root/radiance/ray/src/gen/xform.c
Revision: 2.53
Committed: Tue Apr 22 14:51:29 2025 UTC (2 weeks, 6 days ago) by greg
Changes since 2.52: +3 -5 lines
fix: Changed some errors to warnings for pclose()
2 static const char RCSid[] = "$Id: xform.c,v 2.52 2025/04/22 04:45:25 greg Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtio.h"
17 #include "rtmath.h"
18 #include "object.h"
19 #include "otypes.h"
20
21 int xac; /* global xform argument count */
22 char **xav; /* global xform argument pointer */
23 int xfa; /* start of xf arguments */
24
25 XF tot; /* total transformation */
26 int reverse; /* boolean true if scene mirrored */
27
28 int invert; /* boolean true to invert surfaces */
29
30 int expand; /* boolean true to expand commands */
31
32 char *newmod; /* new modifier for surfaces */
33
34 char *idprefix; /* prefix for object identifiers */
35
36 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
37
38 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
39
40 int nrept = 1; /* number of array repetitions */
41
42 int stdinused = 0; /* stdin has been used by -f option? */
43
44 char mainfn[PATH_MAX]; /* main file name */
45 FILE *mainfp = NULL; /* main file pointer */
46
47 #define progname (xav[0])
48
49 static int doargf(int ac, char **av, int fi);
50 static int doarray(int ac, char **av, int ai);
51 static void xform(char *name, FILE *fin);
52 static void xfcomm(char *fname, FILE *fin);
53 static void xfobject(char *fname, FILE *fin);
54 static int addxform(FILE *fin);
55 static int alias(FILE *fin);
56 void initotypes(void); /* XXX conflict with otypes.h */
57 static void openmain(char *iname);
58
59
60 int
61 main( /* get transform options and transform file */
62 int argc,
63 char *argv[]
64 )
65 {
66 int mal_prefix = 0;
67 int a;
68 /* check for argument list file */
69 for (a = 1; a < argc; a++)
70 if (!strcmp(argv[a], "-f"))
71 return(doargf(argc, argv, a));
72 /* check for regular array */
73 for (a = 1; a < argc; a++)
74 if (!strcmp(argv[a], "-a"))
75 return(doarray(argc, argv, a));
76
77 initotypes(); /* initialize */
78 invert = 0;
79 expand = 1;
80 newmod = NULL;
81 idprefix = NULL;
82
83 for (a = 1; a < argc; a++) {
84 if (argv[a][0] == '-')
85 switch (argv[a][1]) {
86 case 'm':
87 if (argv[a][2] | (a+1 >= argc))
88 break;
89 a++;
90 if (newmod == NULL)
91 newmod = argv[a];
92 continue;
93 case 'n':
94 if (argv[a][2] | (a+1 >= argc))
95 break;
96 a++;
97 if (idprefix == NULL)
98 idprefix = argv[a];
99 else {
100 char *newp;
101 newp = (char *)malloc(strlen(idprefix)+
102 strlen(argv[a])+2);
103 if (newp == NULL)
104 exit(2);
105 sprintf(newp, "%s.%s",
106 idprefix, argv[a]);
107 if (mal_prefix++)
108 free(idprefix);
109 idprefix = newp;
110 }
111 continue;
112 case 'c':
113 if (argv[a][2])
114 break;
115 expand = 0;
116 continue;
117 case 'e':
118 if (argv[a][2])
119 break;
120 expand = 1;
121 continue;
122 case 'I':
123 if (argv[a][2])
124 break;
125 invert = !invert;
126 continue;
127 }
128 break;
129 }
130
131 xav = argv;
132 xfa = a;
133
134 a += xf(&tot, argc-a, argv+a);
135
136 if ( (reverse = (tot.sca < 0.0)) )
137 tot.sca = -tot.sca;
138 if (invert)
139 reverse = !reverse;
140
141 if (a < argc && argv[a][0] == '-') {
142 fprintf(stderr, "%s: command line error at '%s'\n",
143 argv[0], argv[a]);
144 exit(1);
145 }
146
147 xac = a;
148 /* simple header */
149 putchar('#');
150 for (a = 0; a < xac; a++)
151 printf(" %s", xav[a]);
152 putchar('\n');
153 /* transform input */
154 if (xac == argc) {
155 if (stdinused) {
156 fprintf(stderr, "%s: cannot use stdin more than once\n",
157 argv[0]);
158 exit(1);
159 }
160 openmain(NULL);
161 xform(mainfn, mainfp);
162 } else
163 for (a = xac; a < argc; a++) {
164 openmain(argv[a]);
165 xform(mainfn, mainfp);
166 }
167
168 if (mal_prefix)
169 free(idprefix);
170 return(0);
171 }
172
173
174 int
175 doargf( /* take argument list from file */
176 int ac,
177 char **av,
178 int fi
179 )
180 {
181 int inquote;
182 char *newav[256], **avp;
183 char argbuf[2048];
184 char *newid, newidbuf[128];
185 char *oldid;
186 char *cp;
187 FILE *argfp;
188 int n, i, k, newac, err;
189
190 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
191 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
192 exit(1);
193 }
194 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
195 if (stdinused++) {
196 fprintf(stderr,
197 "%s: cannot use stdin more than once\n",
198 av[0]);
199 exit(1);
200 }
201 argfp = stdin;
202 n = 100; /* we just don't know! */
203 } else {
204 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
205 fprintf(stderr,
206 "%s: cannot open argument file \"%s\"\n",
207 av[0], av[fi+1]);
208 exit(1);
209 }
210 n = 0; /* count number of lines in file */
211 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
212 n += (argbuf[0] != '\0') & (argbuf[0] != '#');
213 if (!n) {
214 fprintf(stderr, "%s: empty argument file \"%s\"\n",
215 av[0], av[fi+1]);
216 exit(1);
217 }
218 rewind(argfp);
219 }
220 nrept *= n;
221 err = 0; k = 0; /* read each arg list and call main */
222 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
223 if (!argbuf[0] | (argbuf[0] == '#')) {
224 printf("%s\n", argbuf);
225 continue;
226 }
227 avp = newav+2;
228 avp[0] = av[0];
229 for (i = 1; i < fi; i++)
230 avp[i] = av[i];
231 newac = i;
232 cp = argbuf; /* parse new words */
233 if (*cp == '!') cp++;
234 if (!strncmp(cp, "xform ", 6)) cp += 6;
235 inquote = 0;
236 for ( ; ; ) {
237 skipspaces:
238 while (isspace(*cp)) /* nullify spaces */
239 *cp++ = '\0';
240 if ((*cp == '"') | (*cp == '\''))
241 inquote = *cp++;
242 if (!*cp) /* all done? */
243 break;
244 if (cp[0] == '\\' && cp[1])
245 if (*++cp == '\n')
246 goto skipspaces;
247 avp[newac++] = cp; /* add argument to list */
248 if (inquote) {
249 while (*++cp)
250 if (*cp == inquote) {
251 *cp++ = '\0';
252 break;
253 }
254 } else {
255 while (*++cp && !isspace(*cp))
256 ;
257 }
258 }
259 for (i = fi+2; i < ac; i++)
260 avp[newac++] = av[i];
261 avp[newac] = NULL;
262 newid = newidbuf;
263 oldid = NULL;
264 for (i = 2; i < newac; i++)
265 if (!strcmp(avp[i-1], "-n")) {
266 oldid = avp[i];
267 if (strlen(oldid)+32 > sizeof(newidbuf)) {
268 newid = (char *)malloc(strlen(oldid)+32);
269 if (newid == NULL)
270 exit(2);
271 }
272 avp[i] = newid;
273 break;
274 }
275 if (oldid == NULL) {
276 newav[0] = av[0];
277 newav[1] = "-n";
278 newav[2] = newid;
279 avp = newav;
280 newac += 2;
281 }
282 if (oldid == NULL)
283 sprintf(newid, "i%d", k);
284 else
285 sprintf(newid, "%s.%d", oldid, k);
286 err |= main(newac, avp);
287 if (newid != newidbuf)
288 free(newid);
289 k++;
290 }
291 fclose(argfp);
292 return(err);
293 }
294
295
296 int
297 doarray( /* make array */
298 int ac,
299 char **av,
300 int ai
301 )
302 {
303 char *newav[256], **avp;
304 char newid[128], repts[32];
305 char *oldid = NULL;
306 int n, i, err;
307
308 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
309 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
310 exit(1);
311 }
312 nrept *= n;
313 avp = newav+2;
314 avp[0] = av[0];
315 for (i = 1; i < ac; i++)
316 if (!strcmp(av[i-1], "-n")) {
317 oldid = av[i];
318 avp[i] = newid;
319 } else
320 avp[i] = av[i];
321 avp[ai] = "-i";
322 avp[ai+1] = repts;
323 avp[i] = NULL;
324 if (oldid == NULL) {
325 newav[0] = av[0];
326 newav[1] = "-n";
327 newav[2] = newid;
328 avp = newav;
329 ac += 2;
330 }
331 err = 0;
332 for (i = 0; i < n; i++) {
333 if (oldid == NULL)
334 sprintf(newid, "a%d", i);
335 else
336 sprintf(newid, "%s.%d", oldid, i);
337 sprintf(repts, "%d", i);
338 err |= main(ac, avp);
339 }
340 return(err);
341 }
342
343
344 void
345 xform( /* transform stream by tot.xfm */
346 char *name,
347 FILE *fin
348 )
349 {
350 int nobjs = 0;
351 int c;
352
353 while ((c = getc(fin)) != EOF) {
354 if (isspace(c)) /* blank */
355 continue;
356 if (c == '#') { /* comment */
357 putchar(c);
358 do {
359 if ((c = getc(fin)) == EOF)
360 return;
361 putchar(c);
362 } while (c != '\n');
363 } else if (c == '!') { /* command */
364 ungetc(c, fin);
365 xfcomm(name, fin);
366 nobjs++;
367 } else { /* object */
368 ungetc(c, fin);
369 xfobject(name, fin);
370 nobjs++;
371 }
372 }
373 if (nobjs == 0)
374 fprintf(stderr, "%s: (%s): warning - empty file\n",
375 progname, name);
376 }
377
378
379 void
380 xfcomm( /* transform a command */
381 char *fname,
382 FILE *fin
383 )
384 {
385 FILE *pin;
386 char buf[2048];
387 int i;
388
389 fgetline(buf, sizeof(buf), fin);
390 if (expand) {
391 if ((pin = popen(buf+1, "r")) == NULL) {
392 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
393 progname, fname, buf);
394 exit(1);
395 }
396 xform(buf, pin);
397 if (pclose(pin) != 0)
398 fprintf(stderr, "%s: (%s): warning - bad status from \"%s\"\n",
399 progname, fname, buf);
400 } else {
401 printf("\n%s", buf);
402 if (xac > 1) {
403 printf(" | %s -e", xav[0]); /* expand next time */
404 for (i = 1; i < xac; i++)
405 if (i >= xfa || strcmp(xav[i], "-c"))
406 printf(" %s", xav[i]);
407 }
408 putchar('\n');
409 }
410 }
411
412
413 void
414 xfobject( /* transform an object */
415 char *fname,
416 FILE *fin
417 )
418 {
419 char typ[16], nam[MAXSTR];
420 int fn;
421 /* modifier and type */
422 strcpy(typ, "EOF");
423 fgetword(nam, sizeof(nam), fin);
424 fgetword(typ, sizeof(typ), fin);
425 if ((fn = otype(typ)) < 0) {
426 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
427 progname, fname, typ);
428 exit(1);
429 }
430 putchar('\n');
431 if (ismodifier(fn)) {
432 fputword(nam, stdout);
433 printf(" %s ", typ);
434 } else {
435 fputword(newmod != NULL ? newmod : nam, stdout);
436 printf(" %s ", invert ? ofun[tinvers[fn]].funame : typ);
437 }
438 /* object name */
439 fgetword(nam, sizeof(nam), fin);
440 if (idprefix == NULL || ismodifier(fn))
441 fputword(nam, stdout);
442 else {
443 char nnam[MAXSTR];
444 sprintf(nnam, "%s.%s", idprefix, nam);
445 fputword(nnam, stdout);
446 }
447 putchar('\n');
448 /* transform arguments */
449 if ((*ofun[fn].funp)(fin) < 0) {
450 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
451 progname, fname, ofun[fn].funame, nam);
452 exit(1);
453 }
454 }
455
456
457 int
458 o_default( /* pass on arguments unchanged */
459 FILE *fin
460 )
461 {
462 int i;
463 FUNARGS fa;
464
465 if (readfargs(&fa, fin) != 1)
466 return(-1);
467 /* string arguments */
468 printf("%d", fa.nsargs);
469 for (i = 0; i < fa.nsargs; i++) {
470 fputc(' ', stdout);
471 fputword(fa.sarg[i], stdout);
472 }
473 printf("\n");
474 #ifdef IARGS
475 /* integer arguments */
476 printf("%d", fa.niargs);
477 for (i = 0; i < fa.niargs; i++)
478 printf(" %d", fa.iarg[i]);
479 printf("\n");
480 #else
481 printf("0\n");
482 #endif
483 /* float arguments */
484 printf("%d", fa.nfargs);
485 for (i = 0; i < fa.nfargs; i++)
486 printf(" %18.12g", fa.farg[i]);
487 printf("\n");
488 freefargs(&fa);
489 return(0);
490 }
491
492
493 int
494 addxform( /* add xf arguments to strings */
495 FILE *fin
496 )
497 {
498 int i;
499 int resetarr = 0;
500 FUNARGS fa;
501
502 if (readfargs(&fa, fin) != 1)
503 return(-1);
504 /* string arguments */
505 if (xac > xfa && strcmp(xav[xfa], "-i"))
506 resetarr = 2;
507 printf("%d", fa.nsargs + resetarr + xac-xfa);
508 for (i = 0; i < fa.nsargs; i++) {
509 fputc(' ', stdout);
510 fputword(fa.sarg[i], stdout);
511 }
512 if (resetarr)
513 printf(" -i 1");
514 for (i = xfa; i < xac; i++) /* add xf arguments */
515 printf(" %s", xav[i]);
516 printf("\n");
517 #ifdef IARGS
518 /* integer arguments */
519 printf("%d", fa.niargs);
520 for (i = 0; i < fa.niargs; i++)
521 printf(" %d", fa.iarg[i]);
522 printf("\n");
523 #else
524 printf("0\n");
525 #endif
526 /* float arguments */
527 printf("%d", fa.nfargs);
528 for (i = 0; i < fa.nfargs; i++)
529 printf(" %18.12g", fa.farg[i]);
530 printf("\n");
531 freefargs(&fa);
532 return(0);
533 }
534
535
536 int
537 alias( /* transfer alias */
538 FILE *fin
539 )
540 {
541 char aliasnm[MAXSTR];
542
543 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
544 return(-1);
545 printf("\t%s\n", aliasnm);
546 return(0);
547 }
548
549
550 int
551 m_glow( /* transform arguments for proximity light */
552 FILE *fin
553 )
554 {
555 FUNARGS fa;
556
557 if (readfargs(&fa, fin) != 1)
558 return(-1);
559 if ((fa.nsargs != 0) | (fa.nfargs != 4))
560 return(-1);
561 printf("0\n0\n4");
562 printf(" %18.12g %18.12g %18.12g",
563 fa.farg[0], fa.farg[1], fa.farg[2]);
564 printf(" %18.12g\n", fa.farg[3] * tot.sca);
565 freefargs(&fa);
566 return(0);
567 }
568
569
570 int
571 m_spot( /* transform arguments for spotlight */
572 FILE *fin
573 )
574 {
575 FVECT v;
576 FUNARGS fa;
577
578 if (readfargs(&fa, fin) != 1)
579 return(-1);
580 if ((fa.nsargs != 0) | ( fa.nfargs != 7))
581 return(-1);
582 printf("0\n0\n7");
583 printf(" %18.12g %18.12g %18.12g %18.12g\n",
584 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
585 multv3(v, fa.farg+4, tot.xfm);
586 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
587 freefargs(&fa);
588 return(0);
589 }
590
591
592 int
593 m_mist( /* transform arguments for mist */
594 FILE *fin
595 )
596 {
597 FUNARGS fa;
598 int i;
599
600 if (readfargs(&fa, fin) != 1)
601 return(-1);
602 if (fa.nfargs > 7)
603 return(-1);
604 printf("%d", fa.nsargs);
605 if (idprefix == NULL)
606 for (i = 0; i < fa.nsargs; i++)
607 printf(" %s", fa.sarg[i]);
608 else
609 for (i = 0; i < fa.nsargs; i++) {
610 char sname[256], *sp;
611 char *cp1, *cp2 = sname;
612 /* add idprefix */
613 for (sp = fa.sarg[i]; *sp; sp = cp1) {
614 for (cp1 = idprefix; *cp1; )
615 *cp2++ = *cp1++;
616 *cp2++ = '.';
617 for (cp1 = sp; *cp1 &&
618 (*cp2++ = *cp1++) != '>'; )
619 ;
620 }
621 *cp2 = '\0';
622 printf(" %s", sname);
623 }
624 printf("\n0\n%d", fa.nfargs);
625 if (fa.nfargs > 2)
626 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
627 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
628 for (i = 3; i < fa.nfargs; i++)
629 printf(" %12.6g", fa.farg[i]);
630 printf("\n");
631 freefargs(&fa);
632 return(0);
633 }
634
635
636 int
637 m_dielectric( /* transform arguments for dielectric */
638 FILE *fin
639 )
640 {
641 FUNARGS fa;
642
643 if (readfargs(&fa, fin) != 1)
644 return(-1);
645 if (fa.nsargs != 0 || fa.nfargs != 5)
646 return(-1);
647 printf("0\n0\n5");
648 printf(" %12.6g %12.6g %12.6g",
649 pow(fa.farg[0], 1.0/tot.sca),
650 pow(fa.farg[1], 1.0/tot.sca),
651 pow(fa.farg[2], 1.0/tot.sca));
652 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
653 freefargs(&fa);
654 return(0);
655 }
656
657
658 int
659 m_interface( /* transform arguments for interface */
660 FILE *fin
661 )
662 {
663 FUNARGS fa;
664
665 if (readfargs(&fa, fin) != 1)
666 return(-1);
667 if (fa.nsargs != 0 || fa.nfargs != 8)
668 return(-1);
669 printf("0\n0\n8\n");
670 printf("%12.6g %12.6g %12.6g",
671 pow(fa.farg[0], 1.0/tot.sca),
672 pow(fa.farg[1], 1.0/tot.sca),
673 pow(fa.farg[2], 1.0/tot.sca));
674 printf(" %12.6g\n", fa.farg[3]);
675 printf("%12.6g %12.6g %12.6g",
676 pow(fa.farg[4], 1.0/tot.sca),
677 pow(fa.farg[5], 1.0/tot.sca),
678 pow(fa.farg[6], 1.0/tot.sca));
679 printf(" %12.6g\n", fa.farg[7]);
680 freefargs(&fa);
681 return(0);
682 }
683
684
685 int
686 text( /* transform text arguments */
687 FILE *fin
688 )
689 {
690 int i;
691 FVECT v;
692 FUNARGS fa;
693
694 if (readfargs(&fa, fin) != 1)
695 return(-1);
696 if (fa.nfargs < 9)
697 return(-1);
698 /* string arguments */
699 printf("%d", fa.nsargs);
700 for (i = 0; i < fa.nsargs; i++) {
701 fputc(' ', stdout);
702 fputword(fa.sarg[i], stdout);
703 }
704 printf("\n0\n%d\n", fa.nfargs);
705 /* anchor point */
706 multp3(v, fa.farg, tot.xfm);
707 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
708 /* right vector */
709 multv3(v, fa.farg+3, tot.xfm);
710 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
711 /* down vector */
712 multv3(v, fa.farg+6, tot.xfm);
713 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
714 /* remaining arguments */
715 for (i = 9; i < fa.nfargs; i++) {
716 if (i%3 == 0)
717 putchar('\n');
718 printf(" %18.12g", fa.farg[i]);
719 }
720 putchar('\n');
721 freefargs(&fa);
722 return(0);
723 }
724
725
726 int
727 o_source( /* transform source arguments */
728 FILE *fin
729 )
730 {
731 FVECT dv;
732 FUNARGS fa;
733
734 if (readfargs(&fa, fin) != 1)
735 return(-1);
736 if (fa.nsargs != 0 || fa.nfargs != 4)
737 return(-1);
738 /* transform direction vector */
739 multv3(dv, fa.farg, tot.xfm);
740 /* output */
741 printf("0\n0\n4");
742 printf(" %18.12g %18.12g %18.12g %18.12g\n",
743 dv[0], dv[1], dv[2], fa.farg[3]);
744 freefargs(&fa);
745 return(0);
746 }
747
748
749 int
750 o_sphere( /* transform sphere arguments */
751 FILE *fin
752 )
753 {
754 FVECT cent;
755 double rad;
756 FUNARGS fa;
757
758 if (readfargs(&fa, fin) != 1)
759 return(-1);
760 if (fa.nsargs != 0 || fa.nfargs != 4)
761 return(-1);
762
763 multp3(cent, fa.farg, tot.xfm); /* transform center */
764
765 rad = fa.farg[3] * tot.sca; /* scale radius */
766
767 printf("0\n0\n4");
768 printf(" %18.12g %18.12g %18.12g %18.12g\n",
769 cent[0], cent[1], cent[2], rad);
770 freefargs(&fa);
771 return(0);
772 }
773
774
775 int
776 o_face( /* transform face arguments */
777 FILE *fin
778 )
779 {
780 FVECT p;
781 int i;
782 FUNARGS fa;
783
784 if (readfargs(&fa, fin) != 1)
785 return(-1);
786 if (fa.nsargs != 0 || fa.nfargs % 3)
787 return(-1);
788
789 printf("0\n0\n%d\n", fa.nfargs);
790
791 for (i = 0; i < fa.nfargs; i += 3) {
792 if (reverse)
793 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
794 else
795 multp3(p, fa.farg+i, tot.xfm);
796 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
797 }
798 freefargs(&fa);
799 return(0);
800 }
801
802
803 int
804 o_cone( /* transform cone and cup arguments */
805 FILE *fin
806 )
807 {
808 FVECT p0, p1;
809 double r0, r1;
810 FUNARGS fa;
811
812 if (readfargs(&fa, fin) != 1)
813 return(-1);
814 if (fa.nsargs != 0 || fa.nfargs != 8)
815 return(-1);
816
817 printf("0\n0\n8\n");
818
819 multp3(p0, fa.farg, tot.xfm);
820 multp3(p1, fa.farg+3, tot.xfm);
821 r0 = fa.farg[6] * tot.sca;
822 r1 = fa.farg[7] * tot.sca;
823 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
824 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
825 printf(" %18.12g %18.12g\n", r0, r1);
826
827 freefargs(&fa);
828 return(0);
829 }
830
831
832 int
833 o_cylinder( /* transform cylinder and tube arguments */
834 FILE *fin
835 )
836 {
837 FVECT p0, p1;
838 double rad;
839 FUNARGS fa;
840
841 if (readfargs(&fa, fin) != 1)
842 return(-1);
843 if (fa.nsargs != 0 || fa.nfargs != 7)
844 return(-1);
845
846 printf("0\n0\n7\n");
847
848 multp3(p0, fa.farg, tot.xfm);
849 multp3(p1, fa.farg+3, tot.xfm);
850 rad = fa.farg[6] * tot.sca;
851 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
852 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
853 printf(" %18.12g\n", rad);
854 freefargs(&fa);
855 return(0);
856 }
857
858
859 int
860 o_ring( /* transform ring arguments */
861 FILE *fin
862 )
863 {
864 FVECT p0, pd;
865 double r0, r1;
866 FUNARGS fa;
867
868 if (readfargs(&fa, fin) != 1)
869 return(-1);
870 if (fa.nsargs != 0 || fa.nfargs != 8)
871 return(-1);
872
873 printf("0\n0\n8\n");
874
875 multp3(p0, fa.farg, tot.xfm);
876 multv3(pd, fa.farg+3, tot.xfm);
877 if (invert) {
878 pd[0] = -pd[0];
879 pd[1] = -pd[1];
880 pd[2] = -pd[2];
881 }
882 r0 = fa.farg[6] * tot.sca;
883 r1 = fa.farg[7] * tot.sca;
884 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
885 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
886 printf(" %18.12g %18.12g\n", r0, r1);
887 freefargs(&fa);
888 return(0);
889 }
890
891
892 void
893 initotypes(void) /* initialize ofun[] array */
894 {
895 int i;
896
897 if (ofun[OBJ_SOURCE].funp == o_source)
898 return; /* done already */
899 /* functions get new transform */
900 for (i = 0; i < NUMOTYPE; i++)
901 if (hasfunc(i))
902 ofun[i].funp = addxform;
903 /* special cases */
904 ofun[OBJ_SOURCE].funp = o_source;
905 ofun[OBJ_SPHERE].funp =
906 ofun[OBJ_BUBBLE].funp = o_sphere;
907 ofun[OBJ_FACE].funp = o_face;
908 ofun[OBJ_CONE].funp =
909 ofun[OBJ_CUP].funp = o_cone;
910 ofun[OBJ_CYLINDER].funp =
911 ofun[OBJ_TUBE].funp = o_cylinder;
912 ofun[OBJ_RING].funp = o_ring;
913 ofun[OBJ_INSTANCE].funp =
914 ofun[OBJ_MESH].funp = addxform;
915 ofun[MAT_GLOW].funp = m_glow;
916 ofun[MAT_SPOT].funp = m_spot;
917 ofun[MAT_DIELECTRIC].funp = m_dielectric;
918 ofun[MAT_INTERFACE].funp = m_interface;
919 ofun[MAT_MIST].funp = m_mist;
920 ofun[PAT_CTEXT].funp =
921 ofun[PAT_BTEXT].funp =
922 ofun[MIX_TEXT].funp = text;
923 ofun[MOD_ALIAS].funp = alias;
924 /* surface inverses */
925 tinvers[OBJ_FACE] = OBJ_FACE;
926 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
927 tinvers[OBJ_CONE] = OBJ_CUP;
928 tinvers[OBJ_CUP] = OBJ_CONE;
929 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
930 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
931 tinvers[OBJ_RING] = OBJ_RING;
932 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
933 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
934 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
935 tinvers[OBJ_MESH] = OBJ_MESH; /* ditto */
936 }
937
938
939 #ifdef OLDXFORM
940 void
941 openmain(
942 char *fname
943 )
944 {
945 if (fname == NULL) {
946 strcpy(mainfn, "standard input");
947 mainfp = stdin;
948 return;
949 }
950 if (mainfp != NULL) {
951 if (!strcmp(fname, mainfn)) {
952 rewind(mainfp);
953 return;
954 }
955 fclose(mainfp);
956 }
957 if ((mainfp = fopen(fname, "r")) == NULL) {
958 fprintf(stderr, "%s: cannot open file \"%s\"\n",
959 progname, fname);
960 exit(1);
961 }
962 strcpy(mainfn, fname);
963 }
964 #else
965 void
966 openmain( /* open input, changing directory for file */
967 char *iname
968 )
969 {
970 static char origdir[PATH_MAX];
971 static char curfn[PATH_MAX];
972 static int diffdir;
973 char *fpath;
974
975 if (iname == NULL) { /* standard input */
976 if (mainfp == NULL) {
977 int c;
978 strcpy(mainfn, "standard input");
979 if (nrept <= 1) {
980 mainfp = stdin;
981 return; /* just read once */
982 }
983 /* else copy */
984 if ((mainfp = tmpfile()) == NULL) {
985 fprintf(stderr,
986 "%s: cannot create temporary file\n",
987 progname);
988 exit(1);
989 }
990 while ((c = getc(stdin)) != EOF)
991 putc(c, mainfp);
992 }
993 rewind(mainfp); /* rewind copy */
994 return;
995 }
996 if (mainfp == NULL) { /* first call, initialize */
997 getcwd(origdir, sizeof(origdir));
998 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
999 rewind(mainfp);
1000 return;
1001 } else { /* else close old stream */
1002 fclose(mainfp);
1003 mainfp = NULL;
1004 if (diffdir) { /* return to our directory */
1005 chdir(origdir);
1006 diffdir = 0;
1007 }
1008 }
1009 strcpy(curfn, iname); /* remember input name */
1010 /* get full path for file */
1011 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
1012 fprintf(stderr, "%s: cannot find file \"%s\"\n",
1013 progname, iname);
1014 exit(1);
1015 }
1016 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
1017 fpath += 2;
1018 /* record path name */
1019 strcpy(mainfn, fpath);
1020 if (expand) { /* change to local directory */
1021 char *cp = fpath + strlen(fpath); /* get dir. */
1022 while (cp > fpath) {
1023 cp--;
1024 if (ISDIRSEP(*cp)) {
1025 if (cp == fpath)
1026 cp++; /* root special case */
1027 break;
1028 }
1029 }
1030 *cp = '\0';
1031 if (fpath[0]) { /* change to new directory? */
1032 if (chdir(fpath) < 0) {
1033 fprintf(stderr,
1034 "%s: cannot change directory to \"%s\"\n",
1035 progname, fpath);
1036 exit(1);
1037 }
1038 diffdir++;
1039 }
1040 /* get final path component */
1041 for (fpath = iname+strlen(iname);
1042 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
1043 ;
1044 }
1045 /* finally, open the file */
1046 if ((mainfp = fopen(fpath, "r")) == NULL) {
1047 fprintf(stderr, "%s: cannot open file \"%s\"\n",
1048 progname, mainfn);
1049 exit(1);
1050 }
1051 }
1052 #endif
