root/radiance/ray/src/gen/replmarks.c
Revision: 2.1
Committed: Tue Nov 12 17:04:51 1991 UTC (33 years, 6 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Replace markers in Radiance scene description with objects or instances.
9 *
10 * Created: 17 Feb 1991 Greg Ward
11 */
12
13 #include <stdio.h>
14 #include <ctype.h>
15 #include <math.h>
16
17 #include "fvect.h"
18
19 #ifdef M_PI
20 #define PI M_PI
21 #else
22 #define PI 3.14159265358979323846
23 #endif
24
25 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
26
27 #define MAXVERT 6 /* maximum number of vertices for markers */
28
29 typedef struct {
30 short beg, end; /* beginning and ending vertex */
31 float len2; /* length squared */
32 } EDGE; /* a marker edge */
33
34 int expand = 0; /* expand commands? */
35
36 char *modout = NULL; /* output modifier (for instances) */
37
38 double markscale = 0.0; /* scale markers by this to get unit */
39
40 char *modin = NULL; /* input modifier indicating marker */
41
42 char *objname = NULL; /* output object file (octree if instance) */
43 int doxform; /* true if xform, false if instance */
44
45 char *progname;
46
47
48 main(argc, argv)
49 int argc;
50 char *argv[];
51 {
52 FILE *fp;
53 int i, j;
54
55 progname = argv[0];
56 for (i = 1; i < argc && argv[i][0] == '-'; i++)
57 switch (argv[i][1]) {
58 case 'i':
59 doxform = 0;
60 objname = argv[++i];
61 break;
62 case 'x':
63 doxform = 1;
64 objname = argv[++i];
65 break;
66 case 'e':
67 expand = !expand;
68 break;
69 case 'm':
70 modout = argv[++i];
71 break;
72 case 's':
73 markscale = atof(argv[++i]);
74 break;
75 default:
76 goto userr;
77 }
78 if (i < argc)
79 modin = argv[i++];
80 if (objname == NULL || modin == NULL)
81 goto userr;
82 /* simple header */
83 putchar('#');
84 for (j = 0; j < i; j++) {
85 putchar(' ');
86 fputs(argv[j], stdout);
87 }
88 putchar('\n');
89 if (i == argc)
90 convert("<stdin>", stdin);
91 else
92 for ( ; i < argc; i++) {
93 if ((fp = fopen(argv[i], "r")) == NULL) {
94 perror(argv[i]);
95 exit(1);
96 }
97 convert(argv[i], fp);
98 fclose(fp);
99 }
100 exit(0);
101 userr:
102 fprintf(stderr,
103 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree} modname [file ..]\n",
104 progname);
105 exit(1);
106 }
107
108
109 convert(name, fin) /* replace marks in a stream */
110 char *name;
111 register FILE *fin;
112 {
113 register int c;
114
115 while ((c = getc(fin)) != EOF) {
116 if (isspace(c)) /* blank */
117 continue;
118 if (c == '#') { /* comment */
119 putchar(c);
120 do {
121 if ((c = getc(fin)) == EOF)
122 return;
123 putchar(c);
124 } while (c != '\n');
125 } else if (c == '!') { /* command */
126 ungetc(c, fin);
127 cvcomm(name, fin);
128 } else { /* object */
129 ungetc(c, fin);
130 cvobject(name, fin);
131 }
132 }
133 }
134
135
136 cvcomm(fname, fin) /* convert a command */
137 char *fname;
138 FILE *fin;
139 {
140 FILE *pin, *popen();
141 char buf[512], *fgetline();
142
143 fgetline(buf, sizeof(buf), fin);
144 if (expand) {
145 if ((pin = popen(buf+1, "r")) == NULL) {
146 fprintf(stderr,
147 "%s: (%s): cannot execute \"%s\"\n",
148 progname, fname, buf);
149 exit(1);
150 }
151 convert(buf, pin);
152 pclose(pin);
153 } else
154 printf("\n%s\n", buf);
155 }
156
157
158 cvobject(fname, fin) /* convert an object */
159 char *fname;
160 FILE *fin;
161 {
162 char buf[128], typ[16], nam[128];
163 int i, j, n;
164
165 if (fscanf(fin, "%s %s %s", buf, typ, nam) != 3)
166 goto readerr;
167 if (!strcmp(buf, modin) && !strcmp(typ, "polygon")) {
168 replace(fname, nam, fin);
169 return;
170 }
171 printf("\n%s %s %s\n", buf, typ, nam);
172 if (!strcmp(typ, "alias")) { /* alias special case */
173 if (fscanf(fin, "%s", buf) != 1)
174 goto readerr;
175 printf("\t%s\n", buf);
176 return;
177 }
178 for (i = 0; i < 3; i++) { /* pass along arguments */
179 if (fscanf(fin, "%d", &n) != 1)
180 goto readerr;
181 printf("%d", n);
182 for (j = 0; j < n; j++) {
183 if (fscanf(fin, "%s", buf) != 1)
184 goto readerr;
185 if (j%3 == 0)
186 putchar('\n');
187 printf("\t%s", buf);
188 }
189 putchar('\n');
190 }
191 return;
192 readerr:
193 fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
194 progname, fname, typ, nam);
195 }
196
197
198 replace(fname, mark, fin) /* replace marker */
199 char *fname, *mark;
200 FILE *fin;
201 {
202 int n;
203 char buf[256];
204
205 if (doxform) {
206 sprintf(buf, "xform -e -n %s", mark);
207 if (modout != NULL)
208 sprintf(buf+strlen(buf), " -m %s", modout);
209 if (buildxf(buf+strlen(buf), fin) < 0)
210 goto badxf;
211 sprintf(buf+strlen(buf), " %s", objname);
212 if (expand) {
213 fflush(stdout);
214 system(buf);
215 } else
216 printf("\n!%s\n", buf);
217 } else {
218 if ((n = buildxf(buf, fin)) < 0)
219 goto badxf;
220 printf("\n%s instance %s\n", modout==NULL?"void":modout, mark);
221 printf("%d %s%s\n0\n0\n", n+1, objname, buf);
222 }
223 return;
224 badxf:
225 fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
226 progname, fname, mark);
227 exit(1);
228 }
229
230
231 edgecmp(e1, e2) /* compare two edges, descending order */
232 EDGE *e1, *e2;
233 {
234 if (e1->len2 > e2->len2)
235 return(-1);
236 if (e1->len2 < e2->len2)
237 return(1);
238 return(0);
239 }
240
241
242 int
243 buildxf(xf, fin) /* build transform for marker */
244 char *xf;
245 FILE *fin;
246 {
247 static FVECT vlist[MAXVERT];
248 static EDGE elist[MAXVERT];
249 FVECT xvec, yvec, zvec;
250 double xlen;
251 int n;
252 register int i;
253 /*
254 * Read and sort vectors: longest is hypotenuse,
255 * second longest is x' axis,
256 * third longest is y' axis (approximate),
257 * other vectors are ignored.
258 * It is an error if the x' and y' axes do
259 * not share a common vertex (their origin).
260 */
261 if (fscanf(fin, "%*d %*d %d", &n) != 1)
262 return(-1);
263 if (n%3 != 0)
264 return(-1);
265 n /= 3;
266 if (n < 3 || n > MAXVERT)
267 return(-1);
268 /* sort edges in descending order */
269 for (i = 0; i < n; i++) {
270 if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
271 &vlist[i][1], &vlist[i][2]) != 3)
272 return(-1);
273 if (i) {
274 elist[i].beg = i-1;
275 elist[i].end = i;
276 elist[i].len2 = dist2(vlist[i-1],vlist[i]);
277 }
278 }
279 elist[0].beg = n-1;
280 elist[0].end = 0;
281 elist[0].len2 = dist2(vlist[n-1],vlist[0]);
282 qsort(elist, n, sizeof(EDGE), edgecmp);
283 /* find x' and y' */
284 if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
285 i = elist[1].beg;
286 elist[1].beg = elist[1].end;
287 elist[1].end = i;
288 }
289 if (elist[2].end == elist[1].beg) {
290 i = elist[2].beg;
291 elist[2].beg = elist[2].end;
292 elist[2].end = i;
293 }
294 if (elist[1].beg != elist[2].beg)
295 return(-1); /* x' and y' not connected! */
296 for (i = 0; i < 3; i++) {
297 xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
298 yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
299 }
300 if ((xlen = normalize(xvec)) == 0.0)
301 return(-1);
302 fcross(zvec, xvec, yvec);
303 if (normalize(zvec) == 0.0)
304 return(-1);
305 fcross(yvec, zvec, xvec);
306 n = 0; /* start transformation... */
307 if (markscale > 0.0) { /* add scale factor */
308 sprintf(xf, " -s %f", xlen*markscale);
309 n += 2;
310 xf += strlen(xf);
311 }
312 /* add rotation */
313 n += addrot(xf, xvec, yvec, zvec);
314 xf += strlen(xf);
315 /* add translation */
316 n += 4;
317 sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
318 vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
319 return(n); /* all done */
320 }
321
322
323 addrot(xf, xp, yp, zp) /* compute rotation (x,y,z) => (xp,yp,zp) */
324 char *xf;
325 FVECT xp, yp, zp;
326 {
327 int n;
328 double theta;
329
330 n = 0;
331 theta = atan2(yp[2], zp[2]);
332 if (!FEQ(theta,0.0)) {
333 sprintf(xf, " -rx %f", theta*(180./PI));
334 xf += strlen(xf);
335 n += 2;
336 }
337 theta = asin(-xp[2]);
338 if (!FEQ(theta,0.0)) {
339 sprintf(xf, " -ry %f", theta*(180./PI));
340 xf += strlen(xf);
341 n += 2;
342 }
343 theta = atan2(xp[1], xp[0]);
344 if (!FEQ(theta,0.0)) {
345 sprintf(xf, " -rz %f", theta*(180./PI));
346 /* xf += strlen(xf); */
347 n += 2;
348 }
349 return(n);
350 }
