root/radiance/ray/src/gen/xform.c
Revision: 2.48
Committed: Wed Jul 9 23:14:58 2014 UTC (11 years ago) by greg
CVS Tags: rad5R0, rad4R2, rad4R2P1, rad4R2P2
Changes since 2.47: +18 -13 lines
Call unlocked version of getc()
2 static const char RCSid[] = "$Id: xform.c,v 2.47 2011/08/16 18:09:53 greg Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13
14 #include "platform.h"
15 #include "paths.h"
16 #include "rtprocess.h" /* win_popen() */
17 #include "rtio.h"
18 #include "rtmath.h"
19 #include "object.h"
20 #include "otypes.h"
21
22 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
23 #undef getc
24 #define getc getc_unlocked
25 #endif
26
27 int xac; /* global xform argument count */
28 char **xav; /* global xform argument pointer */
29 int xfa; /* start of xf arguments */
30
31 XF tot; /* total transformation */
32 int reverse; /* boolean true if scene mirrored */
33
34 int invert; /* boolean true to invert surfaces */
35
36 int expand; /* boolean true to expand commands */
37
38 char *newmod; /* new modifier for surfaces */
39
40 char *idprefix; /* prefix for object identifiers */
41
42 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
43
44 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
45
46 int nrept = 1; /* number of array repetitions */
47
48 int stdinused = 0; /* stdin has been used by -f option? */
49
50 char mainfn[PATH_MAX]; /* main file name */
51 FILE *mainfp = NULL; /* main file pointer */
52
53 #define progname (xav[0])
54
55 static int doargf(int ac, char **av, int fi);
56 static int doarray(int ac, char **av, int ai);
57 static void xform(char *name, FILE *fin);
58 static void xfcomm(char *fname, FILE *fin);
59 static void xfobject(char *fname, FILE *fin);
60 static int addxform(FILE *fin);
61 static int alias(FILE *fin);
62 void initotypes(void); /* XXX conflict with otypes.h */
63 static void openmain(char *iname);
64
65
66 int
67 main( /* get transform options and transform file */
68 int argc,
69 char *argv[]
70 )
71 {
72 int mal_prefix = 0;
73 int a;
74 /* check for argument list file */
75 for (a = 1; a < argc; a++)
76 if (!strcmp(argv[a], "-f"))
77 return(doargf(argc, argv, a));
78 /* check for regular array */
79 for (a = 1; a < argc; a++)
80 if (!strcmp(argv[a], "-a"))
81 return(doarray(argc, argv, a));
82
83 initotypes(); /* initialize */
84 invert = 0;
85 expand = 1;
86 newmod = NULL;
87 idprefix = NULL;
88
89 for (a = 1; a < argc; a++) {
90 if (argv[a][0] == '-')
91 switch (argv[a][1]) {
92 case 'm':
93 if (argv[a][2] | (a+1 >= argc))
94 break;
95 a++;
96 if (newmod == NULL)
97 newmod = argv[a];
98 continue;
99 case 'n':
100 if (argv[a][2] | (a+1 >= argc))
101 break;
102 a++;
103 if (idprefix == NULL)
104 idprefix = argv[a];
105 else {
106 char *newp;
107 newp = (char *)malloc(strlen(idprefix)+
108 strlen(argv[a])+2);
109 if (newp == NULL)
110 exit(2);
111 sprintf(newp, "%s.%s",
112 idprefix, argv[a]);
113 if (mal_prefix++)
114 free(idprefix);
115 idprefix = newp;
116 }
117 continue;
118 case 'c':
119 if (argv[a][2])
120 break;
121 expand = 0;
122 continue;
123 case 'e':
124 if (argv[a][2])
125 break;
126 expand = 1;
127 continue;
128 case 'I':
129 if (argv[a][2])
130 break;
131 invert = !invert;
132 continue;
133 }
134 break;
135 }
136
137 xav = argv;
138 xfa = a;
139
140 a += xf(&tot, argc-a, argv+a);
141
142 if ( (reverse = (tot.sca < 0.0)) )
143 tot.sca = -tot.sca;
144 if (invert)
145 reverse = !reverse;
146
147 if (a < argc && argv[a][0] == '-') {
148 fprintf(stderr, "%s: command line error at '%s'\n",
149 argv[0], argv[a]);
150 exit(1);
151 }
152
153 xac = a;
154 /* simple header */
155 putchar('#');
156 for (a = 0; a < xac; a++)
157 printf(" %s", xav[a]);
158 putchar('\n');
159 /* transform input */
160 if (xac == argc) {
161 if (stdinused) {
162 fprintf(stderr, "%s: cannot use stdin more than once\n",
163 argv[0]);
164 exit(1);
165 }
166 openmain(NULL);
167 xform(mainfn, mainfp);
168 } else
169 for (a = xac; a < argc; a++) {
170 openmain(argv[a]);
171 xform(mainfn, mainfp);
172 }
173
174 if (mal_prefix)
175 free(idprefix);
176 return(0);
177 }
178
179
180 int
181 doargf( /* take argument list from file */
182 int ac,
183 char **av,
184 int fi
185 )
186 {
187 int inquote;
188 char *newav[256], **avp;
189 char argbuf[2048];
190 char *newid, newidbuf[128];
191 char *oldid;
192 char *cp;
193 FILE *argfp;
194 int n, i, k, newac, err;
195
196 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
197 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
198 exit(1);
199 }
200 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
201 if (stdinused++) {
202 fprintf(stderr,
203 "%s: cannot use stdin more than once\n",
204 av[0]);
205 exit(1);
206 }
207 argfp = stdin;
208 n = 100; /* we just don't know! */
209 } else {
210 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
211 fprintf(stderr,
212 "%s: cannot open argument file \"%s\"\n",
213 av[0], av[fi+1]);
214 exit(1);
215 }
216 n = 0; /* count number of lines in file */
217 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
218 n += argbuf[0] && argbuf[0] != '#';
219 if (!n) {
220 fprintf(stderr, "%s: empty argument file \"%s\"\n",
221 av[0], av[fi+1]);
222 exit(1);
223 }
224 nrept *= n;
225 rewind(argfp);
226 }
227 err = 0; k = 0; /* read each arg list and call main */
228 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
229 if (!argbuf[0] || argbuf[0] == '#')
230 continue;
231 avp = newav+2;
232 avp[0] = av[0];
233 for (i = 1; i < fi; i++)
234 avp[i] = av[i];
235 newac = i;
236 cp = argbuf; /* parse new words */
237 if (*cp == '!') cp++;
238 if (!strncmp(cp, "xform ", 6)) cp += 6;
239 inquote = 0;
240 for ( ; ; ) {
241 skipspaces:
242 while (isspace(*cp)) /* nullify spaces */
243 *cp++ = '\0';
244 if ((*cp == '"') | (*cp == '\''))
245 inquote = *cp++;
246 if (!*cp) /* all done? */
247 break;
248 if (cp[0] == '\\' && cp[1])
249 if (*++cp == '\n')
250 goto skipspaces;
251 avp[newac++] = cp; /* add argument to list */
252 if (inquote) {
253 while (*++cp)
254 if (*cp == inquote) {
255 *cp++ = '\0';
256 break;
257 }
258 } else {
259 while (*++cp && !isspace(*cp))
260 ;
261 }
262 }
263 for (i = fi+2; i < ac; i++)
264 avp[newac++] = av[i];
265 avp[newac] = NULL;
266 newid = newidbuf;
267 oldid = NULL;
268 for (i = 2; i < newac; i++)
269 if (!strcmp(avp[i-1], "-n")) {
270 oldid = avp[i];
271 if (strlen(oldid)+32 > sizeof(newidbuf)) {
272 newid = (char *)malloc(strlen(oldid)+32);
273 if (newid == NULL)
274 exit(2);
275 }
276 avp[i] = newid;
277 break;
278 }
279 if (oldid == NULL) {
280 newav[0] = av[0];
281 newav[1] = "-n";
282 newav[2] = newid;
283 avp = newav;
284 newac += 2;
285 }
286 if (oldid == NULL)
287 sprintf(newid, "i%d", k);
288 else
289 sprintf(newid, "%s.%d", oldid, k);
290 err |= main(newac, avp);
291 if (newid != newidbuf)
292 free(newid);
293 k++;
294 }
295 fclose(argfp);
296 return(err);
297 }
298
299
300 int
301 doarray( /* make array */
302 int ac,
303 char **av,
304 int ai
305 )
306 {
307 char *newav[256], **avp;
308 char newid[128], repts[32];
309 char *oldid = NULL;
310 int n, i, err;
311
312 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
313 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
314 exit(1);
315 }
316 nrept *= n;
317 avp = newav+2;
318 avp[0] = av[0];
319 for (i = 1; i < ac; i++)
320 if (!strcmp(av[i-1], "-n")) {
321 oldid = av[i];
322 avp[i] = newid;
323 } else
324 avp[i] = av[i];
325 avp[ai] = "-i";
326 avp[ai+1] = repts;
327 avp[i] = NULL;
328 if (oldid == NULL) {
329 newav[0] = av[0];
330 newav[1] = "-n";
331 newav[2] = newid;
332 avp = newav;
333 ac += 2;
334 }
335 err = 0;
336 for (i = 0; i < n; i++) {
337 if (oldid == NULL)
338 sprintf(newid, "a%d", i);
339 else
340 sprintf(newid, "%s.%d", oldid, i);
341 sprintf(repts, "%d", i);
342 err |= main(ac, avp);
343 }
344 return(err);
345 }
346
347
348 void
349 xform( /* transform stream by tot.xfm */
350 char *name,
351 FILE *fin
352 )
353 {
354 int nobjs = 0;
355 int c;
356
357 while ((c = getc(fin)) != EOF) {
358 if (isspace(c)) /* blank */
359 continue;
360 if (c == '#') { /* comment */
361 putchar(c);
362 do {
363 if ((c = getc(fin)) == EOF)
364 return;
365 putchar(c);
366 } while (c != '\n');
367 } else if (c == '!') { /* command */
368 ungetc(c, fin);
369 xfcomm(name, fin);
370 nobjs++;
371 } else { /* object */
372 ungetc(c, fin);
373 xfobject(name, fin);
374 nobjs++;
375 }
376 }
377 if (nobjs == 0)
378 fprintf(stderr, "%s: (%s): warning - empty file\n",
379 progname, name);
380 }
381
382
383 void
384 xfcomm( /* transform a command */
385 char *fname,
386 FILE *fin
387 )
388 {
389 FILE *pin;
390 char buf[2048];
391 int i;
392
393 fgetline(buf, sizeof(buf), fin);
394 if (expand) {
395 if ((pin = popen(buf+1, "r")) == NULL) {
396 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
397 progname, fname, buf);
398 exit(1);
399 }
400 xform(buf, pin);
401 pclose(pin);
402 } else {
403 printf("\n%s", buf);
404 if (xac > 1) {
405 printf(" | %s -e", xav[0]); /* expand next time */
406 for (i = 1; i < xac; i++)
407 if (i >= xfa || strcmp(xav[i], "-c"))
408 printf(" %s", xav[i]);
409 }
410 putchar('\n');
411 }
412 }
413
414
415 void
416 xfobject( /* transform an object */
417 char *fname,
418 FILE *fin
419 )
420 {
421 char typ[16], nam[MAXSTR];
422 int fn;
423 /* modifier and type */
424 strcpy(typ, "EOF");
425 fgetword(nam, sizeof(nam), fin);
426 fgetword(typ, sizeof(typ), fin);
427 if ((fn = otype(typ)) < 0) {
428 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
429 progname, fname, typ);
430 exit(1);
431 }
432 putchar('\n');
433 if (ismodifier(fn)) {
434 fputword(nam, stdout);
435 printf(" %s ", typ);
436 } else {
437 fputword(newmod != NULL ? newmod : nam, stdout);
438 printf(" %s ", invert ? ofun[tinvers[fn]].funame : typ);
439 }
440 /* object name */
441 fgetword(nam, sizeof(nam), fin);
442 if (idprefix == NULL || ismodifier(fn))
443 fputword(nam, stdout);
444 else {
445 char nnam[MAXSTR];
446 sprintf(nnam, "%s.%s", idprefix, nam);
447 fputword(nnam, stdout);
448 }
449 putchar('\n');
450 /* transform arguments */
451 if ((*ofun[fn].funp)(fin) < 0) {
452 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
453 progname, fname, ofun[fn].funame, nam);
454 exit(1);
455 }
456 }
457
458
459 int
460 o_default( /* pass on arguments unchanged */
461 FILE *fin
462 )
463 {
464 int i;
465 FUNARGS fa;
466
467 if (readfargs(&fa, fin) != 1)
468 return(-1);
469 /* string arguments */
470 printf("%d", fa.nsargs);
471 for (i = 0; i < fa.nsargs; i++) {
472 fputc(' ', stdout);
473 fputword(fa.sarg[i], stdout);
474 }
475 printf("\n");
476 #ifdef IARGS
477 /* integer arguments */
478 printf("%d", fa.niargs);
479 for (i = 0; i < fa.niargs; i++)
480 printf(" %d", fa.iarg[i]);
481 printf("\n");
482 #else
483 printf("0\n");
484 #endif
485 /* float arguments */
486 printf("%d", fa.nfargs);
487 for (i = 0; i < fa.nfargs; i++)
488 printf(" %18.12g", fa.farg[i]);
489 printf("\n");
490 freefargs(&fa);
491 return(0);
492 }
493
494
495 int
496 addxform( /* add xf arguments to strings */
497 FILE *fin
498 )
499 {
500 int i;
501 int resetarr = 0;
502 FUNARGS fa;
503
504 if (readfargs(&fa, fin) != 1)
505 return(-1);
506 /* string arguments */
507 if (xac > xfa && strcmp(xav[xfa], "-i"))
508 resetarr = 2;
509 printf("%d", fa.nsargs + resetarr + xac-xfa);
510 for (i = 0; i < fa.nsargs; i++) {
511 fputc(' ', stdout);
512 fputword(fa.sarg[i], stdout);
513 }
514 if (resetarr)
515 printf(" -i 1");
516 for (i = xfa; i < xac; i++) /* add xf arguments */
517 printf(" %s", xav[i]);
518 printf("\n");
519 #ifdef IARGS
520 /* integer arguments */
521 printf("%d", fa.niargs);
522 for (i = 0; i < fa.niargs; i++)
523 printf(" %d", fa.iarg[i]);
524 printf("\n");
525 #else
526 printf("0\n");
527 #endif
528 /* float arguments */
529 printf("%d", fa.nfargs);
530 for (i = 0; i < fa.nfargs; i++)
531 printf(" %18.12g", fa.farg[i]);
532 printf("\n");
533 freefargs(&fa);
534 return(0);
535 }
536
537
538 int
539 alias( /* transfer alias */
540 FILE *fin
541 )
542 {
543 char aliasnm[MAXSTR];
544
545 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
546 return(-1);
547 printf("\t%s\n", aliasnm);
548 return(0);
549 }
550
551
552 int
553 m_glow( /* transform arguments for proximity light */
554 FILE *fin
555 )
556 {
557 FUNARGS fa;
558
559 if (readfargs(&fa, fin) != 1)
560 return(-1);
561 if (fa.nsargs != 0 || fa.nfargs != 4)
562 return(-1);
563 printf("0\n0\n4");
564 printf(" %18.12g %18.12g %18.12g",
565 fa.farg[0], fa.farg[1], fa.farg[2]);
566 printf(" %18.12g\n", fa.farg[3] * tot.sca);
567 freefargs(&fa);
568 return(0);
569 }
570
571
572 int
573 m_spot( /* transform arguments for spotlight */
574 FILE *fin
575 )
576 {
577 FVECT v;
578 FUNARGS fa;
579
580 if (readfargs(&fa, fin) != 1)
581 return(-1);
582 if (fa.nsargs != 0 || fa.nfargs != 7)
583 return(-1);
584 printf("0\n0\n7");
585 printf(" %18.12g %18.12g %18.12g %18.12g\n",
586 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
587 multv3(v, fa.farg+4, tot.xfm);
588 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
589 freefargs(&fa);
590 return(0);
591 }
592
593
594 int
595 m_mist( /* transform arguments for mist */
596 FILE *fin
597 )
598 {
599 FUNARGS fa;
600 int i;
601
602 if (readfargs(&fa, fin) != 1)
603 return(-1);
604 if (fa.nfargs > 7)
605 return(-1);
606 printf("%d", fa.nsargs);
607 if (idprefix == NULL)
608 for (i = 0; i < fa.nsargs; i++)
609 printf(" %s", fa.sarg[i]);
610 else
611 for (i = 0; i < fa.nsargs; i++) {
612 char sname[256], *sp;
613 char *cp1, *cp2 = sname;
614 /* add idprefix */
615 for (sp = fa.sarg[i]; *sp; sp = cp1) {
616 for (cp1 = idprefix; *cp1; )
617 *cp2++ = *cp1++;
618 *cp2++ = '.';
619 for (cp1 = sp; *cp1 &&
620 (*cp2++ = *cp1++) != '>'; )
621 ;
622 }
623 *cp2 = '\0';
624 printf(" %s", sname);
625 }
626 printf("\n0\n%d", fa.nfargs);
627 if (fa.nfargs > 2)
628 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
629 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
630 for (i = 3; i < fa.nfargs; i++)
631 printf(" %12.6g", fa.farg[i]);
632 printf("\n");
633 freefargs(&fa);
634 return(0);
635 }
636
637
638 int
639 m_dielectric( /* transform arguments for dielectric */
640 FILE *fin
641 )
642 {
643 FUNARGS fa;
644
645 if (readfargs(&fa, fin) != 1)
646 return(-1);
647 if (fa.nsargs != 0 || fa.nfargs != 5)
648 return(-1);
649 printf("0\n0\n5");
650 printf(" %12.6g %12.6g %12.6g",
651 pow(fa.farg[0], 1.0/tot.sca),
652 pow(fa.farg[1], 1.0/tot.sca),
653 pow(fa.farg[2], 1.0/tot.sca));
654 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
655 freefargs(&fa);
656 return(0);
657 }
658
659
660 int
661 m_interface( /* transform arguments for interface */
662 FILE *fin
663 )
664 {
665 FUNARGS fa;
666
667 if (readfargs(&fa, fin) != 1)
668 return(-1);
669 if (fa.nsargs != 0 || fa.nfargs != 8)
670 return(-1);
671 printf("0\n0\n8\n");
672 printf("%12.6g %12.6g %12.6g",
673 pow(fa.farg[0], 1.0/tot.sca),
674 pow(fa.farg[1], 1.0/tot.sca),
675 pow(fa.farg[2], 1.0/tot.sca));
676 printf(" %12.6g\n", fa.farg[3]);
677 printf("%12.6g %12.6g %12.6g",
678 pow(fa.farg[4], 1.0/tot.sca),
679 pow(fa.farg[5], 1.0/tot.sca),
680 pow(fa.farg[6], 1.0/tot.sca));
681 printf(" %12.6g\n", fa.farg[7]);
682 freefargs(&fa);
683 return(0);
684 }
685
686
687 int
688 text( /* transform text arguments */
689 FILE *fin
690 )
691 {
692 int i;
693 FVECT v;
694 FUNARGS fa;
695
696 if (readfargs(&fa, fin) != 1)
697 return(-1);
698 if (fa.nfargs < 9)
699 return(-1);
700 /* string arguments */
701 printf("%d", fa.nsargs);
702 for (i = 0; i < fa.nsargs; i++) {
703 fputc(' ', stdout);
704 fputword(fa.sarg[i], stdout);
705 }
706 printf("\n0\n%d\n", fa.nfargs);
707 /* anchor point */
708 multp3(v, fa.farg, tot.xfm);
709 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
710 /* right vector */
711 multv3(v, fa.farg+3, tot.xfm);
712 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
713 /* down vector */
714 multv3(v, fa.farg+6, tot.xfm);
715 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
716 /* remaining arguments */
717 for (i = 9; i < fa.nfargs; i++) {
718 if (i%3 == 0)
719 putchar('\n');
720 printf(" %18.12g", fa.farg[i]);
721 }
722 putchar('\n');
723 freefargs(&fa);
724 return(0);
725 }
726
727
728 int
729 o_source( /* transform source arguments */
730 FILE *fin
731 )
732 {
733 FVECT dv;
734 FUNARGS fa;
735
736 if (readfargs(&fa, fin) != 1)
737 return(-1);
738 if (fa.nsargs != 0 || fa.nfargs != 4)
739 return(-1);
740 /* transform direction vector */
741 multv3(dv, fa.farg, tot.xfm);
742 /* output */
743 printf("0\n0\n4");
744 printf(" %18.12g %18.12g %18.12g %18.12g\n",
745 dv[0], dv[1], dv[2], fa.farg[3]);
746 freefargs(&fa);
747 return(0);
748 }
749
750
751 int
752 o_sphere( /* transform sphere arguments */
753 FILE *fin
754 )
755 {
756 FVECT cent;
757 double rad;
758 FUNARGS fa;
759
760 if (readfargs(&fa, fin) != 1)
761 return(-1);
762 if (fa.nsargs != 0 || fa.nfargs != 4)
763 return(-1);
764
765 multp3(cent, fa.farg, tot.xfm); /* transform center */
766
767 rad = fa.farg[3] * tot.sca; /* scale radius */
768
769 printf("0\n0\n4");
770 printf(" %18.12g %18.12g %18.12g %18.12g\n",
771 cent[0], cent[1], cent[2], rad);
772 freefargs(&fa);
773 return(0);
774 }
775
776
777 int
778 o_face( /* transform face arguments */
779 FILE *fin
780 )
781 {
782 FVECT p;
783 int i;
784 FUNARGS fa;
785
786 if (readfargs(&fa, fin) != 1)
787 return(-1);
788 if (fa.nsargs != 0 || fa.nfargs % 3)
789 return(-1);
790
791 printf("0\n0\n%d\n", fa.nfargs);
792
793 for (i = 0; i < fa.nfargs; i += 3) {
794 if (reverse)
795 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
796 else
797 multp3(p, fa.farg+i, tot.xfm);
798 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
799 }
800 freefargs(&fa);
801 return(0);
802 }
803
804
805 int
806 o_cone( /* transform cone and cup arguments */
807 FILE *fin
808 )
809 {
810 FVECT p0, p1;
811 double r0, r1;
812 FUNARGS fa;
813
814 if (readfargs(&fa, fin) != 1)
815 return(-1);
816 if (fa.nsargs != 0 || fa.nfargs != 8)
817 return(-1);
818
819 printf("0\n0\n8\n");
820
821 multp3(p0, fa.farg, tot.xfm);
822 multp3(p1, fa.farg+3, tot.xfm);
823 r0 = fa.farg[6] * tot.sca;
824 r1 = fa.farg[7] * tot.sca;
825 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
826 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
827 printf(" %18.12g %18.12g\n", r0, r1);
828
829 freefargs(&fa);
830 return(0);
831 }
832
833
834 int
835 o_cylinder( /* transform cylinder and tube arguments */
836 FILE *fin
837 )
838 {
839 FVECT p0, p1;
840 double rad;
841 FUNARGS fa;
842
843 if (readfargs(&fa, fin) != 1)
844 return(-1);
845 if (fa.nsargs != 0 || fa.nfargs != 7)
846 return(-1);
847
848 printf("0\n0\n7\n");
849
850 multp3(p0, fa.farg, tot.xfm);
851 multp3(p1, fa.farg+3, tot.xfm);
852 rad = fa.farg[6] * tot.sca;
853 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
854 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
855 printf(" %18.12g\n", rad);
856 freefargs(&fa);
857 return(0);
858 }
859
860
861 int
862 o_ring( /* transform ring arguments */
863 FILE *fin
864 )
865 {
866 FVECT p0, pd;
867 double r0, r1;
868 FUNARGS fa;
869
870 if (readfargs(&fa, fin) != 1)
871 return(-1);
872 if (fa.nsargs != 0 || fa.nfargs != 8)
873 return(-1);
874
875 printf("0\n0\n8\n");
876
877 multp3(p0, fa.farg, tot.xfm);
878 multv3(pd, fa.farg+3, tot.xfm);
879 if (invert) {
880 pd[0] = -pd[0];
881 pd[1] = -pd[1];
882 pd[2] = -pd[2];
883 }
884 r0 = fa.farg[6] * tot.sca;
885 r1 = fa.farg[7] * tot.sca;
886 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
887 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
888 printf(" %18.12g %18.12g\n", r0, r1);
889 freefargs(&fa);
890 return(0);
891 }
892
893
894 void
895 initotypes(void) /* initialize ofun[] array */
896 {
897 int i;
898
899 if (ofun[OBJ_SOURCE].funp == o_source)
900 return; /* done already */
901 /* functions get new transform */
902 for (i = 0; i < NUMOTYPE; i++)
903 if (hasfunc(i))
904 ofun[i].funp = addxform;
905 /* special cases */
906 ofun[OBJ_SOURCE].funp = o_source;
907 ofun[OBJ_SPHERE].funp =
908 ofun[OBJ_BUBBLE].funp = o_sphere;
909 ofun[OBJ_FACE].funp = o_face;
910 ofun[OBJ_CONE].funp =
911 ofun[OBJ_CUP].funp = o_cone;
912 ofun[OBJ_CYLINDER].funp =
913 ofun[OBJ_TUBE].funp = o_cylinder;
914 ofun[OBJ_RING].funp = o_ring;
915 ofun[OBJ_INSTANCE].funp =
916 ofun[OBJ_MESH].funp = addxform;
917 ofun[MAT_GLOW].funp = m_glow;
918 ofun[MAT_SPOT].funp = m_spot;
919 ofun[MAT_DIELECTRIC].funp = m_dielectric;
920 ofun[MAT_INTERFACE].funp = m_interface;
921 ofun[MAT_MIST].funp = m_mist;
922 ofun[PAT_CTEXT].funp =
923 ofun[PAT_BTEXT].funp =
924 ofun[MIX_TEXT].funp = text;
925 ofun[MOD_ALIAS].funp = alias;
926 /* surface inverses */
927 tinvers[OBJ_FACE] = OBJ_FACE;
928 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
929 tinvers[OBJ_CONE] = OBJ_CUP;
930 tinvers[OBJ_CUP] = OBJ_CONE;
931 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
932 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
933 tinvers[OBJ_RING] = OBJ_RING;
934 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
935 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
936 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
937 tinvers[OBJ_MESH] = OBJ_MESH; /* ditto */
938 }
939
940
941 #ifdef OLDXFORM
942 void
943 openmain(
944 char *fname
945 )
946 {
947 if (fname == NULL) {
948 strcpy(mainfn, "standard input");
949 mainfp = stdin;
950 return;
951 }
952 if (mainfp != NULL) {
953 if (!strcmp(fname, mainfn)) {
954 rewind(mainfp);
955 return;
956 }
957 fclose(mainfp);
958 }
959 if ((mainfp = fopen(fname, "r")) == NULL) {
960 fprintf(stderr, "%s: cannot open file \"%s\"\n",
961 progname, fname);
962 exit(1);
963 }
964 strcpy(mainfn, fname);
965 }
966 #else
967 void
968 openmain( /* open input, changing directory for file */
969 char *iname
970 )
971 {
972 static char origdir[PATH_MAX];
973 static char curfn[PATH_MAX];
974 static int diffdir;
975 char *fpath;
976
977 if (iname == NULL) { /* standard input */
978 if (mainfp == NULL) {
979 int c;
980 strcpy(mainfn, "standard input");
981 if (nrept <= 1) {
982 mainfp = stdin;
983 return; /* just read once */
984 }
985 /* else copy */
986 if ((mainfp = tmpfile()) == NULL) {
987 fprintf(stderr,
988 "%s: cannot create temporary file\n",
989 progname);
990 exit(1);
991 }
992 while ((c = getc(stdin)) != EOF)
993 putc(c, mainfp);
994 }
995 rewind(mainfp); /* rewind copy */
996 return;
997 }
998 if (mainfp == NULL) { /* first call, initialize */
999 getcwd(origdir, sizeof(origdir));
1000 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
1001 rewind(mainfp);
1002 return;
1003 } else { /* else close old stream */
1004 fclose(mainfp);
1005 mainfp = NULL;
1006 if (diffdir) { /* return to our directory */
1007 chdir(origdir);
1008 diffdir = 0;
1009 }
1010 }
1011 strcpy(curfn, iname); /* remember input name */
1012 /* get full path for file */
1013 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
1014 fprintf(stderr, "%s: cannot find file \"%s\"\n",
1015 progname, iname);
1016 exit(1);
1017 }
1018 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
1019 fpath += 2;
1020 /* record path name */
1021 strcpy(mainfn, fpath);
1022 if (expand) { /* change to local directory */
1023 char *cp = fpath + strlen(fpath); /* get dir. */
1024 while (cp > fpath) {
1025 cp--;
1026 if (ISDIRSEP(*cp)) {
1027 if (cp == fpath)
1028 cp++; /* root special case */
1029 break;
1030 }
1031 }
1032 *cp = '\0';
1033 if (fpath[0]) { /* change to new directory? */
1034 if (chdir(fpath) < 0) {
1035 fprintf(stderr,
1036 "%s: cannot change directory to \"%s\"\n",
1037 progname, fpath);
1038 exit(1);
1039 }
1040 diffdir++;
1041 }
1042 /* get final path component */
1043 for (fpath = iname+strlen(iname);
1044 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
1045 ;
1046 }
1047 /* finally, open the file */
1048 if ((mainfp = fopen(fpath, "r")) == NULL) {
1049 fprintf(stderr, "%s: cannot open file \"%s\"\n",
1050 progname, mainfn);
1051 exit(1);
1052 }
1053 }
1054 #endif
