fix: Functio prototypes and other fixes to reduce compiler warnings
fix: Changed some errors to warnings for pclose()
fix: Added check to return value of pclose() in several tools
refactor: Created comparison macros for RREAL and FVECT types
Changed to calling asin() for safety
Increased maximum number of markers from 32 to 128 and added error check
Removed outdated -e option sent to xform command
Various compatibility fixes.
Compile fixes for Linux
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed M_PI definition to ward off long double problems
Added conditional declaration of atof()
added ability to accept multiple mark modifiers
added -m option to xform
