root/radiance/ray/src/gen/replmarks.c
Revision: 2.23
Committed: Sat Jun 7 05:09:45 2025 UTC (7 days, 13 hours ago) by greg
Changes since 2.22: +1 -2 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.23 static const char RCSid[] = "$Id: replmarks.c,v 2.22 2025/06/03 21:31:51 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Replace markers in Radiance scene description with objects or instances.
6     *
7     * Created: 17 Feb 1991 Greg Ward
8     */
9
10 greg 2.5 #include <stdlib.h>
11 greg 1.1 #include <ctype.h>
12     #include <math.h>
13 schorsch 2.7 #include <stdio.h>
14 greg 1.1
15 schorsch 2.7 #include "platform.h"
16 schorsch 2.9 #include "rtio.h"
17 greg 1.1 #include "fvect.h"
18
19     #ifdef M_PI
20 gregl 2.4 #define PI ((double)M_PI)
21 greg 1.1 #else
22     #define PI 3.14159265358979323846
23     #endif
24
25     #define MAXVERT 6 /* maximum number of vertices for markers */
26 greg 2.13 #define MAXMARK 128 /* maximum number of markers */
27 greg 1.1
28 greg 2.11 #define USE_XFORM 1 /* use !xform inline command */
29     #define USE_INSTANCE 2 /* use instance primitive */
30     #define USE_MESH 3 /* use mesh primitive */
31
32 greg 1.1 typedef struct {
33     short beg, end; /* beginning and ending vertex */
34     float len2; /* length squared */
35     } EDGE; /* a marker edge */
36
37 greg 2.2 struct mrkr {
38     char *modout; /* output modifier */
39     double mscale; /* scale by this to get unit */
40     char *modin; /* input modifier indicating marker */
41     char *objname; /* output object file or octree */
42 greg 2.11 int usetype; /* one of USE_* above */
43 greg 2.13 } marker[MAXMARK+1]; /* array of markers */
44 greg 2.2 int nmarkers = 0; /* number of markers */
45 greg 1.1
46 greg 2.2 int expand; /* expand commands? */
47 greg 1.1
48 schorsch 2.9 static void convert(char *name, FILE *fin);
49     static void cvcomm(char *fname, FILE *fin);
50     static void cvobject(char *fname, FILE *fin);
51     static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin);
52     static int edgecmp(const void *e1, const void *e2);
53     static int buildxf(char *xf, double markscale, FILE *fin);
54     static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp);
55 greg 1.1
56 schorsch 2.9
57     int
58     main(
59     int argc,
60     char *argv[]
61     )
62 greg 1.1 {
63     FILE *fp;
64     int i, j;
65
66 greg 2.22 fixargv0(argv[0]); /* sets global progname */
67 greg 2.2 i = 1;
68     while (i < argc && argv[i][0] == '-') {
69     do {
70     switch (argv[i][1]) {
71     case 'i':
72 greg 2.11 marker[nmarkers].usetype = USE_INSTANCE;
73     marker[nmarkers].objname = argv[++i];
74     break;
75     case 'I':
76     marker[nmarkers].usetype = USE_MESH;
77 greg 2.2 marker[nmarkers].objname = argv[++i];
78     break;
79     case 'x':
80 greg 2.11 marker[nmarkers].usetype = USE_XFORM;
81 greg 2.2 marker[nmarkers].objname = argv[++i];
82     break;
83     case 'e':
84     expand = 1;
85     break;
86     case 'm':
87     marker[nmarkers].modout = argv[++i];
88     break;
89     case 's':
90     marker[nmarkers].mscale = atof(argv[++i]);
91     break;
92     default:
93     goto userr;
94     }
95     if (++i >= argc)
96     goto userr;
97     } while (argv[i][0] == '-');
98     if (marker[nmarkers].objname == NULL)
99     goto userr;
100 greg 2.13 if (nmarkers >= MAXMARK) {
101     fprintf(stderr, "%s: too many markers\n", progname);
102     return 1;
103     }
104 greg 2.2 marker[nmarkers++].modin = argv[i++];
105     marker[nmarkers].mscale = marker[nmarkers-1].mscale;
106     }
107     if (nmarkers == 0)
108 greg 1.1 goto userr;
109     /* simple header */
110     putchar('#');
111     for (j = 0; j < i; j++) {
112     putchar(' ');
113     fputs(argv[j], stdout);
114     }
115     putchar('\n');
116     if (i == argc)
117     convert("<stdin>", stdin);
118     else
119     for ( ; i < argc; i++) {
120     if ((fp = fopen(argv[i], "r")) == NULL) {
121     perror(argv[i]);
122     exit(1);
123     }
124     convert(argv[i], fp);
125     fclose(fp);
126     }
127 schorsch 2.9 return 0;
128 greg 1.1 userr:
129     fprintf(stderr,
130 greg 2.11 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n",
131 greg 1.1 progname);
132 schorsch 2.9 return 1;
133 greg 1.1 }
134
135
136 schorsch 2.9 void
137     convert( /* replace marks in a stream */
138     char *name,
139 greg 2.21 FILE *fin
140 schorsch 2.9 )
141 greg 1.1 {
142 greg 2.21 int c;
143 greg 1.1
144     while ((c = getc(fin)) != EOF) {
145     if (isspace(c)) /* blank */
146     continue;
147     if (c == '#') { /* comment */
148     putchar(c);
149     do {
150     if ((c = getc(fin)) == EOF)
151     return;
152     putchar(c);
153     } while (c != '\n');
154     } else if (c == '!') { /* command */
155     ungetc(c, fin);
156     cvcomm(name, fin);
157     } else { /* object */
158     ungetc(c, fin);
159     cvobject(name, fin);
160     }
161     }
162     }
163
164
165 schorsch 2.9 void
166     cvcomm( /* convert a command */
167     char *fname,
168     FILE *fin
169     )
170 greg 1.1 {
171 schorsch 2.8 FILE *pin;
172 greg 2.21 char buf[512];
173 greg 1.1
174     fgetline(buf, sizeof(buf), fin);
175     if (expand) {
176     if ((pin = popen(buf+1, "r")) == NULL) {
177     fprintf(stderr,
178     "%s: (%s): cannot execute \"%s\"\n",
179     progname, fname, buf);
180     exit(1);
181     }
182     convert(buf, pin);
183 greg 2.20 if (pclose(pin) != 0)
184 greg 2.19 fprintf(stderr,
185 greg 2.20 "%s: (%s): warning - bad status from \"%s\"\n",
186 greg 2.19 progname, fname, buf);
187 greg 1.1 } else
188     printf("\n%s\n", buf);
189     }
190
191
192 schorsch 2.9 void
193     cvobject( /* convert an object */
194     char *fname,
195     FILE *fin
196     )
197 greg 1.1 {
198     char buf[128], typ[16], nam[128];
199 greg 2.2 int i, n;
200 greg 2.21 int j;
201 greg 1.1
202 greg 2.14 if (fgetword(buf, sizeof(buf), fin) == NULL ||
203     fgetword(typ, sizeof(typ), fin) == NULL ||
204     fgetword(nam, sizeof(nam), fin) == NULL)
205 greg 1.1 goto readerr;
206 greg 2.2 if (!strcmp(typ, "polygon"))
207     for (j = 0; j < nmarkers; j++)
208     if (!strcmp(buf, marker[j].modin)) {
209     replace(fname, &marker[j], nam, fin);
210     return;
211     }
212 greg 2.14 putchar('\n'); fputword(buf, stdout);
213     printf(" %s ", typ);
214     fputword(nam, stdout); putchar('\n');
215 greg 1.1 if (!strcmp(typ, "alias")) { /* alias special case */
216 greg 2.14 if (fgetword(buf, sizeof(buf), fin) == NULL)
217 greg 1.1 goto readerr;
218 greg 2.14 putchar('\t'); fputword(buf, stdout); putchar('\n');
219 greg 1.1 return;
220     }
221     for (i = 0; i < 3; i++) { /* pass along arguments */
222     if (fscanf(fin, "%d", &n) != 1)
223     goto readerr;
224     printf("%d", n);
225     for (j = 0; j < n; j++) {
226 greg 2.5 if (fgetword(buf, sizeof(buf), fin) == NULL)
227 greg 1.1 goto readerr;
228     if (j%3 == 0)
229     putchar('\n');
230 greg 2.5 putchar('\t');
231     fputword(buf, stdout);
232 greg 1.1 }
233     putchar('\n');
234     }
235     return;
236     readerr:
237     fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
238     progname, fname, typ, nam);
239     }
240
241
242 schorsch 2.9 void
243     replace( /* replace marker */
244     char *fname,
245 greg 2.21 struct mrkr *m,
246 schorsch 2.9 char *mark,
247     FILE *fin
248     )
249 greg 1.1 {
250     int n;
251     char buf[256];
252
253 greg 2.5 buf[0] = '\0'; /* bug fix thanks to schorsch */
254 greg 2.11 if (m->usetype == USE_XFORM) {
255 greg 2.10 sprintf(buf, "xform -n %s", mark);
256 greg 2.2 if (m->modout != NULL)
257     sprintf(buf+strlen(buf), " -m %s", m->modout);
258     if (buildxf(buf+strlen(buf), m->mscale, fin) < 0)
259 greg 1.1 goto badxf;
260 greg 2.2 sprintf(buf+strlen(buf), " %s", m->objname);
261 greg 1.1 if (expand) {
262     fflush(stdout);
263     system(buf);
264     } else
265     printf("\n!%s\n", buf);
266     } else {
267 greg 2.2 if ((n = buildxf(buf, m->mscale, fin)) < 0)
268 greg 1.1 goto badxf;
269 greg 2.11 printf("\n%s %s %s\n",
270     m->modout==NULL?"void":m->modout,
271     m->usetype==USE_INSTANCE?"instance":"mesh",
272     mark);
273 greg 2.2 printf("%d %s%s\n0\n0\n", n+1, m->objname, buf);
274 greg 1.1 }
275     return;
276     badxf:
277     fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
278     progname, fname, mark);
279     exit(1);
280     }
281
282
283 schorsch 2.9 int
284     edgecmp( /* compare two edges, descending order */
285     const void *e1,
286     const void *e2
287     )
288 greg 1.1 {
289 schorsch 2.9 if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2)
290 greg 1.1 return(-1);
291 schorsch 2.9 if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2)
292 greg 1.1 return(1);
293     return(0);
294     }
295
296
297     int
298 schorsch 2.9 buildxf( /* build transform for marker */
299 greg 2.21 char *xf,
300 schorsch 2.9 double markscale,
301     FILE *fin
302     )
303 greg 1.1 {
304     static FVECT vlist[MAXVERT];
305     static EDGE elist[MAXVERT];
306     FVECT xvec, yvec, zvec;
307     double xlen;
308     int n;
309 greg 2.21 int i;
310 greg 1.1 /*
311     * Read and sort vectors: longest is hypotenuse,
312     * second longest is x' axis,
313     * third longest is y' axis (approximate),
314     * other vectors are ignored.
315     * It is an error if the x' and y' axes do
316     * not share a common vertex (their origin).
317     */
318     if (fscanf(fin, "%*d %*d %d", &n) != 1)
319     return(-1);
320     if (n%3 != 0)
321     return(-1);
322     n /= 3;
323     if (n < 3 || n > MAXVERT)
324     return(-1);
325     /* sort edges in descending order */
326     for (i = 0; i < n; i++) {
327     if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
328     &vlist[i][1], &vlist[i][2]) != 3)
329     return(-1);
330     if (i) {
331     elist[i].beg = i-1;
332     elist[i].end = i;
333     elist[i].len2 = dist2(vlist[i-1],vlist[i]);
334     }
335     }
336     elist[0].beg = n-1;
337     elist[0].end = 0;
338     elist[0].len2 = dist2(vlist[n-1],vlist[0]);
339     qsort(elist, n, sizeof(EDGE), edgecmp);
340     /* find x' and y' */
341     if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
342     i = elist[1].beg;
343     elist[1].beg = elist[1].end;
344     elist[1].end = i;
345     }
346     if (elist[2].end == elist[1].beg) {
347     i = elist[2].beg;
348     elist[2].beg = elist[2].end;
349     elist[2].end = i;
350     }
351     if (elist[1].beg != elist[2].beg)
352     return(-1); /* x' and y' not connected! */
353     for (i = 0; i < 3; i++) {
354     xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
355     yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
356     }
357     if ((xlen = normalize(xvec)) == 0.0)
358     return(-1);
359     fcross(zvec, xvec, yvec);
360     if (normalize(zvec) == 0.0)
361     return(-1);
362     fcross(yvec, zvec, xvec);
363     n = 0; /* start transformation... */
364     if (markscale > 0.0) { /* add scale factor */
365     sprintf(xf, " -s %f", xlen*markscale);
366     n += 2;
367 greg 2.5 while (*xf) ++xf;
368 greg 1.1 }
369     /* add rotation */
370     n += addrot(xf, xvec, yvec, zvec);
371 greg 2.5 while (*xf) ++xf;
372 greg 1.1 /* add translation */
373     n += 4;
374     sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
375     vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
376     return(n); /* all done */
377     }
378
379
380 schorsch 2.9 int
381     addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
382 greg 2.21 char *xf,
383 schorsch 2.9 FVECT xp,
384     FVECT yp,
385     FVECT zp
386     )
387 greg 1.1 {
388 greg 1.2 int n;
389     double theta;
390 greg 1.1
391 greg 2.15 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
392     /* Special case for X' along Z-axis */
393     theta = -atan2(yp[0], yp[1]);
394     sprintf(xf, " -ry %f -rz %f",
395     xp[2] < 0.0 ? 90.0 : -90.0,
396     theta*(180./PI));
397     return(4);
398     }
399 greg 1.2 n = 0;
400     theta = atan2(yp[2], zp[2]);
401 greg 2.18 if (!FABSEQ(theta,0.0)) {
402 greg 1.2 sprintf(xf, " -rx %f", theta*(180./PI));
403 greg 2.5 while (*xf) ++xf;
404 greg 1.2 n += 2;
405     }
406 greg 2.16 theta = Asin(-xp[2]);
407 greg 2.18 if (!FABSEQ(theta,0.0)) {
408 greg 1.2 sprintf(xf, " -ry %f", theta*(180./PI));
409 greg 2.5 while (*xf) ++xf;
410 greg 1.2 n += 2;
411     }
412     theta = atan2(xp[1], xp[0]);
413 greg 2.18 if (!FABSEQ(theta,0.0)) {
414 greg 1.2 sprintf(xf, " -rz %f", theta*(180./PI));
415 greg 2.5 /* while (*xf) ++xf; */
416 greg 1.2 n += 2;
417     }
418     return(n);
419 greg 1.1 }
