root/radiance/ray/src/gen/sun.c
Thu Nov 7 23:15:07 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.6: +68 -12 lines
Added more accurate Michalsky solar position calculation and made correction to old IES handbook formula (thanks to Axel Jacobs)
Fri Aug 9 16:51:15 2013 UTC (10 years, 8 months ago) by greg
Added header file for solar position calculations
Sat Jun 6 20:18:32 2009 UTC (14 years, 10 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 2.4: +6 -2 lines
Sun Nov 16 10:29:38 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.3: +19 -11 lines
Changes since 2.2: +1 -4 lines
Fri Oct 2 16:12:29 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.1: +2 -8 lines
Diff to previous 2.1
Tue Nov 12 17:04:42 1991 UTC (32 years, 5 months ago) by greg
Sun Sep 10 16:45:19 1989 UTC (34 years, 7 months ago) by greg
fixed location of SCCSid
Thu Feb 2 11:16:32 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.2
