root/radiance/ray/src/gen/replmarks.c
Revision: 2.12
Committed: Tue Sep 28 17:54:18 2004 UTC (19 years, 6 months ago) by greg
5 * Replace markers in Radiance scene description with objects or instances.
6 *
7 * Created: 17 Feb 1991 Greg Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include <math.h>
13 #include <stdio.h>
14
15 #include "platform.h"
16 #include "rtio.h"
17 #include "rtprocess.h"
18 #include "fvect.h"
19
20 #ifdef M_PI
21 #define PI ((double)M_PI)
22 #else
23 #define PI 3.14159265358979323846
24 #endif
25
26 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
27
28 #define MAXVERT 6 /* maximum number of vertices for markers */
29 #define MAXMARK 32 /* maximum number of markers */
30
31 #define USE_XFORM 1 /* use !xform inline command */
32 #define USE_INSTANCE 2 /* use instance primitive */
33 #define USE_MESH 3 /* use mesh primitive */
34
35 typedef struct {
36 short beg, end; /* beginning and ending vertex */
37 float len2; /* length squared */
38 } EDGE; /* a marker edge */
39
40 struct mrkr {
41 char *modout; /* output modifier */
42 double mscale; /* scale by this to get unit */
43 char *modin; /* input modifier indicating marker */
44 char *objname; /* output object file or octree */
45 int usetype; /* one of USE_* above */
46 } marker[MAXMARK]; /* array of markers */
47 int nmarkers = 0; /* number of markers */
48
49 int expand; /* expand commands? */
50
51 char *progname;
52
53 static void convert(char *name, FILE *fin);
54 static void cvcomm(char *fname, FILE *fin);
55 static void cvobject(char *fname, FILE *fin);
56 static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin);
57 static int edgecmp(const void *e1, const void *e2);
58 static int buildxf(char *xf, double markscale, FILE *fin);
59 static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp);
60
61
62 int
63 main(
64 int argc,
65 char *argv[]
66 )
67 {
68 FILE *fp;
69 int i, j;
70
71 progname = argv[0];
72 i = 1;
73 while (i < argc && argv[i][0] == '-') {
74 do {
75 switch (argv[i][1]) {
76 case 'i':
77 marker[nmarkers].usetype = USE_INSTANCE;
78 marker[nmarkers].objname = argv[++i];
79 break;
80 case 'I':
81 marker[nmarkers].usetype = USE_MESH;
82 marker[nmarkers].objname = argv[++i];
83 break;
84 case 'x':
85 marker[nmarkers].usetype = USE_XFORM;
86 marker[nmarkers].objname = argv[++i];
87 break;
88 case 'e':
89 expand = 1;
90 break;
91 case 'm':
92 marker[nmarkers].modout = argv[++i];
93 break;
94 case 's':
95 marker[nmarkers].mscale = atof(argv[++i]);
96 break;
97 default:
98 goto userr;
99 }
100 if (++i >= argc)
101 goto userr;
102 } while (argv[i][0] == '-');
103 if (marker[nmarkers].objname == NULL)
104 goto userr;
105 marker[nmarkers++].modin = argv[i++];
106 if (nmarkers >= MAXMARK)
107 break;
108 marker[nmarkers].mscale = marker[nmarkers-1].mscale;
109 }
110 if (nmarkers == 0)
111 goto userr;
112 /* simple header */
113 putchar('#');
114 for (j = 0; j < i; j++) {
115 putchar(' ');
116 fputs(argv[j], stdout);
117 }
118 putchar('\n');
119 if (i == argc)
120 convert("<stdin>", stdin);
121 else
122 for ( ; i < argc; i++) {
123 if ((fp = fopen(argv[i], "r")) == NULL) {
124 perror(argv[i]);
125 exit(1);
126 }
127 convert(argv[i], fp);
128 fclose(fp);
129 }
130 return 0;
131 userr:
132 fprintf(stderr,
133 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n",
134 progname);
135 return 1;
136 }
137
138
139 void
140 convert( /* replace marks in a stream */
141 char *name,
142 register FILE *fin
143 )
144 {
145 register int c;
146
147 while ((c = getc(fin)) != EOF) {
148 if (isspace(c)) /* blank */
149 continue;
150 if (c == '#') { /* comment */
151 putchar(c);
152 do {
153 if ((c = getc(fin)) == EOF)
154 return;
155 putchar(c);
156 } while (c != '\n');
157 } else if (c == '!') { /* command */
158 ungetc(c, fin);
159 cvcomm(name, fin);
160 } else { /* object */
161 ungetc(c, fin);
162 cvobject(name, fin);
163 }
164 }
165 }
166
167
168 void
169 cvcomm( /* convert a command */
170 char *fname,
171 FILE *fin
172 )
173 {
174 FILE *pin;
175 char buf[512], *fgetline();
176
177 fgetline(buf, sizeof(buf), fin);
178 if (expand) {
179 if ((pin = popen(buf+1, "r")) == NULL) {
180 fprintf(stderr,
181 "%s: (%s): cannot execute \"%s\"\n",
182 progname, fname, buf);
183 exit(1);
184 }
185 convert(buf, pin);
186 pclose(pin);
187 } else
188 printf("\n%s\n", buf);
189 }
190
191
192 void
193 cvobject( /* convert an object */
194 char *fname,
195 FILE *fin
196 )
197 {
198 extern char *fgetword();
199 char buf[128], typ[16], nam[128];
200 int i, n;
201 register int j;
202
203 if (fscanf(fin, "%s %s %s", buf, typ, nam) != 3)
204 goto readerr;
205 if (!strcmp(typ, "polygon"))
206 for (j = 0; j < nmarkers; j++)
207 if (!strcmp(buf, marker[j].modin)) {
208 replace(fname, &marker[j], nam, fin);
209 return;
210 }
211 printf("\n%s %s %s\n", buf, typ, nam);
212 if (!strcmp(typ, "alias")) { /* alias special case */
213 if (fscanf(fin, "%s", buf) != 1)
214 goto readerr;
215 printf("\t%s\n", buf);
216 return;
217 }
218 for (i = 0; i < 3; i++) { /* pass along arguments */
219 if (fscanf(fin, "%d", &n) != 1)
220 goto readerr;
221 printf("%d", n);
222 for (j = 0; j < n; j++) {
223 if (fgetword(buf, sizeof(buf), fin) == NULL)
224 goto readerr;
225 if (j%3 == 0)
226 putchar('\n');
227 putchar('\t');
228 fputword(buf, stdout);
229 }
230 putchar('\n');
231 }
232 return;
233 readerr:
234 fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
235 progname, fname, typ, nam);
236 }
237
238
239 void
240 replace( /* replace marker */
241 char *fname,
242 register struct mrkr *m,
243 char *mark,
244 FILE *fin
245 )
246 {
247 int n;
248 char buf[256];
249
250 buf[0] = '\0'; /* bug fix thanks to schorsch */
251 if (m->usetype == USE_XFORM) {
252 sprintf(buf, "xform -n %s", mark);
253 if (m->modout != NULL)
254 sprintf(buf+strlen(buf), " -m %s", m->modout);
255 if (buildxf(buf+strlen(buf), m->mscale, fin) < 0)
256 goto badxf;
257 sprintf(buf+strlen(buf), " %s", m->objname);
258 if (expand) {
259 fflush(stdout);
260 system(buf);
261 } else
262 printf("\n!%s\n", buf);
263 } else {
264 if ((n = buildxf(buf, m->mscale, fin)) < 0)
265 goto badxf;
266 printf("\n%s %s %s\n",
267 m->modout==NULL?"void":m->modout,
268 m->usetype==USE_INSTANCE?"instance":"mesh",
269 mark);
270 printf("%d %s%s\n0\n0\n", n+1, m->objname, buf);
271 }
272 return;
273 badxf:
274 fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
275 progname, fname, mark);
276 exit(1);
277 }
278
279
280 int
281 edgecmp( /* compare two edges, descending order */
282 const void *e1,
283 const void *e2
284 )
285 {
286 if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2)
287 return(-1);
288 if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2)
289 return(1);
290 return(0);
291 }
292
293
294 int
295 buildxf( /* build transform for marker */
296 register char *xf,
297 double markscale,
298 FILE *fin
299 )
300 {
301 static FVECT vlist[MAXVERT];
302 static EDGE elist[MAXVERT];
303 FVECT xvec, yvec, zvec;
304 double xlen;
305 int n;
306 register int i;
307 /*
308 * Read and sort vectors: longest is hypotenuse,
309 * second longest is x' axis,
310 * third longest is y' axis (approximate),
311 * other vectors are ignored.
312 * It is an error if the x' and y' axes do
313 * not share a common vertex (their origin).
314 */
315 if (fscanf(fin, "%*d %*d %d", &n) != 1)
316 return(-1);
317 if (n%3 != 0)
318 return(-1);
319 n /= 3;
320 if (n < 3 || n > MAXVERT)
321 return(-1);
322 /* sort edges in descending order */
323 for (i = 0; i < n; i++) {
324 if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
325 &vlist[i][1], &vlist[i][2]) != 3)
326 return(-1);
327 if (i) {
328 elist[i].beg = i-1;
329 elist[i].end = i;
330 elist[i].len2 = dist2(vlist[i-1],vlist[i]);
331 }
332 }
333 elist[0].beg = n-1;
334 elist[0].end = 0;
335 elist[0].len2 = dist2(vlist[n-1],vlist[0]);
336 qsort(elist, n, sizeof(EDGE), edgecmp);
337 /* find x' and y' */
338 if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
339 i = elist[1].beg;
340 elist[1].beg = elist[1].end;
341 elist[1].end = i;
342 }
343 if (elist[2].end == elist[1].beg) {
344 i = elist[2].beg;
345 elist[2].beg = elist[2].end;
346 elist[2].end = i;
347 }
348 if (elist[1].beg != elist[2].beg)
349 return(-1); /* x' and y' not connected! */
350 for (i = 0; i < 3; i++) {
351 xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
352 yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
353 }
354 if ((xlen = normalize(xvec)) == 0.0)
355 return(-1);
356 fcross(zvec, xvec, yvec);
357 if (normalize(zvec) == 0.0)
358 return(-1);
359 fcross(yvec, zvec, xvec);
360 n = 0; /* start transformation... */
361 if (markscale > 0.0) { /* add scale factor */
362 sprintf(xf, " -s %f", xlen*markscale);
363 n += 2;
364 while (*xf) ++xf;
365 }
366 /* add rotation */
367 n += addrot(xf, xvec, yvec, zvec);
368 while (*xf) ++xf;
369 /* add translation */
370 n += 4;
371 sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
372 vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
373 return(n); /* all done */
374 }
375
376
377 int
378 addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
379 register char *xf,
380 FVECT xp,
381 FVECT yp,
382 FVECT zp
383 )
384 {
385 int n;
386 double theta;
387
388 n = 0;
389 theta = atan2(yp[2], zp[2]);
390 if (!FEQ(theta,0.0)) {
391 sprintf(xf, " -rx %f", theta*(180./PI));
392 while (*xf) ++xf;
393 n += 2;
394 }
395 theta = asin(-xp[2]);
396 if (!FEQ(theta,0.0)) {
397 sprintf(xf, " -ry %f", theta*(180./PI));
398 while (*xf) ++xf;
399 n += 2;
400 }
401 theta = atan2(xp[1], xp[0]);
402 if (!FEQ(theta,0.0)) {
403 sprintf(xf, " -rz %f", theta*(180./PI));
404 /* while (*xf) ++xf; */
405 n += 2;
406 }
407 return(n);
408 }
