root/radiance/ray/src/gen/replmarks.c
Revision: 2.16
Committed: Thu Mar 6 00:47:37 2014 UTC (10 years, 3 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changed to calling asin() for safety
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.16 static const char RCSid[] = "$Id: replmarks.c,v 2.15 2008/01/25 02:11:13 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Replace markers in Radiance scene description with objects or instances.
6     *
7     * Created: 17 Feb 1991 Greg Ward
8     */
9
10 greg 2.5 #include <stdlib.h>
11 greg 1.1 #include <ctype.h>
12     #include <math.h>
13 schorsch 2.7 #include <stdio.h>
14 greg 1.1
15 schorsch 2.7 #include "platform.h"
16 schorsch 2.9 #include "rtio.h"
17 schorsch 2.8 #include "rtprocess.h"
18 greg 1.1 #include "fvect.h"
19
20     #ifdef M_PI
21 gregl 2.4 #define PI ((double)M_PI)
22 greg 1.1 #else
23     #define PI 3.14159265358979323846
24     #endif
25
26 greg 1.2 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
27
28 greg 1.1 #define MAXVERT 6 /* maximum number of vertices for markers */
29 greg 2.13 #define MAXMARK 128 /* maximum number of markers */
30 greg 1.1
31 greg 2.11 #define USE_XFORM 1 /* use !xform inline command */
32     #define USE_INSTANCE 2 /* use instance primitive */
33     #define USE_MESH 3 /* use mesh primitive */
34
35 greg 1.1 typedef struct {
36     short beg, end; /* beginning and ending vertex */
37     float len2; /* length squared */
38     } EDGE; /* a marker edge */
39
40 greg 2.2 struct mrkr {
41     char *modout; /* output modifier */
42     double mscale; /* scale by this to get unit */
43     char *modin; /* input modifier indicating marker */
44     char *objname; /* output object file or octree */
45 greg 2.11 int usetype; /* one of USE_* above */
46 greg 2.13 } marker[MAXMARK+1]; /* array of markers */
47 greg 2.2 int nmarkers = 0; /* number of markers */
48 greg 1.1
49 greg 2.2 int expand; /* expand commands? */
50 greg 1.1
51     char *progname;
52
53 schorsch 2.9 static void convert(char *name, FILE *fin);
54     static void cvcomm(char *fname, FILE *fin);
55     static void cvobject(char *fname, FILE *fin);
56     static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin);
57     static int edgecmp(const void *e1, const void *e2);
58     static int buildxf(char *xf, double markscale, FILE *fin);
59     static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp);
60 greg 1.1
61 schorsch 2.9
62     int
63     main(
64     int argc,
65     char *argv[]
66     )
67 greg 1.1 {
68     FILE *fp;
69     int i, j;
70
71     progname = argv[0];
72 greg 2.2 i = 1;
73     while (i < argc && argv[i][0] == '-') {
74     do {
75     switch (argv[i][1]) {
76     case 'i':
77 greg 2.11 marker[nmarkers].usetype = USE_INSTANCE;
78     marker[nmarkers].objname = argv[++i];
79     break;
80     case 'I':
81     marker[nmarkers].usetype = USE_MESH;
82 greg 2.2 marker[nmarkers].objname = argv[++i];
83     break;
84     case 'x':
85 greg 2.11 marker[nmarkers].usetype = USE_XFORM;
86 greg 2.2 marker[nmarkers].objname = argv[++i];
87     break;
88     case 'e':
89     expand = 1;
90     break;
91     case 'm':
92     marker[nmarkers].modout = argv[++i];
93     break;
94     case 's':
95     marker[nmarkers].mscale = atof(argv[++i]);
96     break;
97     default:
98     goto userr;
99     }
100     if (++i >= argc)
101     goto userr;
102     } while (argv[i][0] == '-');
103     if (marker[nmarkers].objname == NULL)
104     goto userr;
105 greg 2.13 if (nmarkers >= MAXMARK) {
106     fprintf(stderr, "%s: too many markers\n", progname);
107     return 1;
108     }
109 greg 2.2 marker[nmarkers++].modin = argv[i++];
110     marker[nmarkers].mscale = marker[nmarkers-1].mscale;
111     }
112     if (nmarkers == 0)
113 greg 1.1 goto userr;
114     /* simple header */
115     putchar('#');
116     for (j = 0; j < i; j++) {
117     putchar(' ');
118     fputs(argv[j], stdout);
119     }
120     putchar('\n');
121     if (i == argc)
122     convert("<stdin>", stdin);
123     else
124     for ( ; i < argc; i++) {
125     if ((fp = fopen(argv[i], "r")) == NULL) {
126     perror(argv[i]);
127     exit(1);
128     }
129     convert(argv[i], fp);
130     fclose(fp);
131     }
132 schorsch 2.9 return 0;
133 greg 1.1 userr:
134     fprintf(stderr,
135 greg 2.11 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n",
136 greg 1.1 progname);
137 schorsch 2.9 return 1;
138 greg 1.1 }
139
140
141 schorsch 2.9 void
142     convert( /* replace marks in a stream */
143     char *name,
144     register FILE *fin
145     )
146 greg 1.1 {
147     register int c;
148
149     while ((c = getc(fin)) != EOF) {
150     if (isspace(c)) /* blank */
151     continue;
152     if (c == '#') { /* comment */
153     putchar(c);
154     do {
155     if ((c = getc(fin)) == EOF)
156     return;
157     putchar(c);
158     } while (c != '\n');
159     } else if (c == '!') { /* command */
160     ungetc(c, fin);
161     cvcomm(name, fin);
162     } else { /* object */
163     ungetc(c, fin);
164     cvobject(name, fin);
165     }
166     }
167     }
168
169
170 schorsch 2.9 void
171     cvcomm( /* convert a command */
172     char *fname,
173     FILE *fin
174     )
175 greg 1.1 {
176 schorsch 2.8 FILE *pin;
177 greg 1.1 char buf[512], *fgetline();
178
179     fgetline(buf, sizeof(buf), fin);
180     if (expand) {
181     if ((pin = popen(buf+1, "r")) == NULL) {
182     fprintf(stderr,
183     "%s: (%s): cannot execute \"%s\"\n",
184     progname, fname, buf);
185     exit(1);
186     }
187     convert(buf, pin);
188     pclose(pin);
189     } else
190     printf("\n%s\n", buf);
191     }
192
193
194 schorsch 2.9 void
195     cvobject( /* convert an object */
196     char *fname,
197     FILE *fin
198     )
199 greg 1.1 {
200 greg 2.6 extern char *fgetword();
201 greg 1.1 char buf[128], typ[16], nam[128];
202 greg 2.2 int i, n;
203     register int j;
204 greg 1.1
205 greg 2.14 if (fgetword(buf, sizeof(buf), fin) == NULL ||
206     fgetword(typ, sizeof(typ), fin) == NULL ||
207     fgetword(nam, sizeof(nam), fin) == NULL)
208 greg 1.1 goto readerr;
209 greg 2.2 if (!strcmp(typ, "polygon"))
210     for (j = 0; j < nmarkers; j++)
211     if (!strcmp(buf, marker[j].modin)) {
212     replace(fname, &marker[j], nam, fin);
213     return;
214     }
215 greg 2.14 putchar('\n'); fputword(buf, stdout);
216     printf(" %s ", typ);
217     fputword(nam, stdout); putchar('\n');
218 greg 1.1 if (!strcmp(typ, "alias")) { /* alias special case */
219 greg 2.14 if (fgetword(buf, sizeof(buf), fin) == NULL)
220 greg 1.1 goto readerr;
221 greg 2.14 putchar('\t'); fputword(buf, stdout); putchar('\n');
222 greg 1.1 return;
223     }
224     for (i = 0; i < 3; i++) { /* pass along arguments */
225     if (fscanf(fin, "%d", &n) != 1)
226     goto readerr;
227     printf("%d", n);
228     for (j = 0; j < n; j++) {
229 greg 2.5 if (fgetword(buf, sizeof(buf), fin) == NULL)
230 greg 1.1 goto readerr;
231     if (j%3 == 0)
232     putchar('\n');
233 greg 2.5 putchar('\t');
234     fputword(buf, stdout);
235 greg 1.1 }
236     putchar('\n');
237     }
238     return;
239     readerr:
240     fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
241     progname, fname, typ, nam);
242     }
243
244
245 schorsch 2.9 void
246     replace( /* replace marker */
247     char *fname,
248     register struct mrkr *m,
249     char *mark,
250     FILE *fin
251     )
252 greg 1.1 {
253     int n;
254     char buf[256];
255
256 greg 2.5 buf[0] = '\0'; /* bug fix thanks to schorsch */
257 greg 2.11 if (m->usetype == USE_XFORM) {
258 greg 2.10 sprintf(buf, "xform -n %s", mark);
259 greg 2.2 if (m->modout != NULL)
260     sprintf(buf+strlen(buf), " -m %s", m->modout);
261     if (buildxf(buf+strlen(buf), m->mscale, fin) < 0)
262 greg 1.1 goto badxf;
263 greg 2.2 sprintf(buf+strlen(buf), " %s", m->objname);
264 greg 1.1 if (expand) {
265     fflush(stdout);
266     system(buf);
267     } else
268     printf("\n!%s\n", buf);
269     } else {
270 greg 2.2 if ((n = buildxf(buf, m->mscale, fin)) < 0)
271 greg 1.1 goto badxf;
272 greg 2.11 printf("\n%s %s %s\n",
273     m->modout==NULL?"void":m->modout,
274     m->usetype==USE_INSTANCE?"instance":"mesh",
275     mark);
276 greg 2.2 printf("%d %s%s\n0\n0\n", n+1, m->objname, buf);
277 greg 1.1 }
278     return;
279     badxf:
280     fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
281     progname, fname, mark);
282     exit(1);
283     }
284
285
286 schorsch 2.9 int
287     edgecmp( /* compare two edges, descending order */
288     const void *e1,
289     const void *e2
290     )
291 greg 1.1 {
292 schorsch 2.9 if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2)
293 greg 1.1 return(-1);
294 schorsch 2.9 if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2)
295 greg 1.1 return(1);
296     return(0);
297     }
298
299
300     int
301 schorsch 2.9 buildxf( /* build transform for marker */
302     register char *xf,
303     double markscale,
304     FILE *fin
305     )
306 greg 1.1 {
307     static FVECT vlist[MAXVERT];
308     static EDGE elist[MAXVERT];
309     FVECT xvec, yvec, zvec;
310     double xlen;
311     int n;
312     register int i;
313     /*
314     * Read and sort vectors: longest is hypotenuse,
315     * second longest is x' axis,
316     * third longest is y' axis (approximate),
317     * other vectors are ignored.
318     * It is an error if the x' and y' axes do
319     * not share a common vertex (their origin).
320     */
321     if (fscanf(fin, "%*d %*d %d", &n) != 1)
322     return(-1);
323     if (n%3 != 0)
324     return(-1);
325     n /= 3;
326     if (n < 3 || n > MAXVERT)
327     return(-1);
328     /* sort edges in descending order */
329     for (i = 0; i < n; i++) {
330     if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
331     &vlist[i][1], &vlist[i][2]) != 3)
332     return(-1);
333     if (i) {
334     elist[i].beg = i-1;
335     elist[i].end = i;
336     elist[i].len2 = dist2(vlist[i-1],vlist[i]);
337     }
338     }
339     elist[0].beg = n-1;
340     elist[0].end = 0;
341     elist[0].len2 = dist2(vlist[n-1],vlist[0]);
342     qsort(elist, n, sizeof(EDGE), edgecmp);
343     /* find x' and y' */
344     if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
345     i = elist[1].beg;
346     elist[1].beg = elist[1].end;
347     elist[1].end = i;
348     }
349     if (elist[2].end == elist[1].beg) {
350     i = elist[2].beg;
351     elist[2].beg = elist[2].end;
352     elist[2].end = i;
353     }
354     if (elist[1].beg != elist[2].beg)
355     return(-1); /* x' and y' not connected! */
356     for (i = 0; i < 3; i++) {
357     xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
358     yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
359     }
360     if ((xlen = normalize(xvec)) == 0.0)
361     return(-1);
362     fcross(zvec, xvec, yvec);
363     if (normalize(zvec) == 0.0)
364     return(-1);
365     fcross(yvec, zvec, xvec);
366     n = 0; /* start transformation... */
367     if (markscale > 0.0) { /* add scale factor */
368     sprintf(xf, " -s %f", xlen*markscale);
369     n += 2;
370 greg 2.5 while (*xf) ++xf;
371 greg 1.1 }
372     /* add rotation */
373     n += addrot(xf, xvec, yvec, zvec);
374 greg 2.5 while (*xf) ++xf;
375 greg 1.1 /* add translation */
376     n += 4;
377     sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
378     vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
379     return(n); /* all done */
380     }
381
382
383 schorsch 2.9 int
384     addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
385     register char *xf,
386     FVECT xp,
387     FVECT yp,
388     FVECT zp
389     )
390 greg 1.1 {
391 greg 1.2 int n;
392     double theta;
393 greg 1.1
394 greg 2.15 if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) {
395     /* Special case for X' along Z-axis */
396     theta = -atan2(yp[0], yp[1]);
397     sprintf(xf, " -ry %f -rz %f",
398     xp[2] < 0.0 ? 90.0 : -90.0,
399     theta*(180./PI));
400     return(4);
401     }
402 greg 1.2 n = 0;
403     theta = atan2(yp[2], zp[2]);
404     if (!FEQ(theta,0.0)) {
405     sprintf(xf, " -rx %f", theta*(180./PI));
406 greg 2.5 while (*xf) ++xf;
407 greg 1.2 n += 2;
408     }
409 greg 2.16 theta = Asin(-xp[2]);
410 greg 1.2 if (!FEQ(theta,0.0)) {
411     sprintf(xf, " -ry %f", theta*(180./PI));
412 greg 2.5 while (*xf) ++xf;
413 greg 1.2 n += 2;
414     }
415     theta = atan2(xp[1], xp[0]);
416     if (!FEQ(theta,0.0)) {
417     sprintf(xf, " -rz %f", theta*(180./PI));
418 greg 2.5 /* while (*xf) ++xf; */
419 greg 1.2 n += 2;
420     }
421     return(n);
422 greg 1.1 }
