root/radiance/ray/src/gen/xform.c
Sun Jul 26 18:36:17 2009 UTC (15 years, 9 months ago) by greg
Changes since 2.41: +5 -5 lines
Diff to previous 2.41 , to selected 2.37
Simplification to bug fix
Sun Jul 26 18:34:59 2009 UTC (15 years, 9 months ago) by greg
Diff to previous 2.40 , to selected 2.37
Fix in last fix to avoid double-call to free()
Sat Jul 25 16:45:06 2009 UTC (15 years, 9 months ago) by greg
Changes since 2.39: +11 -3 lines
Diff to previous 2.39 , to selected 2.37
Bug fix that could cause overflow in name buffer
Wed Dec 28 18:35:42 2005 UTC (19 years, 4 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.38: +16 -9 lines
Diff to previous 2.38 , to selected 2.37
Sat Aug 21 02:59:47 2004 UTC (20 years, 8 months ago) by greg
Diff to previous 2.37
Increased command-line buffer size from 512 to 2048
Revision 2.37 - (view) (download) (annotate) - [selected]
Fri Jul 2 16:45:32 2004 UTC (20 years, 10 months ago) by greg
Diff to previous 2.36
Increased buffer size for long commands/comments in Radiance scenes
Sun Mar 28 20:33:12 2004 UTC (21 years, 1 month ago) by schorsch
Diff to previous 2.35 , to selected 2.37
Sun Nov 16 09:23:46 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 2.34: +117 -58 lines
Diff to previous 2.34 , to selected 2.37
ANSIfication, and fixed switched ac/av parameters in doargf() and doarray().
Mon Oct 27 10:27:25 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.33: +3 -2 lines
Diff to previous 2.33 , to selected 2.37
Various compatibility fixes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 2.32 , to selected 2.37
Fri Aug 29 21:44:17 2003 UTC (21 years, 8 months ago) by greg
Changes since 2.31: +3 -2 lines
Diff to previous 2.31 , to selected 2.37
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.30: +5 -5 lines
Diff to previous 2.30 , to selected 2.37
Mon Jul 14 20:02:29 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.29: +1 -4 lines
Diff to previous 2.29 , to selected 2.37
Thu Jul 3 22:41:44 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.28: +4 -2 lines
Diff to previous 2.28 , to selected 2.37
Mon Jun 30 14:59:11 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.27: +6 -5 lines
Diff to previous 2.27 , to selected 2.37
Fri Jun 27 22:27:45 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.26: +1 -2 lines
Diff to previous 2.26 , to selected 2.37
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.25 , to selected 2.37
Tue May 13 17:58:32 2003 UTC (22 years ago) by greg
Diff to previous 2.24 , to selected 2.37
Tue Mar 11 19:29:05 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.23: +4 -25 lines
Diff to previous 2.23 , to selected 2.37
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.22: +54 -40 lines
Diff to previous 2.22 , to selected 2.37
Fri Jun 4 17:24:56 1999 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 2.21 , to selected 2.37
added -e option after appended xform command for -c option
Fri Jun 4 17:06:31 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.20: +33 -10 lines
Diff to previous 2.20 , to selected 2.37
made it so -n option can be given multiple times with desired effect
Fri Jun 4 16:22:06 1999 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 2.19 , to selected 2.37
reduced size of argument buffer in doargf()
Fri Jun 4 16:00:27 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.18: +3 -1 lines
Diff to previous 2.18 , to selected 2.37
made -f option ignore leading '!' and "xform" on each line
Fri Jun 4 15:51:04 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.17: +6 -3 lines
Diff to previous 2.17 , to selected 2.37
made it so -f option ignores completely empty lines and comments
Fri Jun 4 09:26:04 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.16: +33 -17 lines
Diff to previous 2.16 , to selected 2.37
added ability to read from stdin from -f - option
Thu Jun 3 14:15:01 1999 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.15: +88 -3 lines
Diff to previous 2.15 , to selected 2.37
added -f option to read transform arguments from a file
Fri May 30 18:24:32 1997 UTC (27 years, 11 months ago) by gregl
Changes since 2.14: +3 -5 lines
Diff to previous 2.14 , to selected 2.37
fixed bug handling mist's with > 5 real arguments
Mon Jun 24 09:27:39 1996 UTC (28 years, 10 months ago) by greg
Diff to previous 2.13 , to selected 2.37
fixed bug in definition of mainfn
Tue Jun 18 21:12:51 1996 UTC (28 years, 10 months ago) by greg
Changes since 2.12: +44 -30 lines
Diff to previous 2.12 , to selected 2.37
bug fix in array option and made expansion the default
Wed Jun 12 11:55:27 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.11: +125 -17 lines
Diff to previous 2.11 , to selected 2.37
greatly improved file handling -- lib search and directory change
Mon Dec 11 09:52:11 1995 UTC (29 years, 5 months ago) by greg
Changes since 2.10: +37 -11 lines
Diff to previous 2.10 , to selected 2.37
bug fixes associated with new mist type
Fri Dec 8 18:29:06 1995 UTC (29 years, 5 months ago) by greg
Changes since 2.9: +19 -0 lines
Diff to previous 2.9 , to selected 2.37
added M_MIST type
Fri Oct 27 08:56:18 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.8: +2 -15 lines
Diff to previous 2.8 , to selected 2.37
added missing tinvers initialization for OBJ_FACE
Sat Jan 1 09:19:36 1994 UTC (31 years, 4 months ago) by greg
Changes since 2.7: +7 -1 lines
Diff to previous 2.7 , to selected 2.37
added warning about empty input
Fri Oct 2 16:12:46 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.6: +0 -2 lines
Diff to previous 2.6 , to selected 2.37
Mon Sep 21 12:15:44 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.5: +27 -26 lines
Diff to previous 2.5 , to selected 2.37
Changes for PC port
Thu Jun 25 11:49:46 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.4: +8 -10 lines
Diff to previous 2.4 , to selected 2.37
made text() more flexible for proportional spacing
Thu May 28 12:33:20 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.3: +6 -12 lines
Diff to previous 2.3 , to selected 2.37
fixed bug in xfcomm() causing some things to go unexpanded
Thu Mar 12 11:43:58 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +6 -6 lines
Diff to previous 2.2 , to selected 2.37
fixed handling of surfaces
Tue Dec 24 18:08:25 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.37
fixed bug in addxform() when arrays are used
Tue Nov 12 17:04:57 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.17 , to selected 2.37
Wed Oct 23 15:37:47 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.16: +12 -8 lines
Diff to previous 1.16 , to selected 2.37
changed double var[3] to FVECT var
Tue Oct 22 13:32:58 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.15: +33 -2 lines
Diff to previous 1.15 , to selected 2.37
added -I option to invert surfaces in scene
Tue Jul 23 15:24:21 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.14: +23 -17 lines
Diff to previous 1.14 , to selected 2.37
moved readfargs() to library
Fri Jul 19 09:43:40 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.13: +122 -202 lines
Diff to previous 1.13 , to selected 2.37
moved readfargs() and freefargs() to library
Mon Feb 18 13:45:09 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.12: +21 -15 lines
Diff to previous 1.12 , to selected 2.37
added -m option to xform
Sat Dec 15 14:58:03 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.11: +40 -44 lines
Diff to previous 1.11 , to selected 2.37
added compound matrix type
Thu Dec 13 11:51:17 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.10: +57 -59 lines
Diff to previous 1.10 , to selected 2.37
uses otypes.h for initialization and compatibility
Wed Jan 24 09:16:03 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.9: +24 -14 lines
Diff to previous 1.9 , to selected 2.37
eliminated unnecessary processing for xform -e
Fri Oct 13 19:34:17 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.8: +9 -0 lines
Diff to previous 1.8 , to selected 2.37
Improved argument error checking.
Thu Oct 5 09:49:04 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.7: +46 -3 lines
Diff to previous 1.7 , to selected 2.37
Added array capability.
Wed Oct 4 16:28:14 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.6: +18 -22 lines
Diff to previous 1.6 , to selected 2.37
Added multi-line commands.
Wed Oct 4 13:09:54 1989 UTC (35 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 2.37
Added exapand option to piped command
Wed Jun 7 10:09:07 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.4: +42 -1 lines
Diff to previous 1.4 , to selected 2.37
reinstated spot type, glow also
Wed Jun 7 08:40:59 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.3: +1 -42 lines
Diff to previous 1.3 , to selected 2.37
No more spot type, fewer parameters for glow type
Sat Apr 22 14:51:02 1989 UTC (36 years ago) by greg
Changes since 1.2: +1 -2 lines
Diff to previous 1.2 , to selected 2.37
eliminated unnecessary test
Tue Mar 14 11:36:59 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.37
added texdata type
Thu Feb 2 11:16:33 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.37
