--- ray/src/gen/replmarks.c 2004/01/02 17:11:40 2.10 +++ ray/src/gen/replmarks.c 2004/01/29 22:20:31 2.11 @@ -28,6 +28,10 @@ static const char RCSid[] = "$Id"; #define MAXVERT 6 /* maximum number of vertices for markers */ #define MAXMARK 32 /* maximum number of markers */ +#define USE_XFORM 1 /* use !xform inline command */ +#define USE_INSTANCE 2 /* use instance primitive */ +#define USE_MESH 3 /* use mesh primitive */ + typedef struct { short beg, end; /* beginning and ending vertex */ float len2; /* length squared */ @@ -38,7 +42,7 @@ struct mrkr { double mscale; /* scale by this to get unit */ char *modin; /* input modifier indicating marker */ char *objname; /* output object file or octree */ - int doxform; /* true if xform, false if instance */ + int usetype; /* one of USE_* above */ } marker[MAXMARK]; /* array of markers */ int nmarkers = 0; /* number of markers */ @@ -70,11 +74,15 @@ main( do { switch (argv[i][1]) { case 'i': - marker[nmarkers].doxform = 0; + marker[nmarkers].usetype = USE_INSTANCE; marker[nmarkers].objname = argv[++i]; break; + case 'I': + marker[nmarkers].usetype = USE_MESH; + marker[nmarkers].objname = argv[++i]; + break; case 'x': - marker[nmarkers].doxform = 1; + marker[nmarkers].usetype = USE_XFORM; marker[nmarkers].objname = argv[++i]; break; case 'e': @@ -122,7 +130,7 @@ main( return 0; userr: fprintf(stderr, -"Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree} modname .. [file ..]\n", +"Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n", progname); return 1; } @@ -240,7 +248,7 @@ replace( /* replace marker */ char buf[256]; buf[0] = '\0'; /* bug fix thanks to schorsch */ - if (m->doxform) { + if (m->usetype == USE_XFORM) { sprintf(buf, "xform -n %s", mark); if (m->modout != NULL) sprintf(buf+strlen(buf), " -m %s", m->modout); @@ -255,8 +263,10 @@ replace( /* replace marker */ } else { if ((n = buildxf(buf, m->mscale, fin)) < 0) goto badxf; - printf("\n%s instance %s\n", - m->modout==NULL?"void":m->modout, mark); + printf("\n%s %s %s\n", + m->modout==NULL?"void":m->modout, + m->usetype==USE_INSTANCE?"instance":"mesh", + mark); printf("%d %s%s\n0\n0\n", n+1, m->objname, buf); } return;
