root/radiance/ray/src/gen/replmarks.c
Revision: 1.1
Committed: Sun Feb 17 22:36:30 1991 UTC (33 years, 3 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Replace markers in Radiance scene description with objects or instances.
9 *
10 * Created: 17 Feb 1991 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include <math.h>
16
17 #include "fvect.h"
18
19 #ifdef M_PI
20 #define PI M_PI
21 #else
22 #define PI 3.14159265358979323846
23 #endif
24
25 #define MAXVERT 6 /* maximum number of vertices for markers */
26
27 typedef struct {
28 short beg, end; /* beginning and ending vertex */
29 float len2; /* length squared */
30 } EDGE; /* a marker edge */
31
32 int expand = 0; /* expand commands? */
33
34 char *modout = "void"; /* output modifier (for instances) */
35
36 double markscale = 0.0; /* scale markers by this to get unit */
37
38 char *modin = NULL; /* input modifier indicating marker */
39
40 char *objname = NULL; /* output object file (octree if instance) */
41 int doxform; /* true if xform, false if instance */
42
43 char *progname;
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 FILE *fp;
51 int i, j;
52
53 progname = argv[0];
54 for (i = 1; i < argc && argv[i][0] == '-'; i++)
55 switch (argv[i][1]) {
56 case 'i':
57 doxform = 0;
58 objname = argv[++i];
59 break;
60 case 'x':
61 doxform = 1;
62 objname = argv[++i];
63 break;
64 case 'e':
65 expand = !expand;
66 break;
67 case 'm':
68 modout = argv[++i];
69 break;
70 case 's':
71 markscale = atof(argv[++i]);
72 break;
73 default:
74 goto userr;
75 }
76 if (i < argc)
77 modin = argv[i++];
78 if (objname == NULL || modin == NULL)
79 goto userr;
80 /* simple header */
81 putchar('#');
82 for (j = 0; j < i; j++) {
83 putchar(' ');
84 fputs(argv[j], stdout);
85 }
86 putchar('\n');
87 if (i == argc)
88 convert("<stdin>", stdin);
89 else
90 for ( ; i < argc; i++) {
91 if ((fp = fopen(argv[i], "r")) == NULL) {
92 perror(argv[i]);
93 exit(1);
94 }
95 convert(argv[i], fp);
96 fclose(fp);
97 }
98 exit(0);
99 userr:
100 fprintf(stderr,
101 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree} modname [file ..]\n",
102 progname);
103 exit(1);
104 }
105
106
107 convert(name, fin) /* replace marks in a stream */
108 char *name;
109 register FILE *fin;
110 {
111 register int c;
112
113 while ((c = getc(fin)) != EOF) {
114 if (isspace(c)) /* blank */
115 continue;
116 if (c == '#') { /* comment */
117 putchar(c);
118 do {
119 if ((c = getc(fin)) == EOF)
120 return;
121 putchar(c);
122 } while (c != '\n');
123 } else if (c == '!') { /* command */
124 ungetc(c, fin);
125 cvcomm(name, fin);
126 } else { /* object */
127 ungetc(c, fin);
128 cvobject(name, fin);
129 }
130 }
131 }
132
133
134 cvcomm(fname, fin) /* convert a command */
135 char *fname;
136 FILE *fin;
137 {
138 FILE *pin, *popen();
139 char buf[512], *fgetline();
140
141 fgetline(buf, sizeof(buf), fin);
142 if (expand) {
143 if ((pin = popen(buf+1, "r")) == NULL) {
144 fprintf(stderr,
145 "%s: (%s): cannot execute \"%s\"\n",
146 progname, fname, buf);
147 exit(1);
148 }
149 convert(buf, pin);
150 pclose(pin);
151 } else
152 printf("\n%s\n", buf);
153 }
154
155
156 cvobject(fname, fin) /* convert an object */
157 char *fname;
158 FILE *fin;
159 {
160 char buf[128], typ[16], nam[128];
161 int i, j, n;
162
163 if (fscanf(fin, "%s %s %s", buf, typ, nam) != 3)
164 goto readerr;
165 if (!strcmp(buf, modin) && !strcmp(typ, "polygon")) {
166 replace(fname, nam, fin);
167 return;
168 }
169 printf("\n%s %s %s\n", buf, typ, nam);
170 if (!strcmp(typ, "alias")) { /* alias special case */
171 if (fscanf(fin, "%s", buf) != 1)
172 goto readerr;
173 printf("\t%s\n", buf);
174 return;
175 }
176 for (i = 0; i < 3; i++) { /* pass along arguments */
177 if (fscanf(fin, "%d", &n) != 1)
178 goto readerr;
179 printf("%d", n);
180 for (j = 0; j < n; j++) {
181 if (fscanf(fin, "%s", buf) != 1)
182 goto readerr;
183 if (j%3 == 0)
184 putchar('\n');
185 printf("\t%s", buf);
186 }
187 putchar('\n');
188 }
189 return;
190 readerr:
191 fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
192 progname, fname, typ, nam);
193 }
194
195
196 replace(fname, mark, fin) /* replace marker */
197 char *fname, *mark;
198 FILE *fin;
199 {
200 int n;
201 char buf[256];
202
203 if (doxform) {
204 sprintf(buf, "xform -e -n %s", mark);
205 if (buildxf(buf+strlen(buf), fin) < 0)
206 goto badxf;
207 sprintf(buf+strlen(buf), " %s", objname);
208 if (expand) {
209 fflush(stdout);
210 system(buf);
211 } else
212 printf("\n!%s\n", buf);
213 } else {
214 if ((n = buildxf(buf, fin)) < 0)
215 goto badxf;
216 printf("\n%s instance %s\n", modout, mark);
217 printf("%d %s%s\n", n+1, objname, buf);
218 printf("\n0\n0\n");
219 }
220 return;
221 badxf:
222 fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
223 progname, fname, mark);
224 exit(1);
225 }
226
227
228 edgecmp(e1, e2) /* compare two edges, descending order */
229 EDGE *e1, *e2;
230 {
231 if (e1->len2 > e2->len2)
232 return(-1);
233 if (e1->len2 < e2->len2)
234 return(1);
235 return(0);
236 }
237
238
239 int
240 buildxf(xf, fin) /* build transform for marker */
241 char *xf;
242 FILE *fin;
243 {
244 static FVECT vlist[MAXVERT];
245 static EDGE elist[MAXVERT];
246 FVECT xvec, yvec, zvec;
247 double xlen;
248 int n;
249 register int i;
250 /*
251 * Read and sort vectors: longest is hypotenuse,
252 * second longest is x' axis,
253 * third longest is y' axis (approximate),
254 * other vectors are ignored.
255 * It is an error if the x' and y' axes do
256 * not share a common vertex (their origin).
257 */
258 if (fscanf(fin, "%*d %*d %d", &n) != 1)
259 return(-1);
260 if (n%3 != 0)
261 return(-1);
262 n /= 3;
263 if (n < 3 || n > MAXVERT)
264 return(-1);
265 /* sort edges in descending order */
266 for (i = 0; i < n; i++) {
267 if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
268 &vlist[i][1], &vlist[i][2]) != 3)
269 return(-1);
270 if (i) {
271 elist[i].beg = i-1;
272 elist[i].end = i;
273 elist[i].len2 = dist2(vlist[i-1],vlist[i]);
274 }
275 }
276 elist[0].beg = n-1;
277 elist[0].end = 0;
278 elist[0].len2 = dist2(vlist[n-1],vlist[0]);
279 qsort(elist, n, sizeof(EDGE), edgecmp);
280 /* find x' and y' */
281 if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
282 i = elist[1].beg;
283 elist[1].beg = elist[1].end;
284 elist[1].end = i;
285 }
286 if (elist[2].end == elist[1].beg) {
287 i = elist[2].beg;
288 elist[2].beg = elist[2].end;
289 elist[2].end = i;
290 }
291 if (elist[1].beg != elist[2].beg)
292 return(-1); /* x' and y' not connected! */
293 for (i = 0; i < 3; i++) {
294 xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
295 yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
296 }
297 if ((xlen = normalize(xvec)) == 0.0)
298 return(-1);
299 fcross(zvec, xvec, yvec);
300 if (normalize(zvec) == 0.0)
301 return(-1);
302 fcross(yvec, zvec, xvec);
303 n = 0; /* start transformation... */
304 if (markscale > 0.0) { /* add scale factor */
305 sprintf(xf, " -s %f", xlen*markscale);
306 n += 2;
307 xf += strlen(xf);
308 }
309 /* add rotation */
310 n += addrot(xf, xvec, yvec, zvec);
311 xf += strlen(xf);
312 /* add translation */
313 n += 4;
314 sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
315 vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
316 return(n); /* all done */
317 }
318
319
320 addrot(xf, xp, yp, zp) /* compute rotation (x,y,z) => (xp,yp,zp) */
321 char *xf;
322 FVECT xp, yp, zp;
323 {
324 double tx, ty, tz;
325
326 tx = atan2(yp[2], zp[2]);
327 ty = asin(-xp[2]);
328 tz = atan2(xp[1], xp[0]);
329 sprintf(xf, " -rx %f -ry %f -rz %f", tx*(180./PI),
330 ty*(180./PI), tz*(180./PI));
331 return(6);
332 }
