root/radiance/ray/src/gen/replmarks.c
Revision: 2.20
Committed: Tue Apr 22 14:51:29 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.19: +3 -5 lines
fix: Changed some errors to warnings for pclose()
2 static const char RCSid[] = "$Id: replmarks.c,v 2.19 2025/04/22 04:45:25 greg Exp $";
5 * Replace markers in Radiance scene description with objects or instances.
6 *
7 * Created: 17 Feb 1991 Greg Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include <math.h>
13 #include <stdio.h>
14
15 #include "platform.h"
16 #include "rtio.h"
17 #include "paths.h"
18 #include "fvect.h"
19
20 #ifdef M_PI
21 #define PI ((double)M_PI)
22 #else
23 #define PI 3.14159265358979323846
24 #endif
25
26 #define MAXVERT 6 /* maximum number of vertices for markers */
27 #define MAXMARK 128 /* maximum number of markers */
28
29 #define USE_XFORM 1 /* use !xform inline command */
30 #define USE_INSTANCE 2 /* use instance primitive */
31 #define USE_MESH 3 /* use mesh primitive */
32
33 typedef struct {
34 short beg, end; /* beginning and ending vertex */
35 float len2; /* length squared */
36 } EDGE; /* a marker edge */
37
38 struct mrkr {
39 char *modout; /* output modifier */
40 double mscale; /* scale by this to get unit */
41 char *modin; /* input modifier indicating marker */
42 char *objname; /* output object file or octree */
43 int usetype; /* one of USE_* above */
44 } marker[MAXMARK+1]; /* array of markers */
45 int nmarkers = 0; /* number of markers */
46
47 int expand; /* expand commands? */
48
49 char *progname;
50
51 static void convert(char *name, FILE *fin);
52 static void cvcomm(char *fname, FILE *fin);
53 static void cvobject(char *fname, FILE *fin);
54 static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin);
55 static int edgecmp(const void *e1, const void *e2);
56 static int buildxf(char *xf, double markscale, FILE *fin);
57 static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp);
58
59
60 int
61 main(
62 int argc,
63 char *argv[]
64 )
65 {
66 FILE *fp;
67 int i, j;
68
69 progname = argv[0];
70 i = 1;
71 while (i < argc && argv[i][0] == '-') {
72 do {
73 switch (argv[i][1]) {
74 case 'i':
75 marker[nmarkers].usetype = USE_INSTANCE;
76 marker[nmarkers].objname = argv[++i];
77 break;
78 case 'I':
79 marker[nmarkers].usetype = USE_MESH;
80 marker[nmarkers].objname = argv[++i];
81 break;
82 case 'x':
83 marker[nmarkers].usetype = USE_XFORM;
84 marker[nmarkers].objname = argv[++i];
85 break;
86 case 'e':
87 expand = 1;
88 break;
89 case 'm':
90 marker[nmarkers].modout = argv[++i];
91 break;
92 case 's':
93 marker[nmarkers].mscale = atof(argv[++i]);
94 break;
95 default:
96 goto userr;
97 }
98 if (++i >= argc)
99 goto userr;
100 } while (argv[i][0] == '-');
101 if (marker[nmarkers].objname == NULL)
102 goto userr;
103 if (nmarkers >= MAXMARK) {
104 fprintf(stderr, "%s: too many markers\n", progname);
105 return 1;
106 }
107 marker[nmarkers++].modin = argv[i++];
108 marker[nmarkers].mscale = marker[nmarkers-1].mscale;
109 }
110 if (nmarkers == 0)
111 goto userr;
112 /* simple header */
113 putchar('#');
114 for (j = 0; j < i; j++) {
115 putchar(' ');
116 fputs(argv[j], stdout);
117 }
118 putchar('\n');
119 if (i == argc)
120 convert("<stdin>", stdin);
121 else
122 for ( ; i < argc; i++) {
123 if ((fp = fopen(argv[i], "r")) == NULL) {
124 perror(argv[i]);
125 exit(1);
126 }
127 convert(argv[i], fp);
128 fclose(fp);
129 }
130 return 0;
131 userr:
132 fprintf(stderr,
133 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n",
134 progname);
135 return 1;
136 }
137
138
139 void
140 convert( /* replace marks in a stream */
141 char *name,
142 register FILE *fin
143 )
144 {
145 register int c;
146
147 while ((c = getc(fin)) != EOF) {
148 if (isspace(c)) /* blank */
149 continue;
150 if (c == '#') { /* comment */
151 putchar(c);
152 do {
153 if ((c = getc(fin)) == EOF)
154 return;
155 putchar(c);
156 } while (c != '\n');
157 } else if (c == '!') { /* command */
158 ungetc(c, fin);
159 cvcomm(name, fin);
160 } else { /* object */
161 ungetc(c, fin);
162 cvobject(name, fin);
163 }
164 }
165 }
166
167
168 void
169 cvcomm( /* convert a command */
170 char *fname,
171 FILE *fin
172 )
173 {
174 FILE *pin;
175 char buf[512], *fgetline();
176
177 fgetline(buf, sizeof(buf), fin);
178 if (expand) {
179 if ((pin = popen(buf+1, "r")) == NULL) {
180 fprintf(stderr,
181 "%s: (%s): cannot execute \"%s\"\n",
182 progname, fname, buf);
183 exit(1);
184 }
185 convert(buf, pin);
186 if (pclose(pin) != 0)
187 fprintf(stderr,
188 "%s: (%s): warning - bad status from \"%s\"\n",
189 progname, fname, buf);
190 } else
191 printf("\n%s\n", buf);
192 }
193
194
195 void
196 cvobject( /* convert an object */
197 char *fname,
198 FILE *fin
199 )
200 {
201 extern char *fgetword();
202 char buf[128], typ[16], nam[128];
203 int i, n;
204 register int j;
205
206 if (fgetword(buf, sizeof(buf), fin) == NULL ||
207 fgetword(typ, sizeof(typ), fin) == NULL ||
208 fgetword(nam, sizeof(nam), fin) == NULL)
209 goto readerr;
210 if (!strcmp(typ, "polygon"))
211 for (j = 0; j < nmarkers; j++)
212 if (!strcmp(buf, marker[j].modin)) {
213 replace(fname, &marker[j], nam, fin);
214 return;
215 }
216 putchar('\n'); fputword(buf, stdout);
217 printf(" %s ", typ);
218 fputword(nam, stdout); putchar('\n');
219 if (!strcmp(typ, "alias")) { /* alias special case */
220 if (fgetword(buf, sizeof(buf), fin) == NULL)
221 goto readerr;
222 putchar('\t'); fputword(buf, stdout); putchar('\n');
223 return;
224 }
225 for (i = 0; i < 3; i++) { /* pass along arguments */
226 if (fscanf(fin, "%d", &n) != 1)
227 goto readerr;
228 printf("%d", n);
229 for (j = 0; j < n; j++) {
230 if (fgetword(buf, sizeof(buf), fin) == NULL)
231 goto readerr;
232 if (j%3 == 0)
233 putchar('\n');
234 putchar('\t');
235 fputword(buf, stdout);
236 }
237 putchar('\n');
238 }
239 return;
240 readerr:
241 fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
242 progname, fname, typ, nam);
243 }
244
245
246 void
247 replace( /* replace marker */
248 char *fname,
249 register struct mrkr *m,
250 char *mark,
251 FILE *fin
252 )
253 {
254 int n;
255 char buf[256];
256
257 buf[0] = '\0'; /* bug fix thanks to schorsch */
258 if (m->usetype == USE_XFORM) {
259 sprintf(buf, "xform -n %s", mark);
260 if (m->modout != NULL)
261 sprintf(buf+strlen(buf), " -m %s", m->modout);
262 if (buildxf(buf+strlen(buf), m->mscale, fin) < 0)
263 goto badxf;
264 sprintf(buf+strlen(buf), " %s", m->objname);
265 if (expand) {
266 fflush(stdout);
267 system(buf);
268 } else
269 printf("\n!%s\n", buf);
270 } else {
271 if ((n = buildxf(buf, m->mscale, fin)) < 0)
272 goto badxf;
273 printf("\n%s %s %s\n",
274 m->modout==NULL?"void":m->modout,
275 m->usetype==USE_INSTANCE?"instance":"mesh",
276 mark);
277 printf("%d %s%s\n0\n0\n", n+1, m->objname, buf);
278 }
279 return;
280 badxf:
281 fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
282 progname, fname, mark);
283 exit(1);
284 }
285
286
287 int
288 edgecmp( /* compare two edges, descending order */
289 const void *e1,
290 const void *e2
291 )
292 {
293 if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2)
294 return(-1);
295 if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2)
296 return(1);
297 return(0);
298 }
299
300
301 int
302 buildxf( /* build transform for marker */
303 register char *xf,
304 double markscale,
305 FILE *fin
306 )
307 {
308 static FVECT vlist[MAXVERT];
309 static EDGE elist[MAXVERT];
310 FVECT xvec, yvec, zvec;
311 double xlen;
312 int n;
313 register int i;
314 /*
315 * Read and sort vectors: longest is hypotenuse,
316 * second longest is x' axis,
317 * third longest is y' axis (approximate),
318 * other vectors are ignored.
319 * It is an error if the x' and y' axes do
320 * not share a common vertex (their origin).
321 */
322 if (fscanf(fin, "%*d %*d %d", &n) != 1)
323 return(-1);
324 if (n%3 != 0)
325 return(-1);
326 n /= 3;
327 if (n < 3 || n > MAXVERT)
328 return(-1);
329 /* sort edges in descending order */
330 for (i = 0; i < n; i++) {
331 if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
332 &vlist[i][1], &vlist[i][2]) != 3)
333 return(-1);
334 if (i) {
335 elist[i].beg = i-1;
336 elist[i].end = i;
337 elist[i].len2 = dist2(vlist[i-1],vlist[i]);
338 }
339 }
340 elist[0].beg = n-1;
341 elist[0].end = 0;
342 elist[0].len2 = dist2(vlist[n-1],vlist[0]);
343 qsort(elist, n, sizeof(EDGE), edgecmp);
344 /* find x' and y' */
345 if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
346 i = elist[1].beg;
347 elist[1].beg = elist[1].end;
348 elist[1].end = i;
349 }
350 if (elist[2].end == elist[1].beg) {
351 i = elist[2].beg;
352 elist[2].beg = elist[2].end;
353 elist[2].end = i;
354 }
355 if (elist[1].beg != elist[2].beg)
356 return(-1); /* x' and y' not connected! */
357 for (i = 0; i < 3; i++) {
358 xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
359 yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
360 }
361 if ((xlen = normalize(xvec)) == 0.0)
362 return(-1);
363 fcross(zvec, xvec, yvec);
364 if (normalize(zvec) == 0.0)
365 return(-1);
366 fcross(yvec, zvec, xvec);
367 n = 0; /* start transformation... */
368 if (markscale > 0.0) { /* add scale factor */
369 sprintf(xf, " -s %f", xlen*markscale);
370 n += 2;
371 while (*xf) ++xf;
372 }
373 /* add rotation */
374 n += addrot(xf, xvec, yvec, zvec);
375 while (*xf) ++xf;
376 /* add translation */
377 n += 4;
378 sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
379 vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
380 return(n); /* all done */
381 }
382
383
384 int
385 addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
386 register char *xf,
387 FVECT xp,
388 FVECT yp,
389 FVECT zp
390 )
391 {
392 int n;
393 double theta;
394
395 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
396 /* Special case for X' along Z-axis */
397 theta = -atan2(yp[0], yp[1]);
398 sprintf(xf, " -ry %f -rz %f",
399 xp[2] < 0.0 ? 90.0 : -90.0,
400 theta*(180./PI));
401 return(4);
402 }
403 n = 0;
404 theta = atan2(yp[2], zp[2]);
405 if (!FABSEQ(theta,0.0)) {
406 sprintf(xf, " -rx %f", theta*(180./PI));
407 while (*xf) ++xf;
408 n += 2;
409 }
410 theta = Asin(-xp[2]);
411 if (!FABSEQ(theta,0.0)) {
412 sprintf(xf, " -ry %f", theta*(180./PI));
413 while (*xf) ++xf;
414 n += 2;
415 }
416 theta = atan2(xp[1], xp[0]);
417 if (!FABSEQ(theta,0.0)) {
418 sprintf(xf, " -rz %f", theta*(180./PI));
419 /* while (*xf) ++xf; */
420 n += 2;
421 }
422 return(n);
423 }
