 |
return(-1); |
347 |
printf("0\n0\n4"); |
348 |
printf(" %18.12g %18.12g %18.12g", |
349 |
fa->farg[0], fa->farg[1], fa->farg[2]); |
350 |
printf(" %18.12g\n", fa->farg[3] * totscale); |
351 |
freefargs(fa); |
352 |
return(0); |
353 |
354 |
355 |
356 |
m_spot(fin) /* transform arguments for spotlight */ |
357 |
FILE *fin; |
358 |
359 |
double v[3]; |
360 |
361 |
362 |
363 |
return(-1); |
364 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 7) |
365 |
return(-1); |
366 |
printf("0\n0\n7"); |
367 |
printf(" %18.12g %18.12g %18.12g %18.12g\n", |
368 |
fa->farg[0], fa->farg[1], fa->farg[2], fa->farg[3]); |
369 |
multv3(v, fa->farg+4, totxform); |
370 |
printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); |
371 |
freefargs(fa); |
372 |
return(0); |
373 |
374 |
375 |
376 |
m_dielectric(fin) /* transform arguments for dielectric */ |
377 |
FILE *fin; |
378 |
379 |
double pow(); |
380 |
381 |
382 |
383 |
return(-1); |
384 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 5) |
385 |
return(-1); |
386 |
printf("0\n0\n5"); |
387 |
388 |
pow(fa->farg[0], 1.0/totscale), |
389 |
pow(fa->farg[1], 1.0/totscale), |
390 |
pow(fa->farg[2], 1.0/totscale)); |
391 |
printf(" %18.12g %18.12g\n", fa->farg[3], fa->farg[4]); |
392 |
freefargs(fa); |
393 |
return(0); |
394 |
395 |
396 |
397 |
m_interface(fin) /* transform arguments for interface */ |
398 |
FILE *fin; |
399 |
400 |
double pow(); |
401 |
402 |
403 |
404 |
return(-1); |
405 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs != 8) |
406 |
return(-1); |
407 |
printf("0\n0\n8\n"); |
408 |
printf("%18.12g %18.12g %18.12g", |
409 |
410 |
411 |
412 |
printf(" %18.12g\n", fa->farg[3]); |
413 |
414 |
pow(fa->farg[4], 1.0/totscale), |
415 |
pow(fa->farg[5], 1.0/totscale), |
416 |
pow(fa->farg[6], 1.0/totscale)); |
417 |
printf(" %18.12g\n", fa->farg[7]); |
418 |
freefargs(fa); |
419 |
return(0); |
420 |
421 |
422 |
423 |
text(fin) /* transform text arguments */ |
424 |
FILE *fin; |
425 |
426 |
int i; |
427 |
double v[3]; |
428 |
429 |
430 |
431 |
return(-1); |
432 |
if (fa->niargs != 0 || (fa->nfargs != 9 && |
433 |
fa->nfargs != 11 && fa->nfargs != 15)) |
434 |
return(-1); |
435 |
436 |
437 |
438 |
439 |
printf("\n0\n%d\n", fa->nfargs); |
440 |
/* anchor point */ |
441 |
multp3(v, fa->farg, totxform); |
442 |
printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]); |
443 |
/* right vector */ |
444 |
multv3(v, fa->farg+3, totxform); |
445 |
446 |
/* down vector */ |
447 |
multv3(v, fa->farg+6, totxform); |
448 |
449 |
/* forground and background */ |
450 |
if (fa->nfargs == 11) |
451 |
printf(" %18.12g %18.12g\n", fa->farg[9], fa->farg[10]); |
452 |
else if (fa->nfargs == 15) { |
453 |
printf(" %18.12g %18.12g %18.12g\n", |
454 |
fa->farg[9], fa->farg[10], fa->farg[11]); |
455 |
456 |
fa->farg[12], fa->farg[13], fa->farg[14]); |
457 |
458 |
freefargs(fa); |
459 |
return(0); |
460 |
461 |
462 |
463 |
o_source(fin) /* transform source arguments */ |
464 |
FILE *fin; |
465 |
466 |
double dv[3]; |
467 |
468 |
469 |
470 |
return(-1); |
471 |
472 |
return(-1); |
473 |
/* transform direction vector */ |
474 |
multv3(dv, fa->farg, totxform); |
475 |
/* output */ |
476 |
477 |
478 |
dv[0], dv[1], dv[2], fa->farg[3]); |
479 |
freefargs(fa); |
480 |
return(0); |
481 |
482 |
483 |
484 |
o_sphere(fin) /* transform sphere arguments */ |
485 |
FILE *fin; |
486 |
487 |
double cent[3], rad; |
488 |
489 |
490 |
491 |
return(-1); |
492 |
493 |
return(-1); |
494 |
495 |
multp3(cent, fa->farg, totxform); /* transform center */ |
496 |
497 |
rad = fa->farg[3] * totscale; /* scale radius */ |
498 |
499 |
500 |
501 |
cent[0], cent[1], cent[2], rad); |
502 |
freefargs(fa); |
503 |
return(0); |
504 |
505 |
506 |
507 |
o_face(fin) /* transform face arguments */ |
508 |
FILE *fin; |
509 |
510 |
double p[3]; |
511 |
register int i; |
512 |
513 |
514 |
515 |
return(-1); |
516 |
if (fa->nsargs != 0 || fa->niargs != 0 || fa->nfargs % 3) |
517 |
return(-1); |
518 |
519 |
printf("0\n0\n%d\n", fa->nfargs); |
520 |
521 |
for (i = 0; i < fa->nfargs; i += 3) { |
522 |
if (reverse) |
523 |
multp3(p, fa->farg+(fa->nfargs-i-3), totxform); |
524 |
else |
525 |
multp3(p, fa->farg+i, totxform); |
526 |
printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]); |
527 |
528 |
freefargs(fa); |
529 |
return(0); |
530 |
531 |
532 |
533 |
o_cone(fin) /* transform cone and cup arguments */ |
534 |
FILE *fin; |
535 |
536 |
double p0[3], p1[3], r0, r1; |
537 |
538 |
539 |
540 |
return(-1); |
541 |
542 |
return(-1); |
543 |
544 |
545 |
546 |
multp3(p0, fa->farg, totxform); |
547 |
multp3(p1, fa->farg+3, totxform); |
548 |
r0 = fa->farg[6] * totscale; |
549 |
r1 = fa->farg[7] * totscale; |
550 |
printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]); |
551 |
printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]); |
552 |
printf(" %18.12g %18.12g\n", r0, r1); |
553 |
554 |
freefargs(fa); |
555 |
return(0); |
556 |
557 |
558 |
559 |
o_cylinder(fin) /* transform cylinder and tube arguments */ |
560 |
FILE *fin; |
561 |
562 |
double p0[3], p1[3], rad; |
563 |
564 |
565 |
566 |
return(-1); |
567 |
568 |
return(-1); |
569 |
570 |
printf("0\n0\n7\n"); |
571 |
572 |
573 |
574 |
rad = fa->farg[6] * totscale; |
575 |
576 |
577 |
printf(" %18.12g\n", rad); |
578 |
freefargs(fa); |
579 |
return(0); |
580 |
581 |
582 |
583 |
o_ring(fin) /* transform ring arguments */ |
584 |
FILE *fin; |
585 |
586 |
double p0[3], pd[3], r0, r1; |
587 |
588 |
589 |
590 |
return(-1); |
591 |
592 |
return(-1); |
593 |
594 |
595 |
596 |
597 |
multv3(pd, fa->farg+3, totxform); |
598 |
599 |
600 |
601 |
printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]); |
602 |
603 |
freefargs(fa); |
604 |
return(0); |
605 |
606 |
607 |
608 |
FUNARGS * |
609 |
getfargs(fp) /* get function arguments from stream */ |
610 |
FILE *fp; |
611 |
612 |
char *strcpy(); |
613 |
char sbuf[MAXSTR]; |
614 |
int n; |
615 |
616 |
register int i; |
617 |
618 |
if ((fa = (FUNARGS *)malloc((unsigned)sizeof(FUNARGS))) == NULL) |
619 |
goto memerr; |
620 |
if (fscanf(fp, "%d", &n) != 1 || n < 0) |
621 |
return(NULL); |
622 |
if (fa->nsargs = n) { |
623 |
fa->sarg = (char **)malloc((unsigned)fa->nsargs*sizeof(char *)); |
624 |
if (fa->sarg == NULL) |
625 |
goto memerr; |
626 |
for (i = 0; i < fa->nsargs; i++) { |
627 |
if (fscanf(fp, "%s", sbuf) != 1) |
628 |
return(NULL); |
629 |
if ((fa->sarg[i] = malloc((unsigned)strlen(sbuf)+1)) == NULL) |
630 |
goto memerr; |
631 |
strcpy(fa->sarg[i], sbuf); |
632 |
633 |
} else |
634 |
fa->sarg = NULL; |
635 |
636 |
return(NULL); |
637 |
if (fa->niargs = n) { |
638 |
fa->iarg = (int *)malloc((unsigned)fa->niargs*sizeof(int)); |
639 |
if (fa->iarg == NULL) |
640 |
goto memerr; |
641 |
642 |
if (fscanf(fp, "%d", &fa->iarg[i]) != 1) |
643 |
return(NULL); |
644 |
} else |
645 |
fa->iarg = NULL; |
646 |
647 |
return(NULL); |
648 |
if (fa->nfargs = n) { |
649 |
fa->farg = (double *)malloc((unsigned)fa->nfargs*sizeof(double)); |
650 |
if (fa->farg == NULL) |
651 |
goto memerr; |
652 |
653 |
if (fscanf(fp, "%lf", &fa->farg[i]) != 1) |
654 |
return(NULL); |
655 |
} else |
656 |
fa->farg = NULL; |
657 |
return(fa); |
658 |
memerr: |
659 |
fprintf(stderr, "%s: out of memory in getfargs\n", progname); |
660 |
exit(1); |
661 |
662 |
663 |
664 |
freefargs(fa) /* free memory associated with fa */ |
665 |
666 |
667 |
register int i; |
668 |
669 |
670 |
free(fa->sarg[i]); |
671 |
if (fa->nsargs) |
672 |
free(fa->sarg); |
673 |
if (fa->niargs) |
674 |
free(fa->iarg); |
675 |
if (fa->nfargs) |
676 |
free(fa->farg); |
677 |
free(fa); |
678 |
