root/radiance/ray/src/gen/xform.c
Revision: 2.25
Committed: Tue May 13 17:58:32 2003 UTC (22 years, 2 months ago) by greg
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include "standard.h"
13
14 #include "paths.h"
15
16 #include <ctype.h>
17
18 #include "object.h"
19
20 #include "otypes.h"
21
22 int xac; /* global xform argument count */
23 char **xav; /* global xform argument pointer */
24 int xfa; /* start of xf arguments */
25
26 XF tot; /* total transformation */
27 int reverse; /* boolean true if scene mirrored */
28
29 int invert; /* boolean true to invert surfaces */
30
31 int expand; /* boolean true to expand commands */
32
33 char *newmod; /* new modifier for surfaces */
34
35 char *idprefix; /* prefix for object identifiers */
36
37 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
38
39 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
40
41 int nrept = 1; /* number of array repetitions */
42
43 int stdinused = 0; /* stdin has been used by -f option? */
44
45 char mainfn[MAXPATH]; /* main file name */
46 FILE *mainfp = NULL; /* main file pointer */
47
48 #define progname (xav[0])
49
50
51 main(argc, argv) /* get transform options and transform file */
52 int argc;
53 char *argv[];
54 {
55 int mal_prefix = 0;
56 char *fname;
57 int a;
58 /* check for argument list file */
59 for (a = 1; a < argc; a++)
60 if (!strcmp(argv[a], "-f"))
61 return(doargf(argc, argv, a));
62 /* check for regular array */
63 for (a = 1; a < argc; a++)
64 if (!strcmp(argv[a], "-a"))
65 return(doarray(argc, argv, a));
66
67 initotypes(); /* initialize */
68 invert = 0;
69 expand = 1;
70 newmod = NULL;
71 idprefix = NULL;
72
73 for (a = 1; a < argc; a++) {
74 if (argv[a][0] == '-')
75 switch (argv[a][1]) {
76 case 'm':
77 if (argv[a][2] | a+1 >= argc)
78 break;
79 a++;
80 if (newmod == NULL)
81 newmod = argv[a];
82 continue;
83 case 'n':
84 if (argv[a][2] | a+1 >= argc)
85 break;
86 a++;
87 if (idprefix == NULL)
88 idprefix = argv[a];
89 else {
90 register char *newp;
91 newp = (char *)malloc(strlen(idprefix)+
92 strlen(argv[a])+2);
93 if (newp == NULL)
94 exit(2);
95 sprintf(newp, "%s.%s",
96 idprefix, argv[a]);
97 if (mal_prefix++)
98 free((void *)idprefix);
99 idprefix = newp;
100 }
101 continue;
102 case 'c':
103 if (argv[a][2])
104 break;
105 expand = 0;
106 continue;
107 case 'e':
108 if (argv[a][2])
109 break;
110 expand = 1;
111 continue;
112 case 'I':
113 if (argv[a][2])
114 break;
115 invert = !invert;
116 continue;
117 }
118 break;
119 }
120
121 xav = argv;
122 xfa = a;
123
124 a += xf(&tot, argc-a, argv+a);
125
126 if (reverse = tot.sca < 0.0)
127 tot.sca = -tot.sca;
128 if (invert)
129 reverse = !reverse;
130
131 if (a < argc && argv[a][0] == '-') {
132 fprintf(stderr, "%s: command line error at '%s'\n",
133 argv[0], argv[a]);
134 exit(1);
135 }
136
137 xac = a;
138 /* simple header */
139 putchar('#');
140 for (a = 0; a < xac; a++)
141 printf(" %s", xav[a]);
142 putchar('\n');
143 /* transform input */
144 if (xac == argc) {
145 if (stdinused) {
146 fprintf(stderr, "%s: cannot use stdin more than once\n",
147 argv[0]);
148 exit(1);
149 }
150 openmain(NULL);
151 xform(mainfn, mainfp);
152 } else
153 for (a = xac; a < argc; a++) {
154 openmain(argv[a]);
155 xform(mainfn, mainfp);
156 }
157
158 if (mal_prefix)
159 free((void *)idprefix);
160 return(0);
161 }
162
163
164 doargf(ac, av, fi) /* take argument list from file */
165 char **av;
166 int ac, fi;
167 {
168 int inquote;
169 char *newav[256], **avp;
170 char argbuf[1024];
171 char newid[128];
172 char *oldid;
173 register char *cp;
174 FILE *argfp;
175 int n, i, k, newac, err;
176
177 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
178 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
179 exit(1);
180 }
181 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
182 if (stdinused++) {
183 fprintf(stderr,
184 "%s: cannot use stdin more than once\n",
185 av[0]);
186 exit(1);
187 }
188 argfp = stdin;
189 n = 100; /* we just don't know! */
190 } else {
191 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
192 fprintf(stderr,
193 "%s: cannot open argument file \"%s\"\n",
194 av[0], av[fi+1]);
195 exit(1);
196 }
197 n = 0; /* count number of lines in file */
198 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
199 n += argbuf[0] && argbuf[0] != '#';
200 if (!n) {
201 fprintf(stderr, "%s: empty argument file \"%s\"\n",
202 av[0], av[fi+1]);
203 exit(1);
204 }
205 nrept *= n;
206 rewind(argfp);
207 }
208 err = 0; k = 0; /* read each arg list and call main */
209 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
210 if (!argbuf[0] || argbuf[0] == '#')
211 continue;
212 avp = newav+2;
213 avp[0] = av[0];
214 for (i = 1; i < fi; i++)
215 avp[i] = av[i];
216 newac = i;
217 cp = argbuf; /* parse new words */
218 if (*cp == '!') cp++;
219 if (!strncmp(cp, "xform ", 6)) cp += 6;
220 inquote = 0;
221 for ( ; ; ) {
222 skipspaces:
223 while (isspace(*cp)) /* nullify spaces */
224 *cp++ = '\0';
225 if ((*cp == '"' | *cp == '\''))
226 inquote = *cp++;
227 if (!*cp) /* all done? */
228 break;
229 if (cp[0] == '\\' && cp[1])
230 if (*++cp == '\n')
231 goto skipspaces;
232 avp[newac++] = cp; /* add argument to list */
233 if (inquote) {
234 while (*++cp)
235 if (*cp == inquote) {
236 *cp++ = '\0';
237 break;
238 }
239 } else {
240 while (*++cp && !isspace(*cp))
241 ;
242 }
243 }
244 for (i = fi+2; i < ac; i++)
245 avp[newac++] = av[i];
246 avp[newac] = NULL;
247 oldid = NULL;
248 for (i = 2; i < newac; i++)
249 if (!strcmp(avp[i-1], "-n")) {
250 oldid = avp[i];
251 avp[i] = newid;
252 break;
253 }
254 if (oldid == NULL) {
255 newav[0] = av[0];
256 newav[1] = "-n";
257 newav[2] = newid;
258 avp = newav;
259 newac += 2;
260 }
261 if (oldid == NULL)
262 sprintf(newid, "i%d", k);
263 else
264 sprintf(newid, "%s.%d", oldid, k);
265 err |= main(newac, avp);
266 k++;
267 }
268 fclose(argfp);
269 return(err);
270 }
271
272
273 doarray(ac, av, ai) /* make array */
274 char **av;
275 int ac, ai;
276 {
277 char *newav[256], **avp;
278 char newid[128], repts[32];
279 char *oldid = NULL;
280 int n, i, err;
281
282 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
283 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
284 exit(1);
285 }
286 nrept *= n;
287 avp = newav+2;
288 avp[0] = av[0];
289 for (i = 1; i < ac; i++)
290 if (!strcmp(av[i-1], "-n")) {
291 oldid = av[i];
292 avp[i] = newid;
293 } else
294 avp[i] = av[i];
295 avp[ai] = "-i";
296 avp[ai+1] = repts;
297 avp[i] = NULL;
298 if (oldid == NULL) {
299 newav[0] = av[0];
300 newav[1] = "-n";
301 newav[2] = newid;
302 avp = newav;
303 ac += 2;
304 }
305 err = 0;
306 for (i = 0; i < n; i++) {
307 if (oldid == NULL)
308 sprintf(newid, "a%d", i);
309 else
310 sprintf(newid, "%s.%d", oldid, i);
311 sprintf(repts, "%d", i);
312 err |= main(ac, avp);
313 }
314 return(err);
315 }
316
317
318 xform(name, fin) /* transform stream by tot.xfm */
319 char *name;
320 register FILE *fin;
321 {
322 int nobjs = 0;
323 register int c;
324
325 while ((c = getc(fin)) != EOF) {
326 if (isspace(c)) /* blank */
327 continue;
328 if (c == '#') { /* comment */
329 putchar(c);
330 do {
331 if ((c = getc(fin)) == EOF)
332 return;
333 putchar(c);
334 } while (c != '\n');
335 } else if (c == '!') { /* command */
336 ungetc(c, fin);
337 xfcomm(name, fin);
338 nobjs++;
339 } else { /* object */
340 ungetc(c, fin);
341 xfobject(name, fin);
342 nobjs++;
343 }
344 }
345 if (nobjs == 0)
346 fprintf(stderr, "%s: (%s): warning - empty file\n",
347 progname, name);
348 }
349
350
351 xfcomm(fname, fin) /* transform a command */
352 char *fname;
353 FILE *fin;
354 {
355 FILE *pin;
356 char buf[512];
357 int i;
358
359 fgetline(buf, sizeof(buf), fin);
360 if (expand) {
361 if ((pin = popen(buf+1, "r")) == NULL) {
362 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
363 progname, fname, buf);
364 exit(1);
365 }
366 xform(buf, pin);
367 pclose(pin);
368 } else {
369 printf("\n%s", buf);
370 if (xac > 1) {
371 printf(" | %s -e", xav[0]); /* expand next time */
372 for (i = 1; i < xac; i++)
373 if (i >= xfa || strcmp(xav[i], "-c"))
374 printf(" %s", xav[i]);
375 }
376 putchar('\n');
377 }
378 }
379
380
381 xfobject(fname, fin) /* transform an object */
382 char *fname;
383 FILE *fin;
384 {
385 char typ[16], nam[MAXSTR];
386 int fn;
387 /* modifier and type */
388 strcpy(typ, "EOF");
389 fgetword(nam, sizeof(nam), fin);
390 fgetword(typ, sizeof(typ), fin);
391 if ((fn = otype(typ)) < 0) {
392 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
393 progname, fname, typ);
394 exit(1);
395 }
396 if (ismodifier(fn))
397 printf("\n%s %s ", nam, typ);
398 else
399 printf("\n%s %s ", newmod != NULL ? newmod : nam,
400 invert ? ofun[tinvers[fn]].funame : typ);
401 /* object name */
402 fgetword(nam, sizeof(nam), fin);
403 if (idprefix == NULL || ismodifier(fn))
404 printf("%s\n", nam);
405 else
406 printf("%s.%s\n", idprefix, nam);
407 /* transform arguments */
408 if ((*ofun[fn].funp)(fin) < 0) {
409 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
410 progname, fname, ofun[fn].funame, nam);
411 exit(1);
412 }
413 }
414
415
416 o_default(fin) /* pass on arguments unchanged */
417 FILE *fin;
418 {
419 register int i;
420 FUNARGS fa;
421
422 if (readfargs(&fa, fin) != 1)
423 return(-1);
424 /* string arguments */
425 printf("%d", fa.nsargs);
426 for (i = 0; i < fa.nsargs; i++) {
427 fputc(' ', stdout);
428 fputword(fa.sarg[i], stdout);
429 }
430 printf("\n");
431 #ifdef IARGS
432 /* integer arguments */
433 printf("%d", fa.niargs);
434 for (i = 0; i < fa.niargs; i++)
435 printf(" %d", fa.iarg[i]);
436 printf("\n");
437 #else
438 printf("0\n");
439 #endif
440 /* float arguments */
441 printf("%d", fa.nfargs);
442 for (i = 0; i < fa.nfargs; i++)
443 printf(" %18.12g", fa.farg[i]);
444 printf("\n");
445 freefargs(&fa);
446 return(0);
447 }
448
449
450 addxform(fin) /* add xf arguments to strings */
451 FILE *fin;
452 {
453 register int i;
454 int resetarr = 0;
455 FUNARGS fa;
456
457 if (readfargs(&fa, fin) != 1)
458 return(-1);
459 /* string arguments */
460 if (xac > xfa && strcmp(xav[xfa], "-i"))
461 resetarr = 2;
462 printf("%d", fa.nsargs + resetarr + xac-xfa);
463 for (i = 0; i < fa.nsargs; i++) {
464 fputc(' ', stdout);
465 fputword(fa.sarg[i], stdout);
466 }
467 if (resetarr)
468 printf(" -i 1");
469 for (i = xfa; i < xac; i++) /* add xf arguments */
470 printf(" %s", xav[i]);
471 printf("\n");
472 #ifdef IARGS
473 /* integer arguments */
474 printf("%d", fa.niargs);
475 for (i = 0; i < fa.niargs; i++)
476 printf(" %d", fa.iarg[i]);
477 printf("\n");
478 #else
479 printf("0\n");
480 #endif
481 /* float arguments */
482 printf("%d", fa.nfargs);
483 for (i = 0; i < fa.nfargs; i++)
484 printf(" %18.12g", fa.farg[i]);
485 printf("\n");
486 freefargs(&fa);
487 return(0);
488 }
489
490
491 alias(fin) /* transfer alias */
492 FILE *fin;
493 {
494 char aliasnm[MAXSTR];
495
496 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
497 return(-1);
498 printf("\t%s\n", aliasnm);
499 return(0);
500 }
501
502
503 m_glow(fin) /* transform arguments for proximity light */
504 FILE *fin;
505 {
506 FUNARGS fa;
507
508 if (readfargs(&fa, fin) != 1)
509 return(-1);
510 if (fa.nsargs != 0 || fa.nfargs != 4)
511 return(-1);
512 printf("0\n0\n4");
513 printf(" %18.12g %18.12g %18.12g",
514 fa.farg[0], fa.farg[1], fa.farg[2]);
515 printf(" %18.12g\n", fa.farg[3] * tot.sca);
516 freefargs(&fa);
517 return(0);
518 }
519
520
521 m_spot(fin) /* transform arguments for spotlight */
522 FILE *fin;
523 {
524 FVECT v;
525 FUNARGS fa;
526
527 if (readfargs(&fa, fin) != 1)
528 return(-1);
529 if (fa.nsargs != 0 || fa.nfargs != 7)
530 return(-1);
531 printf("0\n0\n7");
532 printf(" %18.12g %18.12g %18.12g %18.12g\n",
533 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
534 multv3(v, fa.farg+4, tot.xfm);
535 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
536 freefargs(&fa);
537 return(0);
538 }
539
540
541 m_mist(fin) /* transform arguments for mist */
542 FILE *fin;
543 {
544 FUNARGS fa;
545 int i;
546
547 if (readfargs(&fa, fin) != 1)
548 return(-1);
549 if (fa.nfargs > 7)
550 return(-1);
551 printf("%d", fa.nsargs);
552 if (idprefix == NULL)
553 for (i = 0; i < fa.nsargs; i++)
554 printf(" %s", fa.sarg[i]);
555 else
556 for (i = 0; i < fa.nsargs; i++) {
557 char sname[256], *sp;
558 register char *cp1, *cp2 = sname;
559 /* add idprefix */
560 for (sp = fa.sarg[i]; *sp; sp = cp1) {
561 for (cp1 = idprefix; *cp1; )
562 *cp2++ = *cp1++;
563 *cp2++ = '.';
564 for (cp1 = sp; *cp1 &&
565 (*cp2++ = *cp1++) != '>'; )
566 ;
567 }
568 *cp2 = '\0';
569 printf(" %s", sname);
570 }
571 printf("\n0\n%d", fa.nfargs);
572 if (fa.nfargs > 2)
573 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
574 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
575 for (i = 3; i < fa.nfargs; i++)
576 printf(" %12.6g", fa.farg[i]);
577 printf("\n");
578 freefargs(&fa);
579 return(0);
580 }
581
582
583 m_dielectric(fin) /* transform arguments for dielectric */
584 FILE *fin;
585 {
586 FUNARGS fa;
587
588 if (readfargs(&fa, fin) != 1)
589 return(-1);
590 if (fa.nsargs != 0 || fa.nfargs != 5)
591 return(-1);
592 printf("0\n0\n5");
593 printf(" %12.6g %12.6g %12.6g",
594 pow(fa.farg[0], 1.0/tot.sca),
595 pow(fa.farg[1], 1.0/tot.sca),
596 pow(fa.farg[2], 1.0/tot.sca));
597 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
598 freefargs(&fa);
599 return(0);
600 }
601
602
603 m_interface(fin) /* transform arguments for interface */
604 FILE *fin;
605 {
606 FUNARGS fa;
607
608 if (readfargs(&fa, fin) != 1)
609 return(-1);
610 if (fa.nsargs != 0 || fa.nfargs != 8)
611 return(-1);
612 printf("0\n0\n8\n");
613 printf("%12.6g %12.6g %12.6g",
614 pow(fa.farg[0], 1.0/tot.sca),
615 pow(fa.farg[1], 1.0/tot.sca),
616 pow(fa.farg[2], 1.0/tot.sca));
617 printf(" %12.6g\n", fa.farg[3]);
618 printf("%12.6g %12.6g %12.6g",
619 pow(fa.farg[4], 1.0/tot.sca),
620 pow(fa.farg[5], 1.0/tot.sca),
621 pow(fa.farg[6], 1.0/tot.sca));
622 printf(" %12.6g\n", fa.farg[7]);
623 freefargs(&fa);
624 return(0);
625 }
626
627
628 text(fin) /* transform text arguments */
629 FILE *fin;
630 {
631 int i;
632 FVECT v;
633 FUNARGS fa;
634
635 if (readfargs(&fa, fin) != 1)
636 return(-1);
637 if (fa.nfargs < 9)
638 return(-1);
639 /* string arguments */
640 printf("%d", fa.nsargs);
641 for (i = 0; i < fa.nsargs; i++) {
642 fputc(' ', stdout);
643 fputword(fa.sarg[i], stdout);
644 }
645 printf("\n0\n%d\n", fa.nfargs);
646 /* anchor point */
647 multp3(v, fa.farg, tot.xfm);
648 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
649 /* right vector */
650 multv3(v, fa.farg+3, tot.xfm);
651 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
652 /* down vector */
653 multv3(v, fa.farg+6, tot.xfm);
654 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
655 /* remaining arguments */
656 for (i = 9; i < fa.nfargs; i++) {
657 if (i%3 == 0)
658 putchar('\n');
659 printf(" %18.12g", fa.farg[i]);
660 }
661 putchar('\n');
662 freefargs(&fa);
663 return(0);
664 }
665
666
667 o_source(fin) /* transform source arguments */
668 FILE *fin;
669 {
670 FVECT dv;
671 FUNARGS fa;
672
673 if (readfargs(&fa, fin) != 1)
674 return(-1);
675 if (fa.nsargs != 0 || fa.nfargs != 4)
676 return(-1);
677 /* transform direction vector */
678 multv3(dv, fa.farg, tot.xfm);
679 /* output */
680 printf("0\n0\n4");
681 printf(" %18.12g %18.12g %18.12g %18.12g\n",
682 dv[0], dv[1], dv[2], fa.farg[3]);
683 freefargs(&fa);
684 return(0);
685 }
686
687
688 o_sphere(fin) /* transform sphere arguments */
689 FILE *fin;
690 {
691 FVECT cent;
692 double rad;
693 FUNARGS fa;
694
695 if (readfargs(&fa, fin) != 1)
696 return(-1);
697 if (fa.nsargs != 0 || fa.nfargs != 4)
698 return(-1);
699
700 multp3(cent, fa.farg, tot.xfm); /* transform center */
701
702 rad = fa.farg[3] * tot.sca; /* scale radius */
703
704 printf("0\n0\n4");
705 printf(" %18.12g %18.12g %18.12g %18.12g\n",
706 cent[0], cent[1], cent[2], rad);
707 freefargs(&fa);
708 return(0);
709 }
710
711
712 o_face(fin) /* transform face arguments */
713 FILE *fin;
714 {
715 FVECT p;
716 register int i;
717 FUNARGS fa;
718
719 if (readfargs(&fa, fin) != 1)
720 return(-1);
721 if (fa.nsargs != 0 || fa.nfargs % 3)
722 return(-1);
723
724 printf("0\n0\n%d\n", fa.nfargs);
725
726 for (i = 0; i < fa.nfargs; i += 3) {
727 if (reverse)
728 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
729 else
730 multp3(p, fa.farg+i, tot.xfm);
731 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
732 }
733 freefargs(&fa);
734 return(0);
735 }
736
737
738 o_cone(fin) /* transform cone and cup arguments */
739 FILE *fin;
740 {
741 FVECT p0, p1;
742 double r0, r1;
743 FUNARGS fa;
744
745 if (readfargs(&fa, fin) != 1)
746 return(-1);
747 if (fa.nsargs != 0 || fa.nfargs != 8)
748 return(-1);
749
750 printf("0\n0\n8\n");
751
752 multp3(p0, fa.farg, tot.xfm);
753 multp3(p1, fa.farg+3, tot.xfm);
754 r0 = fa.farg[6] * tot.sca;
755 r1 = fa.farg[7] * tot.sca;
756 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
757 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
758 printf(" %18.12g %18.12g\n", r0, r1);
759
760 freefargs(&fa);
761 return(0);
762 }
763
764
765 o_cylinder(fin) /* transform cylinder and tube arguments */
766 FILE *fin;
767 {
768 FVECT p0, p1;
769 double rad;
770 FUNARGS fa;
771
772 if (readfargs(&fa, fin) != 1)
773 return(-1);
774 if (fa.nsargs != 0 || fa.nfargs != 7)
775 return(-1);
776
777 printf("0\n0\n7\n");
778
779 multp3(p0, fa.farg, tot.xfm);
780 multp3(p1, fa.farg+3, tot.xfm);
781 rad = fa.farg[6] * tot.sca;
782 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
783 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
784 printf(" %18.12g\n", rad);
785 freefargs(&fa);
786 return(0);
787 }
788
789
790 o_ring(fin) /* transform ring arguments */
791 FILE *fin;
792 {
793 FVECT p0, pd;
794 double r0, r1;
795 FUNARGS fa;
796
797 if (readfargs(&fa, fin) != 1)
798 return(-1);
799 if (fa.nsargs != 0 || fa.nfargs != 8)
800 return(-1);
801
802 printf("0\n0\n8\n");
803
804 multp3(p0, fa.farg, tot.xfm);
805 multv3(pd, fa.farg+3, tot.xfm);
806 if (invert) {
807 pd[0] = -pd[0];
808 pd[1] = -pd[1];
809 pd[2] = -pd[2];
810 }
811 r0 = fa.farg[6] * tot.sca;
812 r1 = fa.farg[7] * tot.sca;
813 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
814 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
815 printf(" %18.12g %18.12g\n", r0, r1);
816 freefargs(&fa);
817 return(0);
818 }
819
820
821 initotypes() /* initialize ofun[] array */
822 {
823 register int i;
824
825 if (ofun[OBJ_SOURCE].funp == o_source)
826 return; /* done already */
827 /* functions get new transform */
828 for (i = 0; i < NUMOTYPE; i++)
829 if (hasfunc(i))
830 ofun[i].funp = addxform;
831 /* special cases */
832 ofun[OBJ_SOURCE].funp = o_source;
833 ofun[OBJ_SPHERE].funp =
834 ofun[OBJ_BUBBLE].funp = o_sphere;
835 ofun[OBJ_FACE].funp = o_face;
836 ofun[OBJ_CONE].funp =
837 ofun[OBJ_CUP].funp = o_cone;
838 ofun[OBJ_CYLINDER].funp =
839 ofun[OBJ_TUBE].funp = o_cylinder;
840 ofun[OBJ_RING].funp = o_ring;
841 ofun[OBJ_INSTANCE].funp = addxform;
842 ofun[MAT_GLOW].funp = m_glow;
843 ofun[MAT_SPOT].funp = m_spot;
844 ofun[MAT_DIELECTRIC].funp = m_dielectric;
845 ofun[MAT_INTERFACE].funp = m_interface;
846 ofun[MAT_MIST].funp = m_mist;
847 ofun[PAT_CTEXT].funp =
848 ofun[PAT_BTEXT].funp =
849 ofun[MIX_TEXT].funp = text;
850 ofun[MOD_ALIAS].funp = alias;
851 /* surface inverses */
852 tinvers[OBJ_FACE] = OBJ_FACE;
853 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
854 tinvers[OBJ_CONE] = OBJ_CUP;
855 tinvers[OBJ_CUP] = OBJ_CONE;
856 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
857 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
858 tinvers[OBJ_RING] = OBJ_RING;
859 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
860 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
861 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
862 }
863
864
865 #ifdef OLDXFORM
866 openmain(fname)
867 char *fname;
868 {
869 if (fname == NULL) {
870 strcpy(mainfn, "standard input");
871 mainfp = stdin;
872 return;
873 }
874 if (mainfp != NULL) {
875 if (!strcmp(fname, mainfn)) {
876 rewind(mainfp);
877 return;
878 }
879 fclose(mainfp);
880 }
881 if ((mainfp = fopen(fname, "r")) == NULL) {
882 fprintf(stderr, "%s: cannot open file \"%s\"\n",
883 progname, fname);
884 exit(1);
885 }
886 strcpy(mainfn, fname);
887 }
888 #else
889 openmain(iname) /* open input, changing directory for file */
890 char *iname;
891 {
892 static char origdir[MAXPATH];
893 static char curfn[MAXPATH];
894 static int diffdir;
895 register char *fpath;
896
897 if (iname == NULL) { /* standard input */
898 if (mainfp == NULL) {
899 register int c;
900 strcpy(mainfn, "standard input");
901 if (nrept <= 1) {
902 mainfp = stdin;
903 return; /* just read once */
904 }
905 /* else copy */
906 if ((mainfp = tmpfile()) == NULL) {
907 fprintf(stderr,
908 "%s: cannot create temporary file\n",
909 progname);
910 exit(1);
911 }
912 while ((c = getc(stdin)) != EOF)
913 putc(c, mainfp);
914 }
915 rewind(mainfp); /* rewind copy */
916 return;
917 }
918 if (mainfp == NULL) { /* first call, initialize */
919 getwd(origdir);
920 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
921 rewind(mainfp);
922 return;
923 } else { /* else close old stream */
924 fclose(mainfp);
925 mainfp = NULL;
926 if (diffdir) { /* return to our directory */
927 chdir(origdir);
928 diffdir = 0;
929 }
930 }
931 strcpy(curfn, iname); /* remember input name */
932 /* get full path for file */
933 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
934 fprintf(stderr, "%s: cannot find file \"%s\"\n",
935 progname, iname);
936 exit(1);
937 }
938 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
939 fpath += 2;
940 /* record path name */
941 strcpy(mainfn, fpath);
942 if (expand) { /* change to local directory */
943 register char *cp = fpath + strlen(fpath); /* get dir. */
944 while (cp > fpath) {
945 cp--;
946 if (ISDIRSEP(*cp)) {
947 if (cp == fpath)
948 cp++; /* root special case */
949 break;
950 }
951 }
952 *cp = '\0';
953 if (fpath[0]) { /* change to new directory? */
954 if (chdir(fpath) < 0) {
955 fprintf(stderr,
956 "%s: cannot change directory to \"%s\"\n",
957 progname, fpath);
958 exit(1);
959 }
960 diffdir++;
961 }
962 /* get final path component */
963 for (fpath = iname+strlen(iname);
964 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
965 ;
966 }
967 /* finally, open the file */
968 if ((mainfp = fopen(fpath, "r")) == NULL) {
969 fprintf(stderr, "%s: cannot open file \"%s\"\n",
970 progname, mainfn);
971 exit(1);
972 }
973 }
974 #endif
