root/radiance/ray/src/gen/replmarks.c
Tue Sep 28 17:54:18 2004 UTC (20 years, 9 months ago) by greg
Thu Jan 29 22:20:31 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.10: +17 -7 lines
Fri Jan 2 17:11:40 2004 UTC (21 years, 6 months ago) by greg
Removed outdated -e option sent to xform command
Sun Nov 16 10:29:38 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 2.8: +57 -30 lines
Mon Oct 27 10:27:25 2003 UTC (21 years, 8 months ago) by schorsch
Various compatibility fixes.
Sun Jun 8 12:03:10 2003 UTC (22 years ago) by schorsch
Mon Mar 10 17:26:26 2003 UTC (22 years, 3 months ago) by greg
Compile fixes for Linux
Sat Feb 22 02:07:24 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.4: +13 -17 lines
Fri Jan 16 10:48:23 1998 UTC (27 years, 5 months ago) by gregl
changed M_PI definition to ward off long double problems
Mon Aug 2 14:29:31 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +4 -0 lines
Added conditional declaration of atof()
Tue Mar 3 21:30:03 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.1: +69 -51 lines
added ability to accept multiple mark modifiers
Tue Nov 12 17:04:51 1991 UTC (33 years, 7 months ago) by greg
Mon Feb 18 13:45:12 1991 UTC (34 years, 4 months ago) by greg
Changes since 1.1: +29 -11 lines
added -m option to xform
Sun Feb 17 22:36:30 1991 UTC (34 years, 4 months ago) by greg
Diff to selected 2.2
