root/radiance/ray/src/gen/replmarks.c
Revision: 2.13
Committed: Thu Mar 17 06:38:45 2005 UTC (20 years, 2 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
Changes since 2.12: +7 -5 lines
Increased maximum number of markers from 32 to 128 and added error check
2 static const char RCSid[] = "$Id: replmarks.c,v 2.12 2004/09/28 17:54:18 greg Exp $";
5 * Replace markers in Radiance scene description with objects or instances.
6 *
7 * Created: 17 Feb 1991 Greg Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include <math.h>
13 #include <stdio.h>
14
15 #include "platform.h"
16 #include "rtio.h"
17 #include "rtprocess.h"
18 #include "fvect.h"
19
20 #ifdef M_PI
21 #define PI ((double)M_PI)
22 #else
23 #define PI 3.14159265358979323846
24 #endif
25
26 #define FEQ(a,b) ((a)-(b) <= 1e-7 && (b)-(a) <= 1e-7)
27
28 #define MAXVERT 6 /* maximum number of vertices for markers */
29 #define MAXMARK 128 /* maximum number of markers */
30
31 #define USE_XFORM 1 /* use !xform inline command */
32 #define USE_INSTANCE 2 /* use instance primitive */
33 #define USE_MESH 3 /* use mesh primitive */
34
35 typedef struct {
36 short beg, end; /* beginning and ending vertex */
37 float len2; /* length squared */
38 } EDGE; /* a marker edge */
39
40 struct mrkr {
41 char *modout; /* output modifier */
42 double mscale; /* scale by this to get unit */
43 char *modin; /* input modifier indicating marker */
44 char *objname; /* output object file or octree */
45 int usetype; /* one of USE_* above */
46 } marker[MAXMARK+1]; /* array of markers */
47 int nmarkers = 0; /* number of markers */
48
49 int expand; /* expand commands? */
50
51 char *progname;
52
53 static void convert(char *name, FILE *fin);
54 static void cvcomm(char *fname, FILE *fin);
55 static void cvobject(char *fname, FILE *fin);
56 static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin);
57 static int edgecmp(const void *e1, const void *e2);
58 static int buildxf(char *xf, double markscale, FILE *fin);
59 static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp);
60
61
62 int
63 main(
64 int argc,
65 char *argv[]
66 )
67 {
68 FILE *fp;
69 int i, j;
70
71 progname = argv[0];
72 i = 1;
73 while (i < argc && argv[i][0] == '-') {
74 do {
75 switch (argv[i][1]) {
76 case 'i':
77 marker[nmarkers].usetype = USE_INSTANCE;
78 marker[nmarkers].objname = argv[++i];
79 break;
80 case 'I':
81 marker[nmarkers].usetype = USE_MESH;
82 marker[nmarkers].objname = argv[++i];
83 break;
84 case 'x':
85 marker[nmarkers].usetype = USE_XFORM;
86 marker[nmarkers].objname = argv[++i];
87 break;
88 case 'e':
89 expand = 1;
90 break;
91 case 'm':
92 marker[nmarkers].modout = argv[++i];
93 break;
94 case 's':
95 marker[nmarkers].mscale = atof(argv[++i]);
96 break;
97 default:
98 goto userr;
99 }
100 if (++i >= argc)
101 goto userr;
102 } while (argv[i][0] == '-');
103 if (marker[nmarkers].objname == NULL)
104 goto userr;
105 if (nmarkers >= MAXMARK) {
106 fprintf(stderr, "%s: too many markers\n", progname);
107 return 1;
108 }
109 marker[nmarkers++].modin = argv[i++];
110 marker[nmarkers].mscale = marker[nmarkers-1].mscale;
111 }
112 if (nmarkers == 0)
113 goto userr;
114 /* simple header */
115 putchar('#');
116 for (j = 0; j < i; j++) {
117 putchar(' ');
118 fputs(argv[j], stdout);
119 }
120 putchar('\n');
121 if (i == argc)
122 convert("<stdin>", stdin);
123 else
124 for ( ; i < argc; i++) {
125 if ((fp = fopen(argv[i], "r")) == NULL) {
126 perror(argv[i]);
127 exit(1);
128 }
129 convert(argv[i], fp);
130 fclose(fp);
131 }
132 return 0;
133 userr:
134 fprintf(stderr,
135 "Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n",
136 progname);
137 return 1;
138 }
139
140
141 void
142 convert( /* replace marks in a stream */
143 char *name,
144 register FILE *fin
145 )
146 {
147 register int c;
148
149 while ((c = getc(fin)) != EOF) {
150 if (isspace(c)) /* blank */
151 continue;
152 if (c == '#') { /* comment */
153 putchar(c);
154 do {
155 if ((c = getc(fin)) == EOF)
156 return;
157 putchar(c);
158 } while (c != '\n');
159 } else if (c == '!') { /* command */
160 ungetc(c, fin);
161 cvcomm(name, fin);
162 } else { /* object */
163 ungetc(c, fin);
164 cvobject(name, fin);
165 }
166 }
167 }
168
169
170 void
171 cvcomm( /* convert a command */
172 char *fname,
173 FILE *fin
174 )
175 {
176 FILE *pin;
177 char buf[512], *fgetline();
178
179 fgetline(buf, sizeof(buf), fin);
180 if (expand) {
181 if ((pin = popen(buf+1, "r")) == NULL) {
182 fprintf(stderr,
183 "%s: (%s): cannot execute \"%s\"\n",
184 progname, fname, buf);
185 exit(1);
186 }
187 convert(buf, pin);
188 pclose(pin);
189 } else
190 printf("\n%s\n", buf);
191 }
192
193
194 void
195 cvobject( /* convert an object */
196 char *fname,
197 FILE *fin
198 )
199 {
200 extern char *fgetword();
201 char buf[128], typ[16], nam[128];
202 int i, n;
203 register int j;
204
205 if (fscanf(fin, "%s %s %s", buf, typ, nam) != 3)
206 goto readerr;
207 if (!strcmp(typ, "polygon"))
208 for (j = 0; j < nmarkers; j++)
209 if (!strcmp(buf, marker[j].modin)) {
210 replace(fname, &marker[j], nam, fin);
211 return;
212 }
213 printf("\n%s %s %s\n", buf, typ, nam);
214 if (!strcmp(typ, "alias")) { /* alias special case */
215 if (fscanf(fin, "%s", buf) != 1)
216 goto readerr;
217 printf("\t%s\n", buf);
218 return;
219 }
220 for (i = 0; i < 3; i++) { /* pass along arguments */
221 if (fscanf(fin, "%d", &n) != 1)
222 goto readerr;
223 printf("%d", n);
224 for (j = 0; j < n; j++) {
225 if (fgetword(buf, sizeof(buf), fin) == NULL)
226 goto readerr;
227 if (j%3 == 0)
228 putchar('\n');
229 putchar('\t');
230 fputword(buf, stdout);
231 }
232 putchar('\n');
233 }
234 return;
235 readerr:
236 fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n",
237 progname, fname, typ, nam);
238 }
239
240
241 void
242 replace( /* replace marker */
243 char *fname,
244 register struct mrkr *m,
245 char *mark,
246 FILE *fin
247 )
248 {
249 int n;
250 char buf[256];
251
252 buf[0] = '\0'; /* bug fix thanks to schorsch */
253 if (m->usetype == USE_XFORM) {
254 sprintf(buf, "xform -n %s", mark);
255 if (m->modout != NULL)
256 sprintf(buf+strlen(buf), " -m %s", m->modout);
257 if (buildxf(buf+strlen(buf), m->mscale, fin) < 0)
258 goto badxf;
259 sprintf(buf+strlen(buf), " %s", m->objname);
260 if (expand) {
261 fflush(stdout);
262 system(buf);
263 } else
264 printf("\n!%s\n", buf);
265 } else {
266 if ((n = buildxf(buf, m->mscale, fin)) < 0)
267 goto badxf;
268 printf("\n%s %s %s\n",
269 m->modout==NULL?"void":m->modout,
270 m->usetype==USE_INSTANCE?"instance":"mesh",
271 mark);
272 printf("%d %s%s\n0\n0\n", n+1, m->objname, buf);
273 }
274 return;
275 badxf:
276 fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n",
277 progname, fname, mark);
278 exit(1);
279 }
280
281
282 int
283 edgecmp( /* compare two edges, descending order */
284 const void *e1,
285 const void *e2
286 )
287 {
288 if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2)
289 return(-1);
290 if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2)
291 return(1);
292 return(0);
293 }
294
295
296 int
297 buildxf( /* build transform for marker */
298 register char *xf,
299 double markscale,
300 FILE *fin
301 )
302 {
303 static FVECT vlist[MAXVERT];
304 static EDGE elist[MAXVERT];
305 FVECT xvec, yvec, zvec;
306 double xlen;
307 int n;
308 register int i;
309 /*
310 * Read and sort vectors: longest is hypotenuse,
311 * second longest is x' axis,
312 * third longest is y' axis (approximate),
313 * other vectors are ignored.
314 * It is an error if the x' and y' axes do
315 * not share a common vertex (their origin).
316 */
317 if (fscanf(fin, "%*d %*d %d", &n) != 1)
318 return(-1);
319 if (n%3 != 0)
320 return(-1);
321 n /= 3;
322 if (n < 3 || n > MAXVERT)
323 return(-1);
324 /* sort edges in descending order */
325 for (i = 0; i < n; i++) {
326 if (fscanf(fin, "%lf %lf %lf", &vlist[i][0],
327 &vlist[i][1], &vlist[i][2]) != 3)
328 return(-1);
329 if (i) {
330 elist[i].beg = i-1;
331 elist[i].end = i;
332 elist[i].len2 = dist2(vlist[i-1],vlist[i]);
333 }
334 }
335 elist[0].beg = n-1;
336 elist[0].end = 0;
337 elist[0].len2 = dist2(vlist[n-1],vlist[0]);
338 qsort(elist, n, sizeof(EDGE), edgecmp);
339 /* find x' and y' */
340 if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) {
341 i = elist[1].beg;
342 elist[1].beg = elist[1].end;
343 elist[1].end = i;
344 }
345 if (elist[2].end == elist[1].beg) {
346 i = elist[2].beg;
347 elist[2].beg = elist[2].end;
348 elist[2].end = i;
349 }
350 if (elist[1].beg != elist[2].beg)
351 return(-1); /* x' and y' not connected! */
352 for (i = 0; i < 3; i++) {
353 xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i];
354 yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i];
355 }
356 if ((xlen = normalize(xvec)) == 0.0)
357 return(-1);
358 fcross(zvec, xvec, yvec);
359 if (normalize(zvec) == 0.0)
360 return(-1);
361 fcross(yvec, zvec, xvec);
362 n = 0; /* start transformation... */
363 if (markscale > 0.0) { /* add scale factor */
364 sprintf(xf, " -s %f", xlen*markscale);
365 n += 2;
366 while (*xf) ++xf;
367 }
368 /* add rotation */
369 n += addrot(xf, xvec, yvec, zvec);
370 while (*xf) ++xf;
371 /* add translation */
372 n += 4;
373 sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0],
374 vlist[elist[1].beg][1], vlist[elist[1].beg][2]);
375 return(n); /* all done */
376 }
377
378
379 int
380 addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */
381 register char *xf,
382 FVECT xp,
383 FVECT yp,
384 FVECT zp
385 )
386 {
387 int n;
388 double theta;
389
390 n = 0;
391 theta = atan2(yp[2], zp[2]);
392 if (!FEQ(theta,0.0)) {
393 sprintf(xf, " -rx %f", theta*(180./PI));
394 while (*xf) ++xf;
395 n += 2;
396 }
397 theta = asin(-xp[2]);
398 if (!FEQ(theta,0.0)) {
399 sprintf(xf, " -ry %f", theta*(180./PI));
400 while (*xf) ++xf;
401 n += 2;
402 }
403 theta = atan2(xp[1], xp[0]);
404 if (!FEQ(theta,0.0)) {
405 sprintf(xf, " -rz %f", theta*(180./PI));
406 /* while (*xf) ++xf; */
407 n += 2;
408 }
409 return(n);
410 }
